[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Keine Ahnung, obs schon irgendwo stand, aber gerade wär die Gigabyte 4090 Gaming Oc für 1949€ im Mindstar - zudem noch ggf. 20€ Cashback. Laut Geizhals hat die Karte zudem 4 Jahre Garantie.
(Daneben noch die 4090 Palit Gamerock für 1949€)
Oh, besten Dank.
Wusste gar nicht das Gigabyte die Aktion hat, 20€ direkt mal mitgenommen.
Danke dir!
Ich würde gerne dafür zahlen, solange es keine vergleichbar gute und einfache andere Lösung gibt.
Ich würde ebenfalls einen Betrag bezahlen wenn er das Projekt fortfahren könnte.
sieht nicht so aus, als hätte er das game auf DX12 gestellt (geht nur mit dem start-argument) weil erst dann RT Effekte mitkommen. Ohne dem ganzen komme ich auch auf über 200FPS in WQHD
Es hat aber wohl auch Gründe, warum man das über einen Startparameter machen muss und nicht im Spiel selbst aktivieren kann ;)
Am Ende des Tages ist es ja so dass msi das Tool auf ihrer Website Anbietet.
Jetzt fällt das Tool eventuell erstmal weg. Das kann ja nicht im interesse von msi sein.
Mal schauen
ja das ist richtig...aber ich finde es schon krass wie stark da eine einst so starke Karte wie die 3090 auf 23FPS einbricht...daher würde mich ja mal das Ergebnis mit einer 4090 interessieren ^^
gut, AVG FPS hatte ich mit der 3090 auch meist um die 60 @ WQHD und aktivem DX12 Parameter
Update dazu:
Meine defekte 4090FE wurde heute morgen um 7uhr bei nbb zugestellt und ich habe bereits eine Versandbestätigung für die neue erhalten. Also der RMA Prozess bei NBB scheint top zu sein👍
Nächstes Update:
Dummerweise kam ne B-Ware Karte als Ersatz an. Alle Siegel gebrochen, kein Umkarton der 4090, Kratzer etc.. und Spulenfiepen bis in nächsten Raum + der hintere lüfter gut am eiern beim Anlaufen. Hatte dann diesmal per Email Kontakt mit NBB. Habe um Erstattung des teilbetrages zu der B-Ware die im Umlauf war (glaube 1710€?) oder aber Austausch gegen Neuware gebeten.
Laut NBB war das scheinbar ein Fehler und ich schicke die Karte jetzt auch wieder zurück in der Hoffnung dann funktionierende Neuware zu bekommen :fresse:
Fehler...😅
Die probieren es halt
Heute kam die Version 4.6.5 Beta 4 vom Afterburner.
Auf wie viel boostet deine FE?
Stock@1.05v
Zocke auch etwas Tiny Tinas Wonderland, bin aber richtig hart an Witcher 3 hängen geblieben xD
Wie kannst du die Ruckelorgie von Witcher 3 zocken, diese ständigen Frametimeruckler sind der Horror
DX12 auch ;)
4K maxed out mit DLSS/RTX/FG ca 100 FPS, ohne RTX mit DLSS und FG komme ich an die 240Hz Grenze meines 4K Monitors aber ohne RTX kann ich mir mit einer 4090 nicht mehr geben :d
DX12 auch ;)
Bei mir identisch. Wenn es was zu meckern gibt, dann die große Latenz, vermutlich durch FG/DLSS, fühlt sich etwas schwammig an. Aber keine Ruckler.
Spiele mit Gamepad und kann mich über Lazenz null beklagen.
Ist schon Wahnsinn was eine 4090 dank DLSS und FG da in 4K mit RTX auf den Bildschirm zaubert, vor allem wenn man bedenkt, wie alt der Streifen schon ist.
Bemerke auch keine Frametime Ruckler in W3. Läuft butterweich auf 4K. Klasse next gen Update perfekt getimed für eine Klasse Karte. Man muss wirklich sagen dass es an der 4090 und den Treibern nix zu meckern gibt.
Falls jemand noch keine FE bei NBB ergattern konnte einfach gemütlich in Frankreich einkaufen...heute gerade wieder eine für einen Kollegen bestellt..meistens viele Stunden oder sogar Tage verfügbar in Frankreich...
Wie sieht der Status bei dir aus? Habe mir sagen lassen das LDLC diesen Laden auf der Blacklist hat und daher ein storno daraus wird.
Benötigt noch jemand eine 12VHPWR Adapterkabel von be quiet? Habe noch eins über 😅
Es gibt doch noch EVGA Precision X. Sah zumindest in früheren Zeiten genauso aus wie AB. Ist das nicht ne gute Alternative zum AB?
bauen nicht alle tools auf den afterburner oder teile von ihm auf?
die beta 4 gibt es schon länger, wurde nun für alle freigeben :)
Ähnliche Themen
