Aktuelles
[Sammelthread] Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
Sammelthread Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
attachment.php
X370 Taichi
-Herstellerlink- -Handbuch- -Preisvergleich-
attachment.php
attachment.php
Inhaltsverzeichnis:
  • Spezifikationen
  • Links & Reviews
  • UEFI History
  • Q&A
  • Ram & Kühler Kompabilitäts-Liste
  • OC
Technische Daten / Spezifikationen:
Gemeinsame Technische Spezifikationen:
  • CPU:
    AMD AM4 Socket Ryzen Series (Summit Ridge)
  • Chipsatz:
    AMD X370 Promontory
  • Memory:
    Supports DDR4 3200+ (OC)
  • Expansion-Slots:
    2 PCIe 3.0 x16 (16/0 - 8/8), 1 PCIe 2.0 x16, 2 PCIe 2.0 x1, 1 M.2 (Key E - belegt mit WiFI-BT-Modul)
  • Storage:
    10 Sata3, 1 UltraM.2 (PCIe Gen3 x4 & Sata3), 1 M.2 (PCIe Gen2 x4)
  • USB:
    2 USB 3.1 (Type-A, Type-C), 10 USB 3.0 (4 Front, 6 Rear)
  • Network :
    1 Intel Gigabit Lan (10|100|1000 Mb/s - Intel I211AT), 1 Intel 802.11ac (IEEE 802.11a/b/g/n/ac, Dual-Band (2,4|5Ghz))
  • Audio:
    7.1 Channel HD Audio (Realtek ALC 1220)
  • Others:
    1 PS/2 Maose/Keyboard-Port (with Y-Cable Support), 1 Clear CMOS Switch
X370 Taichi:
  • Audio-Software:
    Purity Sound 4
  • Vollständige Spezifikationen:
    Code:
    Einzigartige Features
        ASRock USB 3.1
        - ASRock USB 3.1 Type-A Port (10 Gb/s)
        - ASRock USB 3.1 Type-C Port (10 Gb/s)
        ASRock Super Alloy
        - XXL Aluminum Alloy Heatsink
        - Premium 60A Power Choke
        - Premium Memory Alloy Choke (Reduces 70% core loss compared to iron powder choke)
        - Dual-Stack MOSFET (DSM)
        - Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
        - I/O Armor
        - Matte Black PCB
        - High Density Glass Fabric PCB
        - 2oz Copper PCB
        Intel® 802.11ac WiFi
        ASRock Steel Slots
        ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
        ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
        ASRock Live Update & APP Shop
    CPU
        - Supports AMD AM4 Socket Ryzen Series CPUs (Summit Ridge)
        - IR Digital PWM
        - 16 Power Phase design
        - Supports 300W EX OC
        - Supports ASRock Hyper BCLK Engine II
    Chipsatz
        - AMD Promontory X370
     Arbeitsspeicher
        - Dual Channel DDR4 Memory Technology
        - 4 x DDR4 DIMM Slots
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC and non-ECC, un-buffered memory*
        - Max. capacity of system memory: 64GB**
        - 15μ Gold Contact in DIMM Slots
        *Please refer to Memory Support List on ASRock's website for more information.
        Please refer to below table for DDR4 UDIMM maximum frequency support.
