[Sammelthread] ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
ROG Strix X570-E Gaming
ROG Strix X570-E Gaming Wifi II
ROG Strix X570-F Gaming
ROG Strix X570-I Gaming
BIOS/UEFI Versionen
Reviews & VRM
Häufig gestellte Fragen
BIOS Mods
ChangelogDownload
Flashing and using on your own risk!
  • Added VDDP Voltage
    Might be helpful for CPU overclocking
  • Added ASPM Support (Should be visible by default since v4802)
    PCIe Energy Saving
  • Added Erp Ready (Strix-E only)
    Energy Saving
  • Unlocked AMD PBS
    Hidden options unlocked
  • Added PCH Temerature
    Shows the PCH Temperature in the Bios
  • Added PCH Fan Control
    Gives you control over the PCH Fan
  • Advanced (Pump) Fan Settings
    Min and Middle Duty Cycle can be changed to 0%
  • Added Advanced Boot Settings
    Might be helpful for faster boot
Strix X570-E Gaming
Download Folder
Download Folder
Strix X570-F Gaming
Download Folder
Strix X570-I Gaming
EOL
CPUAMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
ChipsetX570
Memory3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
GraphicIntegrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots3rd Gen AMD Ryzen™ Processors
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LANIntel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
BluetoothBluetooth® 5.0
AudioSupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
AccessoriesUser's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form FactorATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
Bios Version 0807
AiTweaker
Advanced
Monitor
Boot
Tool
Kompatibilitätsliste
Memory QVL Ryzen 3000/4000/5000
Chipsatz Modding
Alternativer Chipsatz Kühler von KCX
ROG Strix X570-E Gaming WIFI II
Produktseite | Handbuch (EN) | Support-Downloads | Preisvergleich
CPUAMD Ryzen™ 5000 Series/ 5000 G-Series/ 4000 G-Series/ 3000 Series/ 3000 G-Series/ 2000 Series/ 2000 G-Series Desktop Processors
ChipsetX570
MemoryAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic1 x HDMI 2.0
1 x DisplayPort
Expansion SlotsAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
StorageSupports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFiWi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
BluetoothBluetooth® v5.2
AudioRealtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB PortsAMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special FeaturesExtreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O PortsFan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
AccessoriesCables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
Full Specs:
ChipsetX570
AMD X570 chipset
2 x PCIe 4.0 x1
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
Anti-surge LANGuard
Audio Feature :
- Sonic Radar III
USB Ports3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
1 x Supporting DVD
Chipsatz Modding
Wasserkühler von Neo111430
ChipsetX570
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
LANIntel® I211-AT
Anti-surge LANGuard
WiFiSupports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
Form FactorMini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
  • Sound setzt aus oder knistert
    Immer wieder USB Disconnects
    Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
  • USB Disconnects
    Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
    UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
    Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
  • USB Flashback funktioniert nicht
    Bitte folgende Punkte ausprobieren:
    - Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
    - Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
    - Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
  • BIOS/UEFI Downgrade
    Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
  • Ist der Chipsatz Lüfter regelbar?
    Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
  • Chipsatz Temperatur zu hoch?
    Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
    Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
  • Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
    Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
  • Rechner bootet nicht, wenn eine Soundkarte verbaut ist
    Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
Hey einmal eine frage an die experten :)
ich erreiche stock und bios default bei CB 20 um die 5733 Punkte mit dem ryzen 5800x /trident z neo 3600 cl16 D.C.O.P. (asus strix x570-e) bios 2802X
sobald ich im bios fmax/ boost overdrive lvl 2/ fbo oder sonstiges aktiviere verliere ich fast 1200 bis 1600 punkte.
sobald ich diese aktiviert habe und CB laufen lasse klettert die cpu nur bei 3,9ghz wenn ich alles ausstelle dann zwischen 4,5 bis 4,7
woran könnte das liegen oder muss ich dazu noch was anderes umstellen?
