Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
AMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Chipset
X570
Memory
3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
Graphic
Integrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support
3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage
3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LAN
Intel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi
2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
Bluetooth
Bluetooth® 5.0
Audio
SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports
3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features
5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
Accessories
User's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS
256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note
*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic
1 x HDMI 2.0
1 x DisplayPort
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
Storage
Supports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN
1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFi
Wi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
Bluetooth
Bluetooth® v5.2
Audio
Realtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB Ports
AMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special Features
Extreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports
8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O Ports
Fan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
Accessories
Cables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
BIOS
Form Factor
ATX Form Factor
Note
Entdecke die Welt von ASUS - Alles rund um die besten Mainboards, Grafikkarten, Monitore, Notebooks und vieles mehr erfährst Du auf der offiziellen ASUS-Seite.
Chipset
X570
Memory
Graphic
Multi-GPU Support
Expansion Slots
AMD X570 chipset
2 x PCIe 4.0 x1
Storage
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
LAN
Anti-surge LANGuard
Audio
Audio Feature :
- Sonic Radar III
USB Ports
3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
Special Features
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
Accessories
User's manual
1 x Supporting DVD
BIOS
Form Factor
ATX Form Factor
Note
Chipset
X570
Memory
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
Graphic
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
Expansion Slots
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
Storage
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
Supports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Bluetooth
Bluetooth® 5.0
Audio
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
USB Ports
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
Special Features
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
Back I/O Ports
1 x DisplayPort
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports
1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
Accessories
User's manual
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
BIOS
Form Factor
Mini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note
*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
Sound setzt aus oder knistert
Immer wieder USB Disconnects
Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
USB Disconnects
Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
USB Flashback funktioniert nicht
Bitte folgende Punkte ausprobieren:
- Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
- Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
- Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
BIOS/UEFI Downgrade
Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
Ist der Chipsatz Lüfter regelbar?
Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
Chipsatz Temperatur zu hoch?
Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
Rechner bootet nicht, wenn eine Soundkarte verbaut ist
Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
Kann ich bestätigen. Der Fmax Enhancer und PBO haben jetzt endlich ein Boost Verhalten wie man sich das vorstellt. Habe zum ersten Mal auf allen Kernen 4,4 gesehen und regelmäßig. So weit ich mich erinnern kann sind 4918 mit PBO Settings bisher am besten bei mir. Single ist quasi immer gleich, egal welches Bios. So 505 bis 507... Mal später schauen ob mein RAM OC läuft.
moin
mein ryzen 5800x dürfte morgen kommen, da ich auf amd umgestiegen bin weiß ich nicht ob das mainboard eine lauffähiges bios für die cpu hat, kann ich die 2802x version vorab flashen? frage nur da in der readme steht Only with zen 2 cpu.
Easy 😬 Überhaupt kein Stress. Selbst 2022 wäre ok. Wenn ich mir die für mich relevanten 4K Benchmarks ansehe, würde ein Upgrade aktuell nicht lohnen.
Aktuell sieht man von DDR5 ja noch überhaupt nix und Early Adapter werde ich da nicht spielen.
Als bekennder 4K Zocker sehe ich das ganz genauso.
Kann mir auch vorstellen erst irgendwann kurz bevor ZEN4 kommt aufzurüsten.
Nen günstigen 5900X zulegen und den Early Adoptern entspannt beim rumärgern zusehen.
Die Preise für den DDR5 Ram werden eh erstmal unverschämt hoch sein.. Custom Modelle werden ebenfalls sehr teuer sein.. Leistungszuwachs ohne gute Optimierung der Spiele wird nicht viel bringen.. denke mal vor 2022 werden wir tatsächlich wenig Nutzen darauß ziehen. Mal unabhängig davon, dass AMD eh erst frühestens Quartal 4 2021 seine neue Basis vorstellen wird.
hi alle habe das x570-e von Asus bekomme irgendwie die OnBoard Grafik nicht angestellt , die von Anfang an aus war. kann mir da vielleicht einer helfen mein English is Bad sorry
Blöde Frage, aber ist jemand vom Aorus Master auf das Strix E umgestiegen oder andersrum und kann was zum Vergleich beider Boards sagen? Schwanke noch, welches ich bevorzuge.
Welche CPU nutzt du denn?
