BIOS
Anleitung
7. Enter drücken
10. PC neu starten
OVERCLOCKING | TOOLS
800mv = 320 Watts
850mv = 370 Watts
900mv = 430 Watts
912mv = 450 Watts
UNDERVOLTING
800mv = 320 Watts
850mv = 370 Watts
900mv = 430 Watts
912mv = 450 Watts
AsusTUFMLCCMLCC
AsusStrixMLCCMLCC
EVGAXC3Mixed (1)Mixed (2)
EVGAFTW3Mixed (2)**Mixed (2)
GalaxBlackMixed (1)Unknown
GigabyteEagleUnknownPOSCAP
GigabyteGamingPOSCAPPOSCAP
MSIVentusMixed (1)Mixed (2)
ZotacTrinityPOSCAPPOSCAP
ZotacX-GamingUnknownPOSCAP
3090 TI Power Limit Übersicht
AsusTUF
AsusStrix OC LC516 W maximal
EVGABlack Gaming
EVGAFTW3
EVGAFTW 3 Ultra
KÜHLERTAUSCH | GARANTIE
ASRockKulanz5
Asus✓1✓1
EVGA✓2
Gainward✓3
Gigabyte
KFA²
MSI
Nvidia
Palit✓4
PowerColor
SapphireKulanz5
XFX
Quelle: Computerbase
MSI:
ZOTAC:
eingereicht werden."
Gainward und Palit
Aktuelle Referenzkarten
Zotac:
GALAX/KFA2:
Gainward:
Palit:
PNY:
INNO3D:
Ich hab dir gesagt mach nicht zuviel.
das ist anscheinend schon vor paar tagen passiert, roch etwas komisches ausm gehaeuse, ist aber sonst nix passiert.
anscheinend ist eher nen PIN aus dem 8pin PSU stecker abgebrochen oder abgefallen beim haeufigen ein und ausbauen, was wiederum mehr wiederstand = mehr hitze erzeugt hat.
that apparently happened a few days ago, smelled something strange from the housing, but nothing else happened.
apparently NEN PIN from the 8pin PSU connector broke off or fell off during frequent installation and removal, which in turn gave more resistance = more heat.
Wait a bloody minute.
You mean to tell me all those benchmark runs you were posting on overclock.net the last few days were done with a burned up cable? And your PSU and Video card lived to tell the story?
Wow. I should go to Las Vegas and play some craps or poker, with those odds ...
Why do people even buy custom cables from non official websites anyway? You never know the quality you're getting.
You're better off just buying the wires yourself and making your own cable. You can get 16 aug wires on digikey or mouser, as well as connectors.....(the 12 pin connector may be hard to find, but 8 pins...no problem).
Habe 3200 CL18, jedoch das Ruckeln nicht.
Vllt mal testweise Command Rate vom Ram auf 2T stellen, falls vom XMP auf 1T gestellt? Sollte ja Ram mit Samsung B-Die's sein bei Dir, nutzen die default nicht sogar 1T?
Daran lags mal, dass auf meinem Core2 Duo-System CS:Source und HL2 Deathmatch nach ner Weile einen Systemfreeze verursacht haben. Betraf nur Games mit Source-Engine, sonst alles rund.
Eh ich darauf gekommen bin... :fresse: auch ewig Memtest gemacht, der natürlich nix ausspuckte.
sehe ich mir dann auch an :). Würde gerne mal die scheiss Photovoltaik Anlage abdrehen und schauen ob das was ändert, aber meine Frau macht da leider faxen, obwohl die nur zum Hauptstrom zugeschaltet ist und die Stromversorgung beim Adrehen normal weiterlaufen würde
Naja, gebe es ein allegemeines Ampere Problem mit Rucklern, wäre das Netz voll davon... Ich hab das erste mal von euch beiden darüber gelesen, habt ihr das auch mal auf nem intel system probiert? Soll jetzt kein AMD Bashing sein...
Ich kann nur sagen, heute wieder ne 4 Std. Session in RDR und das läuft so aalglatt, goil...
Übrigens hab ich auch cl14 3200 Ram, daran kann es nich liegen...
