[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hmm, baue ich die Karte jetzt vertikal mit 3.0 Riser Kabel ein oder horizontal direkt am MB mit 4.0 :unsure:
Mit welchem Programm testet ihr denn überhaupt dieses Spulenfiepen?
Ich hatte bisher damit noch nie Stress. *kopfaufholz* Palit 1080Ti und Suprim 3080
High load. Je höher die fps bei high load desto hochfrequenter der Ton
Rocket League fps uncapped, alt Tab geht ganz gut
Was ist das rechts unten für eine Einsteiger-GPU? :d
Achso, das Case ist so riesig :fresse:
Was hast du da alles drin?
Was kommt alles rein … eigentlich ziemlich wenig.
Hab 2 Moras in separaten Keller Raum hab irgendwo schonmal ein Bild gepostet.
Aber werden Solls 13900K, Asus Z790 Extreme , Asus 4090 mit EKWB … wird aber ohne viel RGB Bling Bling sein.
Aber na ja bis das wieder soweit ist…. Dauert noch.
Wusste nicht so recht welches Gehäuse, wollte aber in jedem Fall wechseln. Offen gestanden vielleicht geht es vielen genauso das Perfekte Gehäuse gibts aktuell für mich zumindest nicht.
jedes % zählt, direkt am MB :)
Dachte ich mir auch gerade, wenn ich schon so unverschämt viel Kohle hinlege, will ich auch alles rauskitzeln.
Hat jemand ne Empfehlung für ein stabiles 4.0 Riser Kabel?
Weiß man zufällig wie viel % Unterschied das sind? :)
Habe gerade mal geschaut, das hat jemand getestet, das sind je nach game 4 - 6 FPS Unterschied bei der 4090
Die subjektive Wahrnehmung ist der Hauptgrund für die unterschiedlichen Berichte.
Deswegen würde ich mich hier auch ziemlich sicher nicht zur Lautstärke meiner Karte äußern, weil ich Zweifel hätte das es für jemanden einen Erkenntisgewinn brächte, es wäre eher irreführend. Mein Rechner ist trotz WaKü nicht auf leise getrimmt, ich zocke immer mit Kopfhörern und ich mag es wenn mein PC eine akustische Grundpräsenz im Raum hat ;) Ich habe noch nie irgendwo Spulenfiepen irgendwo aktiv wahrgenommen auch wenn mein Gehör nach wie vor gut genug ist um diese Frequenz zu hören, aber es hat für mich halt einfach nie den Nervfaktor den es für viele hier hat. Ich persönlich halte es für mich daher für nahezu ausgeschlossen daß ich eine Karte wegen Lärm zurückschicken würde. Daher will ich dann auch niemanden mit "meine Karte ist leise, kein Problem" am Ende unabsichtlich in die Irre führen.
Warum schwören hier eigtl so viele auf Seasonic? Hatte mir ein DP Pro 1500 geholt fürn komplett neuen Rechner, aber irgendwie sehe ich hier fast nur Seasonic Anhänger :fresse:
Das hat möglicherweise damit zu tun weil Seasonic meines Wissens einer der wenigen Netzteilhersteller ist, der auch wirklich herstellt, also seine Netzteile selbst baut. Die meisten anderen Marken die man so kennt lassen (in China) bauen. Das muss selbstverständlich nicht schlecht sein, die Chinesen können von billig bis technisch makellos quasi alles bauen (mittlerweile), es hängt aber halt davon ab, was jeweils gefordert wurde und welches Budget zur Verfügung stand. Gerade bei Corsair gab es dadurch zumindest in der Vergangenheit starke Schwankungen zwischen den Modellreihen, sodaß man Corsair nicht uneingeschränkt empfehlen konnte sondern genau schauen musste um welche Netzteile es jeweils geht. Bei Seasonic ist die allgemeine Qualität aber durchgehen sehr hoch, auch weil sie die volle Kontrolle über den Prozess haben. Jedenfalls ist das mein Kenntnisstand. Ich persönlich bin mit meinen beiden AXi Netzteilen von Corsair bisher sehr gut gefahren, die haben immer Bestnoten eingesammelt. Seasonic ist dagegen eine Marke die ich eher empfehle wenn es um eine Leistungsklasse geht, mit der ich mich nicht so genau auskenne bzw keine Zeit für genaue Hintergrundrecherche habe, da man mit Seasonic eigentlich kaum was falsch machen kann, zumindest ist die Wahrscheinlichkeit geringer.
Man braucht zb keine 700fps in Volarant. Treibt nur unnötig den Verbrauch hoch
Zum Benchen ok - zum Zocken unnötig
Wenn die 4090 also bei zb 300-400fps am Lautesten fiept, wäre es kein Grund sie rauszuschmeissen, wenn +144fps auch reichen
@MADman Kommt genauso aus China
Global company​
Sea Sonic is a truly global company. Headquartered in Taipei, Taiwan, we export our products from our factory in the mainland of China to our offices in the USA, Europe, as well as to other parts of the world.
Quelle: https://seasonic.com/about-us
Vorsicht: Das Video kann verstörende Bilder und Geräusche enthalten (Spulengeräusche und nicht entfernte Schutzfolien bei einer 4090 Strix):
Aber auch so halt trotzdem immer noch schwierig für einen Vergleich, wenn man nicht direkt ne andere Karte im gleichen Video hören kann.
Ich sehe. Alle paar Stunden mal ne Karte. 😅
Fühlt sich genauso an wie Oktober 2020.
Alternate leer, ck leer, mf leer
sehe ich anders, es tauchen permanent karten in shops auf.
war aus meiner erinnerung 2020 nicht so.
und wenn man golem trauen darf, haben die shops deutlich mehr karten zum start erhalten als bei ampere.
Korrekt. Man hat die fps ja in der regel eh auf 2 unter monitorfreq gecapped und wenns bis dahin ok ist , kann sie bleiben
+4-6fps nimmt man gerne mit - zum Benchen. Aber ist bei Gaming nicht spürbar
Ja ist dann wirklich nur eine reine Min-Max-Geschichte
Das war übrigens für 1440p was denke ich kaum einer mit ner 4090 machen würde, bei 4k sinds nur noch 3-4 FPS
Die nachnwenigen Sekunden oder Minuten weg sind. Nichtmal aufn Topf kannst gehen und die Karten sind weg bevor du dir den Hintern abgewischt hast.
Genau so hab ich die Zeit erlebt bis ich die erste 3000er hatte und danach bis zur strix. Immer saß gleiche Spiel. :)
Trotzdem ausverkauft. Und nun
Ist aber ein Unterschied, ob die Karten quasi nach ein paar Sekunden verkauft sind und man ohne Bot chancenlos ist. Oder die Karten teilweise fast für eine Stunde lang ganz regulär kaufbar waren. Klar, je nach Menge ist das anfängliche Kontingent dann auch verkauft.
Deine Behauptung, dass alle Karten binnen Sekunden verkauft sind ist einfach quatsch. Alleine heute früh konnte man problemlos bei Caseking aus vier Modellen wählen, für mehr als 30 Minuten.
Aber aktuell stehen auch noch Karten von gestern auf EKA. Wenn der Run so riesig wäre und die Mengen so homöopatisch wie zum Launch der 3000er wären die ja längst alle weg.
Also einfach ein bisschen Geduld.
Yields dürften dank TSMC diesmal ja auch besser sein.
Mfg
Kiryu
Ähnliche Themen
Antworten
7K
Aufrufe
584K
