[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Sammelklage ist jetzt wieder das andere Extrem und hilft auch erstmal keinem. Das Gute ist: es ist nur ein gammeliges Kabel, das man easy tauschen kann. Ein Fehler auf dem PCB wäre was ganz anderes...
Und was mach ich jetzt bis das gammlige CableMod Kabel ankommt? :ROFLMAO: Morgen is MW2 MP Release :cry:
Bin froh hier noch zwei weitere Systeme mit 3090 und 6900XT stehen zu haben, geht doch nichts über entsprechende Flexibilität. :d
Bis der passende Cablemod Adapter geliefert wird, dauert es leider noch etwas. :hmm:
Braucht man von Cable Mod jetzt eigentlich NUR den rechtwinkligen Adapter (wenn man den verwenden möchte) oder den rechtwinkligen Adapter UND ein 12VHPWR auf 3x bzw. 4x 8 PIN-Kabel?
edit: Muss man wissen, ob man einen oder 2 Artikel bestellt bei der langen Wartezeit. ^^
Dieses Adapterkabel ist reiner Pfusch und Nvidia (sowie der Produzent der Kabel) haben direkt Schuld daran, da sie keine Qualitätskontrolle durchgeführt haben. Einfach dem Produzenten der Kabel vertrauen geht einfach nicht! Hier geht es um einen neuen Anschluss und gerade da muss ganz genau überprüft werden. Vor Allem bei der Leistung die durch diese dünnen Kabelchen fließt
Das ist eine unkalkulierbare, potentiell lebensgefährliche Sache mit diesem verpfuschten Adapter. So ein Produkt darf einfach nicht auf den Markt.
Bis Nvidia anständig produzierte Adapterkabel bereitstellt können jetzt noch mehrere Wochen und Monate vergehen. Und in der Zwischenzeit können wir nicht einmal die Adapterkabel der NT-Hersteller kaufen, da diese ja überall ausverkauft und nicht lieferbar sind.
Ich bin mir sicher, dass es noch mehr solche Fälle geben wird.
Klasse Nvidia! Den Shitstorm habt ihr sowas von verdient! Ich werde bei meiner Karte jetzt erstmal das Powerlimit auf <80% stellen und das Kabel bloß nicht mehr berühren
Du brauchst den kompletten 4 Pin Adapter, optional und auch wegen einer sauberen Verlegung bei wenig Abstand zum Seitenteil, wäre ein zusätzlicher rechtwinkliger Adapter schon sinnvoll.
Ansichtssache. Ich finde es extrem, dass Nvidia bei einem so teuren Produkt, so einen schäbigen Adapter mitliefert, bei dem Brandgefahr besteht.
Geholfen wäre uns ja schon, wenn Nvidia damit eins auf's Maul bekommt und in Zukunft sich 2 mal überlegt, ob sie ihre Kunden minderwertigen Zubehör dazugeben.
Ja, ein schneller Austausch seitens Nvidia ist geboten. Allerdings hat Nvidia die, von diesem vulgären Adpater ausgehende Gefahr billigend in Kauf genommen und das muss Konsequenzen haben. Sorry.
Bei meiner Karte war nur ein "Dreizack" dabei, weil ich ein Standardmodell habe (Phantom ohne "GS").
Dann kann ich doch sicher, wenn ich den rechtwinkligen Adapter bestelle, auch direkt ein 12VHPWR auf 4x8 Pin Kabel bestellen/verwenden, nehme ich an? Dann verteilt sich die Last besser, so mein Gedanke.
Ich würde jetzt warten, wie die Verantwortlichen auf den Befund von Igor reagieren.
Ich schätze, die werden ziemlich schnell eine neue Kabel-Peitsche entwickeln. Insbesondere weil die demnächst erscheinende 4090ti noch ein Stück brandgefährlicher ist. :)
Ich schätze die Abwicklung läuft dann über die Board Partner, du wirst deine SN iwo eingeben müssen und dann bekommst gratis einen neuen Adapter zugeschickt.
Hoffentlich wird das wirklich so ablaufen. Nach Igors Video ist mir beim Gedanken schon bisschen mulmig, diesen Adapter jetzt mindestens zwei Jahre zu benutzen.
Ich dachte die 4090 Ti ist vom Tisch, da die Komponenten vom PCB tropfen, nein?
Korrekt, bzw. du hast mehr Spielraum, 4x150 Watt, falls du alle 4 Stecker nutzt, ich schätze mit dem 4 Pin-Kabel kannst dann auch das Powerlimt im Afterburner erhöhen.
Bin ja kein großer Fan vom Igor, aber das Video hat mal Licht ins Dunkel gebracht.
Naja, wenn der erstmal steckt und auf den Stecker kein Druck ausgeübt wird, dann ist man wohl recht safe... also ich hab meinen mit Kabelbinder entlastet und mach mir erstmal keine Platte.
Die neuen Adapter müssen erstmal produziert werden und bevor Nvidia das nicht veranlasst, passiert erstmal gar nichts.
Ich bin gespannt, wie lange das dauert.
Das möchte ich eigentlich gar nicht. Ich undervolte da lieber. Mehr als 400 Watt darf/soll die Karte bei mir nicht ziehen.
Man fühlt sich einfach sicherer, wenn da pro Kabel nur 100 Watt statt 133 Watt durchgejagt werden. ^^
Genug Anschlüsse am Netzteil habe ich eh.
Sammelklage an Nvidia wäre nicht schlecht.
Wird es definitiv geben, in den USA halt. Da kannst du Gift drauf nehmen :asthanos:
Ich wäre schon froh, wenn andere Hersteller außer Be Quiet ein Kabel anbieten, am besten natürlich gleich mit 90 Grad Stecker.
Seasonic zb kündigt zwar alles an, es dauert aber immer ewig bis da dann auch tatsächlich was kommt...
Ja, selbst wenn sie das veranlassen, kann sich das sicher gut und gerne bis zum Frühjahr hinziehen. Da hängt ja ein riesiger Rattenschwanz dran.
Dann investiere ich doch lieber selber die ~40-50€ bei Cable Mod, selbst wenn mir das Nvidia bzw. mein AIB in einem halben Jahr kostenlos zusenden würde und bin jetzt schon "safe".
Nichts außergewöhnliches in der heutigen Zeit.
Es muss schnell und billig produziert werden. Was sollen denn Mercedes Kunden sagen bei 40-120.000 € Fahrzeugen mit Brandgefahr und ständigen Defekten oder Rückrufe. Wird ja trotzdem gekauft..
Die Methode vom Bauer, einfach das PT zu reduzieren, ist Quatsch in meinen Augen, dann springt Spannung mehrmals die Sekunde rum.
Lieber Undervolten wie gehabt. Auf 1% kommt es dann auch nicht mehr.
Ich glaube derBauer ist schon lange genug im Geschäft und ein absoluter Vollblut Profi, dem vertraue ich dann doch eher als einem 0815 Dude aus dem Netz, oder was genau sind deine Referenzen? :sneaky:
#nohate
Ähnliche Themen
Antworten
7K
Aufrufe
586K