Weil du kannst die Grafikanschlüsse auf dem Mainboard auch nur mit einer CPU nutzen, die eine integrierte Grafikeinheit hat. Dazu gehört z.B. der 3200G.
Mit einer normalen Ryzen CPU geht es nicht. Auf dem Board selber ist keine GPU verbaut.
Bin umgestiegen weil das aorus kaputt war, bzw hatte nicht erklarliche fehler. 😂
Die Spannungswandler und vorallem das bios von Asus sind besser.
Leider ist der Chipsatzlüfter bei Asus schlechter positioniert.
Bei Asus lässt sich der Chipsatz Lüfter nicht steuern, dafür haben wir aber den schönen BIOS Mod, der alles möglichmacht.
Würde von den zwei klar das Asus nehmen.
Ich erdreiste mich aber Mal und schmeiße noch ein MSI Meg unify dazu. Einen Blick hat das Board aufjedenfall verdient, wie ich finde .
Hm, das mit den Spawas wundert mich jetzt etwas - ich dachte gerade da ist das Aorus Master ganz vorn, da 12 "echte" Phasen + top Infineon 16 Phase Controller...
Bios ist Geschmacksache, wobei ich da tatsächlich auch Asus bevorzuge.
MSI mag ich gar nicht, hatte ich @ Z170 und Z390 leider keine gute Erfahrungen gemacht.
Mal schauen, werd mich vermutlich entscheiden, wenn beide Boards vor mir liegen. Hab noch etwas Bedenken beim Asus mit hohem Ram-Takt bei Vollbestückung - ich würde gern wieder 4x8GB 4000er Ram fahren, wie @ Z390.
Bin jetzt kein Elektroniker, Infineons sind auf dem Strix-E auch verbaut, allerdings stellt das Strix CPU und SoC mehr Saft zur Verfügung.
Das Strix hat 12x 60A für die CPU und 4x40A für den SoC, das Aorus Master 12x 50A für die CPU und 2x50A für den SoC.
Beim Strix werden pro PWM Controller wohl je 2 MOSFETs parallel angesteuert, beim Gigabyte jeder PWM Controller seine eigene MOSFETs.
Was jetzt besser (oder sauberer) ist weis ich auch nicht, ich weis nur das es beim Strix gut funktioniert und das reicht mir eigentlich.
Der FMAX Enhancer klaut mir drastisch Performance. Wenn ich mit negativem CPU Spannungsoffset von 0,1V und PBO OFF fahre bekomme ich im CB20 im Schnitt 7350 Punkte. Mit FMAX ON zeigt HWInfo zwar schöne 4250Mhz auf allen Kernen an, aber am Ende kommen nur 6900 Punkte im CB20 raus. Core Voltage wird dabei mit 1,35V angezeigt. Zuwenig Spannung kann es nicht sein. Mit 1,3V kann ich schon stabil 4400Mhz laufen lassen und komme dann auf > 7800 Punkte. Mit 1,2V reicht es noch für 4300Mhz bei 7625 Punkten ...
Ich hatte die CPU und SOC Spannung bei dem Testt auf Auto. Hat einer eine Idee, woran das liegen könnte? LLC stand ebenfalls auf Auto. Werde ich morgen mal mit rumspielen.
Wie sieht es denn mit den Neuen CPUs aus?
Ich lese bei vielen, das der Speicher noch nicht so richtig will. Teilweise kein XMP und bei 3200 mit ach und Krach.
Mal eine ganz andere Sache: hätte jemand Interesse daran, Overclocking über die Command line zu betreiben? Das Command Line Interface bietet 206 API Zugriffe, teils zum Abfragen von Werten, teils zum setzen.
Momentan betreibe ich das Interface mit dem AMDRyzenMasterDriver.sys aus dem aktuellen Ryzen Master. Da scheinen ein par API Aufrufe zusammengefasst worden zu sein. Ist aber mehr oder weniger selbsterklärend.
Was kann man damit tun? Möglich wäre es, vor dem Start eines Programmes, das möglichst viel Power auf allen Kernen braucht die Spannung und die Taktfrequenz von der Command Line zu setzen. Dann spart man sich den Ryzen Master. Im HWInfo könnte man auf CPU PPT z. B. beim erreichen von 80 Watt so reagieren, dass man Overclocking einschaltet um die volle Leistung auf allen Kernen zu haben. Sinkt die CPU PPT kann man das Overclocking abschalten und man hat wieder den vollen Boost Tackt für Single Core Anwendungen.
