[Sammelthread] Offizieller AMD RX 9070 (XT) Overclocking und Modding Thread
I have explained myself, I won't trouble you here anymore, it was my right to present my side of the story. I wanted to explain how I see things from my perspective, just so it's clear, and also for the record.
A more constructive approach would have been: “This is mentioned in the instructions, but the term ‘Reset to Defaults’ is somewhat misleading.”
I wasn't talking about that, I was talking about me explaining my side of the story. But I also will take your advice under consideration, it would be better for the user to not worry about such things, I was focused on other more important aspects with my tool, but I hope to find the time to make it seamless for VID factory presets.
Also forgot to mention, my project is under GPL v3 license. Please read the conditions so you know what you need to do so you are compliant with it.
Important ones: you must make the full source code publicly available, you must credit the original project and you also must offer it under the same GPL v3 license.
You are free to use it, modify it, ask money for it, as long as you are compliant with the license.
Ich bitte jetzt darum, dass man wieder on topic kommt, damit wir hier keinen Mop, äh Mod zum Durchwischen brauchen. Denn anders als OCN wird hier modieriert.
Ich danke!
You still don't understand that there is nothing, absolutely nothing, of yours in the RebelsTool.
It would have been far too unsafe for us to take register addresses from some guy on the internet.
Only the idea of doing this with current AMD GPUs via Linux can be credited to you.
Please study the license file, the license exists to stop what you are trying to do, use "small technicalities" to clone a project and pass it as your own. Study the license, it's important. It is not about same code, it's more complicated.
Ich danke!
Yes we talk about RDNA4, I have also offered good resources for you here: https://www.hardwareluxx.de/communi...king-und-modding-thread.1364991/post-31076777
Full register list for RDNA4 and 3, it is for this thread, hope the people here appreciate having full access to modifying their RDNA4 and RDNA3 voltage regulator parameters! It is on topic, and an offering for this community (a very big offering, it is everything about VRs).
Ok, das hat keinen wert mit dem Kolegen hier.
Das sehe ich auch so.
Wie lädt man denn bei TPU ein Bios File hoch oder geht das nur aus GPU-Z direkt?
Direkt aus der App. Das wird aber wenig gepflegt. Die landen alle im unverified und meist passiert dann nicht mehr viel, wenn ein Modell Mal nicht mehr ganz neu ist.
Boah, bei mir kommen keine Punkte mehr zusammen.
7659 hatte ich mal geschafft, jetzt gehen nur noch max 300 Punkte weniger, trotz fast identischer Einstellungen und effektiv anliegenden Taktzahlen:
Kann das wirklich nur an einem zugemüllten OS liegen?
Treiber?
Es gibt hier auch wohl immer noch leichte Unterschiede. Vielleicht nicht so wild wir früher.
Ja schaus dir an, PJVol hat da einen expliziten Regler für extra Watt rein, wie ich geschrieben hab. Damit so ein Dummy wie ich auch zurechtkommt. Ich vermute, dass es im Hintergrund ein Ampere Offset ist, aber ich weiß es nicht genauer. Ich hab von der Elektrotechnik hier am wenigsten Ahnung. Und die ursprüngliche Variante sagen manche, wäre für RDNA3 und nicht 4. Weißt was, mir is das wurscht, solange es geht. Und - falls das aufkommt - mir ists auch egal, wo es herkommt.
It works because he copied my work in that file. I have researched the RDNA4 offset register, and documented it here:
Not even RebelTool is using it because that is my work. PJVol copied my work into that XML and gave it to you, and you put it on the front page and people think PJVol came up with the offset register. He did not, I did, he just copied my work and tricked you into posting it, without giving credit to my project.
I am ok with you using that file, and keeping it there on the front page, if you also credit my project as the original work it is based on. Without my work that XML file has no extra value compared to the stock one.
I will translate this in German so I make sure you understand the details:
Es funktioniert, weil er meine Arbeit in dieser Datei kopiert hat. Ich habe das RDNA4-Offset-Register untersucht und hier dokumentiert:
Nicht einmal RebelTool verwendet es, da es sich um meine Arbeit handelt. PJVol hat meine Arbeit in diese XML-Datei kopiert und Ihnen gegeben, und Sie haben sie auf die Startseite gestellt, sodass die Leute denken, PJVol hätte das Offset-Register entwickelt. Das hat er nicht, sondern ich. Er hat lediglich meine Arbeit kopiert und Sie dazu gebracht, sie zu veröffentlichen, ohne mein Projekt als Quelle anzugeben.
Ich habe nichts dagegen, dass Sie diese Datei verwenden und sie auf der Startseite belassen, wenn Sie auch mein Projekt als das Originalwerk nennen, auf dem sie basiert. Ohne meine Arbeit hat diese XML-Datei keinen zusätzlichen Wert gegenüber der Standarddatei.
