[Sammelthread] ASUS ROG Maximus VIII Series (Z170)
--- ASUS ROG Mainboards ---
Spezifikationen
ASUS Maximus VIII
Model (Abk.)Extreme (M8E)Formula (M8F)Hero (M8H)Ranger (M8R)Gene (M8G)Impact (M8I)
Bild?
PreisvergleichLinkLinkLinkLinkLinkLink
Formfaktor"E-ATX"
(305x272)
ATX
(305x244)
ATX
(305x244)
ATX
(305x244)
µATX
(244x244)
ITX
(170x170)
Erweiterungs-
steckplätze
(PCIe = 3.0)
3x PCIe x16 (16/0/0, 8/8/0, 8/4/4)
1x PCIe x16 (x4)
2x PCIe x1
3x PCIe x16 (16/0, 8/8)
1x PCIe x16 (x4)
3x PCIe x1
2x PCIe x16 (16/0, 8/8)
1x PCIe x16 (x4)
3x PCIe x1
1x PCIe x16 (x4)
3x PCIe x1
1x PCIe x4
1x PCIe x16
Storage1x M.2 (SATA & PCIe x4)
1 x U.2 (32Gbit/s)
6x SATA 6Gb/s (Z170)
2x SATA 6Gb/s ()
2x SATA Express
1 x U.2 (32Gbit/s)
1 x M.2 (SATA & PCIe)
6x SATA 6Gb/s
2x SATA 6Gb/s (ASM1061)
2 x SATA Express
2x SATA Express
1x M.2 (SATA & PCIe)
6x SATA 6Gb/s
2x SATA Express
6x SATA 6Gb/s
2x SATA Express
1x U.2 (32Gb/s)
4x SATA 6Gb/S
NetworkingIntel I219V
3×3 802.11ac Wi-Fi
Bluetooth 4.0 (BCM9436*)
Intel I219V
2x2 802.11ac Wi-Fi
Bluetooth V4.1 (Atheros)
Intel I219VIntel I219VIntel I219VIntel I219V
2×2 802.11ac Wi-Fi
Bluetooth 4.1 (Atheros)
USB (ext/int)2x USB 3.1 (2x Typ A, ASM1142)
2x USB 3.1 (Typ A+C*², Intel)
8x USB 3.0 (4+4)
6x USB 2.0 (0+6)
8x USB 3.0 (4+4)
2x USB 3.0 (ASMedia)
4x USB 2.0 (0+6)
2x USB 3.1 (Typ A+C, ASM1142)
6x USB 3.0 (2+4)
8x USB 2.0 (4+4)
6x USB 3.0 (2+4)
8x USB 2.0 (4+4)
8x USB 3.0 (6+2)
4x USB 2.0 (4+4)
2x USB 3.1 (Typ A+C, Intel)
6x USB 3.0 (4+2)
AudioSupremeFX 2015 (Realtek)
ESS ES9023P DAC
TI RC4580 OP Amp
ESS ES9023P
ESS ES9023P DAC
TI RC4580 OP Amp
ESS ES9023P DAC
TI RC4580 OP Amp
ESS ES9023P DAC
TI RC4580 OP Amp
ROG SupremeFX Impact III
ESS ES9023P DAC
TI RC4580 OP Amp
GrafikausgängeHDMI 1.4b
DisplayPort 1.2
Thunderbolt 3 (am Typ C)
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
DisplayPort 1.2
HDMI 1.4b
Sonstiges1) Spannungsmesspunkte
2) Heatpipekühler
3) Multi-BIOS
4) OC Panel II
1) ROG Armor
2) Waku-Anschlüsse
3) ROG Aura RGB Lighting
1) TB-Header1) TB-Header1) Spannungsmesspunkte
2) Heatpipekühler
1) M.2 durch Wi-Fi belegt
DownloadsSupportSupportSupportSupportSupportSupport
HandbuchE10739.pdfE11081.pdfE10343.pdfE10485.pdfE10484.pdfE10809.pdf
Special Features
BIOS
Bilder (vom M8G)
Alternativ in der Galerie zum Hardwareluxx Test ab Bild 18: bios-1 » Fotostrecken
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
ASUS Memory QVL:
1) ASUS Maximus VIII Extreme - 100915.pdf
2) ASUS Maximus VIII Hero - 081815.pdf
3) ASUS Maximus VIII Ranger - 20150805.pdf
4) ASUS Maximus VIII Gene - 081815.pdf
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
4) FAQ - Frequently Asked Questions
  • --> Deine Frage hier!
  • Q: Kann man von einer Samsung SM951 AHCI M.2 SSD booten?
  • A: Ja, das ist möglich - bestätigt durch Maverickpx200 ab BIOS 0603 (im UEFI Modus).