        Ryzen Series CPUs:
        UDIMM Memory Slot    Frequency(MHZ)
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
        SR    SR    SR    SR    2133-2400
        SR/DR    DR    SR/DR    DR    1866-2133
        SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
        DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
        **Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
    BIOS
        - 128Mb AMI UEFI Legal BIOS with GUI support
        - Supports "Plug and Play"
        - ACPI 5.1 compliance wake up events
        - Supports jumperfree
        - SMBIOS 2.3 support
        - CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
    Grafik
        - n/a
    Audio
        - 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
        - Premium Blu-ray Audio support
        - Supports Surge Protection
        - Supports Purity Sound™ 4
        - Nichicon Fine Gold Series Audio Caps
        - 120dB SNR DAC with Differential Amplifier
        - TI NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
        - Pure Power-In
        - Direct Drive Technology
        - PCB isolate shielding
        - Impedance Sensing on Line Out port
        - Individual PCB Layers for R/L Audio Channel
        - Gold Audio Jacks
        - 15μ Gold Audio Connector
        - Supports DTS Connect
    LAN
        - Gigabit LAN 10/100/1000 Mb/s
        - GigaLAN Intel® I211AT
        - Supports Wake-On-LAN
        - Supports Lightning/ESD Protection
        - Supports Energy Efficient Ethernet 802.3az
        - Supports PXE
    Drahtloses LAN
        - Intel® 802.11ac WiFi Module (Free Bundle)
        - Supports IEEE 802.11a/b/g/n/ac
        - Supports Dual-Band (2.4/5 GHz)
        - Supports high speed wireless connections up to 433Mbps
        - Supports Bluetooth 4.2 / 3.0 + High speed class II
    Steckplätze
        - 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE3))*
        - 1 x PCI Express 2.0 x16 Slot (PCIE5 @ x4 mode)**
        - 2 x PCI Express 2.0 x1 Slots
        - Supports AMD Quad CrossFireX™ and CrossFireX™
        - Supports NVIDIA® Quad SLI™ and SLI™
        - 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
        - 15μ Gold Contact in VGA PCIe Slot (PCIE2)
        *Supports NVMe SSD as boot disks
        **If PCIE5 slot is occupied, M2_2 will be disabled
    Storage
        - 8 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
        - 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)
        - 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 PCI Express module up to Gen2 x4 (20 Gb/s)*
        *If M2_2 is occupied, PCIE5 slot will be disabled
        Supports ASRock U.2 Kit
    Anschluss
        - 1 x Power LED and Speaker Header
        - 1 x AMD Fan LED Header
        - 2 x RGB LED Headers*
        - 1 x CPU Fan Connector (4-pin)**
        - 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
        - 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
        - 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*****
        - 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
        - 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
        - 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
        - 1 x AMD LED Fan USB Header
        - 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
        - 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
        - 1 x Dr. Debug with LED
        *Supports up to 12V/3A, 36W LED Strip
        **The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
        ***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        ****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        *****CPU_FAN1, CHA_FAN1, CHA_FAN2 can auto detect if 3-pin or 4-pin fan is in use.
    Blende
        - 2 x Antenna Ports
        - 1 x PS/2 Mouse/Keyboard Port
        - 1 x Optical SPDIF Out Port
        - 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
        - 6 x USB 3.0 Ports (Supports ESD Protection)
        - 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
        - 1 x Clear CMOS Switch
        - HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
    Software und UEFI
        Software
        - ASRock A-Tuning
        - ASRock RGB LED
        - ASRock APP Charger
        - ASRock XFast LAN*
        UEFI
        - ASRock Full HD UEFI
        - ASRock Instant Flash
        - ASRock Internet Flash
        - ASRock Crashless BIOS
        - ASRock Easy RAID Installer
        *These utilities can be downloaded from ASRock Live Update & APP Shop.
    Support-CD
        - Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
    Produktzubehör
        - Quick Installation Guide, Support CD, I/O Shield
        - 4 x SATA Data Cables
        - 1 x ASRock SLI_HB_Bridge_2S Card
        - 2 x ASRock WiFi 2.4/5 GHz Antennas
        - 2 x Screws for M.2 Sockets
    Hardware überwachung
        - Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
    Formfaktor
        - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
    Betriebssystem
        - Microsoft® Windows® 10 64-bit*
        *For the updated Windows® 10 driver, please visit ASRock's website for details.
    Zertifizierungen
        - FCC, CE
        - ErP/EuP ready (ErP/EuP ready power supply is required)
  • Audio-Software:
    Creative Sound Blaster Cinema 3
  • Network zusätzlich:
    1 Aquantia 5 Gigabit Lan (10|100|1000|2500|5000 Mb/s - Aquantia AQC108)
  • Onboard:
    1 COM Port Header, 1 TPM Header, 1 Power Switch, 1 Reset Switch
    Code:
    Gaming Armor
        Power
        - Hi-Density Power Connectors (24 pin and 8 pin)
        Memory
        VGA Card
        Internet
        - AQUANTIA 5G LAN
        - Intel® LAN
        Cooling
        - Heat Pipe Design
        Audio
        - Creative Sound Blaster™ Cinema 3
        ASRock USB 3.1
        ASRock Super Alloy
        - I/O Armor
        - Matte Black PCB
        - 2oz Copper PCB
        AQUANTIA 5G LAN
        ASRock Steel Slots
        ASRock Ultra USB Power
    CPU
        - IR Digital PWM
    Chipsatz
    Arbeitsspeicher
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory*
        Ryzen Series CPUs:
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
    BIOS
    Grafik
        - n/a
    Audio
        - Pure Power-In
        - PCB Isolate Shielding
        - RGB LED
        - Gold Audio Jacks
        - Supports Creative Sound Blaster™ Cinema 3
    LAN
        1 x 5 Gigabit LAN 100/1000/2500/5000 Mb/s (AQUANTIA AQC108):
        - Supports PXE
        1 x Intel® Gigabit LAN 10/100/1000 Mb/s (1 x Intel® I211AT):
        - Supports PXE
    Drahtloses LAN
    Steckplätze
    Storage
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)*
    Anschluss
        - 1 x COM Port Header
        - 1 x TPM Header
        - 1 x Power Switch with LED
        - 1 x Reset Switch with LED
    Blende
        - 2 x Antenna Ports
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)*
        - 6 x USB 3.0 Ports (Supports ESD Protection)**
        - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
        *Ultra USB Power is supported on USB3_5_6 ports.