Hier mal ein paar Daten zu dem EKWB für die TUF, vielleicht hilft es jemand ja. Habe mal 30 Minuten Superposition Stresstest @ WQHD und High laufen lassen.
Wassertemperatur ist nach ca. 20 Minuten auch nicht mehr weiter angesteigen.
Die Backplate ist nicht wärmer als 44°C geworden, hat aber auch einen leichten Luftzug vom vorderen Radi. Finde ich aber top, mit Lukü wurde die Karte definitiv wärmer.
Im Ganzen bin ich sehr zufrieden, der Kühler macht also etwas ein Delta von 10k unter Vollast. :)
Achja Karte zieht dabei etwas über 400W, kann man sich aber ja auch von den Verbrauchsdaten des Corsairs errechnen.
Pretty much lol
Also ich habe folgendes System
Seasonic Focus plus gold 1000w
Ryzen 3950x @4.35ghz all core @1.31v
Asus Crosshair Viii Formula (aktuelles BIOS)
Gskill 64gb (4x16gb) 3600er cl16
Asus RTX 3090 strix oc
Und habe keine ruckler.
GeForce experience ist installiert
Aktueller Treiber
Windows 10 20H2
Windows im high performance modus
Gpu scheduling an
Gsync an
Aktuelles BIOS auf der strix
sie läuft im Performance bios
Mit undervolting 1860mhz@0.862v
Was hast denn dadurch gejagt 😁
Ist eher nein pin abgebrochen der wiederum für mehr Abwärme gesorgt hat. Die Kabel sollten das schaffen.
@dante`afk : brauchst neue Kabel :d
Die hab ich hier in der Schublade....cablemods war das Problem
ich hatte davor ein intel system mit z390 und 9900kf@ 5ghz mit 3090, da war es 1:1 gleich wie mit dem amd system jetzt, mitgenommen vom intel system habe ich nur ram und netzteil auf das jetzige System
Aktueller Treiber
Windows 10 20H2
Gpu scheduling an
Gsync an
pagefile erstellt oder einfach gelassen wie se ist?
Ich kann für euch nur hoffen, dass ihr das gelöst bekommt. Ansonsten klinke ich mich mal aus, bin mit meinem Latein zu ende... Ich kann nur bestätigen, wenn die 3090 läuft, dann ist das bombastisch, so glatte Frame Times hatte ich glaub bisher noch nie...
Also Toi Toi Toi, dass ihr noch glücklich mit euren Karten werdet...
Mit curve undervolted.
Hab die leider noch nicht auf wakü umgebaut kommt aber noch.
Mein case is nicht so für luftkühlung geeignet des wegen wird die weng zu warm und ich hab standart boost nur undervolted.
Die Steckerkontakte sind empfindlich du könntest zusätzlich Kontaktspray oder Kontaktfett verwenden, das hilft ein wenig.
Ist mir auch schon passiert bei nen GTX580SLI.
Anhang anzeigen 557506 Anhang anzeigen 557507
Dann ist da der EK Kühler locker um ca.3Grad besser als der Alphacool.Im Schnelltest bei 200L mit aktiver Backplate liege ich bei 430W bei 13Grad Delta zum Wasser.
Und du hast wenigstens noch Durchfluß, ich bezweifle das irgendwer mit dem Alphacool auf gute Temps kommt mit ner "normalen" Kühlung.
ohne gsync und vsync ist sie bei mir auch glatt, irgendwann kommt dann halt ein fetter Ruckler wos nach oben schießt. Mit Gsync ist sie nicht immer aalglatt und der Ruckler kommt auch. Bald kommt mein neuer RAM. Wenns der auch nicht ist bleibt nur mehr das NT oder meine Stromversorgung im Haus. Danke dir auf jeden Fall und freut mich dass bei den anderen alles läuft :)
@Phoenix2000
Mit was machst du dann deine 200 l, wenn du sagst der ist so restriktiv?
Bzgl. Temps, viel isses ja nicht, aber der Alphacool würde mir rein optisch schon nicht ins Case kommen.. :fresse: Hab ja dieses mal auch die Acetal-Version, fügt sich besser in mein aktuellen Build ein und ich bin gottfroh mich von dem Riser-Quark losgelöst zu haben!
