[Sammelthread] ASUS ROG Maximus XI Apex & Gene - Das Mini APEX! (Z390)
[Sammelthread] ASUS ROG Maximus XI Gene (90MB10E0-M0EAY0)
--- Produktseite | PDF-Handbuch | Support-Downloads | Preisvergleich | HWBOT ---
The Gene is back with the Maximus XI family, this time with a twist. Multi-GPU configurations are becoming rarer as NVIDIA and AMD focus on single-card performance, and GPU coolers are growing beyond two slots to improve performance and reduce noise. The old Gene’s dual-GPU focus doesn’t reflect the kinds of systems gamers and enthusiasts are building, so the new model refocuses to aggressively pursue higher performance and support additional storage. It has already made its mark on the hardware leaderboards by claiming 11 global first place scores and eight world records, including the fastest CPU frequency at 7613.19MHz and the highest memory clock at 5566MHz.
Spezifikationen
attachment.php
attachment.php
attachment.php
CPUBuild in Intel® 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® Processors
Supports Intel® Turbo Boost Technology 2.0
* Refer to ASUS Deutschland
for CPU support list
ChipsetBuild in Intel® Z390
MemorySocket 1151 for 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® processors
2 x DIMM, Max. 64GB, DDR4 4700(O.C)/4600(O.C)/4500(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400(O.C.)/2133(O.C.) MHz Non-ECC, Un-buffered Memory *
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
for the Memory QVL (Qualified Vendors Lists).
* Double Capcity DRAM support depends oh the DRAM models
GraphicIntegrated Graphics Processor- Intel® UHD Graphics support
- Supports HDMI 1.4b with max. resolution 4096 x 2160 @ 30 Hz
Expansion SlotsSocket 1151 for 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® processors
1 x PCIe 3.0 x16
Intel® Z390 Chipset
1 x PCIe 3.0 x4
StorageSocket 1151 for 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® processors :
2 x ROG DIMM.2 Module support(CPU_DIMM.2), with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)
Intel® Z390 Chipset :
2 x M.2 Socket 3, with M Key, type 2242/2260/2280 storage devices support (x4 PCIE mode)
4 x SATA 6Gb/s port(s),
Support Raid 0, 1, 5, 10
Intel® Optane™ Memory Ready
LANIntel® I219V, 1 x Gigabit LAN Controller(s)
Anti-surge LANGuard
ROG GameFirst Technology
Wireless Data NetworkIntel® Wireless-AC 9560
Wi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Supports MU-MIMO
Supports channel bandwidth: HT20/HT40/HT80/HT160. Up to 1.73Gbps transfer speed
BluetoothBluetooth® 5.0
AudioROG SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output 113 dB SNR recording input
Audio Feature :
- SupremeFX Shielding™ Technology
- Gold-plated jacks
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB PortsIntel® Z390 Chipset :
1 x USB 3.1 Gen 2 front panel connector port(s)
4 x USB 3.1 Gen 2 port(s) (3 x Type-A+1 x Type-C)
8 x USB 3.1 Gen 1 port(s) (2 at mid-board)
6 x USB 2.0 port(s)
ROG Exclusive FeaturesROG CPU-Z
ROG CloneDrive
Pre-mounted I/O Shield
Slow Mode
CMOS button
Overwolf
ReTry Button
Safe Boot Button
Start Button
Reset Button
LN2 Mode
ROG Aura
- Aura Lighting Control
- Aura RGB Strip Headers
Extreme Engine Digi+ :
- MicroFine Alloy Chokes
- 10K Black Metallic Capacitors
Mem TweakIt
Double Power :
- Dual 8 -pin CPU
USB BIOS Flashback
ROG Exclusive Software
- RAMCache III
- GameFirst V
- Sonic Radar III
Special FeaturesAI Overclocking
ASUS 5X Protection III :
- ASUS SafeSlot Core: Fortified PCIe Slot prevents damage
- ASUS LANGuard: Protects against LAN surges, lightning strikes and static-electricity discharges!
