[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Beides aber viel zu wenig? Sollten eher Richtung 40k GPU Pkt sein, siehe:
Ja, liegt an meiner lahmen CPU, die bremst die 3 stelligen FPS runter. Hab im ersten Graphicstest teilweise nur 75% GPU Auslastung.
Simpel wäre ein screenshot der voltage curve.
das noch dazu, denn mit entsprechender curve einstellungen holt man halt auch was raus. diese lächerliche timespy anzeige ist sowieso bullshit, den takt sieht der benchmark ggf genau 1ms und schon steht da 5000mhz max.. sinnfrei
in dem von mir velrinkten thread gehts um takt, der tatsächlich und dauerhaft anliegt. da laufen seine 3165 halt nicht mehr ....
die 3165 kannst du in den vom mir verlinkten thread halt wahrscheinlich nicht halten und willst deshalb den bench nicht machen :unsure:
:cautious: du raffst es halt nich .. es geht mir nun nich ums halten das hab ich nun schon x mal hier geschrieben .. aber ich glaub dat willst du halt absichtlich einfach nich verstehen
Logischerweise kann ich die 3165 mhz nich halten weil Stock Luftkühler und 450 Watt PT ..... nur ging es mir nich ums halten sondern um den Peak meine Herren is das denn so schwer zu verstehen ?
Wie gesagt macht kein Herrmann draus !!! ... es geht einfach um die Max Core Clock auch wenn sie nur 1 sekunde anliegt was is denn daran so schwer zu verstehen ???
Habs doch auch extra nochmal mit nem roten Pfeil im Bild markiert um was es mir da geht aber selbst das scheint wohl nich auszureichen um manchen hier klar zu machen um was es mir da grad geht
Es sollte einfach ne lustige kleine Aktion hier werden unter uns "Freaks" aber stattdessen muss wieder alles kaputt gemacht werden und in unnötige kleinliche Diskussionen ausarten
weil es bullshit ist da du PT limitiert bist, bei dir dropt der takt von max zu durchscnitt um 72mhz
kein anderer hat diese hohe differenz
Also ja ich bin Powerlimitiert mit 450 Watt das is nun keine neue Erkenntniss hab ich schon x mal hier im Thread geschrieben das ich nur 3 x 8 Pin hab und somit max 450 Watt
.. nur was ändert das an meinen 3165 mhz die ich bei 3D Mark erreicht hab ? Die sind halt fakt und von mir verlinkt und Gültig !!
Gerne nochmal :
bei dir dropt der takt von max zu durchscnitt um 72mhz kein anderer hat diese hohe differenz
Is aber halt so bei mir .. und er droppt halt weil die Temp hochgeht weil Stock Lüfter und ich daher Taktstufen verliere aber weil eben auch die 450 Watt Limitieren weil 3 x 8 Pin.
Neuer Run .. mehr geht bei mir nich ... die 3165 mhz schaffe ich nich stabil bei Superpoition nur mit 3150 mhz läuft er durch dafür aber mit +2000 VRAM
Wenn es nur ums maximale OC geht - 3180 MHz:
1. UdoG 4090 Galax = 3180 Mhz (y)
2. Stagefire mit ner 4090 Strix = 3165 mhz
(*) 3. Nuestrass 4090 Suprim = 3160 mhz
4. s L i X 4090 Palit = 3135 mhz
(*) 5. Gurkengräber = 2950 mhz
(*) = Es fehlt ein Link zum Ergebniss als Beweiss das der Max Core Takt auch erreicht wurde
Platz #6 in der HOF hat auch 3165Mhz, bei dem droppt es aber nur auf 3159 im Durchschnitt. Noch mal, deine 3165 sind fake und werden nur angezeigt, weil du PT limit hast.
Auch Superpostion, 3150 würden dir wahrscheinlich hart um die Ohren fliegen, wenn die Karte den Takt mit vollem PT mehr als eine Millisekunde halten könnte.
PT limitiert mit 31xx Taktraten um sich werfen ist ein joke, mehr nicht.
@s L i X Ich behaupte mal frech das alle 4090 mit 1.1v die 3Ghz schaffen. Richtig gute Chips packen auch 3.1Ghz aber das ist meiner Meinung nach Lotterie und hat nichts mit Strix, Suprim oder den günstigeren Zotac oder Palit Karten zu tun.
2940-2955MHz mit 1,1V, mehr ist nicht drin. (y)
solltest für so ne komsiche max oc was auch immer liste nicht einfach nen eigenen thread aufmachen anstatt hier alles zuzumüllen?
Für das Zumüllen seit ihr zuständig da ihr alles verkomplizieren müsst und kleinliche Diskussionen startet die einfach unnötig sind.
Das ganze sollte einfach n kleines Spass Projekt werden zum auflockern und fun haben .. ne kleine Liste der besten Max Core Karten aber ihr schafft es immer wieder das sowas in kleinliche Diskussionen endet
wo dann ne riesen Wissenschafft draus gemacht wird ... also packt euch somit da mal an die eigene Nase
Zeig mal was deine Karte wirklich kann und mach hier mit:
Der Benchmark zieht nur kaum mehr als 300W, sprich da limitiert dich dein PT nicht
Testlauf 1 .. erstmal 5 min warmlaufen lassen und dann den Benchmark gestartet ... zu 95 % stabile 3150 mhz im ersten versuch mit einigen 3165 mhz Peaks .. mal schauen was im 2ten mit mehr +core mhz passiert
aber auch da wirst du zu 100 % wieder was zum meckern finden das is halt so deine Natur und is ja auch nich das erste mal :
Schön und gut, ist aber stark CPU-Limitiert
Ist doch super! tolle karte! aber das ich die nicht im pt limit bewerten kann sollte dir einleuchten, das ist der grund warum 3d mark hier wenig aussagekraft hat...
