[Sammelthread] ASUS ROG Maximus VIII Series (Z170)
--- ASUS ROG Mainboards ---
Spezifikationen
ASUS Maximus VIII
Model (Abk.)Extreme (M8E)Formula (M8F)Hero (M8H)Ranger (M8R)Gene (M8G)Impact (M8I)
Bild?
PreisvergleichLinkLinkLinkLinkLinkLink
Formfaktor"E-ATX"
(305x272)
ATX
(305x244)
ATX
(305x244)
ATX
(305x244)
µATX
(244x244)
ITX
(170x170)
Erweiterungs-
steckplätze
(PCIe = 3.0)
3x PCIe x16 (16/0/0, 8/8/0, 8/4/4)
1x PCIe x16 (x4)
2x PCIe x1
3x PCIe x16 (16/0, 8/8)
1x PCIe x16 (x4)
3x PCIe x1
2x PCIe x16 (16/0, 8/8)
1x PCIe x16 (x4)
3x PCIe x1
1x PCIe x16 (x4)
3x PCIe x1
1x PCIe x4
1x PCIe x16
Storage1x M.2 (SATA & PCIe x4)
1 x U.2 (32Gbit/s)
6x SATA 6Gb/s (Z170)
2x SATA 6Gb/s ()
2x SATA Express
1 x U.2 (32Gbit/s)
1 x M.2 (SATA & PCIe)
6x SATA 6Gb/s
2x SATA 6Gb/s (ASM1061)
2 x SATA Express
2x SATA Express
1x M.2 (SATA & PCIe)
6x SATA 6Gb/s
2x SATA Express
6x SATA 6Gb/s
2x SATA Express
1x U.2 (32Gb/s)
4x SATA 6Gb/S
NetworkingIntel I219V
3×3 802.11ac Wi-Fi
Bluetooth 4.0 (BCM9436*)
Intel I219V
2x2 802.11ac Wi-Fi
Bluetooth V4.1 (Atheros)
Intel I219VIntel I219VIntel I219VIntel I219V
2×2 802.11ac Wi-Fi
Bluetooth 4.1 (Atheros)
USB (ext/int)2x USB 3.1 (2x Typ A, ASM1142)
2x USB 3.1 (Typ A+C*², Intel)
8x USB 3.0 (4+4)
6x USB 2.0 (0+6)
8x USB 3.0 (4+4)
2x USB 3.0 (ASMedia)
4x USB 2.0 (0+6)
2x USB 3.1 (Typ A+C, ASM1142)
6x USB 3.0 (2+4)
8x USB 2.0 (4+4)
6x USB 3.0 (2+4)
8x USB 2.0 (4+4)
8x USB 3.0 (6+2)
4x USB 2.0 (4+4)
2x USB 3.1 (Typ A+C, Intel)
6x USB 3.0 (4+2)
AudioSupremeFX 2015 (Realtek)
ESS ES9023P DAC
TI RC4580 OP Amp
ESS ES9023P
ESS ES9023P DAC
TI RC4580 OP Amp
ESS ES9023P DAC
TI RC4580 OP Amp
ESS ES9023P DAC
TI RC4580 OP Amp
ROG SupremeFX Impact III
ESS ES9023P DAC
TI RC4580 OP Amp
GrafikausgängeHDMI 1.4b
DisplayPort 1.2
Thunderbolt 3 (am Typ C)
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
Sonstiges1) Spannungsmesspunkte
2) Heatpipekühler
3) Multi-BIOS
4) OC Panel II
1) ROG Armor
2) Waku-Anschlüsse
3) ROG Aura RGB Lighting
1) TB-Header1) TB-Header1) Spannungsmesspunkte
2) Heatpipekühler
1) M.2 durch Wi-Fi belegt
DownloadsSupportSupportSupportSupportSupportSupport
HandbuchE10739.pdfE11081.pdfE10343.pdfE10485.pdfE10484.pdfE10809.pdf
Special Features
BIOS
Bilder (vom M8G)
Alternativ in der Galerie zum Hardwareluxx Test ab Bild 18: bios-1 » Fotostrecken
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
ASUS Memory QVL:
1) ASUS Maximus VIII Extreme - 100915.pdf
2) ASUS Maximus VIII Hero - 081815.pdf
3) ASUS Maximus VIII Ranger - 20150805.pdf
4) ASUS Maximus VIII Gene - 081815.pdf
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
4) FAQ - Frequently Asked Questions
  • --> Deine Frage hier!
