Maximus III Extreme "Republic of Gamers"
Specifications
CPU Intel® Socket 1156 Core™ i7 Processor/Core™ i5 Processor/Core™ i3 Processor
Supports Intel® Turbo Boost Technology
* Refer to ASUSTeK Computer for Intel CPU support list
Chipset Intel® P55 Express Chipset
Memory 4 x DIMM, Max. 16 GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Supports Intel® Extreme Memory Profile (XMP)
* Please refer to ASUSTeK Computer or user manual for the Memory QVL(Qualified Vendors List).
Expansion Slots 5 x PCIe 2.0 x16 Supports single at x16, dual at x16, triple at x 16 x16 x8, quad x8, or 5 x8
1 x PCI 2.2
Multi-GPU Support Supports NVIDIA® SLI™ Technology / ATI® CrossFireX™ Technology
Storage Intel® P55 Express Chipset built-in
6 xSATA 3.0 Gb/s ports (Gray)
Intel Matrix Storage Technology Support RAID 0,1,5,10
JMicron® 363 controllers:
- 1 x SATA 3.0 Gb/s port (Black)
- 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Marvell® PCIe SATA 6Gb/s controller
- 2 x SATA 6.0 Gb/s ports (Red)
LAN Realtek® RTL8112L Gigabit LAN controller
Audio VIA® VT2020 10-Channel High Definition Audio CODEC
- Supports Blu-ray audio layer content protection
- Supports 1 Optical S/PDIF out port at back I/O
- Supports 1 S/PDIF out header
- Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
IEEE 1394 2 x 1394a port(s) (1 port onboard, 1 port at back I/O)
USB NEC® USB 3.0 controller
- 2 x USB 3.0/2.0 ports (at back I/O)
- 11 USB 2.0 ports (4 ports at mid-board, 7 ports at back I/O, 1 port at back I/O is also for ROG connect)
Overclocking Features ROG Connect
RC Bluetooth
Extreme Engine Digi+
- 8-phase CPU digital VRM power
- 3-phase VTT digital VRM power
- 3-phase Memory power
- ML Cap for CPU
ProbeIt
iROG
Extreme Tweaker
BIOS Flashback
Loadline Calibration
Intelligent overclocking tools:
- 8 O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features CPU Level Up
MemOK!
Onboard Button: Power / Reset / Clr CMOS (at back IO)
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Back Panel I/O Ports 1 x External SATA
1 x IEEE 1394a
1 x LAN(RJ45) port
10 -Channel Audio I/O
1 x Clr CMOS switch
1 x PS/2 Keyboard port (purple)
7 x USB 2.0 ports (1 port also for ROG Connect)
1 x ROG Connect On/Off switch
S/PDIF Out (Optical)
Internal I/O Connectors 2 x USB connectors support additional 4 USB 2.0 ports
9 x SATA connectors: 2 x SATA 6.0Gb/s connectors (Red) / 6 x standard SATA connectors (Black) / 1 x SATA_E(Gray)
8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
5 x ProbeIt Measurement Points
3 x Thermal Sensor Connectors
1 x IEEE1394a Connector
1 x SPDIF_Out Connector
1 x 24-pin ATX Power Connector
1 x 8-pin ATX 12V Power Connector
1 x En/Dis-able Clr CMOS Switch
1 x LN2 Mode Header
1 x Power on Switch
1 x Reset Switch
2 x EZ Plug Connectors
1 x OC Station Header
1 x RC Bluetooth Header
1 x Go Button
1 x BIOS Button
System Panel Connector
BIOS 16 Mb Flash ROM AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WOL by PME,WOR by PME,PXE
Accessories 1 x RC Bluetooth Card
1 x I/O Shield
1 x Optional Fan
1 x ROG Connect Cable
1 x SLI Cable
1 x 3-way SLI Cable
1 x 2-in-1 ASUS Q-Connector Kit
1 x 2-in-1 SATA 6.0Gb/s Cables
3 x 2-in-1 SATA 3.0Gb/s Signal Cables
1 x 2-port USB2.0 + ESATA Module
1 x Thermal Sensor Cables Pack
1 x Cable Ties Pack
1 x ROG Theme Label
1 x 12-in-1 ROG Cable Label
1 x User's Manual
Bluetooth Module Accessory Card
- Bluetooth V2.0/V2.1+EDR
- RC Bluetooth On/Off Switch
Support Disc ASUS PC Probe II
ASUS AI Suite
ASUS Update
Kaspersky® Anti-Virus
Support DVD:
- Drivers and Applications
Futuremark® 3DMark® Vantage Advanced Edition
ASUS TurboV EVO Utility
Form Factor ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Reviews
http://www.guru3d.com/article/asus-maximus-iii-extreme-review/
http://www.tweaktown.com/reviews/3193/asus_maximus_iii_extreme_p55_express_motherboard/index.html
http://www.bjorn3d.com/read.php?cID=1807
http://www.pureoverclock.com/review.php?id=942&page=1
OVP+Zubehör
Geizhals Link
ASUS Maximus III Extreme, P55 (dual PC3-10667U DDR3) (90-MIBBX0-G0EAY00Z) Preisvergleich bei Geizhals.at Deutschland
Treiber&Tools
ASUSTeK Computer Inc.-Support-
Bios Screenshots
Bios Downloadlink
ftp://ftp.asus.com.tw/pub/ASUS/mb/LGA1156/Maximus_III_Extreme/
Bios History
[ 0901 ]
