[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wollte ja heute den X3D + Ada einbauen, denkste. DHL hat mir n Strich durch die Rechnung gemacht. Hab die CPU an die Packstation senden lassen. Leider wusste ich nicht, dass man mittlerweile eine App benötigt. Um diese auf dem jeweiligen Smartphone verknüpfen zu können, benötigt man leider einen Aktivierungscode, der aber via Post 3-5 Tage Versandzeit hat.
Tja so kann es manchmal laufen... trotzdem habe ich die Karte heute eingebaut. Die Qualität von der FE ist schon beeindruckend. Brutal edel das Teil und auch die Verpackung ist cool gemacht. Leider hatte ich Probleme die Karte in den Slot zu bekommen. Der Schlitz von meinem Slothaken ist scheinbar zu dünn? Habe einige Male ansetzen müssen bis ich sie reingebracht habe.
Und dann kam da das Corsair Kabel... Holy Shit ist das bocksteif. Hab mir echt unglaublich schwer getan das zu verlegen. Drei Stunden später, inkl. Gehäuse putzen usw, war ich dann fertig... Gestartet habe ich noch nicht, da ich erstmal essen musste. Mal sehen ob es gleich knallt. Das Corsair Kabel scheint in jedem Fall gecrimpt zu sein. Bin mir noch immer nicht sicher ob mein Netzteil überhaupt damit funzt :fresse:
So erstmal Treiber installieren, noch den Ersten oder? Den Neuen kann man wohl vergessen...
Ja aber hier könnte man sagen dass das System mit dem 5800X eigentlich höher gespecct ist.
Die Unterschiede wären also minimal höher.
Derselbe hat hier seinen 5800X gegen den 12900k getestet:
Damit könnte man den 5800X3D gegen den 12900k vergleichen. Die sind beinahe gleich schnell, je nach Spiel.
Wobei ich persönlich sagen muss, mehr als 120FPS in 4k brauche ich nicht...wichtiger sind dafür mich dann die 1%low FPS.
Wobei ich eigentlich 3600 CL14-14-14 schon besser finde als 4000 20-23-23
Und die ~7% bessere AVG FPS in UHD hauen mich jetzt auch nicht so um.
Mit den lows geb ich Dir recht, aber das haben sie bei ihrer conclusion nochmal dazu geschrieben:
The brute force of 5800X3D will also help to safeguard against those frame drops in hectic situations, or busy map areas. With a weaker CPU you might encounter lower FPS from time to time, as the CPU gets overwhelmed, which of course happens quicker with a weaker processor. Also, while it's not reported in this review, the minimum FPS on 5800X3D are considerably better on Ryzen 5800X3D than on Ryzen 5800X.
Habe eine Palit GameRock 4090 (450 W) zusammen mit einem Corsair RM 750x und dem Corsair Kabel seit 2 Wochen am Laufen - völlig problemlos. Habe das Kabel vor dem Einstecken entsprechend zurechtgebogen (ist wirklich sehr steif) und mit dem 5800X3D ist das eine sehr zufriedenstellende Kombination für einen OLED mit 120 Hz.
Optimus hat heute über Twitter informiert das sich die 4090 total anders verhält als die 3090, so soll bei Vollast das Delta Waser-zu-GPU von 9°C auf 19°C steigen da viel mehr Leistung in den GPU-die geht https://www.hardwareluxx.de/community/threads/nvidia-ada-lovelace-40xx-wasserkühler.1323682/page-9#post-29528190
Ich habe jetzt gefühlt 20 mal deinen Beitrag gelesen und versucht darauf zu kommen warum genau du mich zitiert hast und was genau du mir eigentlich sagen willst. Ich steig nicht dahinter. Deshalb denke ich, es ist ein klassiches Kommunikationsproblem. Ich möchte also nochmal aufklären:
Der von dir zitierte Text von mir, ging an die Person über mir. Die Frage war, ob diese Person jetzt bald die zweite Person ist die einen Wasserblock auf ihre 4090 schnallt. Die erste Person hier im Forum war ja ich. Deine Antwort hingegen war, das ein mir völlig fremder (wer auch immer Optimus ist) irgendwas auf Twitter informiert hat. Aber etwas das ich ja a) bereits wusste und b) nicht wissen wollte. Denn ich habe ja die 4090 unter Wasser und hatte davor eine 3090 unter Wasser. Mir ging es nur darum sofern möglich eine Info zu erhalten wie sich der EKWB Block gegenüber dem ALC Block verhält. Beides auf der 4090 installiert.
