[Sammelthread] ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
ROG Strix X570-E Gaming
ROG Strix X570-E Gaming Wifi II
ROG Strix X570-F Gaming
ROG Strix X570-I Gaming
BIOS/UEFI Versionen
Reviews & VRM
Häufig gestellte Fragen
BIOS Mods
ChangelogDownload
Flashing and using on your own risk!
  • Added VDDP Voltage
    Might be helpful for CPU overclocking
  • Added ASPM Support (Should be visible by default since v4802)
    PCIe Energy Saving
  • Added Erp Ready (Strix-E only)
    Energy Saving
  • Unlocked AMD PBS
    Hidden options unlocked
  • Added PCH Temerature
    Shows the PCH Temperature in the Bios
  • Added PCH Fan Control
    Gives you control over the PCH Fan
  • Advanced (Pump) Fan Settings
    Min and Middle Duty Cycle can be changed to 0%
  • Added Advanced Boot Settings
    Might be helpful for faster boot
Strix X570-E Gaming
Download Folder
Download Folder
Strix X570-F Gaming
Download Folder
Strix X570-I Gaming
EOL
CPUAMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
ChipsetX570
Memory3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
GraphicIntegrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots3rd Gen AMD Ryzen™ Processors
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LANIntel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
BluetoothBluetooth® 5.0
AudioSupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
AccessoriesUser's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form FactorATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
Bios Version 0807
AiTweaker
Advanced
Monitor
Boot
Tool
Kompatibilitätsliste
Memory QVL Ryzen 3000/4000/5000
Chipsatz Modding
Alternativer Chipsatz Kühler von KCX
ROG Strix X570-E Gaming WIFI II
Produktseite | Handbuch (EN) | Support-Downloads | Preisvergleich
CPUAMD Ryzen™ 5000 Series/ 5000 G-Series/ 4000 G-Series/ 3000 Series/ 3000 G-Series/ 2000 Series/ 2000 G-Series Desktop Processors
ChipsetX570
MemoryAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic1 x HDMI 2.0
1 x DisplayPort
Expansion SlotsAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
StorageSupports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFiWi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
BluetoothBluetooth® v5.2
AudioRealtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB PortsAMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special FeaturesExtreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O PortsFan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
AccessoriesCables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
Full Specs:
ChipsetX570
AMD X570 chipset
2 x PCIe 4.0 x1
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
Anti-surge LANGuard
Audio Feature :
- Sonic Radar III
USB Ports3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
1 x Supporting DVD
Chipsatz Modding
Wasserkühler von Neo111430
ChipsetX570
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
LANIntel® I211-AT
Anti-surge LANGuard
WiFiSupports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
Form FactorMini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
  • Sound setzt aus oder knistert
    Immer wieder USB Disconnects
    Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
  • USB Disconnects
    Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
    UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
    Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
  • USB Flashback funktioniert nicht
    Bitte folgende Punkte ausprobieren:
    - Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
    - Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
    - Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
  • BIOS/UEFI Downgrade
    Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
  • Ist der Chipsatz Lüfter regelbar?
    Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
  • Chipsatz Temperatur zu hoch?
    Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
    Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
  • Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
    Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
  • Rechner bootet nicht, wenn eine Soundkarte verbaut ist
    Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
ja sind gelistet und selbst ohne XMP läuft es nur mit Spannungserhöhung, was ja nicht sein darf...
Also meine Hynix C-Die (G.Skill Sniper X) brauchen für das serienmäßige XMP Profil (3600 MHz) mindestens 1,38 - 1,4 Volt zum starten.
So viel zu Theorie und Praxis.
@base1900
Nur um sicher zu gehen, die RAM Riegel stecken in den Slots 2 und 4 von der CPU aus gesehen?
Jap habe es auch mal nur mit einem Riegel probiert. Mein Problem ist halt aktuell, dass es schwer ist einzuschätzen ob der IMC vom Prozessor einfach Schrott ist oder das Mainboard/BIOS.
Bei vielen hier läuft das Ding ohne große Probleme und ich bekomme gerade so das Ding zum Booten mit 1.35V bei 2166 MHz... Und das mit zwei verschiedenen Kits getestet.
Habe bei AMD schon einen RMA Antrag gestellt. Finde es sehr schwach, wenn das Ding nicht ohne manuelles Overvolting läuft mit Speicher der offiziell freigegeben ist.
Zum Thema Chipsatzkühler habe ich beim Test auf hardwareinside.de eine interessante Anmerkung gelesen:
Wir müssen darauf hinweisen, dass sich das Verhalten des Chipsatzkühlers auch anders verhalten kann. Sobald wir eine größere Grafikkarte verbauen kann sich das negativ auf die Temperaturen und Lautstärke des Chipsatzkühlers auswirken. Wird eine Triple Slot Grafikkarte im ersten Slot verbaut, so ist der Chipsatzkühler vollständig verdeckt und dementsprechend wird es für den Chipsatzkühler schwieriger den Chipsatz zu kühlen. Des Weiteren kann die Grafikkarte den Chipsatzkühler zusätzlich aufheizen.
