[Sammelthread] Offizieller AMD RX 9070 (XT) Overclocking und Modding Thread
I have explained myself, I won't trouble you here anymore, it was my right to present my side of the story. I wanted to explain how I see things from my perspective, just so it's clear, and also for the record.
A more constructive approach would have been: “This is mentioned in the instructions, but the term ‘Reset to Defaults’ is somewhat misleading.”
I wasn't talking about that, I was talking about me explaining my side of the story. But I also will take your advice under consideration, it would be better for the user to not worry about such things, I was focused on other more important aspects with my tool, but I hope to find the time to make it seamless for VID factory presets.
Also forgot to mention, my project is under GPL v3 license. Please read the conditions so you know what you need to do so you are compliant with it.
Important ones: you must make the full source code publicly available, you must credit the original project and you also must offer it under the same GPL v3 license.
You are free to use it, modify it, ask money for it, as long as you are compliant with the license.
Ich bitte jetzt darum, dass man wieder on topic kommt, damit wir hier keinen Mop, äh Mod zum Durchwischen brauchen. Denn anders als OCN wird hier modieriert.
Ich danke!
You still don't understand that there is nothing, absolutely nothing, of yours in the RebelsTool.
It would have been far too unsafe for us to take register addresses from some guy on the internet.
Only the idea of doing this with current AMD GPUs via Linux can be credited to you.
Please study the license file, the license exists to stop what you are trying to do, use "small technicalities" to clone a project and pass it as your own. Study the license, it's important. It is not about same code, it's more complicated.
Ich danke!
Yes we talk about RDNA4, I have also offered good resources for you here: https://www.hardwareluxx.de/communi...king-und-modding-thread.1364991/post-31076777
Full register list for RDNA4 and 3, it is for this thread, hope the people here appreciate having full access to modifying their RDNA4 and RDNA3 voltage regulator parameters! It is on topic, and an offering for this community (a very big offering, it is everything about VRs).
Ok, das hat keinen wert mit dem Kolegen hier.
Das sehe ich auch so.
Wie lädt man denn bei TPU ein Bios File hoch oder geht das nur aus GPU-Z direkt?
Direkt aus der App. Das wird aber wenig gepflegt. Die landen alle im unverified und meist passiert dann nicht mehr viel, wenn ein Modell Mal nicht mehr ganz neu ist.
Boah, bei mir kommen keine Punkte mehr zusammen.
7659 hatte ich mal geschafft, jetzt gehen nur noch max 300 Punkte weniger, trotz fast identischer Einstellungen und effektiv anliegenden Taktzahlen:
Kann das wirklich nur an einem zugemüllten OS liegen?
Treiber?
Es gibt hier auch wohl immer noch leichte Unterschiede. Vielleicht nicht so wild wir früher.
Ja schaus dir an, PJVol hat da einen expliziten Regler für extra Watt rein, wie ich geschrieben hab. Damit so ein Dummy wie ich auch zurechtkommt. Ich vermute, dass es im Hintergrund ein Ampere Offset ist, aber ich weiß es nicht genauer. Ich hab von der Elektrotechnik hier am wenigsten Ahnung. Und die ursprüngliche Variante sagen manche, wäre für RDNA3 und nicht 4. Weißt was, mir is das wurscht, solange es geht. Und - falls das aufkommt - mir ists auch egal, wo es herkommt.
It works because he copied my work in that file. I have researched the RDNA4 offset register, and documented it here:
Not even RebelTool is using it because that is my work. PJVol copied my work into that XML and gave it to you, and you put it on the front page and people think PJVol came up with the offset register. He did not, I did, he just copied my work and tricked you into posting it, without giving credit to my project.
I am ok with you using that file, and keeping it there on the front page, if you also credit my project as the original work it is based on. Without my work that XML file has no extra value compared to the stock one.