  • Q: Kann man von einer Samsung SM951 AHCI M.2 SSD booten?
  • A: Ja, das ist möglich - bestätigt durch Maverickpx200 ab BIOS 0603 (im UEFI Modus).
  • Q: Gibt es einen Trick gegen sporadische Bootprobleme mit für den Speicher typischen Debug Codes wie 41/44/55?
  • A: Im UEFI die Einstellung Maximus Tweak auf Mode 1 stellen. Dadurch wird Kompatibilität mit problematischen Kits verbessert.
  • Q: Sobald ich das XMP meines Speichers aktiviere habe ich Bildaussetzer am HDMI-Ausgang. Was kann ich dagegen tun?
  • A: Bei meinem System mit M8G war die Lösung VCCIO und VCCSA für den jeweiligen Speichertakt manuell auszuloten. Die AUTO Werte waren vermutlich deutlich zu hoch.
  • Q: Wie kann ich den Startvorgang des System beschleunigen?
  • A: Wer eine UEFI Installation hat, kann mal folgendes versuchen:
    Code:
    MRC Fast Boost [Enabled] [color=red]Vorher unbedingt die Speichereinstellungen auf Stabilität testen, da das Speicherretraining damit deaktiviert wird![/Color]
    MCH Full Check [Disabled]
    PCH Storage configuration Smart self test [Disabled]
    CSM [Disabled]
    Option ROM Messages [Disabled]
    Fast Boot [Enabled]
    POST delay time [0]
    Boot Logo [AUTO] oder [Full Screen]
    Start in unter 10 Sekunden, je nach Datenträger & Peripherie eventuell auch knapp darüber.
5) M8G Wallpaper (by emissary42)
6) Sondermodelle
HARDWARELUXX News Sondermodelle: ASUS ROG Maximus VIII Hero Alpha und ROG Maximus VIII Extreme/Assembly
SondermodelleProduktfotoPreisvergleichSupportUnterschiede (zum Standardmodell)
ASUS ROG Maximus VIII Extreme AssemblyLinkDownloadsPlasma Copper Color Scheme
+ 10Gbit PCIe x4 LAN Adapter
+ SupremeFX Hi-Fi Frontpanel
- OC Panel II
ASUS ROG Maximus VIII Hero AlphaLinkDownloads+ 2x U.2 (32Gbit/s)
+ ROG Aura RGB Controller (2x LED-Header)
Press Release: ASUS Republic of Gamers Announces Maximus VIII Extreme/Assembly and Matrix GTX 980 Ti
7) Wasserkühler (Mainboard)
WORK IN PROGRESS :angel:
Hallo Zusammen,
habe vielleicht zwei nützliche Tipps.
1. Ich hatte wie viele andere auch Probleme mit der Speicherkompatibilität (unter anderem hängte mein System beim "neu starten", das System klemmte oft beim Booten im POST-Modus).
Dieses Problem muss irgendwie mit der automatischen Speichererkennung zu tun haben und lässt sich beheben indem man unter
-Extrem Tweaker Menu
-DRAM Timing Control
-Die Timings manuell einträgt.
Seither laufen auch 4x8GB Ram mit den G.Skill RipJaws V rot DIMM Kit 16GB, DDR4-3000, CL15-15-15-35 mit den ab Werk vorgegebenen Timings.