Ich werde dies ins Deutsche übersetzen, damit Sie die Details auch sicher verstehen
More exactly, he added this bit into the XML:
XML:
            <Item>
                <Name>MFR IIN Offset</Name>
                <PreExec>
                    <Command>00</Command>
                    <Data>1</Data> <!-- Page 1 -->
                </PreExec>
                <Register Type="List">
                    <Command>10</Command>
                    <Length>2</Length>
                    <Data Desc="None">0000</Data>
                    <Data Desc="+30W">F600</Data>
                    <Data Desc="+60W">EC00</Data>
                    <Data Desc="+90W">E200</Data>
                    <Data Desc="+120W">D800</Data>
                    <Data Desc="+150W">CE00</Data>
                    <Data Desc="+180W">C400</Data>
                    <Data Desc="+210W">BA00</Data>
                    <Data Desc="+240W">B000</Data>
                    <Data Desc="+270W">A600</Data>
                    <Data Desc="+300W">9C00</Data>
                    <Data Desc="+330W">9200</Data>
                    <Data Desc="+360W">8800</Data>
                </Register>
            </Item>
The important bit is:
This is the power offset register on RDNA4, I have discovered this, not PJVol. He copied this information from my research, and made the XML file, but he did not discover this, and without this information there is no extra value to the XML.
You can credit PJVol for creating the XML file, yes, but what matters is knowing which command at what address. That is based on my work, he just copied the register information from my work.
Genauer gesagt fügte er diesen Teil in die XML-Datei ein:
XML:
            <Item>
                <PreExec>
                </PreExec>
                    <Length>2</Length>
                </Register>
            </Item>
Der wichtige Teil ist:
<Data>1</Data> <!-- Seite 1 -->
Dies ist das Leistungsausgleichsregister auf RDNA4. Ich habe dies entdeckt, nicht PJVol. Er hat diese Informationen aus meiner Forschung kopiert und die XML-Datei erstellt, aber er hat dies nicht entdeckt, und ohne diese Informationen hat die XML-Datei keinen zusätzlichen Wert.
Man kann PJVol zwar die Erstellung der XML-Datei zugutehalten, aber wichtig ist, zu wissen, welcher Befehl an welcher Adresse steht. Das basiert auf meiner Arbeit, er hat lediglich die Registerinformationen aus meiner Arbeit kopiert.
This is PJVol's work:
Dies ist die Arbeit von PJVol:
Code:
But AI can also do that, it's nothing, banal, easy, anyone with minimal understanding can create it. That is not information about offset register, it's interface design option, for the list. You cannot do anything without knowing about page 1 register 10. That is what I discovered, and PJVol copied from my work into this XML file.
Aber KI kann das auch, das ist nichts Besonderes, banal, einfach, jeder mit minimalen Kenntnissen kann das erstellen. Das sind keine Informationen zum Offset-Register, sondern Optionen für das Schnittstellendesign für die Liste. Ohne Kenntnisse über Seite 1 Register 10 kann man nichts machen. Das habe ich herausgefunden, und PJVol hat es aus meiner Arbeit in diese XML-Datei kopiert.
Es ist wichtig, weil der RDNA4-Leistungsausgleich nicht PJVols Leistung ist. Er hat ihn nicht entdeckt, sondern ich. Ich habe viel Arbeit investiert, um ihn zu entdecken, nicht er. Er hat meine Entdeckung kopiert und als seine eigene Leistung präsentiert, das ist nicht in Ordnung. Es handelt sich nicht um sein geistiges Eigentum oder seine geistige Arbeit.
Ich kann dir zwar nicht für dein Auftreten gratulieren, aber für deine Forschung und Entdeckungen.
Ich verstehe, dass es manchmal schwierig sein kann, mit mir umzugehen, aber für Menschen wie mich ist das nicht immer eine Wahl, die ich habe, wie es vielleicht bei Ihnen der Fall ist.
Auch wenn Ihnen mein Verhalten nicht gefällt, ist das kein Grund, meine Ideen zu stehlen.
Schließlich habe ich meine Arbeit allen angeboten. Mein Skript, RebelTool, EVC2-Power-Offset-Datei – sie existieren, weil ich meine Arbeit öffentlich gemacht habe.
Die Leute genießen die zusätzliche Leistung von RDNA3 und RDNA4, und im Gegenzug werden meine Ideen gestohlen? Weil Ihnen meine Art zu reden nicht gefällt? Ich verstehe, dass wir vielleicht keine Freunde sind, aber das ist doch etwas anderes, als wenn Ihre Ideen gestohlen werden, oder?