Gamer's Guardian:
- SafeSlot
ASUS Optimem II:
- Optimem (Improved DDR4 stability)
- Improved DDR4 Stability
ASUS Exclusive Features :
- MemOK! II
- Pre-mounted I/O Shield
- ASUS NODE : hardware control interface
- BIOS Flashback Button
- Clear CMOS Button
- Reset Button
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 4
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
AURA: RGB Lighting Control
Armoury Crate
Operating System SupportWindows® 10 64-bit
Back I/O Ports1 x PS/2 keyboard/mouse combo port(s)
1 x HDMI
1 x LAN (RJ45) port(s)
3 x USB 3.1 Gen 2 (red)Type-A,
1 x USB 3.1 Gen 2 (red)Type-C
6 x USB 3.1 Gen 1 (blue)
2 x USB 2.0
1 x Clear CMOS button(s)
1 x Wi-Fi antenna port(s)
BIOS1 x 128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 6.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information.
ManageabilityWfM2.0, DMI3.0, WOL by PME, PXE
Support DiscOverwolf
1-year Anti-Virus software
Daemon Tools Software
WinRAR
Form FactormATX Form Factor
9.6 inch x 8.9 inch ( 24.4 cm x 22.6 cm )
Backpanel:
attachment.php
Special Features
1) Double-capacity DIMM support (DC DIMM)
Maximus XI Gene features a unique memory-trace design that supports up to 32GB per slot for a total memory capacity of 64GB. With double-capacity UDIMM modules, Maximus XI Gene delivers four-DIMM memory capacity in a compact, dual-DIMM design.
--> [Sammelthread] Double Capacity DIMM DDR4 (DC DIMM)
2) Overclocker's toolkit
1) MEMOK! II - DRAM Auto Training Switch
2) QLED - 4 LEDs to show current boot status.
3) LN2 Mode - Jumper to enable special options and functions for liquid-nitrogen (LN2) overclocking.
4) Pause Switch - Activate to pause the system and fine-tune OC parameters mid-benchmark.
5) Slow Mode Switch - Instantly reduces the CPU ratio to 8X to bypass finicky benchmark passages.
6) ReTry Button - One press instantly initiates a hard reset.
7) Safe Boot Button - Instantly reset the PC and boot directly in to a safe mode.
8) ProbeIt - Check the voltage via integrated measurement points.
BIOS
Reguläre Releases (Support Downloads - BIOS Shortcut)
  • 1502 (2020/04/29, Improved system stability)
  • 1401 (2019/12/11, Improve Memory-OC rules & Intel Optane H10 compatibility, fixed Tjmax for i9-9900KS)
  • 1302 (2019/09/11, Improve system stability)
  • 1105 (2019/06/20, Improved DRAM compatibility & system performance & storage device comp, Updated ME to v12.0.39 & microcode for Security)
  • 1005 (2019/04/25, Enhanced security. Improved SSD & DRAM compatibility, Updated RAID driver)
  • 0905 (2019/04/11, Enhanced Security)
  • 0903 (2019/03/22, Microcode Update)
  • 0805 (2019/01/02, Supported JEDEC Standard DDR4 32GB memory, Updated RST driver & ME FW, Improve system performance & DRAM stability)
  • 0702 (2018/12/18, Improved system stability and performance, updated RST Driver)
  • 0602 (2018/10/31, Updated Microcode, improved DRAM stability, fixed USB issue)
  • 0506 (2018/09/29, First Release BIOS)
Bilder ( ASUS Maximus XI Gene BIOS walkthrough. - YouTube )
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
  • 0021 (OC BIOS, New Sammy A2 Profiles, need to be logged in @ HWBOT Forums to download)
  • 0050 (OC BIOS, allows BCLK change with OC PANEL)
  • 0093 (OC BIOS, allow higher voltages without LN2 mode, need to be logged in @ HWBOT Forums to download)
  • 0057 (3rd OC BIOS, improves a2 dimms overclocking)
  • 0044 (2nd OC BIOS, some memory related fixes vs 0084)
  • 0084 (1st OC BIOS for short-traced DIMMs such as G.Skill RGB or Galax based A2-pcb)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
  • Hersteller Modell @ Preisvergleich | Quelle | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller Modell @ Preisvergleich | Quelle | inkompatibel | Grund/Foto(s)
  • --> Bitte helft mit sammeln!