2.Eine schöne Übersicht aktueller Treiber ist hier zu finden.
Gruß Soldi
Hi Soldi,
hast du im Bios nur die Timings angepasst? Wie sieht es mit der Spannung aus, der Ram braucht ja 1,35V. Und hast du XMP aktiv?
Und hast du VCCIO und oder VCCSA verändert?
Kann grad nicht nachschauen, da ich noch "große Datensicherung" mache. Alle Werte im "Extrem Tweaker Menu" ausser Schnittstellen sind unverändert, da ich auf das nächste Bios warte.
Das scheinen mir aber eher keine so unbedarften User zu sein und das Prob wurde durch mehrere bestätigt ?
Da die ME aktualisiert wird empfiehlt es sich aber IMHO eh mit USB Flashback zu flashen - das haben die eventuell nicht gemacht.
Haste Deine Probs lösen können ?
ich konnte meine Probleme so fast lösen, habe die alte ssd 830 eingebaut und windows neu aufgesetzt.
Habe die Treiber von der CD benutzt, office, bitdefender, asus software, afterburner, winrar, samsung SSD Software, vlc, infraview usw installiert. soweit kam kein fehler ich konnte super pi zu zwar nicht starten da er ewig nach hardware scannt und wenn ich es abbreche öffnet es sich nicht aber es kam keine fehlermeldung.
Dann habe ich 2 Inteltreiber nach installiert den Rapid Storage Technology Driver und den Intel(R) Chipset Software Installation Utility, weil ich das symbol nicht in der taskleiste hatte. leider habe ich bei dem neustart auch im bios etwas an den Spannungen der CPU rumgespielt und das XMP eingeschaltet. als ich dann prime gestartet habe und um es zu testen kam wieder die werfault.exe.
ich habe davor auch noch die CPU Z version von Asus installiert.
Die Fehlermeldung kam aber erst nach dem bios rumspielen und dem Intel treiber und Cpuz installieren. Somit hat es wohl was dem den Treiber oder einem Programm zu tun. Die SSD tausche ich aber auch aus, morgen müsste die neue 850 evo von amazon kommen. Da sich die 830 doch etwas besser verhalten hat.
das neue bios werde ich erstmal nicht testen auch wenn ich mir dadurch hilfe versprochen habe, man greift ja nach jedem Strohhalm:)
Wozu das RSTD gedöns ... das würde ich mal weg lassen ... das scheint teilweise auch auf anderen Boards problematisch zu sein.
Lad einfach das Gamers OC Profile und stell den Muti 44x Sync für alle Cores - Cache auf 40x minimum und max. SVID disable - Spread Spectrum disable.
Die Vcore bissi runter - versuch mal 1.35 Manual VC (ASUS setzt 1.45VC :fresse:) und stelle die LLC auf 5.
Wenn Du weisst was die CPU für den jeweiligen Takt benötigt kannst ja auch auf OFFSET/Adaptiv umstellen.
Hier gibts auch einen Skylake OC Guide der auf ROG Boards "zugeschnitten" ist.
ASUS Maximus VIII Hero [CPU OC Guide] Overclocking.Guide 6600K 6700K Skylake Z170 (c) derBauer
Eventuell auch noch Interessant - weil auch auf einem Hero durchgeführt:
Skylake – Overclocking – Power Consumption and Voltage Scaling | Overclocking.Guide
Abkürzung für rapid storage technology driver ... das Intel Geraffel halt ;)
Wenn Du eine dedizierte Grafikkarte hast würde ich auch noch die iGPU deaktivieren.
Ok ich dachte die IGPU ist automatisch deaktiviert wenn ich eine GPU einbaue.
ich brauche also nur den Chipsatztreiber, LAN, Soundtreiber und die USB treiber den Rest lasse ich weg, richtig?
Das Intel zeug werde ich mal runterhauen.