... weil mein B550-I die Funktion hat. Das geht jedoch zurück, der verbugte Intel NIC I225 macht nur Probleme, trotz aktualisierten Firmware und Treiber. Danke fürs Feedback :)
Da muss ich doch mal nachfragen. Welche Probleme hast Du konkret?
Bei mir steht ein System mit B550-E (Hauptrechner) neben einem mit X570-E.
Das B550-E ist wie bei Dir mit einem "Intel® I225-V 2.5Gb Ethernet port" ausgestattet.
Das X570-E hat einen "Intel® I211-AT, 1 x Gigabit LAN Controller" und zusätzlich den "Realtek® RTL8125-CG 2.5G LAN". Ich nutze da den Intel, weil ich am Switch ingesamt nur zwei schnelle Ports habe und die verbinden i.d.R. das B550-E mit dem NAS).
Ich habe mit beiden Rechnern das Problem, dass die "Energie sparen"-Funktion, also Suspend-to-RAM, überhaupt nicht funktioniert. Eher früher als später wachen diese PC wieder auf, mitunter direkt nach dem aktivieren des Standby. Echt nervig und so noch bei keinem PC/Notebook zuvor beobachtet.
Windows?
Probier mal:
powercfg /lastwake
powercfg /devicequery wake_armed
powercfg /waketimers
oder Event Viewer:
Event Viewer > Windows Logs > System > Right Click: Filter Current Log > Event Sources : "Power Troubleshooter"
Danke Dir.
Habe das eben mal auf dem B550-E gemacht.
Ich sehe keine Auffälligkeiten.
bzw. der Filter schreibt nur: "Reaktivierungsquelle: Unbekannt".
Ich hänge das Log der letzten 100 Einträge mal an.
  • Event-Log Windows System gefiltert Power-Troubleshooter.txt
Erst einmal nur für das Strix-E
läuft soweit super. Habe niederigere temps auf dem CPU, dabei etwas mehr punkte in CB.
Die soc spannung wurde als stock setting um 0,075 auf 1,025 gesenkt.
Lässt sich ohne Probleme flashen und habe wieder die Chipset temp als Temp richtwert zur verfügung ( ging beim vorherigen auch nach mehrmaligen flashen nicht)
Mal eine ganz andere Sache: hätte jemand Interesse daran, Overclocking über die Command line zu betreiben? Das Command Line Interface bietet 206 API Zugriffe, teils zum Abfragen von Werten, teils zum setzen.
Klingt nach einer Windows Version vom "Dynamic OC Switcher" 😁
Falls für unsere Boards etwas derartiges nicht vorgesehen ist, wäre es denke ich eine Überlegung wert.
Für einen Vergleich wäre dann noch interessant mit welcher zeitlichen Auflösung die beiden Verfahren laufen und welchen Overhead das Windows-Tool mit sich bringt :unsure:
Ich habe nun auch das aktuelle Beta Bios V2812 installiert. DOCP geladen (Stock auf 3200 MHZ). Leider musste man wieder die Lüftersteuerung neu optimieren lassen und danach erneut alles einstellen. Ansonsten funktioniert soweit alles gut. Vorher war noch 1201 installiert und mit dem neuen Beta Bios erreiche ich In Cinebench 20 nun 6961 Punkte, 100 Punkte mehr als vorher. Der Maximaltakt geht noch immer nicht über 4.6 GHz. Ich erreiche weiterhin maximal ca. 4'516 Mhz und das schafft nun nur ein Kern. Unter 1201 erreicht ich immerhin über 4,55 Ghz und das auf 3-4 Kernen. Dafür Boosten alle anderen Kerne nun höher mit min. 4,34 Ghz. So richtig happy bin ich damit im Moment nicht. Dann habe ich testweise PBO und Fmax von Auto auf Enabled gesetzt. Und in CB 20 ergibt das nochmals satte 300 Punke mehr und damit 7276. Sieht schon besser aus, ein Kern geht nun wieder auf 4,591 Ghz. Aber das packt nur einer und nur kurz. Ansonsten ist das min. 4,342 Ghz. Getestet wurde mit CB15, CB20, 3D Mark und Red Dead Redemption.