Vielen Dank @funkflix dann wirds bei mir doch der EKWB in der schwarzen Acetal-Version.
Bist Du mit den Pads zufrieden? Also ist das so knochentrockenes, steifes Zeugs oder eher anschmiegsam & weich? Sonst bestelle ich mir gleich noch n paar Eisschicht Softpads dazu?
Gibts noch n paar Pics vom verbauten Kühler? 😇
Du hast natürlich auch das Gleiche Mainboard, CPU und die restlichen Komponenten wie er? Eher nicht...
Im Bios umstellen auf 2T kostet ihn 5 Minuten, wahrscheinlich ist die CR sogar schon auf 2T. Und wieder was ausgeschlossen, was es sein könnte.
Komme immer mehr in Richtung Netzteil, auch wenn das RoG Thor eigentlich eine teure Marken-PSU ist.
Hab ich vor lauter Vorfreude leider versäumt.. Aber kannst glaub guten Gewissens kaufen. War ja eigentlich von der 2080 Ti Strix Backplate geschädigt, da die reproduzierbar Kurzschlüsse produziert hatte, aber dieses Mal wurde ich zum Glück nicht enttäuscht! Und meine 2080 Ti hatte das zum Glück irgendwie überlebt...
Edit: Achso, die Pads sind top, sind die die schon immer bei EK bei waren. Brauchst nix anderes.
Das ist sehr positiv .
Dann mache ich mir auch keine gedanken mehr , wenn ich den WC Block mit passiver BP bestücke.
Luftzug habe ich auch ausreichend.
Vorne zwei rein und von unten einen rein und hinten und oben je einen raus.
Kabel mache ich dann auch ordentlich und die Kabelabdeckung passt dann auch wieder ins Case bei dem kurzem PCB,
sofern es mit dem USB 3.0 Kabel kein stress gibt .
Mal schauen
Da hast du ja recht, ist nicht unwarscheinlich das auch CPU -Mobo-RAM-Kombo mit einfließen, mir gings spezifisch um 3200er mit geringen Timings und davon ausgeklammert alles andere. Grundsätzlich ist auch die Frage ob dies über die gesamte Spieldauer in allen Games so zu beobachten ist, oder nur an ganz spezifischen Orten/Situationen vorkommt. Das ist mir bisher aus Posts nicht so klar herauslesbar, auch ist das in den Videos wirklich nur an der Frametime Kurve zu erkennen, die bewegt sich natürlich auch nach oben/unten in funktionierenden Systemen. Man könnte auch daraus schließen, das es "Nachladeruckler" sind und zusammenhängen mit der Bestückung der SSD's und HDs. Wenn man die wenigen Lanes mit vielen Pci Geräten malträtiert geht die Bandbreite auch down....
Außerdem führen i.d.R ja so "Hardware Bugs" wie inkompatible Timings, Instabilitäten grundsätzlich zu abstürzen, Bsod usw. Ganz ausgeschlossen das es sich in Ruckeln äußert, ist es deswegen nicht.
Da sich bei beiden mit unterschiedlichen Komponenten, aber mit dem selben Fehlerbild dies äußert, tendiere ich zu einem grundlegendes Problem mit den Ampere Treibern und älteren Engines in den spezifischen Games. Sotr macht ja z.B. bei mir auch ein Problem, es lastet meine GPU nicht aus, dafür läufts trotzdem flüssig, aber eben nur mit 60-80 FPS unter WQHD... Alle anderen Games die ich so nutze laufen sauber, sogar die Oberzicke Red Dead Redemption 2...
Was bei AC Valhalla ja auch von den Redaktionen bestätigt wurde, ist das es kurze Ruckler gibt/gab nach dem man das Spiel direkt gestartet hat, das geht so 5 Sekunden lang, danach ist alles super smooth. War bei mir auch so. Was ja eigentlich kein Problem ist, da man nur kurz warten muss und dann läuft alles sauber...