I will translate this in German so I make sure you understand the details:
Es funktioniert, weil er meine Arbeit in dieser Datei kopiert hat. Ich habe das RDNA4-Offset-Register untersucht und hier dokumentiert:
Nicht einmal RebelTool verwendet es, da es sich um meine Arbeit handelt. PJVol hat meine Arbeit in diese XML-Datei kopiert und Ihnen gegeben, und Sie haben sie auf die Startseite gestellt, sodass die Leute denken, PJVol hätte das Offset-Register entwickelt. Das hat er nicht, sondern ich. Er hat lediglich meine Arbeit kopiert und Sie dazu gebracht, sie zu veröffentlichen, ohne mein Projekt als Quelle anzugeben.
Ich habe nichts dagegen, dass Sie diese Datei verwenden und sie auf der Startseite belassen, wenn Sie auch mein Projekt als das Originalwerk nennen, auf dem sie basiert. Ohne meine Arbeit hat diese XML-Datei keinen zusätzlichen Wert gegenüber der Standarddatei.
Ich werde dies ins Deutsche übersetzen, damit Sie die Details auch sicher verstehen
More exactly, he added this bit into the XML:
XML:
            <Item>
                <Name>MFR IIN Offset</Name>
                <PreExec>
                    <Command>00</Command>
                    <Data>1</Data> <!-- Page 1 -->
                </PreExec>
                <Register Type="List">
                    <Command>10</Command>
                    <Length>2</Length>
                    <Data Desc="None">0000</Data>
                    <Data Desc="+30W">F600</Data>
                    <Data Desc="+60W">EC00</Data>
                    <Data Desc="+90W">E200</Data>
                    <Data Desc="+120W">D800</Data>
                    <Data Desc="+150W">CE00</Data>
                    <Data Desc="+180W">C400</Data>
                    <Data Desc="+210W">BA00</Data>
                    <Data Desc="+240W">B000</Data>
                    <Data Desc="+270W">A600</Data>
                    <Data Desc="+300W">9C00</Data>
                    <Data Desc="+330W">9200</Data>
                    <Data Desc="+360W">8800</Data>
                </Register>
            </Item>
The important bit is:
This is the power offset register on RDNA4, I have discovered this, not PJVol. He copied this information from my research, and made the XML file, but he did not discover this, and without this information there is no extra value to the XML.
You can credit PJVol for creating the XML file, yes, but what matters is knowing which command at what address. That is based on my work, he just copied the register information from my work.
Genauer gesagt fügte er diesen Teil in die XML-Datei ein:
XML:
            <Item>
                <PreExec>
                </PreExec>
                    <Length>2</Length>
                </Register>
            </Item>
Der wichtige Teil ist:
<Data>1</Data> <!-- Seite 1 -->
Dies ist das Leistungsausgleichsregister auf RDNA4. Ich habe dies entdeckt, nicht PJVol. Er hat diese Informationen aus meiner Forschung kopiert und die XML-Datei erstellt, aber er hat dies nicht entdeckt, und ohne diese Informationen hat die XML-Datei keinen zusätzlichen Wert.
Man kann PJVol zwar die Erstellung der XML-Datei zugutehalten, aber wichtig ist, zu wissen, welcher Befehl an welcher Adresse steht. Das basiert auf meiner Arbeit, er hat lediglich die Registerinformationen aus meiner Arbeit kopiert.
This is PJVol's work:
Dies ist die Arbeit von PJVol:
Code:
But AI can also do that, it's nothing, banal, easy, anyone with minimal understanding can create it. That is not information about offset register, it's interface design option, for the list. You cannot do anything without knowing about page 1 register 10. That is what I discovered, and PJVol copied from my work into this XML file.
Aber KI kann das auch, das ist nichts Besonderes, banal, einfach, jeder mit minimalen Kenntnissen kann das erstellen. Das sind keine Informationen zum Offset-Register, sondern Optionen für das Schnittstellendesign für die Liste. Ohne Kenntnisse über Seite 1 Register 10 kann man nichts machen. Das habe ich herausgefunden, und PJVol hat es aus meiner Arbeit in diese XML-Datei kopiert.