Das klingt auch logisch, diese Karten überdecken den Slot und der Kühler ist an der Stelle offen, so dass die warme Abluft der Grafikkarte direkt in den Chipsatzlüfter kommt.
Einen Versuch wäre es da wert, einfach die Öffnung des Kühlers an der Stelle mit Tesa abzukleben und dann die Temperaturen bzw den Lüfter beobachten. Die Luft kann ja immer noch an der anderen Seite raus.
Mit einer WaKü sollte das demnach nicht so sein, da damit keine Warme Abluft im Gehäuse bzw über dem Chipsatz entsteht.
Meiner ist durch die Grafikkarte verdeckt, meiner dreht auch ordentlich auf und trotzdem hör ich das Ding nicht aus dem Gehäuse heraus. Selbst im Idle nicht, wenn CPU und Gehäuselüfter mit ca. 600 UPM werkeln.
Meine GPU (original Lüfter) ist vertikal verbaut und die Gehäuse Lüfter nicht weit entfernt. Da geht also nix "direkt" drauf an warmer Luft. Trotzdem sehe ich hin und wieder 65°C und ca. 3000RPM. Hab auch schonmal die Plastikabdeckung abgenommen aber konnte nicht wirklich eine Verbesserung feststellen. Das Pad gegen WLP tauschen werde ich noch machen - aktuell aber kein B alles auseinanderzubauen.
Sowas müsset man kaufen können:
Leider habe ich so ein Werkzeug nicht und kenne auch niemanden :cry:
Die Plastikabdeckung braucht der Lüfter, da der Radiallüfter sonst den Luftstrom nicht auf die wenigen Finnen richten kann.
Wenn du das Pad gegen Wärmeleitpaste austauschst, achte auf dem Abstand vom Kühler zum Chip. Das Pad hat eine gewisse Dicke.
  • Danke
Reaktionen: KCX
Hatte ich beim Crosshair auch schon überlegt, jedoch muss man gut 1mm überbrücken, das wird mit WLP nichts.
Man müsste den Kühler dichter dran bekommen, dann geht WLP
  • Danke
Reaktionen: KCX
Wenn mir der Kühler tatsächlich zu laut ist, dann kommt da sowas drauf:
Passende Löcher kann ich mir da reinbohren + dünner schwarzer Lack drauf. Kühlt sicher doppelt so gut wie das Ding von Asus.
  • Danke
Reaktionen: KCX
Am besten noch jeweils einzeln zuerst im zweiten und dann nochmal jeweils beide im vierten Slot testen. Kannst du bei allen 4 Möglichkeiten kein XMP laden? Auch schon mal mit dem 2802 Bios probiert?
Ja hab auch einen Stick in verschiedenen Slots getestet. Wenn ich 1.35 Volt dran einstelle bekomme ich max 2166mhz hin. Aber auch nur bei dem crucial kit. Bei den trident z geht's damit auch nicht. Also schmiert mit bluescreen ab.
Kann hier jemand die schlechte Performance mit dem Asus Strix X570-I Gaming + Ryzen 5000 bestätigen?
Das PC Build ist auf Truoble ausgelegt. Nicht nur das sein 750W Corsair NT zu schwach auf der Brust ist nein auch die AIO kann nicht atmen weswegen der 5950x nicht über die 3,8GHz Allcore gehen dürfte, Tempproblem. Dazu kommt das er ein PCIe 3.0 Rizerkabel benutzt. Die GPU meldet ans Board 4.0 das Bord läuft unter 4.0 nur das Rizerkabel spielt nicht mit. Klar kann er es manuell ändern aber was er bemängelt, natürlich stellt das Board wieder auf 4.0 wenn er das Bios zurücksetzt. Logisch oder? Dann muss er halt für die Settings eine PCIe 3.0 Karte einsetzen, ist halt so.
Ist zwar nett das er mit dem NT und dem kleinen Case die 3090 lauffähig bekommen hat aber sie so weit zu drosseln das sie Leistungstechnisch unter einer 3080 liegt nur damit die Konfig läuft, ich weiß nicht.
Zuminmdest ist er ehrlich sagt das es eher weniger sinnvoll ist, ich würde aber nicht von einem Problem beim 570 Strix-I ausgehen.
Das Problem ist selbstgemacht, weil bei der Konfig einfach zuviel unstimmig ist.
Ich hab eine ähnliches verhalten mit meinen 5900x und dem Asus Strix x570-e Gaming.
Was heißt denn schlechte Performance?
Kann man das in Worte fassen, was er im Video feststellt? Habe eigentlich jetzt keine Lust extra dafür das Video zu schauen.
Er bekommt das Sytem halt nicht gekühlt und somit taktet der 5950X nur 3,8GHz Allcore und bringt nicht die CB Werte wie erhofft. Das Case in dem er das System verbaut hat ist fast schon zu klein für das ITX Board, dazu hat er noch eine 3090 mit reingestopft und nur ein 750W NT.
