[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das möchte ich eigentlich gar nicht. Ich undervolte da lieber. Mehr als 400 Watt darf/soll die Karte bei mir nicht ziehen.
Man fühlt sich einfach sicherer, wenn da pro Kabel nur 100 Watt statt 133 Watt durchgejagt werden. ^^
Genug Anschlüsse am Netzteil habe ich eh.
Ich find UV auch super :)
Hab gestern 4 Stunden Port Royal Stresstest laufen lassen mit 2600Mhz@0,89 mv. --> eventuell hilft dir das als Richtwert.
Selbst mit 5260*2160 DLSDR beim neuen Sniper Elite (ultra Setting) komme ich da nie auf über 300 Watt eher so 220-275 Watt bei über 130 FPS..
Selbst beim neuem PlaqueTale mit dieser Auflösung, ohne DLSS (ansonsten Ultra-Preset) und mit Framegeneration habe ich 250-280 Watt und 90-100 FPS..
Die Leistung ist abartig. Ob jetzt 2600 Mhz oder 2800 Mhz im Standard (bei der Suprim) ist bums, du sparst aber über 200 Watt an verbrauch.
Also auf das Spielen muss hier niemand verzichten, aber die Karte jetzt unbedingt hochprügeln zu müssen, ist halt jetzt vorerst nicht angesagt.
Das PT zu senken ist ebenso eine Möglichkeit, ich find UV aber letztendlich eleganter, einfach weil der definierte Maximaltakt immer gehalten wird,
was noch etwas mehr Perfomance liefert --> kann aber jeder so halten wir er möchte :)
Finde gut, dass das Thema jetzt große Wellen schlägt, sodass Nvidia sich vielleicht gezwungen sieht zu handeln.
Teste es doch selbst. Aber genau das ist dein Problem als Halbblinder 40 jähriger. Du vertraust blind auf andere ohne was selbst zu testen und verteidigst die dann auch noch.
Whoa du wirst auch immer gleich so Aggro und beleidigend, klar habe ich es selbst getestet und für gut befunden.
Selbst beim neuem PlaqueTale mit diesen Settings, ohne DLSS (Ultra-Preset) und mit Framegeneration habe ich 250-280 Watt und 90-100 FPS..
Absolute Zustimmung. Und wenn man die Karte nur mit 300 Watt oder weniger betreibt, fühle ich mich auch mit dem "schlechtesten aller PCBs" laut Buildzoid (Palit/Gainward) sicher.
Drauf scheißen und zocken mit 0,875 oder 0,900v Und dabei den Max-Takt ermitteln.
2600 MHz bei 0,890v halte ich nicht für Game stable. Muss man halt mit den richtigen Games testen.
Schade, dass es keinen neuen Content für Division 2 gibt. Das Game war ganz gut zum Testen.
Hab ich schon gemacht 0.91 @ 2610 Mhz bisher Gamestable, mit 0.9V is MW2 in der Kampagne gecrasht ;)
BF2042, Requiem, RE Village, MW2 liefen dann aber bisher mit 0.91V @ 2610 MHz
Solange nix was ich spiele crasht fasse ich das Setting nicht mehr an :d
Ich selbst habe noch keine Probleme mit dem Kabel. Habe aber auch 3x8 Pin Adapter und zusätzlich untervoltet. Das Kabel stammt von Moddiy
Alles andere als ein sofortiger Rückruf und Austausch aller in den Handel gekommenen Adapter wäre fatal. Wird nv viele 100k Dollars kosten. Vielleicht ein Anstoß in Zukunft die Arbeit von irgendwelchen Zulieferern besser zu kontrollieren vor dem ausliefern 🤷
Du willst mir doch nicht erzählen, dass du fixes Undervolting vs PT nur reduzieren getestest hast :)
Wie lange hast du die Karte eingebaut? Seit gestern?
Jup, Mit 40 ist man halt flott, multitasking und effizient unterwegs. :bigok:
Hätte ich vielleicht genauer beschreiben sollen. Aussage von dir. Klingt das besser ?
Hattest du doch. Dass du nachträglich "Meinung" in deinem urpsrünglichen Beitrag in die Pluralform geändert hast ist mir nicht entgangen. Wir wissen ja warum.
Hab schon mit meiner 3090er gute Erfahrungen mit dem 3D Mark Port Royal Stress Test gemacht.
Wenn es damit mehrfach (60-100 Loops) über 99 Prozent im Ergebnis durchläuft, sollte das "rockstable" sein --> gibt sogar ein Achievement. :banana:
Ist das Bild richtig? Ich sehe keinen brandherd Adapter...nur mit dem von Nvidia gibt es Probleme...
Außerdem scheinen 2 Ram Sticks nicht richtig drin zu sitzen...