2) RAM
ASUS Memory QVL (PDF).
attachment.php
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
  • RAM OC MemOK per SChalter auf dem Board deaktiiveren beim RAM OC
  • ASMedia USB 3(.1) Treiber in das Windows 7 Image integrieren oder P/S2 Tastatur verwenden und die Treiber von einer angeschlossenen Festplatte installieren. Alternativ einen PCIe USB Controller verwenden, der nativ unterstützt wird.
4) FAQ - Frequently Asked Questions
  • Q: Wie exakt wird die Vcore per Software ausgelesen?
  • A: Elmor hat dies so erklärt:
    Elmor schrieb:
    A note on voltage reporting on the Maximus XI-series, and voltage measurements in general. Like on Crosshair VII Hero, we've improved the SIO voltage readings for better accuracy. The CPU Core Voltage is now reading very close to the voltage the CPU is getting. Applied voltages and load-line levels are comparable to before, but not the software voltage readings.
    When measuring voltages on a motherboard and large currents are involved, it's important to use accurate measurement points due to resistance/impedance present on the board. The power plane for example can be modeled as a resistor connected in series between the VRM output and the target device, together with Ohm's law, U = R*I. The larger the current, the larger the voltage drop. If you measure the voltage at the VRM output, for example at the inductor, you'll see a large difference compared to the voltage measured at the CPU socket MLCC. What we're interested in is what voltage the CPU die is actually getting after passing through the output filter, power plane, socket and package.
    The Super I/O controller is used by BIOS/AiSuite/CPU-Z/HWInfo/AIDA64 for reading most voltages, temperatures and fan speeds. Its single-ended ADC inputs measure the input voltage referenced to the local SIO ground. With increased VRM output currents, this reading will be more and more inaccurate. We've added a circuit for measuring the differential CPU-die sense and converting it to a single-ended signal to the SIO. The CPU-die sense is accessible through two dedicated pins on the CPU, and are routed to the supply and ground on the CPU die itself. It's typically used by the CPU VRM controller for output voltage control.
    Something to look out for is when you're seeing a voltage reported during load which is much higher than what you've set. It would require a negative load-line which is just not supported on any controller as far as I know. At 0 mOhm load-line, you get exactly what you set (Level 8 on M11).
    The resulting difference can be seen in the graph below.
    Prime95 26.6 12K FFTs
    Manual Mode Voltage = Voltage set in BIOS
    CPU-die Sense = DMM measurement of the CPU die-sense pins, "true" CPU Core Voltage
    Socket MLCC = DMM measurement of the capacitors at the back of the socket
    SIO (traditional) = Software reading with standard SIO voltage sense circuit
    SIO (Maximus XI Hero) = Software reading with the improved SIO voltage sense circuit
  • Q: Das Bluetooth funktionert mit den ASUS Treibern nicht. Gibt es dafür eine Lösung?
  • A: Mit den original Intel Treibern v20.70.0.4 gibt es laut Low keine Probleme (Download).
  • Q: Meine Tastatur wird beim Systemstart nicht rechtzeitig initialisiert. Wie komme ich ins UEFI?
  • A: Die einfachste Möglichkeit ist es, wie im Handbuch beschrieben die Reset Taste dafür zu verwenden. Wer keine Taste mehr dafür an seinem Gehäuse hat, kann auch den Onboard Button verwenden. Für wen weder das Eine noch das Andere in Frage kommt, der kann alternativ auch einen Start ins UEFI mit dem Power Button erzwingen (siehe Handbuch Seite 3-2 "Entering BIOS Setup after POST").
  • Q: Wie sind die einzelnen M.2 Steckplätze genau angebunden?
