zrxGhost
1805 Release...
1. This is AMI BIOS release
2. This BIOS fixes the following problem of the previous version:
- AGESA PI 1.2.8.0 updated.
- Improved memory compatibility.
3. 2025/12/03
Gibt's irgend eine Info wieso die 1804 Final Hero Bios(e) zurückgezogen wurden bzw verschwunden sind?
There’s no need to worry
There was an Aura fw issue when updating from the very old BIOS to 1804 BIOS and 1805 fixed that problem.
This issue only x870e hero/x870e hero btf, So this is the reason why we removed the X870E Hero / Hero BTF 1804 BIOS from the website.
Agesa 1280 update soon
1. Update AGESA version to 1.2.8.0
2. Improve system performance
*Starting from this BIOS, TRFC2 and TRFCSB are work now, so if you set the values low, cant to boot
2. Changed the default Nitro to 1/3/1
3. Some ODT rules changes for 16x2 6000cl26 1.4v and 1.45v kit
4. Already apply Group B parameters for 16x2 6000cl26 1.4v and 1.45v kit
- Windows® 11 25H2 OS support added
- Installer EULA is updated
- Bug fixes.
AMD Chipsatz Treiber 7.11.26.2142
Ja habe eine von nem ASUS Board drauf gemacht, musste mal schauen, seit dem läuft schon mal der USB C Netzwerkadapter scheinbar.Hallo an Euch,
Ich weis leider nicht wo ich das am Besten posten sollte. Gibt bei ASUS (in meinem Fall Rog Strix X870E-E Wifi, vermutlich auch für andere Asus 8xx Boards) eine neue AS Media FW:
ROG STRIX X870E-E GAMING WIFI | ROG Strix | Gaming Motherboards|ROG - Republic of Gamers|ROG Global
The ROG Strix X870E-E Gaming WiFi elevates builds with 18 power stages, DDR5 slots and extensive PCIe 5.0 connectivity. It features five M.2 SSD slots with heatsinks, USB4® support, WiFi 7, AI Overclorog.asus.com
ASUS 4242 and PD-GX Firmware Windows Update Tool
Version 4242: 250708, IT8857: 0206
5.83 MB 2025/12/12
SHA-256 :99DFED62167F0F5CD43522AF6611ACF9A5E6D8433996910B9FDC6B4A53BA8E4A
Updated firmware to ver. 250708 for ASM4242 and V0206 (GX) for IT8857 to improve compatibility with connected devices.
Soeben installiert. Mein Rechner ist nicht "explodiert", alles funktioniert. War problemlos.
l. G.
Karl
AMD was notified of a bug in “Zen 5” processors that may cause the RDSEED instruction to return 0 at a rate inconsistent with randomness while incorrectly signaling success (CF=1), indicating a potential misclassification of failure as success. This issue was initially reported publicly via the Linux kernel mailing list and was not submitted through AMD’s Coordinated Vulnerability Disclosure (CVD) process.
AMD has determined that the 16-bit and 32-bit forms of the RDSEED instruction on “Zen 5” processors are affected. The 64-bit form of RDSEED is not affected. AMD plans to release mitigations for this vulnerability. Please see the details below.
AMD Ryzen™ 9000 Series Desktop Processors
ComboAM5PI 1.2.8.0
11/25/2025
2. Rollback to refresh mode
3. Apply new odt rules for 16x2 6000cl26 1.4v and 1.45v kit
Seit dem 15.12. zumindest für das B850 Riptide in der Bios Version 4.03 enthalten:ASRock veröffentlicht erste Beta Bios mit AGESA 1.2.7.1
Ist leider eine Maßnahme die ergriffen werden musste, um Spamlinks einzudämmen.Ich liebe ja dieses Forum, siehe Bild:
Agesa 1300 needs more internal testing, so we'll release Agesa 1290 first
1. Update AGESA version to 1.2.9.0
Starting from AGESA version 1280, the refresh mode has been changed to mixed mode
Therefore, if you want to use the previous mode, need to set M_ORDERING to NORM
Weiß jemand, was es mit dieser Option auf sich hat?Starting from AGESA version 1280, the refresh mode has been changed to mixed mode
tRFC..Weiß jemand, was es mit dieser Option auf sich hat?
Version 0502
39.28 MB 2026/01/07
SHA-256 :0B6098D15DA2F6A6C2452F46F6E8D475698C47FE2C9D16CB22E7F74B4900BAF3
"Enhance system stability and compatibility.
Before running the USB BIOS Flashback tool, please rename the BIOS file (A5741.CAP) using BIOSRenamer."