Teste ich mal nachher. Ich bin mit 2400 MHz bei 0,875v unterwegs.
Wenn aber ein Game sich beendet, bitte nicht aufs Game schieben.
In 99% der Fälle ist es das OC und dementsprechend der Anwender verantwortlich.
Also ich hab jetzt so 10 Games getestet und etliche Benchmarks gemacht. Cyberpunk so 5 Stunden, COD Cold War 5 Stunden und Uncharted 14 Stunden, hier scheint das alles stable zu sein. Als erstes hatte ich noch 2640 @ 900mv, das war in der Tat nicht stable.
Wenn es damit über 99 Prozent im Ergebnis durchläuft, ist das schon "rockstable" --> gibt sogar ein Achievement. :banana:
nein Port Royal lief, mit 99% auch mit 0.9V@ 2610Mhz, MW2 Kampagne ist trotzdem abgesoffen, mit 0.91V kam das dann nicht mehr vor :d und ob es nun 0.9V oder 0.91V sind stört mich nicht :d
Oky hmm bisher hatte ich damit nie Probleme.. Aber ist ja gut zu wissen, falls es doch bei mir iwo crasht, werde ich auch die 0,91 mV versuchen. :)
So dann versuch ichs auch noch mal hier. Ich habe gestern meinen 13900K bekommen, ding rennt wie sau nur hab ich ein Problem , den Score im Fire Strike ( nicht ultra oder extrem , der normale ).
Habe am Dienstag noch fix nen Run mit meinem 12900KF und meiner Suprim X gemacht und rausgekommen sind 55k Pkt, CPU am Mittwoch gewechselt, ausgelotet 5,8 auf allen P-Kernen und 4.5 auf E-Core und Ring. So direkt mal paar benches gefahren und siehe da in fire Strike nur noch 45K punkte. Um die Geschichte kurzt zu machen egal welcher Bench egal was ich machen, in den Ratings von 3dMark bin ich immer +-Gut dabei NUR der Firestrike da bin ich absolut letzter. Getestet, etc gemacht , sogar mal Windows neu aufgesetzt nix, 45k.
Jetzt meine Bitte an euch, könnt ihr die eine 4090er und einen 13900K haben den Firestrike mal durchlaufen lassen und mir die Ergebnisse schicken ?
und vorallem Suprim X besitzer mit einem 13900K. Ich danke euch.
Läuft der auf einem Z690 Board? Da gab es nämlich schon in den Reviews Probleme mit der Performance mit dem 13900k
doch doch die Ramsticks sitzen richtig, das sieht nur so aus....das KABEL der AIO Links vom Arbeitsspeicher drückt entgegen:)
Schon mal das PUBG Hauptmenü getestet? oder Cyberpunk2077? Beides scheinen extreme Lastszenarien zu sein.
Damals bei meiner 3090 ging PR normal durch und führte bei Cyberpunk 2077 zu random crashes. Speziell die eine Quest wo man das eine Apartment vom Arasaka Chef im Braindance taktieren sollte, crashte permanent...aber das war Version 1.0...
Hast du mal geschaut ob rebar aktiv ist und die Karte mit pci-e 4 und 16 lanes angebunden ist?
Ja Cyberpunk läuft auch grundsätzlich mit DL-DSR, wollte wenn der DLSS3 Patch kommt nochmal durchspielen dann seh ich's ja ... PUBG auch. Hab das schon im Griff 🙈 wie gesagt solange alles was ich spiele läuft, muss ich nichts anpassen.
Der 12VHPWR Anschluss müsste eigentlich so ne Vorrichtung haben, dass man in leicht verschraubt, wie die DVI Anschlüsse aus der Steinzeit.
Zumindest am Netzteil.
Am Netzteil ist das weniger das Problem die Stecker rasten fest ein, es geht eher um die andere Seite meiner Ansicht nach.
Und selbst da klickt der ja ein, problem sind ja beim Nvidia Adapter die innereien, bei den Netzteil Hersteller gelieferten kabeln ist ja das Problem nicht vorhanden da separate kabel pro Pin verwended werden. So soll das ja auch sein.
Bios durchchecken und gegebenenfalls PCI-E GEN 4 manuell anschalten :d
Am 1500W Netzteil sollte es nicht liegen...
Dann gibt es Windows Energiepläne, andere Bios Version, etc... die Liste ist lang...
Mit diesem Kabel:
Bräuchte man ja noch ein dual female adapter.. aber soviele Übergänge und lange Kabel...
Da warte ich lieber auf den 90 Grad cablemod.
Wenn man die Karte < 300 Watt fährt (ob per pt oder uv egal) ist man damit erstmal Safe? Woher "weiss" ich denn dass die Last über alle 6 Pins geht und nicht ungleichmäßig?