  • A: Die beiden auf dem DIMM.2 Modul, teilen sich PCIe Lanes von der CPU mit dem PEG. Wenn das DIMM.2 verwendet wird, reduziert sich dessen Anbindung auf x8. Die beiden Steckpätze auf dem MAinboard selbst sind mit PCIe Lanes vom Chipsatz angebunden. Man hat also die frei Wahl, was einem wichtiger ist (Storage/GPU-Performance).
  • Q: Was ist der Unterschied zwischen XMP-1 und XMP2? Mein Kit sollte eigentlich gar kein zweites XMP besitzen.
  • A: ASUS hat den Z390 Modellen eine Funktion spendiert, die statt dem originalen XMP des RAM-Hertellers (XMP-2), von ASUS optmierte Einstellungen verwendet (XMP-1). In der Regel ist XMP-1 zu bevorzugen und etwas performanter, im Fall von Performance- oder Stabilitätsproblemen, empfiehlt es sich aber auf XMP-2 auszuweichen.
    Silent Scone@ASUS schrieb:
    On Z390, there is now the option to use the DIMM profile which is XMP II. These settings are not validated, so mileage will vary depending on the kit and CPU.
    XMP I - Board optimised timings
    XMP II - Default XMP timings
    Often, XMP II timings will be slightly looser depending on the memory kit. If you check within the UEFI or memtweakit, you'll see a difference in memory subsets.
  • Q: Wie stelle ich die RTL/IOL richtig ein?
  • A: Dazu hat swdtechnik eine Anleitung im Coffee Lake RAM OC Thread gepostet:
    Nun wegen RTL`s und IO-L`s und wie man steuern bzw. beeinflussen kann:
    wir gehen ins Bios und setzen MRC Fast Boot auf [Disabled]
    (wenn Modulen B-Die A2 sind dann zusätzlich noch Trace Centering auf [Enabled])
    dann MCH Full Check auf [Enabled]
    dazu noch Round Trip Latency auf [Enabled]
    noch müssen wir folgende Settings unbedingt auf diese Werte setzen :
    DRAM RTL INIT value [x Wert]
    DRAM RTL (CHA DIMM0 Rank0) [Auto]
    DRAM RTL (CHA DIMM0 Rank1) [Auto]
    DRAM RTL (CHA DIMM1 Rank0) [Auto]
    DRAM RTL (CHA DIMM1 Rank1) [Auto]
    DRAM RTL (CHB DIMM0 Rank0) [Auto]
    DRAM RTL (CHB DIMM0 Rank1) [Auto]
    DRAM RTL (CHB DIMM1 Rank0) [Auto]
    DRAM RTL (CHB DIMM1 Rank1) [Auto]
    DRAM IOL (CHA DIMM0 Rank0) [Auto]
    DRAM IOL (CHA DIMM0 Rank1) [Auto]
    DRAM IOL (CHA DIMM1 Rank0) [Auto]
    DRAM IOL (CHA DIMM1 Rank1) [Auto]
    DRAM IOL (CHB DIMM0 Rank0) [Auto]
    DRAM IOL (CHB DIMM0 Rank1) [Auto]
    DRAM IOL (CHB DIMM1 Rank0) [Auto]
    DRAM IOL (CHB DIMM1 Rank1) [Auto]
    CHA IO_Latency_offset [21]
    CHB IO_Latency_offset [21]
    CHA RFR delay [14]
    CHB RFR delay [14]
    den DRAM RTL INIT value [x Wert] rechnen wir mit : (euer tCAS x 2) + IO-L bzw. 4 + IOL Offset bzw. 21 + 10
    Jetzt wo alles eingestellt, speichern und Neustarten!
    Wenn bootet wieder ins Bios und NUR DRAM RTL INIT value auf eine Zahl runter setzen, speichern und Neustarten!
    Und nun so weiter wiederholen mit DRAM RTL INIT value Senkung bis nicht mehr bootet.
    Nun haben wir irgendwann Punkt erreicht wo es nicht mehr bootet, dann Power Knopf 5 Sek. lang halten
    Rechner geht dann aus.
