Domdtxdissar
Profi
Little comparison between 5800x3d @ 4550/4450mhz with ~4066MT/s memory and 5950x @ ~5200/5050mhz with ~4000MT/s memory
No way around it, in these memory benchmarks cpu clockspeed is still king in everything except in PYprime
(dual CCD with twice the cores and much higher write bandwidth also helps
Did also some Geekbenches but results seem to be all the place, not really sure why
Geekbench3 - Single Core - 7390 points, Multi Core - 86068 points (ST and especially MT seems to be too low)
Geekbench4 - Single Core - 8104 points, Multi Core - 62264 points (Normal ST, MT score way to low)
Geekbench5 - Single Core - 1859 points, Multi Core - 17831 points (good ST, MT score way to low)
Think I have to do some more runs to figure out what's going on here.. Could be down to whea throttling above 1900:3800 in the MT tests.
5800x3d
SuperPi - 1M with BenchMate - 7sec 686ms - Ryzen 7 5800X3D @ 4567.2MHz
SuperPi - 32M with BenchMate - 6min 4sec 610ms - Ryzen 7 5800X3D @ 4567.2MHz
PYPrime - 2b with BenchMate - 8sec 397ms
y-cruncher - Pi-25m - 0sec 501ms - Ryzen 7 5800X3D @ 4461.1MHz
y-cruncher - Pi-1b - 32sec 75ms - Ryzen 7 5800X3D @ 4461.1MHz
y-cruncher - Pi-2.5b - 1min 32sec 459ms - Ryzen 7 5800X3D @ 4450MHz
wPrime - 32m with BenchMate - 2sec 340ms - Ryzen 7 5800X3D @ 4461.4MHz
wPrime - 1024m with BenchMate - 1min 4sec 98ms - Ryzen 7 5800X3D @ 4466.8MHz
7-Zip - 105612 MIPS - Ryzen 7 5800X3D @ 4467MHz
PiFast with BenchMate - 17sec 400ms - Ryzen 7 5800X3D @ 4567MHz
Full 32 gigs used in all benchmarks -> no maxmem used
5950x
SuperPi - 1M with BenchMate - 6sec 696ms - Ryzen 9 5950X @ 5213.3MHz
SuperPi - 32M with BenchMate - 5min 32sec 276ms - Ryzen 9 5950X @ 5213.4MHz
PYPrime - 2b with BenchMate - 9sec 779ms
y-cruncher - Pi-1b - 20sec 433ms - Ryzen 9 5950X @ 4775.2MHz
y-cruncher - Pi-2.5b - 58sec 362ms - Ryzen 9 5950X @ 4750.2MHz
wPrime - 32m with BenchMate - 1sec 486ms - Ryzen 9 5950X @ 5059.6MHz
wPrime - 1024m with BenchMate - 29sec 504ms - Ryzen 9 5950X @ 5034.5MHz
7-Zip - 205233 MIPS - Ryzen 9 5950X @ 4950.1MHz
PiFast with BenchMate - 15sec 170ms - Ryzen 9 5950X @ 5234.9MHz
Full 32 gigs used in all benchmarks -> no maxmem used.
