[Sammelthread] Asus Sabertooth 990fx
Inhalt:
  • Spezifikationen
  • Bilder
  • Bios
  • Review´s / Test´s
  • Downloads
  • Kompatibilität
  • Preis
  • FAQ
Spezifikationen:
CPU
AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
Supports AM3+ 32 nm CPU
Supports CPU up to 8 cores
Supports CPU up to 140 W
AMD Cool 'n' Quiet™ Technology​
Chipset
AMD 990FX/SB950​
AMD 990FX/SB950
Memory
4 x DIMM, Max. 32GB, DDR3 1866/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture​
Expansion Slots
3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8) *1
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI​
Storage
AMD SB950 controller :
6 x SATA 6Gb/s port(s), brown
Support Raid 0, 1, 5, 10
JMicron® JMB362 controller :
2 x SATA 3Gb/s port(s), black
1 x Power eSATA 3Gb/s port(s), green
1 x eSATA 3Gb/s port(s), red​
LAN
Realtek® 8111E , 1 x Gigabit LAN Controller(s)​
Audio
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- Blu-ray audio layer Content Protection
- ASUS Noise Filter
- Optical S/PDIF out port(s) at back panel
IEEE 1394
VIA® 6308P controller
2 x IEEE 1394a port(s)
(1 at mid-board, 1 at back panel)​
USB Ports
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
14 x USB 2.0 port(s) (10 at back panel, black+red, 4 at mid-board)​
Special Features
ASUS Dual Intelligent Processors 2 with DIGI+ VRM
TUF ENGINE! Power Design :
- 8 +2 Digital Phase Power Design
- TUF Components (Alloy choke, Cap. & MOSFET; certified by military-standard)
- ASUS DIGI+ VRM Utility
- E.S.P. : Efficient Switching Power Design
Ultimate COOL! Thermal Solution :
- TUF CeraM!X Heatsink Coating Tech.
- TUF Thermal Radar​
ASUS Exclusive Features
- MemOK!
- AI Suite II
- Anti-Surge
- ESD Guards
- Front Panel USB 3.0 Support
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector​
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
1 x LAN (RJ45) port(s)
2 x USB 3.0
10 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)​
Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x COM port(s) connector(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
4 x Chassis Fan connector(s) (3 x 4 -pin, 1 x 3 -pin)
1 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x Clear CMOS jumper(s)​
Accessories
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x TUF Certification card(s)
1 x TUF 5 Year Warranty manual(s) (by region)​
BIOS
32 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2,​
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities​
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )​
Bilder:
Bilder von Huddel (nochmals danke)
Bilder von JACK RABBITz
(Quelle: User Huddel, Asus, JACK RABBITz)
Bios:
(0402)
Review´s/Test´s
Deutsch
HWLUXX
hartware.net
pcgameshardware
Tom´s Hardware
Englisch
guru3d.com
hardwarecanucks.com
legitreviews.com
Downloads
ASUS Sabertooth Downloadbereich
Asus FTP-Server derzeit wieder mal offline :-(
Betabios 0607 -Fan ignore Bug gefixed, CPU-Lüfter Monitor lies sich nicht abschalten, dadurch kam eine Fehlermeldung beim Booten
Bios 0705
1. Enhance RAID expansion card compatibility.
2. Enable support for Spanish and Russian Language.
3. Enhance RAID0 performance with SB950 native SATA ports.
4. Enable support for UEFI RAID Driver to support RAID partition above 2.2TB
Bios 0810
Bios 0813
1. Improve memory compatibility
2. Improve system stability
Bios 0901
Probleme mit X6 CPU´s, Board startet nicht mehr!
Bios 1102
1.Improve system stability.
2.Enhance compatibility with some USB devices.
3.Patch system hanged when use AM3 1090T or 1100T CPU.
Bios 1208
Bios 1304
Bios 1503
Kompatibilität
Arbeitsspeicher
-Kingston HyperX 2133Mhz 4x 2GB
-G.Skill Ripjaws-X 8GB Kit
-G.SKILL 8GB Kit DDR3-1600 F3-12800CL8D-8GBECO / 1,35V
inkompatibler Arbeitsspeicher
-2x2GB G.Skill F3-10666CL8D-4GBRM 8-8-8-24 1,5v (kein Boot möglich)
Luftkühlung
-Prolimatech Megahalems (mit Retentionmodul)
Wasserkühlung für Chipsatz
Preis
HWLUXX
FAQ
Asus Supportforum
Ich hoffe das geht erstmal soweit (Ist mein erster Sammelthread :)), ich versuche alles aktuell zu halten, nun her mit den Erfahrungen und Informationen...
ja, so langsam..., mal schauen was noch so für Bretter auf den Markt kommen
Kann man mit diesem Board den Speicher genauso gut übertakten, wie mit dem Crosshair V ?
da ich das Crosshair V nicht kenne, kann ich keinen direkten Vergleich machen, aber mit 1872Mhz laufen meine Speicher mit XMP Einstellungen und FSB bei 234Mhz.