        ACPI wake-up function is not supported on USB3_5_6 ports.
        **1 x Fatal1ty Mouse Port (USB 3.0) is included
    Software und UEFI
        Software
        - ASRock F-Stream
        - ASRock RGB LED
        - ASRock Key Master
        - ASRock XFast LAN*
        UEFI
    Support-CD
    Produktzubehör
    Formfaktor
    Betriebssystem
    Zertifizierungen
        - FCC, CE
Links & Reviews:
Allgemeine Links
X370 Taichi:
UEFI History:
X370 Taichi:
Link Asrock
  • 2.00
    Update AGESA to 1.0.0.4a, Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup
  • 2.20
    Update Agesa Version string "SummitPI-AM4 1.0.0.4a
  • 2.30
    Enhance OC setting for advanced Overclocker
  • 2.40
    Update AGESA to 1.0.0.6
  • 3.00
    Update AGESA to 1.0.0.6a
  • 3.10
    Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature. Windows update is available for version P3.00 or later.
  • 3.20
    With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
  • 3.30
    Bridge BIOS
  • 4.40
    Update AGESA for future coming processors.
    * Before updating this BIOS, please update the BIOS to P3.30 firstly
  • 4.60
    Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a.
    (Einwurf: Wenn nicht das 4.40 schon drauf ist)
  • 4.70
    Enhance compatibility for Raven CPU with Intel WiFi.
    (Einwurf: Wenn nicht das 4.40 oder höher schon drauf ist)
  • 4.80
    Update PinnaclePI-AM4_1.0.0.4
Link Asrock
  • 2.00
  • 2.20
  • 2.30
  • 2.40
  • 3.00
  • 3.10
  • 3.30
    Bridge BIOS
  • 4.40
  • 4.60
  • 4.70
  • 4.80
Q&A:
Allgemeingültige Q&A:
  • Spannungsversorgung Bios
    It is our BIOS extra setting instead of a bug.
    Normally, users could only modify CPU internal voltage.
    But on this model, we mounted with extra PWM IC to let users control CPU external voltage.
    In BIOS \ OC Tweaker \ CPU Configuration \ CPU Voltage, this option is to adjust CPU internal voltage.
    In BIOS \ OC Tweaker \ Voltage Configuration \ Fixed (Offset) Voltage, this option is to adjust CPU external voltage.
    Note: If users set CPU internal voltage and CPU external voltage at the same time, CPU voltage would only change based on CPU external voltage setting.
    Quelle
  • Offizelle AMD Ram-Support Liste Agesia 1.0.0.6 (06-2017)
X370 Taichi:
  • folgt, sobald was gesammelt wird
CPU-Kühler & Ram Kompabilitäts-Liste
X370 Taichi:
Ram:
CPU-Kühler:
Ram:
CPU-Kühler:
OC:
  • AMD Ryzen Processor and AMD Ryzen Master Over-clocking User’s Guide
  • Overclockers Ryzen Overclocking Guide
  • AMD Ryzen (Zen) "Summit Ridge" Socket AM4 OC Thread
  • AMDs Community Update #4: Let's Talk DRAM! (RamSpecs)
  • P-State Values:
    Code:
    Values for P State Overclocking -
    FID (Clock Speed) 90 - 3600mhz, 91 = 3625, 92 = 3650, 93 = 3675, 94 = 3700, 95 = 3725, 96 = 3750, 97 = 3775, 98 = 3800, 99 = 3825,
    9a = 3850, 9b = 3875, 9c = 3900, 9d = 3925, 9e = 3950, 9f = 3975
    a0 = 4000, a1 = 4025 (my max sweetspot OC), a2 = 4050, a3 = 4075, a4 = 4100, a5 = 4125, a6 = 4150, a7 = 4175, a8 = 4200 = a9 = 4225, aa = 4250, ab = 4275, ac = 4300, ad = ugh you win the lottery.
