[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das war genau falsch herum dann.
Liefern sie, hast Du ohne Angabe von Gründen das Recht zurückzugeben.
Holst Du ab, ist der Kauf final.
Ähm nein. Wenn du die Karte ONLINE bestellst ist es egal ob die Karte geliefert wird oder du sie vor Ort abholst. Es bleibt immer noch eine Onlinebestellung. Nur wenn du den Kauf vollständig vor Ort durchführst. Dh. du fährst in den Laden ohne Bestellung, gehst rein, sagst du willst die 4090 und kaufst sie dort, dann hast du kein Widerrufsrecht.
@rückgabe bei nbb
rückgabe in den ersten 14 tagen ab kauf ist kein problem. kack egal ob du hendi-fan und online-shopper oder einfach nur durchlaufkunde im laden bist.
im grunde bedienen die verkäufer/innen im laden auch nur den onlineshop im browser.
tobi
  • Danke
Reaktionen: bRv
Das hab ich so noch nie gehört und bin zu faul es nachzuprüfen, ... aber im Zweifelsfall würde ich keinem Laden außer Amazon trauen dabei.
Alles so im Bereich +1000-1500 scheint Standard zu sein bei dem was ich gelesen habe . 1500 mhz bekomme ich durch den bench , aber ist nicht stable.
Die Chips scheinen alle so + 250 mhz vom Stock wert zu können .
Unter Wasser gehen dann wahrscheinlich paar MHZ mehr und der Vram sollte auch etwas stabiler dann laufen , aber das wäre so Luft Bereich 50-60•C GPU Temps bei den meisten Kühler und aufgedrehte Lüfter .
Das wäre auch ziemlich genau meine Einschätzung der aktuellen Situation.
Die Taktrate ist trotzdem 90% der Zeit höher als mit Curve UV bei gleichem Verbrauch. Der Algorithmus von ADA arbeitet da hervorragend. Sieht man doch auch an deinen Testergebnis, höhere Punktzahl bei praktisch gleichem Verbrauch.
Wenn ich das Powerlimit nicht ausnutze, z.B. weil ich bei mir mit 120 FPS in den Vsync laufe, geht der Verbrauch natürlich deutlich runter aber auch der Boost maximal hoch. Das funktioniert hier schon sehr gut und auch anders als UV auf der Ampere mit fixer Spannung und Takt.
Mein Vorgehen bisher ist also den maximalen OC ausloten. Da schaffen mit 1.1v fast alle karten +250 gpu und +1000-1500 mem. Dann halt nur noch das PT senken.
Fast, aber nicht ganz. Entscheidend ist, dass der Kaufvertrag online zustande kommt, um die Möglichkeit zum Wideruf zu haben, Abholung und Bezahlung können dabei vor Ort geschehen.
Viele Händler umgehen die gesetzlichen Regelungen zu Crosschannel-Verträgen aber, indem sie dem Kunden die Ware lediglich online reservieren. In dem Fall kommt der Abschluss des Kaufvertrags erst vor Ort zustande, womit das Recht auf Widerruf verfällt.
Da hast du recht, hier ging es jetzt um NBB. Aber ja, bei sowas muss man grundsätzlich die Augen offen halten. Wenn man aber direkt online bezahlt, dann sollte das ne sichere Sache sein.
So, nächste Woche mal rausfinden, welcher DHL Mitarbeiter meine FE eingesteckt hat und deswegen verprügelt werden will. (y)
Ich versuche das positiv zu sehen, immerhin gilt das FAG erst up Erhalt der Ware. Bis dahin hat Lisa ihre GPUs vorgestellt und wenn sie nen Burner sind, dann kann mich noch entscheiden ob ich die FE behalte sollte sie überhaupt hier ankommen. (y)
Ich versuche das positiv zu sehen, immerhin gilt FAG erst up Erhalt der Ware. Bis dahin hat Lisa ihr GPUs vorgestellt und wenn sie nen Burner sind, dann kann mich noch entscheiden ob ich die FE behalte sollte sie überhaupt hier ankommen. (y)
Ich sehe hier keinen Fehler...du kommst doch aus Wien...
Normalerweise dauert es nicht 1,5 Tage von Regensburg bis nach Wien, das sind 400km. Eigentlich hätte die Shice letzte N8 in Wien ankommen sollen, normalerweise schafft DHL ca 600km pro Tag (wie alle anderen auch per Landweg), oder zumindest in nem Zwischenlager, ev in Linz, hätte das Teil landen können, warum auch immer. (y)
Scheinst krass hinterm Mond zu wohnen. Die ganzen Medien waren voll die letzten Wochen, dass DHL aktuell völlig überlastet ist aufgrund von Mitarbeiter Mangel. Auch meine Paketlaufzeiten waren diese Woche oft anstatt 1 Tag 2-3 Tage.
meine gpu ist angekommen*-*
hat jemand die gigabyte rtx 4090 gaming oc im betrieb? wie macht sie sich so?