    Wieder Start Knopf drücken, mit F1 ins Bios landen und DRAM RTL INIT value auf den letzten funktionierenden Wert setzen, speichern und Neustarten und ins Windows booten lassen.
    So, sind wir im Windows,
    Starten nun und ASRock Timing Configurator Programm und schauen auf unsere IO-L´s an!
    Die werden im Idealfall gleich sein 7-7 oder 6-6 also, wenn nicht (was am meisten der Fall ist) zbsp. 7-6 oder 6-7 oder 7-13 oder 11-7 oder was auch immer,
    dann alles was wir nun brauchen ist nur auf unser Channel A or Channel B, schauen bei dem IOL Wert falsch ist.
    Beispiel:
    euer letzte ermittelte bootfähige DRAM RTL INIT value Wert ist 68 <---- nur für Beispiel genommene Zahl <---
    dabei hat es folgende RTL/IO-L Kombo bei euer DRAM RTL INIT value 68 trainiert
    62-63-6-7
    aber wir wollen natürlich unsere Werte auf 62-63-6-6 haben
    dann alles was wir nun brauchen ist:
    ins Bios gehen und unser CHB IO_Latency_offset auf von 21 auf [22] setzen weil genau da unser IO-L nicht stimmt! , speichern und Neustarten.
    Nun wird es 62-63-6-6 sein.
    Wollen wir mal unser RTL/IO-L Werte beispielweise auf 62-63-5-5 haben
    dann gehen wir ins Bios und erhöhen unser DRAM RTL INIT value Wert um eins höher UND NOCH beide CHA IO_Latency_offset / CHB IO_Latency_offset auch um eins höher., nun speichern und Neustarten.
    Schon wird es dann 62-63-5-5 sein!
    Falls jemand noch Fragen hat, einfach melden ;)
    P.S. - Was aber komisch oder ein Bug von ASRock Timing Configurator Tool ist - manch mal werden die Änderungen von CH IO_Latency_offset im ASRock Timing Configurator Tool nicht angezeigt (oder es ist nur bei mir so das ASRock Tool spinnt), das Asus MemTweakIt dagegen zeigt die Änderungen immer korrekt an (im Reiter "Timings 4" zusehen).
  • --> Deine Frage hier!
5) ASUS ROG Wallpaper
6) Wasserkühler (Mainboard)
[Sammelthread] ASUS ROG Maximus XI Apex (90MB0XV0-M0EAY0)
Reviews
  • 0021 (OC BIOS, New Sammy A2 Profiles)
  • 0093 (OC BIOS, allows higher voltages without LN2 switch)
  • 0033 (early OC BIOS)
Dancops ApeXI Guide (Samsung 8Gbit B-Die SR/A2): ROG Maximus XI APEX - NEW BIOS PROFILES small guide @ HWBOT Community Forums
M11G_01.jpg M11G_02.jpg M11G_03.jpg M11G_3D.jpg M11G_2D.jpg M11G_BP.jpg M11G_BP2.jpg M11G_3D500.jpg M11G_2D2.jpg M11G_2D500.jpg M11G_3D2.jpg ASUS ROG Maximus XI Gene QVL.png
Für die Gene-User, die evtl. auf auf das selbe Problem stoßen.
Neues Board (Bios 0702) eingebaut und konfiguriert. Läuft.
Danach testweise nur CPU + CPU opt Lüfter getauscht. Memory Error 23.
Bios zurückgesetzt und Profil geladen.
Board braucht dann wieder eine Ewigkeit bis der Speicher trainiert wurde.
Läuft.
CPU + CPU-Opt-Lüfter wieder getauscht. (OK Sonderfall, kann aber vorkommen)
Das selbe Spiele wieder. Error 23. Bios zurückgesetzt.
Profil geladen. Training … Training … Läuft.
Fazit: Nach 2x tauschen von CPU-Lüfter (Unterschiedliche Lüfter bzw Hersteller!) wieder ein 23 Error.