Beispiel: Wenn man im Cinebench beide Tests anstartet, würde kurz nach dem Start des Multicore Tests der CPU Takt auf 4400Mhz all Core gesetzt. Ist der Test zuende würde das Overclocking automatisch abgeschaltet und der Single Core Test liefe mit vollem Boost von 4700Mhz. Da könnte ich einen kleinen Batch als Demo für schreiben.
Hier noch ein Beispiel was man so auslesen kann:
GetPMTableData .................................... PPT Fused Limit : 142.000000 W
GetPMTableData .................................... PPT Current Limit : 142.000000 W
GetPMTableData .................................... PPT Current Value : 34.636303 W
GetPMTableData .................................... EDC Fused Limit: 140.000000 A
GetPMTableData .................................... EDC Current Limit : 140.000000 A
GetPMTableData .................................... EDC Value : 11.985840 A
GetPMTableData .................................... TDC Fused Limit: 95.000000 A
GetPMTableData .................................... TDC Current Limit : 95.000000 A
GetPMTableData .................................... TDC Current Value : 7.040934 A
GetPMTableData .................................... cHTC Current Limit: 95.000000 celsius
GetPMTableData .................................... cHTC Current Value: 35.067268 celsius
GetPMTableData .................................... Fabric Clock Frequency : 1800.00 MHz
GetPMTableData .................................... CLDO_VDDP : 0.900231 V
GetPMTableData .................................... CLDO_VDDG : 1.047745 V
GetPMTableData .................................... CCLK Fmax Fused Value : 4775.00 MHz
GetPMTableData .................................... P0 Memory Clock Frequency : 1800.00 MHz
GetPMTableData .................................... P0 Fabric Clock Frequency : 1800.00 MHz
GetPMTableData .................................... VDDCR_CPU_POWER : 8.648526 W
GetPMTableData .................................... VDDCR_SOC_POWER : 15.908564 W
GetCurrentOCMode .................................. Auto Overclocking Mode.
GetEffectiveFrequency Core : 0 ................... 160.4 MHz-Sleep
GetEffectiveFrequency Core : 1 ................... 562.5 MHz-Active
GetEffectiveFrequency Core : 2 ................... 559.7 MHz-Active
GetEffectiveFrequency Core : 3 ................... 138.3 MHz-Sleep
GetEffectiveFrequency Core : 4 ................... 571.5 MHz-Active
GetEffectiveFrequency Core : 5 ................... 580.8 MHz-Active
GetEffectiveFrequency Core : 6 ................... 135.2 MHz-Sleep
GetEffectiveFrequency Core : 7 ................... 143.2 MHz-Sleep
GetEffectiveFrequency Core : 8 ................... 122.4 MHz-Sleep
GetEffectiveFrequency Core : 9 ................... 630.5 MHz-Active
GetEffectiveFrequency Core : 10 ................... 623.1 MHz-Active
GetEffectiveFrequency Core : 11 ................... 611.9 MHz-Active
GetPeakCore(s)Voltage ............................. 1.251412 V
GetVDDCR_SOC ...................................... 1.100002 V
GetCurrentTemperature ............................. 35.07 Celsius
GetAverageCoreVoltage ............................. 0.831851 V
Kurzum: soll ich mal etwas zusammenstellen, welche Dateien man von der Asus Software braucht? Ich selbst habe keinerlei Asus Software installiert. Die kam heute nur so lange drauf, bis ich - wieder erwarten - das Command Line Interface für den Ryzen darin gefunden hatte. Jetzt bin ich wider Asus-Softwarefrei
Timings waren aber nicht stramm, Crucial Ballistix Elite 4000 MHz 18-19-19-19-38.
Mainboard war das Hero noch. Nicht das Dark.
Non oc
CB R15
Multi 3532
Single 266
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
Also ich kann wie vorher ohne Probleme den Speicher mit XMP laufen lassen. 3600MHz CL16. Habe da keine Probleme mit der neuen CPU und den Speicher festgestellt.
Höher habe ich noch nicht getestet. Aber glaube der Speicher macht auch nicht viel mehr mit.