Liege ich richtig mit dem Kommunikationsproblem? Falls nicht, klär mich gerne auf.
Hast du denn Information, wann er in den Handel kommt?
Lg
MooresLawIsDead hat eventuell vor Weihnachten spekuliert, es gibt wohl einen 7800X3D mit 10 kernen der gerade evaluiert wird von diversen Testern :| , erscheint mir allerdings merkwürdig, so CCX technisch ergibt das nicht so viel Sinn :d
so wirds laufen
- wecker weckt mich um 5 vor
- seite ist punkt 2 uhr down
- ich schlaf weiter.
- 6:15 klingelt der wecker erneut
- seite wieder erreichbar, aber alles ausverkauft
Finde die Galax Version der 4090 echt verdammt schick und echt cool mit dem zusätzlichen Lüfter hinten! Meint ihr es wird für die anderen Versionen noch einen optionalen Lüfter geben? Ansonsten würde ich mir einfach einen 80/90mm Lüfter dahin basteln. Nicht, dass der nötig wäre aber schaden kann er bestimmt nicht 🤔
Ich frag mich ja eher warum man für die Global/EU/Schlagmichtot-Stores bei CableMod getrennte Accounts braucht :d
Ich schlafe um 2 Uhr. Später stellt sich wieder raus das dieses Ding einen Fehler hat und die Early Adoper bluten erneut.
Interessanter Artikel. Hier läuft ja ein 5800x und der Wechsel auf den 3D wäre denkbar. Die 6-7% Steigerung un 4k triggern mich aber noch nicht so wirklich. Zumal ich den Eindruck habe der 5800x3D wird noch künstlich ausgebremst.
Auf Reddit sind mittlerweile auch weitere Fälle mit schlechten BeQuiet Kabeln (12VHPWR) aufgefallen. Wie hier schon von jemandem auf hardwareluxx gezeigt, sind die Pins nicht fest genug im Gehäuse. Laut Bequiet Support sollte das angeblich ein Einzelfall gewesen sein, ist aber offensichtlich nicht so.
Offizielles Statement von bequiet dazu https://www.hardwareluxx.de/community/threads/atx-3-0-und-12vhpwr-netzteile.1324076/post-29521116
Und alles explodiert?
ist aber das einzig sinnvolle, wenn man vor einem 4k OLED sitzt. also sich die benchmarks in der entsprechenden auflösung reinziehen. ich würde jetzt auch nicht für 5 oder 10% höhere fps board und cpu wechseln. viel zu aufwendig und vermeidbare ausgabe.
btw,
ich habe eben ein paar runden last erzeugt und ein bisschen mit dem laserthermometer gespielt.. alles im grünen bereich.. 38°C am stecker.. und schlappe 800W auf dem leistungsmessgerät hintern NT.
tobi
Dann geb ich zu der Frage welche ja auf mich bezogen war Antwort. @WilliWonka
Ja soweit ich es bisher hier im Thread mitbekommen habe währe ich die 2. Person die die 4090 auf Wakü umbaut.
Ich melde mich dazu sobald ich den ELWB vector2 für die FE habe und weiteres berichte kann. 😉
keine cpu benchmarks in 4k anschauen. das hat keine aussagekraft^^
Kann man schon tun wenn man einen 4K Bildschirm besitzt, wüsste auch nicht warum man das nicht tun sollte?
stimmt. solange der tester mit keinen beweiß liefert dass er das gpu limit ausgeschlossen hat, sind 720p tests quasi unumgänglich ^^
Mein ATX 3.0 Netzteil kommt am Mittwoch. Die GPU nicht.
endlich schreibt das mal einer richtig...mein monk rastet immer aus.
Ansonsten why not? 2 CCD´s a 5 Kerne
Ja stimmt, aber will man die Latenz? Ich weiß ja nicht, ob dann 8 Kerne nicht besser wären.
Ähnliche Themen
