Aktuelles
[Sammelthread] Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
Sammelthread Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
attachment.php
X370 Taichi
-Herstellerlink- -Handbuch- -Preisvergleich-
attachment.php
attachment.php
Inhaltsverzeichnis:
  • Spezifikationen
  • Links & Reviews
  • UEFI History
  • Q&A
  • Ram & Kühler Kompabilitäts-Liste
  • OC
Technische Daten / Spezifikationen:
Gemeinsame Technische Spezifikationen:
  • CPU:
    AMD AM4 Socket Ryzen Series (Summit Ridge)
  • Chipsatz:
    AMD X370 Promontory
  • Memory:
    Supports DDR4 3200+ (OC)
  • Expansion-Slots:
    2 PCIe 3.0 x16 (16/0 - 8/8), 1 PCIe 2.0 x16, 2 PCIe 2.0 x1, 1 M.2 (Key E - belegt mit WiFI-BT-Modul)
  • Storage:
    10 Sata3, 1 UltraM.2 (PCIe Gen3 x4 & Sata3), 1 M.2 (PCIe Gen2 x4)
  • USB:
    2 USB 3.1 (Type-A, Type-C), 10 USB 3.0 (4 Front, 6 Rear)
  • Network :
    1 Intel Gigabit Lan (10|100|1000 Mb/s - Intel I211AT), 1 Intel 802.11ac (IEEE 802.11a/b/g/n/ac, Dual-Band (2,4|5Ghz))
  • Audio:
    7.1 Channel HD Audio (Realtek ALC 1220)
  • Others:
    1 PS/2 Maose/Keyboard-Port (with Y-Cable Support), 1 Clear CMOS Switch
X370 Taichi:
  • Audio-Software:
    Purity Sound 4
  • Vollständige Spezifikationen:
    Code:
    Einzigartige Features
        ASRock USB 3.1
        - ASRock USB 3.1 Type-A Port (10 Gb/s)
        - ASRock USB 3.1 Type-C Port (10 Gb/s)
        ASRock Super Alloy
        - XXL Aluminum Alloy Heatsink
        - Premium 60A Power Choke
        - Premium Memory Alloy Choke (Reduces 70% core loss compared to iron powder choke)
        - Dual-Stack MOSFET (DSM)
        - Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
        - I/O Armor
        - Matte Black PCB
        - High Density Glass Fabric PCB
        - 2oz Copper PCB
        Intel® 802.11ac WiFi
        ASRock Steel Slots
        ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
        ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
        ASRock Live Update & APP Shop
    CPU
        - Supports AMD AM4 Socket Ryzen Series CPUs (Summit Ridge)
        - IR Digital PWM
        - 16 Power Phase design
        - Supports 300W EX OC
        - Supports ASRock Hyper BCLK Engine II
    Chipsatz
        - AMD Promontory X370
     Arbeitsspeicher
        - Dual Channel DDR4 Memory Technology
        - 4 x DDR4 DIMM Slots
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC and non-ECC, un-buffered memory*
        - Max. capacity of system memory: 64GB**
        - 15μ Gold Contact in DIMM Slots
        *Please refer to Memory Support List on ASRock's website for more information.
        Please refer to below table for DDR4 UDIMM maximum frequency support.
