[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5​
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit B-Die (Q1)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den, von den DDR3 und DDR4 Modellen
bekannten, seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten
statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine
Identifikation der ICs mehr möglich.
Update: Bei neueren Modellen sind auch diese 5 Sternchen nicht mehr vorhanden.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Speed Bin | Die Revision
Micron Part Number Decoder (für IC Codes):
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWiNFO (ab 7.26), Passmark RAMMon (ab 3.0) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
Mensch sehr gut, ich danke euch und werden Berichten. Habe erst am Freitag Zeit zu testen. Ich hatte mir die anderen Seiten durchgelesen, deswegen wollte ich auch meine Geschichte mal erzählen und hab mich extra dafür angemeldet. Hier habe ich sofort die passenden Antworten bekommen, darauf warte ich in nem anderen Forum (CB) schon seit Tagen.
Ich hatte mich zwar gefreut über die CL36 aber wenn die eh nur auf CL40 laufen, dann ist es ja egal welche man hat.
Könnte es sein, das das durch ein BIOS Update noch behoben wird? Wenn man so etwas ASUS mitteilt, also denen einfach mal ne Mail schreibt, wird so etwas eventuell berücksichtigt?
Aus diesem Grunde überlege ich auch momentan, auch wenn ich kein "Extrem-OC" betreibe, zum Apex zu greifen.
Gäbe alternativ auch das Z690 Unify-X von MSI.
Ich persönlich würde für den Normalgebrauch aber keine der OC Platinen nehmen sondern eher auf die Features achten. Das Z690-Creator ist unter dem Aspekt z. B. ein ganz nettes Platinchen.
Klar, hab auch mit dem Gedanken gespielt, das Creater zu nehmen. Letztendlich doch das Hero bestellt wegen dem besseren Sound, zum gleichen Preis!
Meine G-Skill DDR5-5600 CL36 liegen in der Packstation. Ich teste heute Abend mal, wie die mit dem Gigabyte Z690 Aorus Pro laufen. Auf der QVL stehen sie, was natürlich nichts heißen muss.
Das neue Mainboard ist schon eingebaut. Nur noch RAM reinstecken und los gehts (mit dem Memtest). :-)
Wenn das so weiter geht mit den Preisen kaufe ich bald alle paar Jahre nur noch fertig PCs 😆
Nur noch was zu bekommen zu überteuerten Preisen.
Hast Du das neueste BIOS bereits geflasht mit Q-Flash?
Hatte ich auch bei dem 2x16 Pack. Einzelne Module konnte ich kaufen. Beim auschecken sagte das System noch 31 verfügbar.
Da kann man nix kaufen. Man wird nur in einer Endlosschleife auf die gleiche Seite weitergeleitet. Bei Kaufoptionen steht "Bestand: Auf Lager" und wenn man Jetzt kaufen klickt kommt man wieder auf die gleiche Seite.
Du kannst nur die Module kaufen wo der "In den Warenkorb" hinzufügen Button angezeigt wird.
Ich hab mir vorhin das 64er Kit geordert.
Ach Mist, die einzelnen 16er sind auch schon weg. :fresse:
So, ich bin mit meinem neuen System online (Gigabyte Z690 Aorus Pro, i7-12700K und G-Skill F5-5600U3636C16GX2-TZ5RK). Der G-Skill RAM scheint stabil zu laufen. Zwei Durchläufe Memtest ohne Fehler auf DDR5-5600 CL36 mit den im XMP-Profil hinterlegten 1,20 Volt. Laut GPU-Z läuft der RAM auch wirklich auf dem Takt. Windows 11 und Games laufen ebenfalls stabil.
Anfangs hatte ich massive Probleme, da sich das System ständig an unterschiedlichen Stellen mit einem Blackscreen verabschiedet hat. Irgendwann habe ich herausgefunden, dass die Intel iGPU (ich hatte die Graka noch nicht eingebaut) sich irgendwie nicht mit meinem Ultrawide-Monitor verträgt. Nach Einbau der Geforce läuft alles traumhaft.
Ich muss natürlich noch einiges testen und optimieren. Zum Glück habe ich jetzt zwei Wochen Urlaub, also genug Zeit zum Basteln vorhanden. 8-)
Versteh ich nicht warum auf deinem Board das xmp problemlos läuft und beim master überhaupt nicht. Die verwenden doch mit Sicherheit die gleichen timings
Toms Hardware hatte das Aorus Pro mit dem exakt gleichen RAM im Test und deren Aussage war auch, dass der G-Skill ohne jede Anpassung auf DDR5600 CL36 mit dem Aorus Pro läuft.
The board did though run our GSkill Trident Z5 2x16GB DDR5 5600 kit without issue (Link).
Hat es eigentlich bei DDR5 noch einen Vorteil zwei RAM Sticks einzubauen? Wenn ich das richtig verstanden habe läuft jeder einzelne Stick ja bereits im Dual Channel Modus. Wäre das dann bereits Quad Channel oder trotzdem noch Dual Channel?
so ist es, das ist dann quad Channel
Probier mal das Test BIOS 0010 (Apex, Hero, Strix I, Strix F):
Na da bin ich mal gespannt was da alles wieder storniert wird. :unsure:
hat jemand glück gehabt? hab sofort bestellt und schon steht beim status Der Auftrag kann aktuell nicht bearbeitet werden, da einer oder mehrere Artikel nicht lieferbar sind
Jo hab grad das apex,12900k und gskill 5600 c36 bestellt. Bis jetzt in Bearbeitung. Bestellung ist durch :-)
