- Ort
- Hannover
- AMD Ryzen 9 7950X3D
- ASUS ROG Strix B650E-F Gaming WIFI
- Custom Wasserkühlung
- 32GB CORSAIR DOMINATOR PLATINUM 6000Mhz CL28-36-36-36-36
- Palit GeForce RTX 4080 GameRock
- Xiaomi G Pro 27i & HP X34
- WD_BLACK SN 850 1TB & Kingston KC3000 1TB
- Fractal Design TG Light Tint RGB
- Thermaltake Toughpower GF1 750W
- Keyboard
- ROG Strix Flare II Animate
- Mouse
- RAZER BASILISK V3 PRO + Razer Mouse Dock Pro
- Windows 11
- Sonstiges
- iPhone 17 Pro Max
- Internet
- ▼1082 ▲54
The issue is, if you use ASM1166/ASM1164 on an M2 extension card you are not able to get into lower Cstates.
You have to use it as PCIe Card to get powersaving working with this.
8 watts - No SATA controller - C8 power state
9 watts - ASM1166 on an x4 slot connected to the chipset - C8 power state
12 watts - JMB585 on the x16 slot connected to the CPU - power state C3
15 watts - JMB585 on an x4 slot connected to the chipset - power state C3
22 watts - ASM1166 on the CPU-connected x16 slot - power state C2
The ASM1166 performs well here when plugged into a chipset-connected slot (only +1 watt), but it performs horribly when plugged into the main PCI-E slot (+14 watts) where the CPU package power state drops to C2. Shockingly, the JMB585 behaves the other way round, its consumption is lower on the slot connected to the CPU (and it doesn't cause C2)