        Ryzen Series CPUs:
        UDIMM Memory Slot    Frequency(MHZ)
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
        SR    SR    SR    SR    2133-2400
        SR/DR    DR    SR/DR    DR    1866-2133
        SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
        DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
        **Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
    BIOS
        - 128Mb AMI UEFI Legal BIOS with GUI support
        - Supports "Plug and Play"
        - ACPI 5.1 compliance wake up events
        - Supports jumperfree
        - SMBIOS 2.3 support
        - CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
    Grafik
        - n/a
    Audio
        - 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
        - Premium Blu-ray Audio support
        - Supports Surge Protection
        - Supports Purity Sound™ 4
        - Nichicon Fine Gold Series Audio Caps
        - 120dB SNR DAC with Differential Amplifier
        - TI NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
        - Pure Power-In
        - Direct Drive Technology
        - PCB isolate shielding
        - Impedance Sensing on Line Out port
        - Individual PCB Layers for R/L Audio Channel
        - Gold Audio Jacks
        - 15μ Gold Audio Connector
        - Supports DTS Connect
    LAN
        - Gigabit LAN 10/100/1000 Mb/s
        - GigaLAN Intel® I211AT
        - Supports Wake-On-LAN
        - Supports Lightning/ESD Protection
        - Supports Energy Efficient Ethernet 802.3az
        - Supports PXE
    Drahtloses LAN
        - Intel® 802.11ac WiFi Module (Free Bundle)
        - Supports IEEE 802.11a/b/g/n/ac
        - Supports Dual-Band (2.4/5 GHz)
        - Supports high speed wireless connections up to 433Mbps
        - Supports Bluetooth 4.2 / 3.0 + High speed class II
    Steckplätze
        - 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE3))*
        - 1 x PCI Express 2.0 x16 Slot (PCIE5 @ x4 mode)**
        - 2 x PCI Express 2.0 x1 Slots
        - Supports AMD Quad CrossFireX™ and CrossFireX™
        - Supports NVIDIA® Quad SLI™ and SLI™
        - 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
        - 15μ Gold Contact in VGA PCIe Slot (PCIE2)
        *Supports NVMe SSD as boot disks
        **If PCIE5 slot is occupied, M2_2 will be disabled
    Storage
        - 8 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
        - 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)
        - 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 PCI Express module up to Gen2 x4 (20 Gb/s)*
        *If M2_2 is occupied, PCIE5 slot will be disabled
        Supports ASRock U.2 Kit
    Anschluss
        - 1 x Power LED and Speaker Header
        - 1 x AMD Fan LED Header
        - 2 x RGB LED Headers*
        - 1 x CPU Fan Connector (4-pin)**
        - 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
        - 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
        - 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*****
        - 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
        - 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
        - 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
        - 1 x AMD LED Fan USB Header
        - 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
        - 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
        - 1 x Dr. Debug with LED
        *Supports up to 12V/3A, 36W LED Strip
        **The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
        ***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        ****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        *****CPU_FAN1, CHA_FAN1, CHA_FAN2 can auto detect if 3-pin or 4-pin fan is in use.
    Blende
        - 2 x Antenna Ports
        - 1 x PS/2 Mouse/Keyboard Port
        - 1 x Optical SPDIF Out Port
        - 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
        - 6 x USB 3.0 Ports (Supports ESD Protection)
        - 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
        - 1 x Clear CMOS Switch
        - HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
    Software und UEFI
        Software
        - ASRock A-Tuning
        - ASRock RGB LED
        - ASRock APP Charger
        - ASRock XFast LAN*
        UEFI
        - ASRock Full HD UEFI
        - ASRock Instant Flash
        - ASRock Internet Flash
        - ASRock Crashless BIOS
        - ASRock Easy RAID Installer
        *These utilities can be downloaded from ASRock Live Update & APP Shop.
    Support-CD
        - Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
    Produktzubehör
        - Quick Installation Guide, Support CD, I/O Shield
        - 4 x SATA Data Cables
        - 1 x ASRock SLI_HB_Bridge_2S Card
        - 2 x ASRock WiFi 2.4/5 GHz Antennas
        - 2 x Screws for M.2 Sockets
    Hardware überwachung
        - Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
    Formfaktor
        - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
    Betriebssystem
        - Microsoft® Windows® 10 64-bit*
        *For the updated Windows® 10 driver, please visit ASRock's website for details.