Vielleicht solltet ihr mal mit AB/RTSS Overlay inkl. aller relevanten Daten, Kernauslastung, Vram, GPU Temps, GPU auslastung, GPU Takt und Leistungsaufnahme usw. mal aus den betroffenen Games so 5 Min Gameplay Videos mit Hilfe der Aufnahme Funktion (Geforce Experience) machen, dass man sich richtig ein Bild machen kann, wie sich die Hardware und das/die Game(s) verhalten...
Habe nur in Fifa 20 Ruckler XD. Wenn ich auf rahmenlosen Fenstermodus geh ist alles weg. Ist bei mir denke ich ein Bug in Fifa
kann ich gerne machen. Weil du Valhalla erwähnst, das ruckelt bei mir definitiv mehr als in den ersten 5 sekunden, da ist immer wieder ein kurzer Ruckler wahrnehmbar. zb wenn ich mit dem Schiff fahre und ein waal auftaucht oder eine bombe auf mir explodiert oder ich untertauche. Ich habe nur eine einzige pcie gen 4 500gb ssd verbaut, sonst kein anderes Speichermedium
Super, mach da auch mal ein Gameplay Video. Pcie Gen 4, da klingelts bei mir... Kann es sein, das sich Graka, CPU und SSD vielleicht hier Bandbreite gegenseitig "klauen"? Nur ne Vermutung. Pcie Gen 4 ist ja relativ neu, kann auch an verbuggten Chipsatz/SSD Treibern liegen? :confused:
Wobei Thrawn oder du auch ja auch nen Intel nutzten...
Übrigens kann es manchmal einfach sein, bei mir ist Red Dead immer wieder abgestürzt, nachdem ich die dämliche XBox Gamebar in Win ausgestellt habe, ist das passe... Habt ihr eigentlich mal nen sauberen Clean Install versucht, bei derer nur die wichtigsten Treiber/Software installiert werden? Also ganz ohne Tastatur, RGB usw. gedöns.... Wenn nicht, wäre das ein Versuch wert...
Weiss jemand wo die Blöcke von Corsair hergestellt werden?
Hab mal was von EK gehört, ist aber schon lange her.
@Phoenix2000
Mit 2xDDC 3.25 auf nen EK Dual Turbotop, das sind auf max. 11m bzw. 1,1bar Druck, das ist dann aber alles andere als leise.
Ich hab das getestet ohne Graka über 200L pumpen bei ca. 3400U/min, mit Graka 150L.Im Silentbetrieb sind es ohne 135-140L mit Graka 115L, sprich er bremst bei höheren Flow da die Kanäle zu eng sind.
Dazu kommt noch das die WLP´s zu niedrig sind um 0,5mm, was dem einen oder anderen die Graka zerstören könnte.
Jo moin, hatte mir letzte Woche die 3090 FE bestellt, bei den 1499 Euro konnte ich nicht nein sagen, wird naechste Montag geliefert. Jetzt gucke ich nach nem Block fuer die Karte und ich finde nur den von Corsair und Bitspower welche mir beide nicht gefallen und eh nicht lieferbar sind.
Bin kurz davor die Karte nicht anzunehmen, habt ihr vllt. Infos ob EK da noch was bringen wird?
Diese Auflistung ist sehr aktuell, sieht momentan eher schlecht aus für die Founders.
Wahrscheinlich scheuen AC und WC davor zurück, weil so wenige bei den europäischen Endkunden aufgeschlagen sind?
Ne FE nicht annehmen? Was ist denn in Dich gefahren? Hätte gern eine gehabt, heute ists halt ne Asus TUF geworden...
Bei Aqua steht der Block jetzt als lieferbar dran: :oops:
Leider die Backplate noch nicht:
Hauptsache die haben meinen beiseite gepackt. :rolleyes2:
ja habe ich alles schon gemacht, gameplayvideo mache ich heute Abend, vielen Dank für deine Hilfsbereitschaft :). Gamebar habe ich auch immer abgestellt, ebenso wie den Gamemodus
Tausch sie gerne gegen meine ventus;)
Wenn ich kurz fragen darf, was für Netzteile rockt ihr so? 750w müssten doch reichen oder?