Es ist wichtig, weil der RDNA4-Leistungsausgleich nicht PJVols Leistung ist. Er hat ihn nicht entdeckt, sondern ich. Ich habe viel Arbeit investiert, um ihn zu entdecken, nicht er. Er hat meine Entdeckung kopiert und als seine eigene Leistung präsentiert, das ist nicht in Ordnung. Es handelt sich nicht um sein geistiges Eigentum oder seine geistige Arbeit.
Ich kann dir zwar nicht für dein Auftreten gratulieren, aber für deine Forschung und Entdeckungen.
Ich verstehe, dass es manchmal schwierig sein kann, mit mir umzugehen, aber für Menschen wie mich ist das nicht immer eine Wahl, die ich habe, wie es vielleicht bei Ihnen der Fall ist.
Auch wenn Ihnen mein Verhalten nicht gefällt, ist das kein Grund, meine Ideen zu stehlen.
Schließlich habe ich meine Arbeit allen angeboten. Mein Skript, RebelTool, EVC2-Power-Offset-Datei – sie existieren, weil ich meine Arbeit öffentlich gemacht habe.
Die Leute genießen die zusätzliche Leistung von RDNA3 und RDNA4, und im Gegenzug werden meine Ideen gestohlen? Weil Ihnen meine Art zu reden nicht gefällt? Ich verstehe, dass wir vielleicht keine Freunde sind, aber das ist doch etwas anderes, als wenn Ihre Ideen gestohlen werden, oder?
Grüße,
Ist hier der limitierende Faktor Pcie 3.0?
Glaube ich nicht wirklich, mein bester DX12 Run mit PCIe5x4, was PCIe 3x16 entspricht, war 8.038 Punkte (363W; -140mV; 2825Mhz FT)
Welche Karte hast du denn?
ASRock Steel Legend.
Karte boostet im Benchmark im schnitt auf 3100mhz.
Hängt an einem Riser Kabel (20cm)
Cpu ist 5800x OC auf nen Asus 470 prime pro.
RAM 3800 CL 16 plus schnelle timings.
BF6 Boostet die karte zwischen 3300 und 3420.
Selbst wenn ich noch bissel was dran drehe, werd ich keine 8000 sehen.
Die 8000 bekommst auch nicht ohne Modifikation der Karte.
Bist doch schon über dem durchschnitt:
Hm, dann teste ich auch mal in dx12. Meine ich hatte knapp 8100 Punkte.
Edith: +- 8.060 ist schluss
The only common components are standard Linux kernel headers: i2c-dev.h, i2c.h, and i2c/smbus.h.
These are provided by the Linux kernel and are not original to your project. Their use does not constitute copying GPL-licensed project code, nor does it trigger GPLv3 obligations.
How do you know you can use that to modify the GPU VR parameters?
I post it here:
Your programmer copies my information to your forum two days later:
So even if he copies my information, you still don't know you can do it for RDNA4. How do you this method also works for RDNA4? There is no information that such a thing is possible anymore on RDNA4.
But again, I discover it may be possible, here:
I have worked to figure this out. Everyone was saying RDNA4 uses a different way of power monitoring, and you all were soldering your power monitoring chips. But I again found a way.
So you need to use a lot of my work, before you even think "to find a different register". You have no register to find, if you do not use my work.
You are trying to pretend you do not understand this. You do not have a grateful attitude towards what I worked for, you take it like it's yours, and use cheap explanations for why you don't have to credit my work. This is very shameful for you. You are trying to get away with stealing my ideas, legally.
And in German:
Woher wissen Sie, dass Sie damit die GPU-VR-Parameter ändern können?
Ich poste es hier:
Ihr Programmierer kopiert meine Informationen zwei Tage später in Ihr Forum:
Selbst wenn er meine Informationen kopiert, wissen Sie immer noch nicht, ob dies für RDNA4 funktioniert. Wie können Sie sicher sein, dass diese Methode auch für RDNA4 funktioniert? Es gibt keine Informationen darüber, dass so etwas bei RDNA4 möglich ist.