Dann merkte ich, dass der Energiesparplan steht auf Balanced steht. Ich hatte mal gelesen das dieser keinen riesigen Einfluss hat, aber ich habe eine CB20 Test gemacht mit High Performane. Damit erreicht ich dann nur noch 7249, als 27 Punkte weniger. Das kann natürlich auch Messtoleranz sein. ABER, der Maximaltakt war nun auf 4,641 GHz. Über 4.6 hatte ich bisher nie gepackt, gefällt mir.
/Edit: Gerade noch eine 3D Mark Time Spy laufen und da werden nun deutlich höhere Taktraten erreicht mit dem High Performance Profil. 2 Kerne takten auf 4,64 Ghz, 4 Kerne takten auf 4,62 Ghz. Die restlich schaffen 4.37 - 4.42. Gefällt mir.
OC wurde nicht betrieben. Ist das ein normaler "Gewinn" unter Stock Einstellungen?
Überlege ob ich mit leichten Optimierungen noch wirklich etwas herausholen kann.
Deshalb kurz ein paar Fragen:
- Ignoriert das Board bei Auto Einstellungen die Funktionen? Der Unterschied zwischen PBO / Fmax auf Auto und Enabled ist enorm.
- Der RAM Bus Clock ist noch immer auf 99.8 MHz (CPU-Z). Lässt sich dies auf 100 MHz erhöhen? Im Bios steht 100 MHz. Ergibt dies überhaupt einen messbaren Unterschied?
- AMD Chipsatz-Treiber trotzdem installieren, auch wenn AMD selbst dies nur bei Problemen empfiehlt? Ich habe soweit keine Probleme.
- Überlege ob ich meinen Crucial RAM auf 3'600 MHz übertakten soll. Dies wird in Test ja als optimaler Sweetspot angegeben. (1:1) Ich habe mich mal eingelesen, verstehe aber trotzdem nur die Hälfte. ;) :d Ist der Zugewinn wirklich spürbar in normalen Anwendungen? In meinem Fall hauptsächlich Lightroom, Photoshop und Spiele.
Gefühlt, ja ... auf Auto gibts bei mir keinen Unterschied.
SB Clock Spread Spectrum auf Disabled - Ja minimal bessere RAM Latenz und die vollen MHz
btw. für RAM OC hatte ich noch keine Zeit :cry:
Ok Quelle? Ich hab immer den aktuellsten Chipsatz-Treiber bzw. das Paket installiert.
Nur im CPU Limit und je nach Anwendung unterschiedlich.
Bin jetzt kein Elektroniker, Infineons sind auf dem Strix-E auch verbaut, allerdings stellt das Strix CPU und SoC mehr Saft zur Verfügung.
Das Strix hat 12x 60A für die CPU und 4x40A für den SoC, das Aorus Master 12x 50A für die CPU und 2x50A für den SoC.
Beim Strix werden pro PWM Controller wohl je 2 MOSFETs parallel angesteuert, beim Gigabyte jeder PWM Controller seine eigene MOSFETs.
Was jetzt besser (oder sauberer) ist weis ich auch nicht, ich weis nur das es beim Strix gut funktioniert und das reicht mir eigentlich.
Ehhhjaaa... und trotzdem hat das Strix X570-E Im vergleich zu anderen Mainboards immer ne Miesere Performance ^^
Was kann man damit tun? Möglich wäre es, vor dem Start eines Programmes, das möglichst viel Power auf allen Kernen braucht die Spannung und die Taktfrequenz von der Command Line zu setzen. Dann spart man sich den Ryzen Master. Im HWInfo könnte man auf CPU PPT z. B. beim erreichen von 80 Watt so reagieren, dass man Overclocking einschaltet um die volle Leistung auf allen Kernen zu haben. Sinkt die CPU PPT kann man das Overclocking abschalten und man hat wieder den vollen Boost Tackt für Single Core Anwendungen.