Asus gibt wirklich viel vcore auf die CPU, wie ich das so sehe ist meine CPU aber auch etwa gierig nach spannung:)
Vielen Dank für deine Geduld und Hilfe.
Jo eben nur das nötigste ... was nicht benötigt wird auf disable.
Wenn Du keine SATA Devices an den Asmedia Anschlüssen hast kannst den auch im UEFI deaktivieren.
Jedes ROM das nicht geladen werden muss beschleunigt den Startvorgang.;)
Und das TurboV Core drauf um im OS Spannungen/Nebenspannungen anpassen und damit testen zu können.
Und fürs Monitoring der Temps etc. eignet sich HWInfo sehr gut.
HWiNFO, HWiNFO32/64 - Download
Ich nehme immer die neuste Beta Portable Version davon.
So mache ich das auch. Der große Vorteil gegenüber anderen Programmen ist, dass es ein relativ kompaktes Programm ist, dessen Ausgabe sich fast komplett den eigenen Bedürfnissen entsprechend anpassen lässt.
Naja ich habe sie zwar drauf aber nicht im Autostart ... an sich ist die Software ja ganz brauchbar.
Allerdings scheint die noch nicht perfekt auf Z170 Express angepasst zu sein.
Bekomme unter Win 8.1 ja Floating Point Errors beim Starten - was eben nicht so vertrauenserweckend ist und eher suboptimal bei OC Tests.
Ich würds einfach mal weg lassen um eine weitere mögliche Ursache für Deine Probs ausschließen zu können.
soll ich um das Intel zeug zu entsorgen einen driver cleaner nutzen oder reicht es wenn ich es über windows lösche?
werde ich mal so testen, hoffe mal dass es das dann war:)
Habt ihr das neue Bios am laufen?
Nope ... ich lass erst mal das 0902 drauf ... habe ja keine Probs damit.
Zum Impact VIII gibts auch Infos und Fotos / UEFI Screenshots.
http://nl.hardware.info/productinfo/324506/asus-maximus-viii-impact/fotos
SKU: 90MB0NS0-M0EAY0
Zu haben dann ab 230€ aufwärts und ETA in UK 20.10.2015. ;)
Habe bisher rmit manueller Vcore getestet ... aber mit OFFSET läuft die CPU mit weniger VC Prime95 stable.
Hatte mich schon gewundert warum ich mit VID 1.2 bei 4.4 GHZ leicht über 1.3 VC gehen muss.
News zum Impact ist in Arbeit, danke für den Hinweis :wink:
Freut mich wenn Du es verwerten kannst ... vielleicht magst ja noch die Links aus Post #102 in den OP aufnehmen ? :d
Von manueller VC komme ich entgegen meiner Gewohnheiten bei früheren ROG Boards aber eben ab.
Mit Offset läuft es definitiv mit weniger VC.
[...] Da die ME aktualisiert wird empfiehlt es sich aber IMHO eh mit USB Flashback zu flashen - das haben die eventuell nicht gemacht. [...]
Wo hast denn die Info her? Habe bisher immer alles mit USB-Stick im Bios geflasht, auch wenn da ME-Updates mit dabei waren. Bisher hat es geklappt...
Den RST Treiber habe ich aber auch installiert, das ist doch der Treiber für AHCI. Allerdings habe ich nur den Treiber installiert ohne Utility!
War das jetzt falsch?
Ich kann da auf andere Erfahrungen zurückschauen ... beim Z97 Gene Update mit ME Firmware und Microcode Patch mit EZ Flash/UEFI Flash > Fail.
Flashback ist halt die von mir bevorzugte Methode - kann ja jeder halten wie er mag. :)
@Emi
Das Impact ist übrigens auch schon bei wenigen Deutschen Händlern gelistet.
z.B.
http://odenwaldpc-shop.com/shop/details.php?art=181469&artname=MB+ASUS+MAXIMUS+VIII+IMPACT