@Jonkie wie warm wird denn dein 5900X? Wie kühlst du Ihn?
Schlechte Performance ist auch ein wenig übertrieben, allerdings schaffe ich mit meinen 5900x stock mit PBO im CB R20 "nur" 610 und im Multicore 8100 Punkte. Und Kühlung sollte bei mir nicht das Problem sein. Er beschreibt im seinem video das er auf zwei Asus Boards schlechtere werte erreicht als auf seinem MSI Board.
Ich habe ne Custom WAKÜ mit 2x 360er Radiator und einem EKWB Monoblock
Teste mit Prime 95 und lass nebenbei HWINFO64 laufen. Schau wie sich die Temps entwickeln und welche Taktraten dein CPU dann fährt. Mach Screenshots davon und poste sie hier.
Schau auch wieviel offenen Programme nebenbei Leistung ziehen wenn du bencht, versuch alle unwichten zu schliessen.
8auer hatte auch auf einem ASUS Board getestet und Bestwerte bekommen. Gut es war ein Crosshair, ich glaube aber nicht das die Strixx so viel schlechter sind.
Das Problem hat nichts mit Temperaturen zu tun. Sagt er auch hier:
Wenn ich es richtig verstehe hat er auch mit dem 5900 X getestet und trotzdem schlechtere Werte als mit einem MSI Creation Board. Das scheint also am Board zu liegen.
mache ich heute Abend bin @WORK. Wird aber relativ warm das kann ich dir jetzt schon sagen ca. 80-85°
Die Frage wäre halt ob er den 5900X dann wenigstens im offenen Aufbau getestet hat oder ob er den wieder in das Minicase ohne Luftzufuhr gequetscht hatte. Ich selber kann aber nur erahnen wo das Problem lag da ich leider keinen 5000er abbekommen habe ;).
Die Aussagen bezüglich Ursache zu kleines Netzteil, zu wenig Kühlung usw. sind einfach falsch. Es liegt am Board/Bios mit stocksettings. Der Allcoreboost ist niedriger als bei anderen boards. Mit PBO on ist alles vergleichbarer.....
Kann genau das aus dem Video bestätigen! Abwarten auf neue Bios oder PBO anmachen...der normale SC boost ist da!
Einfach falsch ist auch relativ, denn daas er sich bei 90°C runtertaktet ist auch normal. Kann duraus sein das die Allcoretaktwerte auf den Strixxbrettern niedriger sind nur lässt sein Video keinen wirklichen Schluß darauf zu. Hätte er einen offenen Aufbau gehabt wäre es eindeutiger gewesen.
Nope - tut bei mir einwandfrei.
Details kann ich liefern wenn ich wieder zuhause bin heut Abend.
Ich habe zwar nur einen 3900X, mit Bios 2802 auf Strixx-E läuft er gut. Mich würde es wundern wenn die 5000er so einbrechen aber nichts ist unmöglich.
CB20 SC ausm Kopf raus 636, AC wie in den Reviews mit +100MHz Override, ohne PBO und Fmax. RAM auf 3600 CL16, BIOS 2813 beta
[edit] hab was gefunden
HWInfo zeigt SC 4950MHz, effektiv ~4850, AC 4500MHz, Temps mit Scythe Fuma 2 bei 86°C
  • Danke
Reaktionen: KCX
Danke für deine Idee, bei AliExpress gibt es wirklich so einiges was infrage käme 👌
Schwierig. Man müsste jetzt CPU und Board gegen testen. Für die CPU hast du ja bereits RMA beantragt, wenn ich das richtig im Kopf habe? Dann würde ich erst einmal abwarten wie es mit der neuen CPU ist.
Ich persönlich glaube, dass Asus noch ein paar Probleme mit dem BIOS bei Zen-3 CPUs hat. Hatte mal diverse Online Tests verglichen und die durchschnittliche Punktzahl auf Asus Boards war zumindest in diesen Tests geringer als auf MSI Boards.
Hatte dazu was in meinem Thread geschrieben.
Ob das stimmt oder ob ich mir das einbilden steht auf einem anderen Brett und ich will absolut keine Pferde sscheu machen.
Mein 5900x auf meine Strix-e boostet @Stock auch nicht so prall, obwohl die CPU recht kühl bleibt (CB 63 bis 65 Grad).
Dafür ist bei mir der Unterschied mit Pbo on / off extremer als zum Beispiel beim Test von Computerbase.
Wie gesagt, kann das natürlich auch andere Ursachen haben.
Ich persönlich glaube, dass Asus noch ein paar Probleme mit dem BIOS hatHatte mal diverse Online Tests verglichen und die durchschnittliche Punktzahl auf Asus Boards war zumindest in diesen Tests geringer als auf MSI Boards.
Ich hoffe er nutzt nicht Fmax...
PBO nutzt dem 5900x weil der hart in die Limits läuft. Mein 5800x läuft mit PBO schlechter.