Beispiel: Wenn man im Cinebench beide Tests anstartet, würde kurz nach dem Start des Multicore Tests der CPU Takt auf 4400Mhz all Core gesetzt. Ist der Test zuende würde das Overclocking automatisch abgeschaltet und der Single Core Test liefe mit vollem Boost von 4700Mhz. Da könnte ich einen kleinen Batch als Demo für schreiben.
Hä sowas geht? Ich dachte um fixen Allcore Turbo zu aktivieren müsste man zwingend den PC Neustarten?
Wäre ja ziemlich cool.
btt:
Na toll... Dann machen wir uns halt mal dran wieder alle settings im BIOS neu einzutippen...
Diesmal scheiss Aura Stealth mode nicht vergessen -.-
Ich hab eine ganz blöde Frage: Habe das BIOS 2407 würde gerne auf 2812X updaten, hab das über den Bios Flashback noch nie gemacht. Muss ich da vorher so wie bei einen normalen Bios Update die Einstellungen im Bios auf Default setzen?
lg Roman
@Radio71
Nein nur die Datei 2812X entpacken und den Inhalt auf einen FAT32 formatierten USB Stick kopieren.
Dann über den Flashback Knopf liegendem USB Slot stecken.
Nun nur ca. 7 sec. die Taste halten, mein USB Stick hat eine Diode. Da sieht man wenn es los geht besser.
Um jegliche Art von Komplikationen zu vermeiden, empfehle ich persönlich immer die Standard Einstellungen davor zu laden. Sind zum Beispiel für USB noch Energiesparmaßnahmen aktiv, dann wird Flashback nicht funktionieren.
Wie sieht es mit den IOPS auf den SATA Ports aus mit dem 2812. Ich hab noch das 2802 und bin eigentlich zufrieden, sollten die IOPS besser ausfallen werd ich auch auf 2812 flashen.
Danke, werde ich noch testen. Hat dies noch auf etwas Einfluss?
PBO / Fmax musste ich wieder deaktivieren. Hat bei CB15, CB20, 3Mark Firestrike, etc. gut geklappt. In Red Dead Redemption 2 gab es immer zwischen 5 und 30 Min einen Bluescreen. Nur tragisch das ich die angegebenen 4.6 Ghz ohne PBO nie erreiche. Nun, unabhängig vom Energieprofil, komme ich nie über 4.49 Ghz. Das ist enttäuschend, mit 1201 waren es immerhin 4.55 Ghz. Muss ich noch etwas beachten? Ich werde noch die finale Bios-Version abwarten und überlege sonst ein Flashback...
Das ist jetzt sowas was ich kaum benche, aber im meinem Fall läuft 2812 leicht schlechter.
Mit 2802 hatte ich auf allen Kernen schon mal die 4400 bei meinem 3700x gesehen, mit 2812 sehe ich die boosts nur noch auf zwei Kernen.
Ok, ist jammern auf hohem Niveau, die CB 15 und CB 20 Werte sind identisch.
Jojojo, messbar ja, aber fühlbar?
Böö ^^ Tatsache ist das laut diversen Tests das Mainboard eher schlecht Performt. Obwohl es technisch doch eigentlich super ist.
Glücklicherweise gibts ja nun das Fmax das ihm die sporen gibt.
Laut Handbuch reichen 3 sekunden. Auch wenn es sich wirklich wie 7 anfühlt ^^
So.... Hab Bios 2812X mal geflash und komischerweise ist der SingleCore wert (mit fast allen Einstellungen wieder so wie vorher) wesentlich tiefer!
Komme nun auf 510, vorher ging der auf 535 hoch.
Aber das mal beiseite... Hier par Tests. Hab PC aufgestartet... 2 Minuten gewartet und dann 3x CB20 Multicore durchlaufen lassen.