Danke für den Sammelthread. Er wurde bereits mit in die Liste aufgenommen.:)
ja, danke...
Schwanke zwischen dem Sabertooth 990FX und dem Crosshair V. Da ich kein großer Übertakter bin denke ich, dass das Sabertooth besser für meine Zwecke ist, oder was meint ihr ?
Benötige ein neues Board, da mein altes AsRock abgeraucht ist. Habe zur Zeit einen AMD Phenom II 965 am laufen und will demnächst auf den Bulldozer umsteigen.
Wichtig bei einem Board ist mir, dass es stabil läuft und lange hält.
also das Sabertooth läuft zumindest bei mir sehr stabil, auch im OC.
Mir stellt sich die Frage, wenn du kein OC betreiben willst, vieleicht ein SLI aufbauen möchtest, was du mit dem Board willst.
Ich denke, da gibt es auch andere, welche Preiswerter sind (z.B. das deluxe5 von AR)
Aber wenn es eins von beiden sein soll, würde ich das Preiswertere nehmen, denke mal, beide sind gleich potent.
Wobei das Crosshair V
2x USB3.0 - Anschlüsse (Pfostenstecker auf Board) mehr hat (also 2 + 4 = 6)! :bigok:
Das Sabertooth insgesamt NUR 2 + 2 = 4 :)
oki doki
fuzzy
ja, aber bis jetzt habe ich das 3.0er USB noch nicht benötigt, zumal ich eh erstmal schauen muß, was man da am besten für einen Adapter benutzt, weil mitgeliefert wird da leider nichts.
ah,
danke, habe mir mal das 2x 3.0 USB geordert, das sieht so ähnlich aus, wie das was man zum Asrock Deluxe4/5 dazu bekommt.
Das ist haargenau das gleiche wie von ASR, nur ohne Gigabreit Aufdruck. ;)
Ich hab das damals einfach mit eingebaut, benutzt aber noch nie. Ist halt nur da weils dabei war.
@ KeBeNe: Nur mal so interessenhalber. Wie spannungsstabil läuft das "Sabber" mit der CPU-Voltage idle/last und wie verhält sich das mit der unter Bios eingestellten vCore zu jener die dann unter OS mit zb. CPU-Z oder den Asus Tool(s) ausgelesen wird? Hast du das schonmal überprüft?
ah,
Das habe ich auch da man bei dem anderen ein Kabel tot-legen müsste da der Anschluss beim Sabertooth fehlt entgegen den Anschlüssen beim Crosshair V, da kann man alle nutzen. :)
Gruß, fuzzy
soweit ich Prüfen kann/konnte stimmt die Spannung zwischen Bios und Programmen.
Die Stabilität ist ist sehr gut, bei abgeschalteten LLC liegt die Schwankung im 0,00X Bereich.
Kein vergleich mit dem UD5 von GB, was vorher kurz hier werkelte.
Also, im Vergleich zum Deluxe5 ist es recht gut, beide sind auf einer Höhe und gleich performant.
mfg René
Naja, mit den vCore_Gehopse des GB hab ich auch schon mit den 990FX-UD3 meine Erfahrungen gemacht. :fresse:
Gruß, fuzzy
Hallo, ich kann nicht erkennen, dass das Crosshair V auf dem Board mehr Anschlüsse (Stecker) für USB 3.0 Anschlüsse hat wie das Sabertooth.
Wie kann man beim Crosshair V im Gegensatz zum Sabertooth alle vier USB 3.0 Anschlüsse nutzen ?
Meiner Meinung nach liegt da dann ein Kabel genau so tot wie beim Sabertooth und man kann auch nur 2 der 4 Anschlüsse nutzen.
@Psychodad1707
Du hast Recht, ich habe es mit dem Gigabyte verwechselt.
Das CH V hat zwar 6 x USB3.0, aber eben auch nur 2x auf dem Board und 4x am I/O back panel.