Jepp is halt ne Asus 4090 Strix :d und hab da wohl ein Gutes Los bei der Lotterie gezogen auch was fiepen angeht .. mal wieder .. da ich 2020 mit meiner 3080 Strix auch schon in der Lotterie gewonnen hab.
Wie gesagt nich verkomplizieren .. es war simple ne Frage nach der Max Core Clock auch wenn das dann nur für 1 sekunden anliegt
es ging somit auch nich darum eine Karte zu bewerten oder welche Durschnittstakt Karte X erreicht ihr habt daraus halt voll die wissenschafft gemacht und unnötige kleinliche Diskussionen gestartet
Das ganze sollte einfach ne kleine Spassige Nummer unter uns Freaks werden aber es war ja klar das im Luxx das nich so einfach geht spass zu haben da muss alles bis ins kleinste bewiesen werden
und alles kleinlich Diskutiert werden da kann man nich einfach mal etwas spass haben .. hmpf
Wie oft willst du immer das selbe posten?
Stagefire: JA !
:ROFLMAO:
Solange dumme unnötige kleinliche Diskussionen gestartet werden geht das halt weiter ... wie gesagt packt euch da lieber mal an die eigene Nase
Alles was ich wollte waren zahlen aber die bekamm ich nich sondern unnötige lange kleinliche Diskussionen die immer weiter gingen und wo alles immer umständlicher wurde
nur weil ich von ein paar Leuten hier ausm Thread einfach nur wissen wollte was deren Max Core Clock is .. ganz Simple .. aber Simple geht scheinbar im Luxx nich
Warst es nicht du, der hier von den Usern die bei deiner spaßigen Nummer teilnehmen wollten, Beweise forderte?! 😂🤣
logischerweise sonst kann ich ja auch sagen ich hab 4 ghz erreicht. .. das heisst aber nich das es auch mit "Beweise" nich auch spass machen kann mal zu schauen wo wer liegt
und ich wollte nich "Beweise" das Clock X 3 std anliegen sondern mir hätten 1 oder 2 sekunden gereicht
Egal ich hab daraus gelernt .. die Sache is nun durch für mich .. ich frag nun nich weiter wer welchen Max Core erreicht hat weils hier echt kein SInn macht .. ihr macht mir daraus zuviel Wissenschafft
Spaß hast du also nur, wenn du Beweise fordern kannst, Beweise liefern dass das mehr als 1Sekunde läuft ist dann nicht mehr so spaßig oder wie?
Und jetzt bist du traurig und heulst rum wie ein kleines Kind? Ich dachte du hast Spaß an sowas?!
Welche 4090 für eine Wasserkühlung würdet Ihr empfehlen?
Phanteks Enthoo Primo / AMD R9 5950x / ASUS ROG Strix Gaming E / Asus GeForce RTX 3090 24GB Strix / GSKILL 64GB 4000Mhz CL18
/ Samsung PM9A1 M2 2TB / 2x Samsung EVO 870 2TB Raid=0 / 2x Toschiba Enterprise 18TB Raid=0 / Corsair AX1200i / WinTV-HVR-5525 -S2 / Aquaero 5 Watercooled
/ 2xD5 USB Pumpe 1x420Radi 1x280Radi / GPU kryographics & CPU Heatkiller / Soundblaster AE-5 Plus / Teufel Concept E Digital / Razer Firefly / Razer LanceHead
/ G19 / XBOX Elite Controller / Samsung Galaxy S22 Ultra 1TB / S6 Lite 4G / Lenovo T480 / DS415Plus 2x Seagate IronWolf 8TB Raid=0 / Backup 2x Toschiba Enterprise 16TB Raid=0
/ Dell UltraSharp UP2718Q 4K / ASUS ROG Swift PG32UQ 4K 144Hz
Sag ich dir morgen, falls ich bis dahin deine signatur durchgelesen habe 🤣
Wenn man bekommt eine FE alleine schon aus preislicher Sicht.
Wenn man möglichst leise Spulen haben mag , dann würde ich wohl eine ZOTAC RTX 4090 AMP Extreme AIRO probieren.
Die hat ein 24+4 Phasen Design welche zwar pro Power Stages nicht so stark aber durch die Menge immerhin in der Summe 1320 W kommt.
Ist ggf. eine nette kombi aus leisen und in der Summe starkes VRM Design . Glaube aber PL liegt bei 500 Watt .
Wenn dir das reicht und es primär ums zocken geht , dann diese und wenn du benchen willst muss es eben eine Karte mit 600 Watt PL sein.
TUF,Strix , FE , Master und glaube Suprim X mit neusten Bios bin aber nicht sicher (Vorher waren es 520 Watt)
Ne Zotac Trinity , Palit, Gainward , PNY , GB Gaming OC mit ihren VRM Design welche im Bereich 700-800 Watt liegen würde ich aus prinzip nicht nehmen,
weil alle Karten kosten ordenltich Kohle und dann darf auch mehr als das absolute minimum sein meiner Meinung nach auch wenn das laufen kann über lange Zeit.
Ähnliche Themen
Antworten
7K
Aufrufe
586K