STOCK 2812X: (RAM Takt nur 2666Mhz)
Run1: 6902
Run2: 6979
Run3: 6979
Screenshot
RAM OC: (IF1900Mhz Ram 3800CL16)
Run1: 7012
Run2: 7035
Run3: 7035
Screenshot
Fmax: (PBO +200Mhz 10x Scalar)
Run1: 7300
Run2: 7334
Run3: 7334
Sreenshot
Ganzes Album mit allen Screenshots: Hier
Was mir auffällt das das CB20 nicht 3x nacheinander laufen sollte... beim zweiten mal gibts immer eine höhere Score... aber der dritte durchlaufe bleibt immer gleich. Da kann man direkt mal davon ausgehen das es kaputt gegangen ist.
Was man aber auf den ersten blick sieht, (Links FMax) die Spannung mit der der CPU Läuft ist wesentlich geringer, obwohl er 200mhz schneller läuft. Auch wurde das PPT Limit gewaltig erhöht. Ohne das ich iwas daran gemacht habe. 142W 100% zu 163W 41%. Lustig ist aber dass das EDC Limit durch die Tiefer Spannung bei weitem nicht erreicht wurde. Wo es vorher auf 140A lag kommt es nun auf 105A (evtl Anzeige fehler? Da TDC und EDC identisch sind....) Wie sieht das bei euch mit Fmax aus? Wird dann EDC und TDC auch identisch? Genaue einstellungen die ich gemacht habe waren die.
bei mir war es sogar noch schlimmer.
Setz mal LLC auf 3, dann sollten bessere Werte kommen.
sollte LoadLine Calibration nicht auf Auto gelassen werden wenn Fmax aktiviert wird?
Hello!
I don't have ASUS X570 mb ATM so I can't check it myself: which sensor is used to control M.2_FAN? Is it possible to change it? For example, CPU_FAN & CPU_OPT are strictly mapped to CPU sensor while for CHA_FANs you could set CPU, MB or external thermal sensor as a reference.
Unter Allgemein stand dort nichts anderes als im angehängten Log.
2020-11-09 07-45-11 B550-E Ereignisanzeige.png 2020-11-09 08-02-47 B550-E Ereignisanzeige.png
Unter Details sehen diese beiden Ereignisse so aus:
- <Event xmlns=" ">
- <System>
<Provider Name="Microsoft-Windows-Power-Troubleshooter" Guid="{cdc05e28-c449-49c6-b9d2-88cf761644df}" />
<EventID>1</EventID>
<Version>3</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2020-11-09T06:41:24.448401100Z" />
<EventRecordID>77021</EventRecordID>
<Correlation ActivityID="{faad9974-7bad-4f09-9b73-38ec5bb4b2ee}" />
<Execution ProcessID="5940" ThreadID="7976" />
<Channel>System</Channel>
<Computer>B550-E</Computer>
<Security UserID="S-1-5-19" />
</System>
- <EventData>
<Data Name="SleepTime">2020-11-09T06:40:49.425675100Z</Data>
<Data Name="WakeTime">2020-11-09T06:41:23.846365400Z</Data>
<Data Name="SleepDuration">2819</Data>
<Data Name="WakeDuration">3350</Data>
<Data Name="DriverInitDuration">2834</Data>
<Data Name="BiosInitDuration">1383</Data>
<Data Name="HiberWriteDuration">0</Data>
<Data Name="HiberReadDuration">0</Data>
<Data Name="HiberPagesWritten">0</Data>
<Data Name="Attributes">1912621312</Data>
<Data Name="TargetState">4</Data>
<Data Name="EffectiveState">4</Data>
<Data Name="WakeSourceType">1</Data>
<Data Name="WakeSourceTextLength">0</Data>
<Data Name="WakeSourceText" />
<Data Name="WakeTimerOwnerLength">0</Data>
<Data Name="WakeTimerContextLength">0</Data>
<Data Name="NoMultiStageResumeReason">0</Data>
<Data Name="WakeTimerOwner" />
<Data Name="WakeTimerContext" />
<Data Name="CheckpointDuration">30</Data>
</EventData>
</Event>
- <Event xmlns=" ">
- <System>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2020-11-08T12:38:01.823984400Z" />