Aber ich habe hier entdeckt, dass es möglicherweise doch möglich ist:
Ich habe daran gearbeitet, das herauszufinden. Alle sagten, dass RDNA4 eine andere Art der Leistungsüberwachung verwendet, und ihr habt alle eure Leistungsüberwachungs-Chips verlötet. Aber ich habe wieder einen Weg gefunden.
Ihr müsst also viel von meiner Arbeit nutzen, bevor ihr überhaupt daran denkt, „ein anderes Register zu finden”. Ihr habt kein Register zu finden, wenn ihr meine Arbeit nicht nutzt.
Du versuchst so zu tun, als würdest du das nicht verstehen. Du bist nicht dankbar für das, wofür ich gearbeitet habe, du nimmst es einfach so hin, als gehöre es dir, und suchst nach billigen Ausreden, warum du meine Arbeit nicht würdigen musst. Das ist sehr beschämend für dich. Du versuchst, mit dem Diebstahl meiner Ideen rechtlich davonzukommen.
Haha! On page 1 here is an XML with the register from "some guy on the internet", 64 downloads. Seems that people get use from that register "from some guy on the internet". Lol
In the end, your users are worse off with your "solution", you offer on 2x power increase = 115C hotspot. That is not safe. I would have preffered if your users had full control over the limit.
If you would have given my project credit, and keep yours open-source, you could have used everything I was using. That was best version for your users, if you really cared about them.
You only care about you posing as having come up with "RDNA4 power increase", which you didn't. You used my work to find a slightly different way (and worse), to achieve what I have achieved, and you pat yourselves on the back for doing it. 115C hotspot, great!
You get nothing out of "proprietary" code, it's nothing important there, any LLM can do it. Your users only get 2x power increase, high hotspot, you look sub-standard with 2x power increase, and you risk your users damage their GPUs in time, with 115C hotspot.
This makes no sense, only for your ego of posing like you achieved "RDNA4 software power increase" (because you failed to do something for years).
Not the smartest move, lol
Herzlichen Glückwunsch! Du bist jetzt der erste auf meiner Ignorieren - Liste... 😊
Stammespolitik, das ist einfach. Ich erwarte nichts anderes von den meisten von Ihnen hier, die meisten von Ihnen scheinen denselben Charakter zu haben.
Wenn Sie jahrelang keine Lösung gefunden haben, müssen Sie demjenigen Anerkennung zollen, der Sie betreut hat. Das ist Charakterstärke, nicht meine Arbeit als Ihre eigene auszugeben.
Sie beglückwünschen sich selbst dafür, dass Sie meine Arbeit übernommen haben, das ist lächerlich. Sie waren selbst nicht in der Lage, dies zu tun.
Deshalb würdigt man die Person, die es entdeckt hat, damit wir alle solche Situationen vermeiden können. Wenn ihr nicht versucht hättet, so zu tun, als hättet ihr es selbst gemacht, und den Urheber der Methode gewürdigt hättet, wäre das jetzt nicht passiert. Alles wäre in Ordnung. Eure Leistung besteht nicht darin, einen Hack für die Leistungsbegrenzung von RDNA4 gefunden zu haben, sondern darin, die Arbeit eines anderen zu übernehmen, ohne ihn dafür zu würdigen, und euch selbst dafür zu beglückwünschen.
Yeah I'm done with this place, ungrateful group of entitled people :cautious:
Erinnert mich an den einen Kollegen der den Intel RAM OC Thread damals zugespamt hatte.
@RedF ich hab noch bissel gewerkelt.
Mit angepasster lüftersteuerung sind wahrscheinlich auch 7700 drin :d
So hab ich wahrscheinlich das Max. an leistung ohne das die Karte laut wird :) und es stabil läuft ingame.
Sieht gut aus : )