Ich habe diese Karte seit Freitag im Rechner. Bin sehr zufrieden. Hatte am Releasetag eine Asus Rog Strix OC abbekommen, die war aber deutlich schlechter. Die hatte so extremes Spulenfiepen ab schon unter 50Fps das ich sie als Defekt zurückgeschickt habe. Der Chip ging auch nur so bis 2950. War denke ich das berühmte Montagsgerät. Die Gaming OC ist in Sachen Spulenfiepen sehr angenehm, geht eigentlich erst hörbar los ab über 200FPS. Dann aber in einer Frequenz die noch mehr oder weniger unter geht zwischen dem Rest an Geräuschen im PC. Erst ab 300FPS wird es dann deutlicher hörbar. Für mich so voll in Ordnung, in dem Bereich der täglichen Nutzung nichts zu hören. Der Chip geht nach ersten Versuchen bis über 3100. Lüfter stehen aktuell noch auf Auto, kann man ja noch nach eigenen Bedürfnissen anpassen. Temps sind auch alle voll im grünen Bereich. Die Karte hat etwas wenige Bling Bling als andere, aber von der Leistung ist alles OK.
Das ist die Antwort vom MSI Support auf meine Anfrage, ob sie ein 600W BIOS rausrücken…
Naja.
PNY bei Amazon (vor)bestellbar mit Lieferung Mitte Nov für 2211.
ASIN B0BG93V9GW
Soll Referenz sein.
E. Schon wieder weg.
Das hört sich ja schon mal super an. Meine kommt morgen. Muss ich das Gigabyte Controllcenter dafür installieren oder frisst sich das auch so in den PC ein wie Armoury Crate. Hatte schon ewig nix mehr von Gigabyte, eher Asus. Die Aorus 1080ti hatte ich mal von denen, die läuft heute noch täglich bei einem Bekannten.
Ich hab die gigabyte 4090 gaming oc, läuft gut aber der mitgelieferte Adapter war defekt, zuviele Leitungen die zusammenführen, haben sich wohl unter dem schrumpfschlauch berührt. Der mitgelieferte ist ein 4x8 pin zu 12-V-HPWR. Das führte dazu das die Monitore im Betrieb ausgingen und die Lüfter aufgedreht haben und man einen Neustart machen musste und den Stromstecker platt drücken damit die Kontakte auseinander gehen. Hab mir einen 2x8 zu 12-V-HPWR gekauft und jetzt läuft alles ohne Probleme.
hast du spulenfiepen? ist die karte kühl. magst du mal erzählen?
DHL in Deutschland hat derzeit große Probleme, speziell Fahrer (nicht Zusteller). Da sind manch Pakete statt 2 Tage 5-6 Tage unterwegs...bzw liegen im Lager rum.
Ich habe dasselbe Problem mit Paketen für die Arbeit. Und bald kommt das Weihnachtsgeschäft...
ich habe bisher nur mit MSI Afterburner gearbeitet, von Gigabyte selber habe ich bisher nIchs installiert. Habe mich aber bisher auch nicht um die Beleuchtung der Karte gekümmert, weiß noch nicht ob man da spezielle Software brauch um da was zu steuern. Alles andere relevante geht mit dem MSI Afterburner würde ich aktuell vermuten.
Ich habe die Karte auch. Spulenfiepen hat meine so ab 200FPS. Wobei es erst ab ca. 300 FPS von der Lautstärke aus dem geschlossenen Gehäuse störend wird. Wobei das natürlich extrem subjektiv ist. Bis 200FPS braucht es auf jeden Fall das Ohr an der Karte um was zu höheren. Temps sind kein Problem, die Kühler sind riesig bei dieser Generation. Selbst mit Übertaktung wenn man grob die 600 Watt der Karte nutzt wird es nicht kritisch. Die Temps sollten denke ich generell kein Problem sein bei der 4090 wenn man einigermaßen Airflow im Gehäuse hat. Letztlich braucht man einfach Glück was den Chip angeht und das Spulenfiepen. Spulenfiepen haben vermutlich alle, ist nur die Frage wie stark ausgeprägt. Ich habe nicht den Eindruck das es da Unterschiede zwischen den Herstellern gibt, können alle betroffen sein.
Gibt's nen Test zum Spulenfiepen ich höre nämlich absolut 0 bei meiner ZOTAC Amp Extreme Airo.