1. Added additional memory settings for improved performance.
2. Enhanced overclocking.
3. Enhanced K series CPU support
[ 0805 ]
1.Fix system might hang when using Clarkdale i5 655 CPU and DIMM with 1600Mhz default SPD.
2.Fix BIOS setup might show incorrect Target DRAM Frequency when using DIMM with 1600Mhz default SPD.
[ 0705 ]
1. Improve memory compatibility
2. Improve system stability
3. Fix 2.2T HDD size is wrong if Quick Boot option is disabled
4. Improve compatibility with some USB3.0 devices
5. Support new CPUs. Please refer to our website at: ASUSTeK Computer Inc.-Support-
[ 0606 ]
3. Fix system will stay at POST screen too long when iPod 80GB is connected
4. Fix DEL and F8 keys doesn't work with Microsoft Reclusa Keyboard
5. Fix tRRD option can't be set to values lower than 4
[ 0503 ]
Fix TurboV and PC probeII may get incorrect value.
[ 0402 ]
[ 0309 ]
First Release Bios
CPU Support Liste
Core i3 530(2.93G,L2:4M, IGPU,rev.C2,73W) ALL 0218
Refer to below URL for more info: http://support.asus.com/faq
Core i3 540(3.06G,L2:4M,IGPU, rev.C2,73W) ALL 0218
Core i3 550(3.2G,L2:4M, IGPU,rev.K0) ALL 0705
Core i5 650(3.2G,L2:4M, IGPU,rev.C2,73W) ALL 0218
Core i5 655K(3.2G,L2:4M, IGPU,rev.K0,73W) ALL 0705
Core i5 660(3.33G,L2:4M, IGPU,rev.C2,73W) ALL 0218
Core i5 661(3.33G,L2:4M,IGPU, rev.C2,87W) ALL 0218
Core i5 670(3.46G,L2:4M, IGPU,rev.C2,73W) ALL 0218
Core i5 680(3.6G,L2:4M, IGPU,rev.K0,73W) ALL 0705
Core i5 750(2.66G,L3:8M, rev.B1,95W) ALL 0218
Core i5 750S(2.4G,L3:8M, rev.B1,82W) ALL 0218
Core i7 860(2.80G,L3:8M, rev.B1,95W) ALL 0218
Core i7 860S(2.53G,L3:8M, rev.B1,82W) ALL 0218
Core i7 870(2.93G,L3:8M, rev.B1,95W) ALL 0218
Core i7 875K(2.93G,L3:8M, rev.B1,) ALL 0705
Core i7 880(3.06G,L3:8M, rev.B1) ALL 0705
Pentium G6950(2.8G,L2:4M, IGPU,rev.C2,73W) ALL 0218
man sollt einfach mal genauer gucken... hmm also wird der megahalem mit Noisblocker Lüfter und den G.Skill PIs wohl nicht passen oder? Dann vielleich der Armageddon?
ich verstehs ja selber nicht!... ^^ hat ehct keiner einen Plan ?! Kann mir nich der Threadstarter oder so ma helfen... ihr habt doch das board auch ?!... need help & knowledge ^^