    Zertifizierungen
        - FCC, CE
        - ErP/EuP ready (ErP/EuP ready power supply is required)
  • Audio-Software:
    Creative Sound Blaster Cinema 3
  • Network zusätzlich:
    1 Aquantia 5 Gigabit Lan (10|100|1000|2500|5000 Mb/s - Aquantia AQC108)
  • Onboard:
    1 COM Port Header, 1 TPM Header, 1 Power Switch, 1 Reset Switch
    Code:
    Gaming Armor
        Power
        - Hi-Density Power Connectors (24 pin and 8 pin)
        Memory
        VGA Card
        Internet
        - AQUANTIA 5G LAN
        - Intel® LAN
        Cooling
        - Heat Pipe Design
        Audio
        - Creative Sound Blaster™ Cinema 3
        ASRock USB 3.1
        ASRock Super Alloy
        - I/O Armor
        - Matte Black PCB
        - 2oz Copper PCB
        AQUANTIA 5G LAN
        ASRock Steel Slots
        ASRock Ultra USB Power
    CPU
        - IR Digital PWM
    Chipsatz
    Arbeitsspeicher
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory*
        Ryzen Series CPUs:
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
    BIOS
    Grafik
        - n/a
    Audio
        - Pure Power-In
        - PCB Isolate Shielding
        - RGB LED
        - Gold Audio Jacks
        - Supports Creative Sound Blaster™ Cinema 3
    LAN
        1 x 5 Gigabit LAN 100/1000/2500/5000 Mb/s (AQUANTIA AQC108):
        - Supports PXE
        1 x Intel® Gigabit LAN 10/100/1000 Mb/s (1 x Intel® I211AT):
        - Supports PXE
    Drahtloses LAN
    Steckplätze
    Storage
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)*
    Anschluss
        - 1 x COM Port Header
        - 1 x TPM Header
        - 1 x Power Switch with LED
        - 1 x Reset Switch with LED
    Blende
        - 2 x Antenna Ports
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)*
        - 6 x USB 3.0 Ports (Supports ESD Protection)**
        - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
        *Ultra USB Power is supported on USB3_5_6 ports.
        ACPI wake-up function is not supported on USB3_5_6 ports.
        **1 x Fatal1ty Mouse Port (USB 3.0) is included
    Software und UEFI
        Software
        - ASRock F-Stream
        - ASRock RGB LED
        - ASRock Key Master
        - ASRock XFast LAN*
        UEFI
    Support-CD
    Produktzubehör
    Formfaktor
    Betriebssystem
    Zertifizierungen
        - FCC, CE
Links & Reviews:
Allgemeine Links
X370 Taichi:
UEFI History:
X370 Taichi:
Link Asrock
  • 2.00
    Update AGESA to 1.0.0.4a, Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup
  • 2.20
    Update Agesa Version string "SummitPI-AM4 1.0.0.4a
  • 2.30
    Enhance OC setting for advanced Overclocker
  • 2.40
    Update AGESA to 1.0.0.6
  • 3.00
    Update AGESA to 1.0.0.6a
  • 3.10
    Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature. Windows update is available for version P3.00 or later.
  • 3.20
    With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
  • 3.30
    Bridge BIOS
  • 4.40
    Update AGESA for future coming processors.
    * Before updating this BIOS, please update the BIOS to P3.30 firstly
  • 4.60
    Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a.
    (Einwurf: Wenn nicht das 4.40 schon drauf ist)
  • 4.70
    Enhance compatibility for Raven CPU with Intel WiFi.
    (Einwurf: Wenn nicht das 4.40 oder höher schon drauf ist)
  • 4.80
    Update PinnaclePI-AM4_1.0.0.4
Link Asrock
  • 2.00
  • 2.20
  • 2.30
  • 2.40
  • 3.00
  • 3.10
  • 3.30
    Bridge BIOS
  • 4.40
  • 4.60
  • 4.70
  • 4.80
Q&A:
Allgemeingültige Q&A:
  • Spannungsversorgung Bios
    It is our BIOS extra setting instead of a bug.
    Normally, users could only modify CPU internal voltage.
    But on this model, we mounted with extra PWM IC to let users control CPU external voltage.
    In BIOS \ OC Tweaker \ CPU Configuration \ CPU Voltage, this option is to adjust CPU internal voltage.
    In BIOS \ OC Tweaker \ Voltage Configuration \ Fixed (Offset) Voltage, this option is to adjust CPU external voltage.
    Note: If users set CPU internal voltage and CPU external voltage at the same time, CPU voltage would only change based on CPU external voltage setting.
    Quelle
  • Offizelle AMD Ram-Support Liste Agesia 1.0.0.6 (06-2017)
X370 Taichi:
  • folgt, sobald was gesammelt wird
CPU-Kühler & Ram Kompabilitäts-Liste
X370 Taichi:
Ram:
CPU-Kühler:
Ram:
CPU-Kühler:
OC:
  • AMD Ryzen Processor and AMD Ryzen Master Over-clocking User’s Guide
  • Overclockers Ryzen Overclocking Guide
  • AMD Ryzen (Zen) "Summit Ridge" Socket AM4 OC Thread
  • AMDs Community Update #4: Let's Talk DRAM! (RamSpecs)
  • P-State Values:
    Code:
    Values for P State Overclocking -
    FID (Clock Speed) 90 - 3600mhz, 91 = 3625, 92 = 3650, 93 = 3675, 94 = 3700, 95 = 3725, 96 = 3750, 97 = 3775, 98 = 3800, 99 = 3825,
    9a = 3850, 9b = 3875, 9c = 3900, 9d = 3925, 9e = 3950, 9f = 3975
    a0 = 4000, a1 = 4025 (my max sweetspot OC), a2 = 4050, a3 = 4075, a4 = 4100, a5 = 4125, a6 = 4150, a7 = 4175, a8 = 4200 = a9 = 4225, aa = 4250, ab = 4275, ac = 4300, ad = ugh you win the lottery.
