[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
huhu,
ich bräuchte dringend eine netzteil empfehlung für dieses board, da mir meins letzte nacht beim primen zerbröselt ist...(OCU 520 W Modstream
meine sonstige konfig ist:
dvd brenner, zwei s-ata 1 festplatten, ein asus crosshair formula 4, ein x6 1090t auf 4,1 ghz bei 1,45v, 4gb ram bei 1,65 vdimm und eine unübertaktete 8800gt
dazu sollen noch ein paar gehäuselüfter kommen...
es sollte schwarz bzw schwarz rot sein und meinetwegen einen rot beleuchteten led-lüfter haben und natürlich solide und nicht überteuert.
möglicherweise heute auch noch in filialen bei kmelektronik oder arlt in stuttgart zu kaufen sein :-)
wer kann mir einen tip geben ?
danke im voraus !
gruß
H.
Also ich hab nen Enermax Pro 82+ 425W und der durfte für deine Config auch reichen.
Ok hat kein Beleuchteten Lüfter aber brauchst das wirklich?
Bald ist Weihnachten ha? :fresse2:
Ich nutze ein Corsair HX520 und auch das reicht aus. Ein Bekannter hat so eine ähnliche Config mit einem Liberty 400 Watt betrieben.
ich nutze das corsair hx 1000 ,ich weiss das ich die leistung im moment nicht brauche ,das stammt aus einer zeit als mein sys beim zocken 752W gebraucht hat
sodele,
es ist das Enermax Pro 82+ 525W geworden und es lag tatsächlich daran, dass ich mein altes ocz modstream 520 w durchgefeuert habe...
100 eu sind zwar happig, aber wenn ich wieder 4-5 jahre ruhe habe, bin ich zufrieden...
Bequite Dark Power p7 850. kann aber auch weniger sein wenn du bei der karte bleibst.
---------- Beitrag hinzugefügt um 11:57 ---------- Vorheriger Beitrag war um 11:54 ----------
So ich frag noch einmal wo habt ihr S.M.A.R.T im Bios gefunden bzw Aktiviert?
hab ich auch grad gelesen und hab gleichma umgestellt. guter leistungssprung laut atto
Wie hast du das umgestellt?
Wo habt ihr die Datei her bzw inf Treiber?
Bei mir ist folgendes unter dem Geräte Manager
Danke habs nun auch gefunden. versuch nur das zu installieren. anscheind ist er drauf. wie kann ich das nachvollziehen, das er drauf ist?
Cool...
Das klingt doch schon mal gut :)
@ Smokey Skull und alle Crucial Besitzer wie zufrieden bist du/Ihr mit der Crucial ?
Weiss einer wann der AMD Phenom 1100 kommt?
LG
Agony
naja, ich hab ja keine crucial sondern 2 supertalent, bin aber mit denen auch sehr zufrieden. die nächste steigerung wird dann keine sata3 ssd sein sondern eher so ein pcie dingens, brauch meine sata anschlüsse für hdd's ;)
lol,was die leute immer viele festplatten brauchen ,ich habe in mein rechner 1x128gb und das wars und da sind 2 spiele die ich im moment zocke drauf und noch 60gb frei
hast also keine filme, musik, spiele images, bilder, private daten....?
klar habe 150gb musik auf einer externen ,klar habe ich filme aber sobald ich sie geguckt habe dann werden sie gelöscht,mmh und spiele image habe ich schon lange nicht mehr ,weil nach der installation laufen sie eh ohne cd ,spiele kaufe ich auch immer weil ich nur online spiele
huhu,
ich habe noch die bios version 0905 drauf und würde gerne auf eine der beiden neueren bzw neueste updaten, oder spricht da irgendwas dagegen bzw, hat jemand danach mehr probleme gehabt als vorher ?
ich nutze den onboardsound und würde gerne meine monitorlautsprecher mit dem hinteren anschluss verbinden und möglicherweise kopfhörer schnell mal in die front-buchse meines gehäuses. letzteres funktioniert, ersteres nicht.
woran könnte das liegen ? geht das nciht beides gleichzeitig ? wann stellt man im bios ac97 bzw hd ein ?
e-sata geht ja nur hinten raus, oder gibts onboard noch mal einen connector um meine e-sata buchse mit meinem front e-sata des gehäuses zu verbinden ?
was ist der unterschied zwischen den drei usb onboard steckplätzen die im handbuch usb7 , usb89, usb101`1 oder so, heissen ? die sehen ja unterschiedlich aus. die beigefügte klammer, könnte man anschliessen und sie auch nach hinten raus gehen zu lassen, oder aber mein front-usb anschluss am gehäuse, oder ?
dank im voraus.
gruß
H.