An Zufall glaub ich nicht mehr … Entweder ist das ein Fehler in der BIOS-Version im Umgang mit 2 x 16 GB und/oder vom Board selber
oder dem Baby muss man vorher gut zureden, wenn es sich mal seitlich hinlegen muss … :d
Ich werde mit Sicherheit jetzt keine (CPU) Lüfter mehr tauschen oder nochmals testen … nervt nämlich richtig.
Ich hätte da mal eine Frage an euch:
Ich nutze das M2 Modul auf meinem Maximus XI Apex und habe eine Samsung 970 Evo + 500 Gb verbaut. Auf der Seite vom Modul, wo keine M2 SSD verbaut ist, leuchtet seid heute eine rote LED.
Leuchtet diese weil keine M2 verbaut ist?
Da ich die ganze Beleuchtung deaktiviert habe, nervt dieses helle Rot doch schon ein wenig, da das Case auf dem Schreibtisch steht.
Habe unter google leider keine Lösung gefunden. Mich wundert es nur weil die LED vorher nicht geleuchtet hat.
Win 10 läuft einwandfrei auf der M2
MFG
Ich weiß nicht , ob hier die richtige Anlaufstelle ist oder eher im cpu Bereich, aber so langsam bin ich etwas am Ende. Hauptfrage ist meine COu kaputt oder das Board? RAM kann’s nicht wirklich sein, da ich es mit 3 Kits getestet habe.
Das Problem die CPU wird selbst im Auto Zustand und bei XMP Profil und standardtakt extrem heiß. Und das bei einer 360 AIO. Hinzukommmen so Sachen wie: manchmal geht die Tastatur beim Windows Start nicht, er schmeißt beim RAM OC random irgendwelche krummen RTL und IOS. Wenn ich die manuell eintrage, bootet er gar nicht und die Q Codes flackern quasi nur. Obwohl er diese RTLs und IOS schon davor selbst trainiert hat. Die Asus Prediction ist auch schon enorm zurückgegangen, so dass ich aktuell nur 4780 AVX stabile angezeigt bekomme. Die rote M2 LED die mein Vorgänger bereits erwähnt hat, habe ich bei mir auch schon gesehen.
Screenshots dazu: Imgur: The magic of the Internet
Ohne die Voltage zu sehen, ist das eh im trüben fischen ^^.
Dann kann es noch deine AIO sein die schlecht montiert ist oder falsch. Vielleicht ist sie auch hin oder hat nen Luftsack. Mal einen anderen Kühler drauf gepackt? Würde das aber auch in einen CPU Problem Thread packen.
Haha klar. Imgur hat irgendwie den Zweiten Screen da nicht. Bin gerade nur am Handy, aber vcore 1,22 , vccio 1,32 und sa 1,26. xmp profil 1 war aktiviert (bei dem Kit 3600 15 15 35. ) die Temperaturen sind nur durch den cpu z test , also noch nicht mal Prime oder Aida. Davor war ein d15s mit 2 Lüftern drauf. Lief 10 Grad kühler aber ist dann immer noch viel zu heiss oder? (Also selbst für den hitzkopf). Ich hab morgen noch nen 9900kf zum testen da.... würde nur hoffen, dass nicht das Board im arsch ist.
Also bei 1,22v unter last kommt das schon hin.
Wenn mit dem Noctua kühler war, stimmt aber was mit der aio nicht. Aber für standard Einstellung sind 1,2v viel.
Würde aber die Temperatur erklären, 9900k ist halt ein übelster Hitzkopf wenn du dann noch einen schlecht verlöteten hast kommt das hin. Würde erstmal die vcore senken wenn du den eh mit intel specs fährst
So um das aufzuklären: man muss auch peinliche Sachen zugeben: Die Wärmeleitpaste auf meiner Asus 360 AIO war ausgetrocknet......... Nachdem ich den Staub runtergekratzt habe und neue drauf gemacht habe, sind die Temperaturen nun besser als mit dem Noctua..... Zu @Majohandro: die rote LED ist ein fancy Zeichen und keine Warnleuchte soweit ich das Internet lesen konnte ;)
- - - Updated - - -
So mal wieder mehr zum eigentlichen Threadthema: Jemand schon das neue BIOS 1302 drauf und Erfahrungswerte? In der Beschreibung steht als Feature nur 9900KS Support.