    Values for DID (Increment adjustment adjuster and or bclk adjustments, not too sure what it does TBH, as I found an overclock that I was already comfortable with and have not spent much time with this yet, though looking at it more closely, here are the values) - 8 = 25 mhz increments, 9 =22.2196, a = 20 b = 18.18, c = 16.667, d (final recommendation) = 15.384mhz - 3943mhz cap).
    Values for VID Voltage Control = 30 = 1.25v, 2f = 1.256v, 2e, 1.2562v, 2d = 1.268, 2c = 1.275v, 2b = 1.2812v, 2a = 1.287v, 29 = 1.293v, 28 = 1.3v, 27 = 1.3062v, 26 = 1.3125v, 25 = 1.318v, 24 = 1.325v, 23 = 1.3312v, 22 = 1.3375v, 21 = 1.343v, 20 = 1.35v, 1f = 1.356v, 1e = 1.3625v, 1d = 1.368v, 1c = 1.375v, 1b = 1.3812v, 1a = 1.3875v, 19 = 1.3937v, 18 = 1.4v, 17 = 1.406v, 16 = 1.4125v, 15 = 1.418v, 14 = 1.425v, 13 = 1.4321v, 12 = 1.4375v, 11 = 1.443v, 10 = 1.45v, *next set is from f - a, 9 - 9 (1.45 - 1.55v), though be very careful overclocking in this voltage range*.
  • Ryzen Timing Checker
  • AMD Memory OC Showdown: Frequency vs. Memory Timings
  • Ryzen DRAM Calculator
Ergbenisse:
(Blau = Taichi | Rot = Prof Gamnig)
  • Ryzen Modell | Quelle | Geschwindigkeit | Spannung | LLC | Bios
  • R7 1700 | immortuos | 3,9Ghz | 1,35V| 3 | 2.00
  • R5 1600 | darkpope| 3,85Ghz| 1,28V | 3 | 2.40
  • R7 1800X | jc110 | 4,05Ghz| 1,3925V | 3 | 2.40
  • R7 1700 | Nimrais | 3,50 Ghz| 1,2V | 3 | 2.40
  • R7 1700x | HW-Mann | 4,075 Ghz| 1,488V | ? | 3.00
  • R7 1600x | 4Stroke | 4,09 Ghz| ca. 1,4V | ? | 3.20
  • R7 1600x | reinhardrudi | 4,0Ghz | 1,376V| 3 | 3.20
  • R7 1600x | 4Stroke | 3,9 Ghz | 1,256V | ? | 3.10
to be continued
Tanatos
Ich hab sogar einen von Bruder versucht. Immer das selbe mit Code 07.
Gesendet von meinem SM-G935F mit Tapatalk
hast du den netzstecker gezogen, den cmos clear-button auf der rückseite (beim PS2-anschluss) gedrückt und gleichzeitig auch den startbutton mal gedrückt?
piepst es beim einschalten? wenn ja, gib dem board mal 1-2 minuten^^
darkpope
Einsteiger
OWL
Welchen Ram hast Du verbaut? Hab auf die schnelle keine Angabe gefunden
Benutzerprofil ..., Systeminfo gibt es beim Handy ja nicht. Der gleiche hat schon einmal beim 1.94a das Phänomen verursacht. Eventuell in einen anderen gleich mit umtauschen.
Nozomu
Legende
Bruder hat die Corsair VENGEANCE® LED 16*GB (2x 8*GB) DDR4 DRAM 3.200*MHz C16-Speicherkit – Rote LEDs (CMU16GX4M2C3200C16R)
Meine stehen in Profil.
Hab alles versucht. War auch schon über eine Stunde ohne Strom.
Ich hab dieses Kit hier G.Skill Trident Z RGB 16GB DDR4 16GTZR Kit 3866 CL18 (2x8GB) - computeruniverse
2 Kits und da ist es unwahrscheinlich das die + Bruders Riegel daran schuld sind.
ro8otron
Banned
Warum schaltet ihr nicht auf den zweiten Bios Chip um und repariert Bios A? Oder gibts das nicht mehr bei so teuren Brettern?
darkpope
Einsteiger
OWL
Asrock sind die einzigen , die kein Fallback Modus haben.
So was wie bei Asus mit dem Crashfree wäre schon schön. Vielleicht kommt das noch...