Sry @ all.
grEEtz
fuzzy
So habe nun sowohl das Crosshair V als auch das Sabertooth zu Hause. Muss sagen das Crosshair V sieht schon super aus. Das Sabertooth wirkt dagegen schon etwas schlicht. Aber darum gehts ja nicht. Stehe nun vor der Entscheidung welches ich behalten soll. Bin eigentlich kein großer Overclocker und tendiere daher eher zum Sabertooth. Hat halt auch 5 Jahre Garantie. Das Crosshair V wiederum hat den besseren Sound onboard und 4 USB 3.0 Ports plus 2 intern. Was soll ich nur machen ? Will am Wochende mit dem Einbau beginnen. Mensch was mach ich nur. Bin hin und her gerissen. Helft mir!
das ist eine schwierige Frage, ich kenn deine Gewohnheiten nicht, welche externen Geräte usw. benutzt werden, bzw. geplant sind (wegen USB 3.0).
Von der Performance her, werden sich beide nicht viel bis nichts nehmen.
Aber ich habe mal eine Frage an die Sabertooth-Nutzer hier.
Da ich meine CPU wasserkühle, habe ich keinen Lüfter an den CPU FAN/Opt Anschlüssen.
Im Bios sind alle Monitoringfunktionen auf "Ignore", aber es kommt trotzdem die "CPU FAN ERROR" Meldung.
Ich habe auch schon alles was mit Lüftern zu tun hat auf Ignore bzw. disabled ohne Erfolg.
Kann das Verhalten noch jemand bestätigen?
Das gleiche Problem hatte ich bei meinem Crosshair V Formula, dort wurde es mit dem ersten Bios-Update (Version 0506) gefixt. Gibt es für das Sabertooth eventuell auch schon ein Update? Falls nicht, eventuell mal an den Support werden, ich nutze im Moment auf dem Crosshair V auch ein noch unreleastes Bios (0602) vom Support aufgrund einer anderen Problematik.
Gruß,
Chelli
Hallo Chelli,
habe den Support mal angeschrieben im Supportforum gibt es auch Hinweise zu einem Beta Bios 0501, wo es gefixt sein soll.
Was gab es bei deinem Board noch für Probleme?
Hallo Chelli,
Das Problem bei meinem Crosshair V ist, das die Tastatur in Bootloadern wie Grub2 oder auch im Windows-Bootloader (Auswahl abgesicherter Modus und co.) nicht funktioniert - im Bios und im gebooteten Betriebssystem gibt es keine Probleme.
Mit dem genannten Beta-Bios 0602 ist das ganze zumindest für PS/2-Tastaturen gefixt, so das ich endlich direkt beim Starten wählen kann, ob ich Linux oder Windows starten möchte.
Mit (meinen beiden) USB-Tastaturen klappt es allerdings auch mit dem Beta-Bios noch nicht.
Ansonsten habe ich bisher noch keinerlei Probleme mit dem Board gehabt.
ja, nagut, sowas habe ich noch nicht probiert.
Zum eigentlichen Problem, der Asus Support hat auch geantwortet.
Es gibt ein neues Bios oder Betabios(0607), damit soll das Lüfterproblem behoben worden sein, ich kann es aber erst heute Abend oder morgen testen.
Ich habe das Bios mal oben unter Downloads eingefügt.
Habe noch mal eine Frage zu dem Gigabyte USB 3.0 Frontpanel-Adapter (gibts übrigens auch von Coolermaster Cooler Master USB 3.0 Adapter (RA-USB-3035-IN) | Geizhals.at Deutschland ).
Im Handbuch vom Sabertooth steht auf Seite 2-23 USB 3.0-Anschluss (20-1 pol. USB3_34) für den Anschluss einer USB 3.0 Fronttafel beim Crosshair V steht auf Seite 2-21 USB 3.0 Anschluss (18-1 pol. USB3_56) für den Anschluss eines 3.0 Moduls an einer Steckplatzaussparung an der Rückseite des Computergehäuses.
Meine Frage ist nun, ob der Frontpanel Adapter von Gigabyte bzw. Coolermaster auch für das Crosshair V geeignet ist da der Anschluss beim Sabertooth im Handbuch mit 20-1 Polig USB 3.0_34 bezeichnet ist und beim Crosshair V mit 18-1 Polig USB 3.0_56.
Ich habe den von Coolermaster, ich hoffe der paßt auf beide Boards. Ich weis nur nicht warum der Anschluss auf den beiden Boards nicht der gleiche ist bzw. die gleiche Bezeichnung hat.
So,
habe mal das 0607 Bios aufgespielt, jetzt kann man die Lüfter endlich auf "Ignore" setzen und es funktioniert wie es soll.
ZU den USB 3.0 Anschlüssen, gibt es von dem Asus irgendwo ein Bild?