Version 1302
2019/09/11 8.07 MBytes
ROG MAXIMUS XI APEX BIOS 1105
1. Intel Core i9-9900KS CPU support
Before running the USB BIOS Flashback tool, please rename the BIOS file (*.CAP) using BIOSRenamer.
Wo hast du denn das Bios gesehen? Finde nichts dazu.
EDIT: fehlt einfach nur auf der deutschen Seite
@The Professor: Sag mal, hattest Du nicht diese krassen RTL IO Trainingsprobleme? Hast Du diese mittlerweile gelöst? Die hab ich nämlich aktuell.... Also sehr genau das was Du hier oder im RAM OC Thread beschrieben hast.
Ja hatte ich. Sind nun gelöst, lag einfach daran, dass die Platine keine geraden IOs mochte. 6-6-6-6 sollte man erwarten, es war aber 6-6-6-7
1302 schluckt auch bei mir meine 2x16GB Settings nicht, auch entschäft bootet da gar nichts.
Nein auch dann nicht :d
Also ich spreche nicht für alle, aber viele beobachten das selbe. Alles nach 0702 Müll. Das Board bekommt einfach nichts trainiert. Ich habe alles sauber eingetragen, jeden Wert manuell, wie bei beim 0602 Setting, wo es sofort bootet. Bei 1302 Tod. Hab sogar sämtliche Werte entschärft, weiterhin 23 oder 55 oder mal buntes wildes geblinke, dass er gar nichts trainiert bekommt.
Ab Bios XXXX hat Asus den 2x16gb Support zurückgefahren. 4000Mhz sind kaum machbar.
2x16GB @4200
Läuft stabil ... 2/3rd Timings werden noch etwas gestrafft ... was halt noch möglich ist und 24/7 safe ist ...
Vorher lief der RAM@4000 mit 16-17-17-36 ... aber 4200 schaut einfach nicer aus ... für was haut man die fette Kohle raus ...
Da hätte ich mit mein Hero X ja weiterwurschteln können ... :d
Wobei das EVGA Dark einfach noch fetter ausschaut ... aber 550.- Mücken bei Amazon sind eine Ansage ...
Alleine schon, dass alle Anschlüsse beim Dark schön gewinkelt sind ... da hat jemand mitgedacht ... :hail:
2x16GB @4200
Läuft stabil ... 2/3rd Timings werden noch gestrafft.
Macht der IMC gut mit.
Andere Sache hatte gestern Windows neugemacht und dementsprechend natürlich einige Games geloadet. Mein Gene hat Spulenfipen aus der Hölle, wenn die Netzwerkkarte/Chip gefordert wird...dachte erst irgendein Lüfter wäre hinüber.
Seit Bios 0903 laufen keine 2x16gb mit mehr als 3733 Mhz bzw. selbst mit weniger Mhz eher schlechter. 0805 läuft noch wie die Vorgänger.
4133 bekomme ich nicht stabil gebootet.
Andere Frage: ich will die Lüftersteuerung für die CPU auf andere Werte setzen. Die Lüfter sollen konstant auf 300rpm (oder weniger laufen). Leider läßt Asus keine niedrigeren Werte zu. Und durch das Einmessen stimmen die Werte hinten und vorne nicht mehr. Wie kann man freie Werte eintragen?
Wie schon oft erwähnt bei 4000+ mit 2x16GB führt kein Weg an 0602 vorbei (0702 geht auch noch) alles darüber geht beschissen PUNKT
Frage in die Runde:
Nach sporadischen Nachstarts verbleibt der Rechner für ca. 10-15 Sekunden im Herunterfahren -> PC aus -> PC an und dann Neustart
Q-Code 23
IMC?
Zuwenig Voltage auf IMC/SA oder ist der IMC praktisch mit den Speed (4200) überfordert/am Ende?
Würde jetzt eher sagen der Ram mag nicht mehr ^^. Da werden die Timings zu straff sein oder der Takt zu hoch.
