[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So Strix ist auch angekommen.
Bzgl. Spulenfiepen hatte eine TUF ganz am Anfang ohne fiepen dann eine Strix 3090 die ging auch garnicht noch schlimmer war aber die 6900XT ;-)
Netzteil tauschen hilft meist nicht… was ich aber schon hatte das es mit der Zeit Verschwunden ist.
Wenn die Asus das Problem wieder hat geht sie zurück. Die Suprim X 3090Ti unter Wasser hat auch Spulenfiepen.
Also in das Gehäuse würden fast 2 passen ;-)
Beim TX-1300 ist das passende Kabel mit dabei.
Beim TX-1300 ist das passende Kabel mit dabei..?
Lg
welche Pins muss ich am Mainboard Brücken um den pc ohne case zu starten?
Vorsicht: Das Video kann verstörende Bilder und Geräusche enthalten (Spulengeräusche und nicht entfernte Schutzfolien bei einer 4090 Strix):
Aber auch so halt trotzdem immer noch schwierig für einen Vergleich, wenn man nicht direkt ne andere Karte im gleichen Video hören kann.
:ROFLMAO:
Die nachnwenigen Sekunden oder Minuten weg sind. Nichtmal aufn Topf kannst gehen und die Karten sind weg bevor du dir den Hintern abgewischt hast.
Genau so hab ich die Zeit erlebt bis ich die erste 3000er hatte und danach bis zur strix. Immer saß gleiche Spiel. :)
und das ist diesmal nicht so, aber so hat jeder eben seine eigene wahrnehmung der dinge.
Ist aber ein Unterschied, ob die Karten quasi nach ein paar Sekunden verkauft sind und man ohne Bot chancenlos ist. Oder die Karten teilweise fast für eine Stunde lang ganz regulär kaufbar waren. Klar, je nach Menge ist das anfängliche Kontingent dann auch verkauft.
Aber aktuell stehen auch noch Karten von gestern auf EKA. Wenn der Run so riesig wäre und die Mengen so homöopatisch wie zum Launch der 3000er wären die ja längst alle weg.
Also einfach ein bisschen Geduld.
Yields dürften dank TSMC diesmal ja auch besser sein.
Mfg
Kiryu
Aktuell macht für mich keinen Unterschied ob die Karte 5 Sekunden oder 5 Minute verfügbar ist. Ich muss ja auch mal was arbeiten und kann nicht jede 2 mim aufs Handy glotzen.
Ich warte auf be alternate strix oder tuf oder suprim wegen pp. Aber sa kommt nix außer 1 bis 2 game rocks 😆
Ich habe mir nun extra ein Seasonic Netzteil gekauft damit ich nicht mit irgendwelchen Adaptern oder sonst was hantieren muss :ROFLMAO:
Habe gerade mal geschaut, das hat jemand getestet, das sind je nach game 4 - 6 FPS Unterschied bei der 4090
Danke für den Link!!
Ok, ist tatsächlich weniger dramatisch als ich gedacht habe. Aber ich glaube ein 4.0 Riser Kabel kostet ja nur 50.-€ ? Ich denke dann investiere ich die auch noch. Ich will einfach mal eine Grafikkarte vertikal einbauen :d
@MADman Kommt genauso aus China
Global company​
Sea Sonic is a truly global company. Headquartered in Taipei, Taiwan, we export our products from our factory in the mainland of China to our offices in the USA, Europe, as well as to other parts of the world.
Quelle: https://seasonic.com/about-us
Sorry, ich habe es mißverständlich formuliert, es ging mir nicht um China, ich meinte damit daß Seasonic selber baut und eigene Werke hat meines Wissens. Corsair z.B. baut keine Netzteile selber, da stecken verschiedende Auftragsfertiger dahinter, teilweise völlig unterschiedliche Firmen je nach Modell. Das AX1600i und AX1200i wurde meines Wissens von Flextronics gebaut während das HX1200i von CWT gebaut wurde, manche der kleineren AX Modelle von Corsair wurden sogar von Seasonic gebaut.
grüße in die runde sag mal jemand ne idee warum nvflash die gpu nicht erkennt ?! er sagt immer das dass device nicht vorhande ist egal welche version ich nehme.
Ich sehe. Alle paar Stunden mal ne Karte. 😅
Fühlt sich genauso an wie Oktober 2020.
Alternate leer, ck leer, mf leer
Warte mal auf nächste Woche und ab dem 3.11. wirst man mit Karten tot geschmissen.:giggle:
PC-Setup am Drop-Tag im WC aufbauen? :d
Die Gainward GS kam heute an. Da ich aber doch noch ne TUF ergattern konnte werd ich die Gainward wohl fürn Selbstkostenpreis abgeben, wenn sie kein Kumpl haben will. Ansonsten geht sie dann zurück. Bleibt natürlich auch OVP. Die TUF ist schon verschickt und kommt hoffentlich morgen inkl. meinem HDMI Kabel. Endlich wieder mehr als 60 fps und alle Games zocken können. 😍
WArum ab dem 3. November? Meines Wissens ist da erst die Vorstellung von AMDs RDNA3 mit Markeing Benchmarks, Verkauf startet erst im Dezember dachte ich.
@Holzmann Ob das wieder mit den "Krüppelkurven" zusammenhängt, wie bei Pascal? Er hat seine Curve zwar nicht gezeigt, aber die von seiner 3090 wäre bei Pascal absolut fürn A****.
War schon …
Auf der arbeit schwierig 😄 homeoffice kann ich erst in ein paar wochen machen wenn ich alle Rechte habe. Bin nur übers handy unterwegs
Deine Behauptung, dass alle Karten binnen Sekunden verkauft sind ist einfach quatsch. Alleine heute früh konnte man problemlos bei Caseking aus vier Modellen wählen, für mehr als 30 Minuten.
Mfg
Kiryu
Ich hab Sekunden oder Minuten geschrieben :)
Ups sorry ich dachte da wäre auch der Verkauf.:oops:
Na dann doch noch bis Dezember warten.😖
meine gs hat direkt lüfterschaden an einem lüfter -.-
Der für die Inno könnte drauf passen, wenn man die PCBs so Vergleich ist das alles nahezu identisch.
Beste Grüße
Erzähl mal bisschen was zur Gamerock, ist es die OC oder non Oc Version? Was macht sie so an Takt, was sind die Temps etc. Ist aktuell meine Favoritenkarte :)
