[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja, eigentlich ist die 4090 weit über meinem Budget und bisher hatte ich nur max x080 Karten, und trotzdem bin ich irre genug mir die 4090 diese Woche jetzt zu bestellen, sobald ich das letzte Geld zusammen habe... nach fast nem 3/4 Jahr hart sparen (glaub besser kann man nicht zeigen wie sehr über meinem Budget die Karte wirklich ist XD). Gut, zuerst war auch nur die 4080 geplant, aber dann wurde ich gierig nach VRAM dank KI. :d
Ist nichts falsches daran, auch mal auf Sachen zu sparen. Habe auch ein paar Gehälter warten müssen aber der Leistungssprung von einer Turing-Grafikkarte ist natürlich immens und lohnt sich in jedem Fall. In meinem Fall hat sich die Framerate mal eben verdoppelt und gibt genug Puffer für die Zukunft.
Selbst von der 3090 her ist der Sprung definitiv die vielen Euros wert gewesen. Mehr FPS, weniger Lautstärke. Die 3090 kam bei mir nach der 1080ti, da hatte ich schon nen ziemlichen Sprung aber halt getrübt durch die Lautstärke. Jetzt bin ich absolut happy.
was für eine wurde es denn genau?
Geht mir genauso. Da ich aber nun mal in 4K spiele (schon etliche Jahre), kann ich jedes extra fps gut gebrauchen. Gerade in Cyberpunk 2077 rutschen die fps gerne mal unter die kritischen 60.
Knapp 3 Jahre habe ich die Karte im August (damals fast zum UVP geschossen). Jetzt liegt die ASUS RTX 4090 TUF hier bei mir und ich warte auf den Watercool Heatkiller.
Mit Luftkühler bekomme ich die Karte nicht in mein Case, weil der AGB im Weg ist (es fehlen 5 cm).
Mit der neuen TUF OG hätte es gepasst. :sneaky:
Wollte nicht mehr als nötig ausgeben und deren Kühler soll besonders gut sein, kühl und leise.
Ja, ich spiele ja auch schon seit 10 Jahren in 4K, oft halt nur mit 30-60 FPS, was für mich Ok ist. Neuere AAA Titel hab ich gar nicht gespielt, mal von Elden Ring abgesehen. Wird sich mit der 4090 wohl nun wieder etwas ändern, man will ja dann auch sehen was sie grafisch kann. Mit der RTX 2080 war RT ja noch etwas arg schwach. :d
Perfekte Wahl ;-) Die hab ich mir auch gegönnt, war lange unsicher weil ich davor nur Asus und MSI hatte aber die Karte ist super. Ich hab mir allrdings ne separate Stütze gegönnt weil der mitgelieferte bei mir nicht funktioniert hat. Die von PNY müsste man mit dem Mainboard verschrauben, also mit 2 der Mainboard-Befestigungsschrauben. Da ich haber ne Soundblaster ZxR mit im System hab ging das nicht sonst hätte ich da nen Loch reinbohren müssen :LOL:
Falls das mit der Stütze bei mir nicht hin haut... ich hab nen 3D Drucker. Sollte nicht das Ding sein da was passendes zu drucken. :d
Dito. Die 4090 ist ein feines Stück Hardware dass man noch lange genießen kann ohne wieder in Upgrade Stress zu verfallen.
Me likes. :)
Wenn das wirklich so kommt, würde das eine Matrix natürlich noch interessanter machen :unsure:
Jap am besten wäre eine Matrix mit 4090ti :)
Wenn das so ist, können die sich auch bis 2026 Zeit lassen bzw. so lange wie AMD braucht zu folgen
Ich hätte schon noch gerne vor 2030 eine neue Grafikkarten Generation. :d
Primär jetzt an RT gedacht, wo AMD massiv hinterher hinkt.
Ich bleibe dabei, dass höchstens eine Lovelace Titan aktuell Sinn machen würde für Nvidia. Aber wir werden sehen. Es gibt ja bisher nur immer wieder Fotos vom Kühler. Ich würde erstmal eine 4080 Ti erwarten.
Würde ich auch erwarten. Einfach weil da der Abstand auch gefühlt am größten ist. Eine 4090 TI braucht es aktuell einfach nicht, weil AMD nichts in Spuckweite hat dass der 4090 gefährlich werden könnte. Es macht irgendwie keinen Sinn.
Das Problem ist ja auch, dass AMD gefühlt so weit weg ist, dass die nicht mal mit einem 7950 XTXTXT mega Refresh irgendwie auch nur annähernd in Reichweite kommen würden...
Mit 600w wäre die Karten auf 4090 Niveau aber das macht laut amd keinem Sinn die Power Brechstange zu fahren
Wo wären die da auf NVidia Niveau? Vielleicht maximal in 2 3 Games. Und dann schmeißt NVidia FG an und tschüssikovski.
AMD braucht eine neue Generation, um hier wirklich aufzuholen. Man darf auch nicht vergessen dass die 4090 selbst in 4K oft noch durch das CPU Bottleneck zurückgehalten wird. Im übrigen auch der Grund warum die meisten hier mit solch sanften Temps durch den Sommer kommen. Lasst mal die nächste Stufe an Games zünden, in denen die 4090 wirklich gefordert wird, dann kann man getrost Arrivederci zum Undervolting und <80° GPU Temp sagen.
Also meine FE hat letzte Woche bei ca. 30 Grad Zimmertemperaur in Jedi Survivor das erste mal 75 Grad erreicht. Denke mehr passiert da nicht und die meisten Customs haben ja eine leicht bessere Kühlung.
Betreibt ihr die Karten da "offen" mit 600W, oder? Denn wenn man auf 450W bleibt, erreicht man ja oftmals schon den Leistungsdeckel.
Ja die Karte läuft oft am Limit in 4K, da braucht man keine zukünftigen Games für. Ich betreibe die auf 450W und leichtes UV. 600W bringt ja kaum was. Damit dürfte man die 80 Grad an einem heißen Sommertag aber packen.
Einigen Karten kommen ja auch gar nicht auf 600W. Die Inno hier kann ich zwar auf über 450 bekommen mit dem TDP aber wie bei der Strix geht das nicht.
Im Sommer überhaupt von 600W zu reden bringt mich gedanklich schon ins schwitzen. :d
Wenn man die Stromkosten jedenfalls mit einkalkuliert, lohnt sich das kaum, aber wenn man wirklich das kleinste bisschen Leistung raus kitzeln will, sicher, dann muss man das machen. Dürfte sich nur kaum lohnen bei dem bisschen Leistungsgewinn, oder kann man da wirklich noch so viel FPS raus kitzeln?
Die Kühler der 4090 sind ja für 600w abzuführen gedacht
700w https://www.computerbase.de/2023-05...n-rx-7900-xtx-jagt-mit-700-watt-die-rtx-4090/
Ähnliche Themen
Antworten
7K
Aufrufe
434K