Hat jemand mit 1302 auch plötzlich schlechtere Latenzen trotz gleichem Setting? Gute 2-3ns mehr in AIDA, scheinbar nur durch das Bios. Bin jetzt aber gerade zu faul wieder zurück zu flashen.
Ich bekomm das Apex heute. Würdet ihr wie beim Gene um den Ram über 4000 laufen zu lassen auch das 602 Bios empfehlen?
Prozesse die im Hintergrund laufen?
Bei mir macht es z.B. auch 3-4ns aus, ob 96% idle oder 99%.
gibt's nicht...
für's Apex XI ist wohl das 0805 vergleichbar.
Wir reden aber schon über 2x16GB?!... ansonsten stellt sich die Frage nicht wirklich.
- - - Updated - - -
Frage in die Runde:
Q-Code 23
IMC?
eig uns mal deine RAM settings (AsRock Timing tool) und deine Spannungen (hwinfo64)
so aus dem Bauch heraus... Mode1, 1,485v, CL17-19-19, IO 1,25v, SA 1,3v (oder genau andersrum)
IO-L und RTLs trainieren lassen und event. von Hand schärfen.
https://abload.de/img/screenshot16f2jeu.png
https://abload.de/img/screenshot198aj0v.png
ne ist 2x8... da kann man auch einfach zum aktuellen greifen. Hab jetzt mit jmd geschrieben, ein meint er fährt gut mim 0022
Da Wheity im ASUS Support Unterforum ein entsprechendes Angebot gemacht hat, wollen wir das 2x16GB Problem der neueren BIOS Versionen beim Gene mal gemeinsam angehen?
Damit das Ganze gesittet abläuft und möglichst zielführend ist, bräuchte von euch folgende Infos:
1) Welche Kits sind betroffen/wurden getestet? Hier wären vor allem Modelle interessant, welche sich auch auf der QVL befinden (CMK32GX4M2F4000C19, F4-4000C19D-32GTZSW, F4-4000C19D-32GTZKK).
2) Wie äußert sich das Problem genau? Möglichst detaillierte Beschreibungen des Verhaltens beim POST (mit XMP/manuellem OC, ggf mit Video auf YT).
3) Welches ist die letzte nicht betroffene BIOS Version? Vermutlich ja 0602, es wäre in dem Zusammenhang aber gut, wenn auch noch mal jemand 0702 prüfen könnte.
4) Mit welchen BIOS Versionen wurde das Problem von euch verifiziert? Hier sind vermutlich vor allem die letzten drei Releases für den Support interessant.
( 5) Zur Sicherheit weil die Frage vermutlich kommen wird: Mit welchen Prozessor Modellen und welcher Kühlung wurde getestet? )
Ich werde die Informationen dann kompilieren, einen entsprechenden Thread im Support Sub erstellen und diesen auch hier verlinken.
Also mit dem Gene werde ich nicht warm ... weder mit GSKILL F4-4133C19D-16GTZA noch mit F4-4000C19D-32GTZA geht nix über 4100 ...
ob 8700K oder jetzt neu der 9900k ... SA/IMC/Voltage rumschrauben etc. etc.
Ständig Q-Code 23 und Lüfter beim Neustart auf 100% usw... Hero X wieder eingebaut mit 4x8 GSKill GTZA/KW und läuft ...
Mein Fazit ... nen Hero tuts genauso und schont meine Nerven ...
Und sowieso aktuell keine 16 GB Module verbauen ... zickig bis zum abwinken ... mit 1005 läuft nur XMP-Profil ...
sobald man irgendwas an den Timings verändert ... Code 23 ...
Ich beschäftige mich ja gerne mit Hardware ... aber Gene und RAM ...
Für sowas werde ich zu alt ...
16GB Module geht nur Bios 0602 und 0702 gescheit, selbst alles schon ausprobiert. Bei den neueren kommt man zusätzlich nicht mal mehr über 4000MHz, auch mein 4000C16 Setting läuft komplett ins leere 23 lässt grüßen.
Ähnliche Themen