    Values for DID (Increment adjustment adjuster and or bclk adjustments, not too sure what it does TBH, as I found an overclock that I was already comfortable with and have not spent much time with this yet, though looking at it more closely, here are the values) - 8 = 25 mhz increments, 9 =22.2196, a = 20 b = 18.18, c = 16.667, d (final recommendation) = 15.384mhz - 3943mhz cap).
    Values for VID Voltage Control = 30 = 1.25v, 2f = 1.256v, 2e, 1.2562v, 2d = 1.268, 2c = 1.275v, 2b = 1.2812v, 2a = 1.287v, 29 = 1.293v, 28 = 1.3v, 27 = 1.3062v, 26 = 1.3125v, 25 = 1.318v, 24 = 1.325v, 23 = 1.3312v, 22 = 1.3375v, 21 = 1.343v, 20 = 1.35v, 1f = 1.356v, 1e = 1.3625v, 1d = 1.368v, 1c = 1.375v, 1b = 1.3812v, 1a = 1.3875v, 19 = 1.3937v, 18 = 1.4v, 17 = 1.406v, 16 = 1.4125v, 15 = 1.418v, 14 = 1.425v, 13 = 1.4321v, 12 = 1.4375v, 11 = 1.443v, 10 = 1.45v, *next set is from f - a, 9 - 9 (1.45 - 1.55v), though be very careful overclocking in this voltage range*.
  • Ryzen Timing Checker
  • AMD Memory OC Showdown: Frequency vs. Memory Timings
  • Ryzen DRAM Calculator
Ergbenisse:
(Blau = Taichi | Rot = Prof Gamnig)
  • Ryzen Modell | Quelle | Geschwindigkeit | Spannung | LLC | Bios
  • R7 1700 | immortuos | 3,9Ghz | 1,35V| 3 | 2.00
  • R5 1600 | darkpope| 3,85Ghz| 1,28V | 3 | 2.40
  • R7 1800X | jc110 | 4,05Ghz| 1,3925V | 3 | 2.40
  • R7 1700 | Nimrais | 3,50 Ghz| 1,2V | 3 | 2.40
  • R7 1700x | HW-Mann | 4,075 Ghz| 1,488V | ? | 3.00
  • R7 1600x | 4Stroke | 4,09 Ghz| ca. 1,4V | ? | 3.20
  • R7 1600x | reinhardrudi | 4,0Ghz | 1,376V| 3 | 3.20
  • R7 1600x | 4Stroke | 3,9 Ghz | 1,256V | ? | 3.10
to be continued
Nozomu
Legende
Mein Perf und 1600X ist angekommen und Win10 wird gerade Neu eingerichtet.
Paar Startprobleme noch aber wird schon noch.
Gesendet von meinem SM-G935F mit Tapatalk
H
HW-Mann
Guest
Die Startprobleme sind sicher das "Ramtraining" ... das dauert immer bissele. ;)
Nozomu
Legende
Habs geschafft.
Lag an Nvidia Treibers.
SuLux
Chicken Wings
So, kleines Update von mir:
Mein RAM läuft wie geölt :d
Vorher waren nur 2666MHz möglich.
Es handelt sich bei mir um 4 x 8 GB DR.
H
HW-Mann
Guest
Mit was rennt er denn ? In dem Screen gibts keine aktuelle Taktangabe. -> HWiNFO ist das Mittel der Wahl. ;)
SuLux
Chicken Wings
Huch den wichtigen Tab vergessen :d
Jetzt erstmal testen wie stabil der RAM ist.