,@iWebi
der 07 wurde beim BIOS 1.94a beim Taichi durch das flashen mit identischem Ram verursacht. Vielleicht liegt da eine Inkompabilität noch vor.
Ansonsten probiere beim nächsten Board zum flashen die Riegel deines Bruders.
Ray62
Hauptstadt, an der Südseite des Westens
Ich habe das Bios L2.36 jetzt auch auf meinem X370 Professional Gaming drauf gespielt.
Mein Fazit vorab: Die eingestellte Command Rate wird nicht (immer) übernommen!
Bei Dual Rank Modulen wie bei meinen CMK32GX4M2B3000C15 ist das zwingend notwendig, zumindest ab einer gewissen Frequenz.
Stelle ich 2400 oder kleiner ein, wurde schon bei den älteren Bios Versionen immer 2T für die Command Rate automatisch eingestellt, ab 2666 MHz kurioserweise immer 1T!
Das hätte ich genau anders herum erwartet.
Meine Hoffnung lag jetzt natürlich darin, dass das neue Beta Bios, welches endlich die Command Rate manuell einstellen lässt, diese Einstellung auch übernimmt, was aber leider nicht stimmt.
Obwohl ich 2T einstelle, steht nacher 1T drin! Zu sehen unter Windows mit CPU-Z oder HWINFO und auch im Bios selbst nach Restart.
Gehe ich von 2666 zurück auf 2400, ist die Command Rate wieder automatisch 2!
Das ist eben ein Test Bios, aber solange die Command Rate nicht wirklich einstellbar ist, sind Dual Rank RAM und Vollbestückung nach wie vor problematisch.
Nozomu
Legende
Gibt kein zweites Bios.
Woran es auch gelegen hat, ich Versuch ein Austausch zu erhalten und Versuch dann das 2.36 Bios.
Wenn es wieder scheitert werde ich wohl mein Geld zurückverlangen.
Ray62
Alle wollen AGESA 1.0.0.6, das Test Bios L2.36 hat es drin. Nun fängt die Arbeit mit den Einstellungen für's RAM erst an!
Die Tabelle unter Gaming: Community Update #4: Let's Talk DRAM! | Community sollte man ernst nehmen.
Geardown Mode:
Allows the DRAM device to run off its internally-generated ½ rate clock for latching on the command or address buses. ON is the default for speeds greater than DDR4-2667, however the benefit of ON vs. OFF will vary from memory kit to memory kit. Enabling Geardown Mode will override your current command rate.
In der Tat, Geardown Mode OFF und schon wird die Command Rate übernommen.
2666 14-16-16-33-49 TC2 läuft nun und damit ist der Start des Systems auch sehr schnell.
RAM: Corsair Vengeance LPX 3000, 2x16 GB, CMK32GX4M2B3000C15, Dual Rank mit Hynix Chips
Heute abend geht's dann wahrscheinlich weiter mit Testen.
JZ_
Urgestein
Iserlohn
Komisch, bei mir laufen alle Module die ich hier habe, auch Trident-Z :)
H
HW-Mann
Guest
Laufen ja - aber eben nicht wenn man über 3333 raus will. Teiler im UEFI ist ja schick, aber eben nicht brauchbar / nutzbar aktuell.
Also ich steck bei DDR4-3200 C14 1T stable, DDR4-3333 C14 1T stable und DDR4-3466 C16/C18 ( nichtmal mit 1,50v stable ) fest.
Lose Timings, 2T, hohe vDimm, erhöhte SoC-Voltage - nichts hilft.
G.Skill Trident Z DDR4-3600 C16-16-16-36 ( Samsung B-Die ).
Vielleicht kommt da ja noch was - ich wüsste jetzt auch nicht, wie man den Ramtakt noch stabilisieren kann, ob man noch mehr vCore geben sollte, damit die CPU eventuell mehr Ramtakt mitmacht. SoC-Voltage scheint ja nichts zu reissen.