<EventRecordID>76581</EventRecordID>
<Correlation ActivityID="{a5d93499-111c-4bdc-9560-fa7daa947512}" />
<Execution ProcessID="4860" ThreadID="6320" />
</System>
- <EventData>
<Data Name="SleepTime">2020-11-08T12:10:39.392256700Z</Data>
<Data Name="WakeTime">2020-11-08T12:37:59.857881500Z</Data>
<Data Name="SleepDuration">774</Data>
<Data Name="WakeDuration">1357</Data>
<Data Name="DriverInitDuration">1252</Data>
<Data Name="BiosInitDuration">13045</Data>
<Data Name="HiberWriteDuration">548</Data>
<Data Name="HiberReadDuration">654</Data>
<Data Name="HiberPagesWritten">187128</Data>
<Data Name="Attributes">1912619265</Data>
<Data Name="TargetState">6</Data>
<Data Name="EffectiveState">5</Data>
<Data Name="WakeSourceType">0</Data>
<Data Name="CheckpointDuration">28</Data>
</EventData>
</Event>
Aber in diesem Thread sollte ich vom X570-E Gaming schreiben. "Gut", dass auch dieses System, wo erst gestern BIOS 2812 und dann 2818X aufgespielt und Windows 10 Pro 20H2 komplett neu aufgesetzt wurde, gerade eben ungewollt aus dem Standby (STR, S3) erwachte.
So langsam hab ich die Master-Slave-Steckdosenleiste in Verdacht. :unsure:
Yes, it's kinda just a renamed chassis fan. So same settings available.
Habe dazu einige Berichte gelesen und Videos angeschaut... das scheint teilweise stark vom Board abhängig zu sein. Teilweise war z.B. bei MSI Aorus kein Unterschied messbar ob nun auf Auto oder Enabled. Allgemein taktete die CPU jedoch höher auf dem MSI Board als z.B. auf dem Asus. Interessant fand ich das auf dem MSI Board PBO +200 MHZ kein wirkliches Geschwindigkeits-Plus brachte, was wohl daran liegt, da die CPU eben bereits auf PBO Auto ziemlich hoch taktete.
Bei mir läuft PBO und Fmax auf Enabled nicht stabil. Ich vermute für die ganz hohen Taktraten ist vor allem Fmax verantwortlich? Lässt sich dies irgendwie ein wenig "drosseln"? Aktuell werden maximal 4640 Mhz mit PBO+Fmax enabled erreicht. Das ist unter CB15, CB20, 3d Mark stabil. In Red Dead Redemption stürzt der Rechner mit einem Bluescreen nach 5 bis 30 min ab. Ich hatte leider HWInfo nicht mitloggen lassen, gehe aber schwer von einer hohen VCore der CPU aus. Die Temperaturen sahen jeweils gut aus während dem Spielen mit meist unter 70°C, selten knapp unter 80°C. Die CPU ist im Spiel bei WQHD auch selten wirklich gefordert.
Ich kenne mich damit ja nicht wirklich im Detail aus, meine aber mal irgendwo gelesen zu haben, dass dies auf An sein soll, damit soll irgendein Abstrahlverhalten angepasst werden und die Verbindungen passen sich darauf an. Wie gesagt, keine Ahnung was das im Detail bedeuten soll. Ich weiss nur das die Funktion dann Variabel ist und +/- 1.5 MHZ einstellen kann. Bei mir steht im Bios immer 100 Mhz, im Windows aber immer 98.5 Mhz und das ändert sich auch nie.
Sorry, ich hatte das falsch im Kopf. Ich habe nochmals danach gesucht und auf einigen Treiber-Seiten und auch Magazinen (CB, Gamestar, etc.) den Hinweis gelesen, dass die Treiber eigentlich nur bei sehr neuen oder alten Rechnern nötig seien, da Windows 10 die Treiber automatisch installiert. Da die Treiber aber immer mal wieder mit Verbesserungen aufwarten, werde ich die aktuellen Treiber heute Abend mal installieren und den Maximaltakt testen.