Tanatos
Das 2.36 auf meinem Gaming Pro is ne Katastrophe :(
...bootet teilweise nicht mal mit UEFI defaults! trotz mehrmaligen cmos-clear inkl. Start-Button drücken und nochmal defaults loaden^^
Das Board bleibt immer im Ram-Training hängen und resettet dann.
Einmal konnte ich es dann zum Starten bewegen und Speicher wieder Stufenweise auf 3200 hochstellen, aber dafür hat das Board das CPU-OC komplett ignoriert :eek:
...ich geh wieder zurück auf 2.30
Tanatos
Mit 2.30 läufts wieder einwandfrei!
Alte Werte eingestellt - gespeichert - gebootet - läuft^^ :)
plainvanilla
Meines ist definitiv Tod! Aber gerade vor ladenschluss noch ein crosshair ergattert. Jetzt kann ich umbauen auch noch, tja netter Versuch gewesen nach 10 Jahren wiedermal AMD, mit ziemlich enttäuschenden Ausgang.
Dann wird's halt doch wieder 2066er, statt threadripper.
Tanatos
...kannst meine Kombo haben, wenn du gerne ein Ryzen-System willst :)
plainvanilla
nein danke! ;), das bleibt nur solange da bis 2066 raus ist, threadripper werde ich mir wahrscheinlich nach der
heutigen erfahrung nicht antun. aber wer weiss, wenn der ärger mal verflogen ist............ aber bei X370 bleibt es
definitiv nicht, das taugt mir mit der PCIe lane knappheit nicht, das habe ich aber vorher schon gewusst.
so umgebaut ist auch schon, mal schauen wie das crosshair funkt. :shot:
Nozomu
Legende
Hilfe nach Bios Update spuckt Mainbaord Fehlercode 07 aus.
Hab auch schon versucht nur mit einen Speicher, bringt kein Erfolg.
Einer ein Tipp was ich machen kann?
CMos Reset hilft auch nichts.
Phantomias88
Banned
StuggiTown
24 Stunden vom Netz trennen, bzw. alles ab-stöpseln was an der Kiste hängt, ink. Bios Batterie. ;)
CMOS-clear schon gemacht?
Nozomu
Legende
Sicher? Was soll nach 24std anders sein?
CMOS-clear hab ich gemacht und ändert nichts dran.
Phantomias88
Banned
StuggiTown
Auch ohne USB was weiß ich was dran und ohne Strom vom 230V Netz?
CMOS-clear ist ein Phänomen für sich...
Nozomu
Legende
Was meinst mit 230V Netz?
Phantomias88
Banned
StuggiTown
Den Kaltgeräte Stecker am Netzteil abziehen, der in der Steckdose (230V) endet.
Dann den Gehäuse Ein-Taster drücken, und zuschauen wie das System kurz aufleuchtet dann in sleep Mode geht..
Nun die Bios/UEFI Batterie entfernen und nochmal den Ein-Taster drücken, Rest-Entladungen loswerden = Erden!
P.S. Windows "schnell-start" deaktivieren, sonst wacht das System nur aus dem "Schlaf auf".
plainvanilla
na hoffentlich hast nicht den gleichen schmarrn wie ich!
ganz vom netz nehmen auf alle fälle, cmos jumper setzen, ein paarmal hintereinander!
was du auch noch probieren kannst, ich habs dann nicht mehr gemacht, cpu rausnehmen und wieder einsetzen.
Nozomu
Legende
Die P2.30 also die neuste von AsRock seite
Nozomu
Legende
Bringt mir jetzt auch nichts mehr. Geht ja nichts mehr.
immortuos
München
Was hat das denn mit AMD zu tun wenn ein Boardhersteller das Bios versemmelt?
Warum hast du nicht einfach eine RMA gemacht?
Tanatos
wie hast du das bios-update gemacht?
und wie hast du den cmos clear gemacht?
piepst es ein paar mal nach dem einschalten?
Nozomu
Legende
Mir reicht es. Geht morgen zu MF zurück und lasse mir Neues zuschicken. Das Brett ist krank.
Ganz normal von AsRock geladen und über Boot halt.
darkpope
Einsteiger
OWL
Was passiert nach dem einschalten? Eventuell mal die Speicherriegel entfernen und nur mit einem probieren. Vielleicht mal wirklich noch die CPU ausbauen.
Nozomu
Legende
Ich hab sogar einen von Bruder versucht. Immer das selbe mit Code 07.
Oben Unten
