[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja stimmt, aber will man die Latenz? Ich weiß ja nicht, ob dann 8 Kerne nicht besser wären.
kommt drauf an, aber für mich ist der eh nichts... board, ram und cpu viel zu teuer für aktuell keinen Mehrwert. Jetzt nochmal den 5800X3D zu holen war das beste was ich machen konnte... CPU Upgrade dann erst Ende 2024
Dann geb ich zu der Frage welche ja auf mich bezogen war Antwort. @WilliWonka
Ja soweit ich es bisher hier im Thread mitbekommen habe währe ich die 2. Person die die 4090 auf Wakü umbaut.
Ich melde mich dazu sobald ich den ELWB vector2 für die FE habe und weiteres berichte kann. 😉
Ich auch aber erstmal muss der WB zur Suprim X kommen 😄
Bei mir stand auch
Pre-Order: This product is expected to ship out in mid November 2022.
Ist aber am Freitag schon versendet worden.
Ich hatte allerdings den Block für die FE vorbestellt.
Und alles explodiert?
Erster Test, Elder Scrolls Online @4k ja leckomio :eek: Die Karte ist so abartig leise im Vergleich zu meiner 3090 Strix! Minimal Spulenfiepen aber kaum wahrnehmbar aus dem geschlossenen Gehäuse. Verbrauch lag max. bei 329W mit 2760Mhz Boost, wo die Strix 405W gezogen hat und das wohlgemerkt mit UV. Was mich gerade total flashed sind die Lüfter! So was laufruhiges habe ich selten erlebt... Keine komischen Geräusche, kein eiern, keine schwingenden Resonanzen, einfach super angenehm. Nach dem ersten Eindruck würde ich sagen die bleibt aber ich muss sie mal noch etwas mehr stressen.
Die 4090FE? Also die Lüfter find ich bei der FE lauter als die Gamerock.. aber die Gamerock (Bananenkarte die Zurück ging) hat Stock schon fast an die 400-430 Watt gezogen. Die FE braucht weniger Watt für die gleiche Leistung. Geh mal hin und erhöhe die Lüfter >50% ob es dann unangenehmer wird. .. Aber selbst mit 133% PT, +100%V und +250 MHZ, ~3000Mhz bei Cyberpunk, geht sie nicht über 50% Lüftergeschwindigkeit, sondern bleibt drunter. Finde die FE sehr wertig und einfach schön. Wie die 3090 nen schönes Stück Metall und fein verarbeitet.
Ich warte auf die alphacool/watercool/aquacomputer (je nachdem wer erster sein wird) Modelle. Andererseits finde ich die FE optisch so horny, dass ich mich mit dem Gedanken nicht anfreunden can, den Shice-Luftküfter upzunehmen. :o
Naja, was sein muss, muss sein. :unsure:
Ja die FE ist schon schick, aber
performance > optik
klar die Luftkühler sind diese Generation extrem stark, aber ein MoRa ist dem bei weitem überlegen.
Bei mir warten sogar 2 Mora (360+420). Den 2ten extra für die 4090 gekauft und nun überlege ich den Lüftkühler drauf zu lassen. :o
Alles qool, kommt runter. 8-)
Jop die FE. Ich schaue mir das die Tage noch genauer an aber der Ersteindruck ist euphorisch! Die Karte ist sehr edel bzw. wertig :hail:
performance > optik
Ja mag sein aber die Unterschiede sind diesmal eher marginal.
Meine Strix OC von Bora Computer ist abholbereit. Geordert am Releasetag :) hätte nicht gedacht, dass da nochmal was kommt.
Weis zwar jetzt nicht was bei 400W zwischen ca. 60Grad Luftgekühlt vs. ca. 40Grad Wassergekühlt marginal sein soll, aber gut.
Noch dazu kommt die wesentlich leisere Geräuschkulisse des MoRa zu den 2 oder 3 Lüftern der Grafikkarte.
Kann ja aber jeder selbst entscheiden, aber für mich ist das ne klare Sache.
Meine MSI RTX4090 GAMING X TRIO 24G die ich ja am Release Tag bestellt hatte mit Verfügbarkeit ist bis heute noch nicht da 😄😄😄
Funktioniert der Fanstop bei der Gigabyte Gaming OC wie zu erwarten? Also Lüfter aus sobald keine/minimale Last anliegt? Bei meiner KFA2 scheint das immer ne ganze Weile zu dauern bis die Lüfter sich abschalten und das führt die Funktion quasi ad absurdum, wenn die GPU-Lüfter nach dem Booten und nach jedem Spiel 10+ Minuten hörbar am drehen sind.
Die KFA2 hat einen etwas längeren Nachlauf. Erst wenn die Temperatur im Idle-/Desktopbetrieb 33°C erreicht, greift der Fanstop.
Dabei liegen 1000RPM an. Nach 2 Stunden COD MW2 dauert das aber keine Minute bei mir (5000D Airflow).
Nach Boot läuft sie maximal 10 Sekunden im Idle-/Desktopbetrieb auf 1000RPM.
Habe gerade mal spaßeshalber nach 4090er bei ebay-kleinanzeigen geschaut. Allein dort gibt es über 200 Stück... verrückt
Ähnliche Themen
Antworten
7K
Aufrufe
582K