Reous
Mr AMD
@HW-Mann wenn nicht schon getan dann spiele auch mal etwas mit der ProcODT. Bewirkt bei manchen Taktraten Wunder.
darkpope
Einsteiger
OWL
Es ging mir nicht ums laufen. Wenn mich nicht alles täuscht, gab es bei Asus auch eine Kombi, bei der, wenn ein bestimmter Ram-Typ (meine das war eine Sorte Ripjaws) eingestzt worden ist, jedes Bios-Update das Board gebrickt hatte. Ich probiere das noch mal zu finden. Nun habe ich gestern, zumindest bei den Taichis, 4-5 Fälle gefunden, bei denen der Trident-3866 beim Bios-Update zu dem 07 geführt hat. Das ware das Beta-Bios 1.94a. Welche Biosbasis Asrock für das aktuelle 2.36 verwendet, weiß man nicht. Deshalb auch der Vorschlag, beim Biosupdate vielleicht die Riegel des Bruders einsetzten, um Inkompabilitäten beim Bios-Update (und nur da!) zu vermeiden.
H
HW-Mann
Guest
Am Ende kaufen wir noch 1 Stick mit DDR4-2133 aus der QVL Liste, damit wir sicher updaten können. :d
- - - Updated - - -
Teste ich heute Abend ... muss erstmal arbeiten. =/
JZ_
Urgestein
Iserlohn
Code 07: X370 Problem im Zusammenhang mit Speicher nach einem BIOS-Update. Bitte entfernen Sie die CPU und den Speicher. Mit dem Jumper machen Sie dann ein ClearCMOS. Wenn das Problem noch besteht, installieren Sie bitte nur ein Speichermodul oder versuchen Sie es mit anderen Speichermodulen.
- - - Updated - - -
Wenn beim BIOS Update durch fehlerhaftes Timing oder inkompatible Speicher ein Crash passiert, ist das BIOS zerflasht und starte nicht mehr. Dafür hat der Hersteller Wiederherstellungsroutinen bereit gestellt. Diese sollte man einfach mal versuchen. Es ist auch immer zu empfehlen, dass das BIOS vor dem Updaten auf Default gesetzt wird !!!
- - - Updated - - -
Die User, die hier bei mir in der Nähe wohnen, können mit NUR dem nackten Board zu mir kommen und flashe das BIOS neu :)
H
HW-Mann
Guest
Na das ist doch ein sehr nettes Angebot! :)
Hab eben gelesen, dass tatsächlich einige User trotz gegenteiliger Empfehlung AMDs mit ProcODT 80Ohm arbieten unter Luft. O_O
Nozomu
Legende
Soll es zu MF schicken und sie Prüfe das dann.
Reous
Mr AMD
80Ohm ist laut Robert Hallock noch ok. Mit Agesa 1006 war sogar die Rede von 96Ohm (Im Overlock Forum)
Bei deinen Rams würde ich mit 53.3 starten oder das nächst höhere. Glaube 60OHm waren das dann.
darkpope
Einsteiger
OWL
Wenn Du das Board eh ausbaust, würde ich vielleicht noch mal den Workaround von JZ ausprobieren. CPU & Speicher ausbauen, ClerCMOS per Jumper und dann von vornherein mit einem Speicherrigel und einer Graka auserhalb des Gehäuses testen. Vielleicht bewirkt das was und Du kannst Dir den Rücksendestress sparen. Ich weiß nicht, wie kulant MF zur Zeit ist.
Nozomu
Legende
Hab schon Paste abgewischt.
Was hat das mit Kulanz zutun? Bin immer noch in den 14 Tage wideruf. MF ist aber schon sehr gut.
immortuos
München
Die Datei.exe anklicken und auf einem USB-Stick auspacken lassen und normal mit Instant-Flash im BIOS updaten ;)
Na dann hoffe ich mal dass das funktioniert, werde jetzt updaten :d
Nozomu
Legende
Kann ich das für den Test auch ohne Paste und Kühler machen?
Nozomu
Legende
Und auf die Folie lege?
Sry für die dummen Fragen aber sonst macht alles mein Bruder für mich.
immortuos
München
Hmm, also Update lief problemlos, mehr als 2666 bekomme ich aber nicht so einfach rausgequetscht.
2666 CL14 lief bei 2.30 schon mit 1,2V, mehr ging partout nicht, jetzt dasselbe.
1,35-1,4V auf dem RAM, Timings entschärft bis 18-20-20-38, SOC Voltage auf bis zu 1,1V hoch, ProcODT auf bis zu 80 Ohm, bringt alles nichts, nicht mal 2933 gehen...
Die Samsung Dual Rank Chips von meinen Domis scheinen da einfach ein Problem zu haben -.-
Nozomu
Legende
Ich trau mich ehrlich gesagt nicht.
Mein Bruder ist nicht da.
Holzmann
The Saint
Schreibt dein Bruder auch sonst die Beiträge hier? ;)
Oben Unten
