[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
von BeQuiet gibt es auch 2 solcher Kabel, aber eben nur reversed
Bei mir stand das vor kurzem nur zur Debatte, da die originalen Adapter ganz schön an den Kabeln gezogen haben und da hab ich sie eben durch originale von BeQuiet getauscht. Da ich allerdings ASUS Karten habe, konnte ich das reversed nicht verwenden und musste weiterhin auf dem alten Standard bleiben
Und wenn ich dann die 5090 kaufe brauche ich das Kabel eh und es ist ausverkauft, weil das ganze Luxx eins bestellt hat 😅 Kenn den Scheiß doch.
Läuft seit nun fast 2 Jahren bei mir mit der ollen Krake ohne Probleme, das 90 Grad Kabel liegt seit langer Zeit daneben und wird nun erst mit der 5090 Verwendung finden:
Hatte mir schon überlegt statt der Temperatur folgendes Bild anzeigen zu lassen, hat was:
Ist es irgendwie möglich einen Hdmi Ausgang der Gpu als Soundausgang zu nutzen für eine Soundbar?
Machen das nicht alle mit einem AVR so?
Bild Dublizieren. Dann wird auch der Ton mitgeschickt.
Fragt sich halt nur, ob das auch funktioniert wenn Du 480hz anzuliegen hast (ich hab keine eigenen Erfahrungen in der Sache).
Ja, geht problemlos.
Ich meinte ohne irgendetwas dazwischen.
Hatte es probiert aber windows erkennt da nix wenn ich die Soundbar anschließe an den Hdmi.
Wäre da ein Wireview nicht inzwischen preiswerter gewesen?
Im Nachhinein ist man immer schlauer. Ich hab dummerweise bei Cablemod gekauft, die Austausch Frechheit wo man jedesmal bei den diversen Rückrufen noch die utopischen Versandkosten selber zahlen durfte ist hier ja bekannt. An nem Wireview hab ich aber eigentlich auch kein Interesse, ich will einfach nur ein Kabel mit 90° Anschluss das funktioniert und nicht abbrennt :fresse:
Thermal Grizzly warnt davor, dass der WireView Pro GPU im Betrieb sehr warm werden kann. Bei einer luftgekühlten Grafikkarten kühlt der Luftstrom der Lüfter auch den WireView Pro GPU. Dennoch kann dieser bis zu 60 °C warm werden. Bei einer wassergekühlten Karte spricht der Hersteller sogar von bis zu 100 °C. Auf welche Grenzwerte der WireView Pro GPU hinsichtlich der Warnung vor zu hoher Temperatur und Stromstärke eingestellt ist, ist nicht bekannt.
:unsure: :oops::rolleyes2:
Das "neue Treiber-Archiv" ist eine einzige Katastrophe... :rolleyes2:
Bis man mal dort ist, wo mal hin will, muss man x-mal klicken. Die angelegten Favoriten, der alten Ansicht funktionieren leider nicht mehr
Wieder so ein "neuer = schlechter"... :cautious:
Treiber Archiv? Wozu wird das genau benötigt?
RTX HDR soll jetzt auch im Multi Monitor Setup funktionieren mit dem neuen Nvidia App Update. Nett
Hm, ok, klingt übel.
Ich nutze einfach immer Deskmodder, die sind die ersten die einen neuen Treiber melden. CB und Luxx zb sind da immer recht spät, manchmal kommt auch gar keine Meldung…
Und dann paar Klicks: bäm. Bringt mich jetzt nicht um. 😏
Wäre auch eine Alternative - die Treiber schön gelistet mit Releasedate, ohne Schnick-Schnack und ohne Mega-Platzverschwendung (bei NV)
Vom alten Layout hab ich grad keinen Shot da, aber mal muss die Seite stark verkleinern, um "bissl Content" auf die Seite zu bekommen :rolleyes2:
Habe mir tatsächlich noch nie Gedanken darum gemacht, werde auch damit nicht anfangen.
Aber you do you 🤘
Das war’s wohl mit der 4090:
Dann werden bestimmt auch die Gebrauchtkartenpreise anziehen. Aber ich glaube nicht, dass ich mich von meiner 4090 schon vor Release der 5090 trennen werde. Bin eigentlich ganz happy mit meiner Karte. Und solange ich noch keine endgültigen Specs von Blackwell kenne, solange werde ich definitiv an meiner RTX 4090 festhalten.
Dito, wird erst nach dem Release der 5090 verkauft, auch wenn es dann weniger gibt als aktuell.
Aber jetzt monatelang ohne die 4090 leben, freiwillig? Hell no! :devilish::asthanos:
die 4090 wird preisstabil bleiben wenn die 5090 2,6k kostet und die 5080 ein Äquivalent zur 4070 ist :d
mmh dann sollte man sich jetzt noch einmal eine 4090 sichern :)