Im Moment verstehe ich nicht, dass ich nach dem Bios-Update erst noch knapp über 4.5 Ghz erreicht habe und nun, nachdem ich PBO/Fmax wieder auf Auto gestellt habe noch einmal mehr ganz 4.45 Ghz erreiche...
So in fact it is just a renamed CHA_FAN, nice. Is smoothing time also available for it?
with bios MOD u can use VRM und PCH (Chipset), too
mal PBO 100Mhz ausprobiert ?
Bei mir sind 200Mhz ein absoluter Schuss in den Ofen
Hast du vllt kein Boost-Scenario gehabt ?
Ich booste mit dem ryzen 3700x auch nur in bestimmten games auf 4,475 (auf 2 Kernen )
Den Chipset Driver sollte man bei den Ryzen selber updaten von der Hersteller Webseite.
Nei, 100 MHz hatte ich gestern nicht mehr getestet. Werde ich die Tage mal machen und mit Prime95 testen. Oder empfiehlt sich noch eine andere Software zum testen?
Inwiefern war es bei dir ein Schuss in den Ofen? Ebenfalls nicht stabil? Evtl. würde minimales Undervolten helfen?
Oder die finale Version geht da dann besser zu Werke.
Boostszenario sollte eigentlich bei CB15 und 20 (Multi und Single) erfüllt sein. Zumindest mit 1201 hatte ich da Boosts mit 4549 MHz. Mit 2812X waren es dann auch noch 4549 MHz, aber er boostet weniger oft so hoch. Der CB20 Run war trotzdem besser als unter 1201. Nach den PBO/Fmax Test habe ich diese Funktionen wieder auf Auto gestellt und erreich nur noch 4449 Mhz... satte 100 Mhz weniger. Trotzdem war der CB20 Multirun gleich gut. Ich hatte gestern keine Zeit und Lust mehr zum weitertesten. werde ich die Tage mal machen. Der Single-Test unter CB20 ist noch offen... darum will ich noch nichts verschreien. In Spielen hatte ich, wenn ich mal wieder kontrolliert habe, nie 4.6 Ghz auf einem Kern erreicht, weder unter 1201 oder 2812X.
Chipset werde ich vor den weiteren Tests erst mal updaten von der AMD Seite. Verstehe momentan nur nicht warum ich vor PBO/Fmax enabled einen höheren Takt erreicht habe, als nachher, wo ich wieder die gleichen Einstellungen genutzt habe.
ich meinte damit nur, das dadurch mein boost niedriger war.
Bei beispielsweise Call of Duty Booste ich eindeutig höher als in CB, aber halt auch nur kurz.
Die SOC Voltage wurde bei mir massiv per update reduziert.
Diesen blackscreen Fehler hatte ich damals, als ich SOC Spannung unter 1,075 gestellt habe. Mittlerweile sind sogar 1,025 per stock angelegt.
ich habe eine Frage zum Asus ROG STRIX X570-E GAMING.
Habe es im Bundle mit dem 5900x bestellt. Leider habe ich zu spät im Mainboard-Handbuch gelesen:
Sie können 2 GB, 4 GB, 8 GB und 16 GB ungepufferte DDR4 DIMMs in den DIMM-Steckplätzen installieren
Bestellt habe ich allerdings, 64GB (2x32GB) Crucial Ballistix DDR4-3600.
Müssen die zurück oder funktionieren sie doch. Vor allem da der Max-Speicher, vom Mainboard 128GB ist.
In der QVL-Liste kann ich nichts finden.
Kann mir jemand weiterhelfen, würde mich sehr freuen.
Habe schon längere Zeit keinen PC mehr zusammengebaut und bin wohl etwas eingerostet.
Ist meine erste Frage hier, bitte um Nachsicht!