  • Q: Gibt es einen Trick gegen sporadische Bootprobleme mit für den Speicher typischen Debug Codes wie 41/44/55?
  • A: Im UEFI die Einstellung Maximus Tweak auf Mode 1 stellen. Dadurch wird Kompatibilität mit problematischen Kits verbessert.
  • Q: Sobald ich das XMP meines Speichers aktiviere habe ich Bildaussetzer am HDMI-Ausgang. Was kann ich dagegen tun?
  • A: Bei meinem System mit M8G war die Lösung VCCIO und VCCSA für den jeweiligen Speichertakt manuell auszuloten. Die AUTO Werte waren vermutlich deutlich zu hoch.
  • Q: Wie kann ich den Startvorgang des System beschleunigen?
  • A: Wer eine UEFI Installation hat, kann mal folgendes versuchen:
    Code:
    MRC Fast Boost [Enabled] [color=red]Vorher unbedingt die Speichereinstellungen auf Stabilität testen, da das Speicherretraining damit deaktiviert wird![/Color]
    MCH Full Check [Disabled]
    PCH Storage configuration Smart self test [Disabled]
    CSM [Disabled]
    Option ROM Messages [Disabled]
    Fast Boot [Enabled]
    POST delay time [0]
    Boot Logo [AUTO] oder [Full Screen]
    Start in unter 10 Sekunden, je nach Datenträger & Peripherie eventuell auch knapp darüber.
5) M8G Wallpaper (by emissary42)
6) Sondermodelle
HARDWARELUXX News Sondermodelle: ASUS ROG Maximus VIII Hero Alpha und ROG Maximus VIII Extreme/Assembly
SondermodelleProduktfotoPreisvergleichSupportUnterschiede (zum Standardmodell)
ASUS ROG Maximus VIII Extreme AssemblyLinkDownloadsPlasma Copper Color Scheme
+ 10Gbit PCIe x4 LAN Adapter
+ SupremeFX Hi-Fi Frontpanel
- OC Panel II
ASUS ROG Maximus VIII Hero AlphaLinkDownloads+ 2x U.2 (32Gbit/s)
+ ROG Aura RGB Controller (2x LED-Header)
Press Release: ASUS Republic of Gamers Announces Maximus VIII Extreme/Assembly and Matrix GTX 980 Ti
7) Wasserkühler (Mainboard)
WORK IN PROGRESS :angel:
Hallo *****,
noch mal vielen Dank für deine Antwort.
Auch das Update hat nicht geholfen. :-(
Ich habe noch einen USB Stick mit der Vorgänger Window 10 Version gefunden und habe wieder Version 1511 Build 10586 installiert,
schon funktioniert alles wider.
Also ist das auf jeden Fall ein Windows Problem ob es an der Unterstützung des Treiber oder an der jeweiligen Software von Roccat für die Maus oder Logitech für das Headset liegt kann ich so leider auch nicht sagen.
Ich hoffe mal das MS und die beider HW Hersteller nachbessern.
Ich hab eben mal versucht das Firmware update aufzuspielen aber es kam nur die Meldung your host device is not ready, firmware update failed... Muss ich auf was bestimmtest achten das es funktioniert?
UPADTE
Hab den Fehler selbst gefunden fürs formula brauch ich die firmware für den ASM1142A also den 3.0... Der 3.1 wird beim formula über den Intel Chipsatz bereitgestellt..
Mein 32" braucht zum "booten" länger als der Systemstart, deshalb ist es mir auch wayne ob dieser 5s oder 8s dauert :d
Ist hier irgendwer mit einem Maximus VIII und einem 2x16GB oder 4x16B Kit unterwegs (Hersteller und Takt egal)? Ich bräuchte mal MemTweakIt Screenshots von euren Kits @ XMP zum vergleichen :wink:
Edit: Die Bilder aus dem Startbeitrag sind fast vollständig wieder online
meinst du mit 4x16GB, 4 module a 4 GB =16GB oder meinst du mit 4x16GB 4 modula a 16GB=64GB? Zur ersten Konfiguration kann ich dir Screenshots mit xmp werten machen!
Hey, ich meinte tatsächlich Kits bestehend aus 16GB Modulen. Mit 4x4GB bin ich schon durch. Bekomme morgen dann mein erstes 2x16GB Kit und wollte vorab schon mal schauen, ob ich mir für den Test ein paar Timings genauer ansehen sollte. Kann dann hier im Thread auch schon ein paar Screenshots vorab zeigen.
Edit: Dein Kit ist noch gar nicht im Startbeitrag als kompatibel verlinkt? Gibst du mir mal die exakte Modellnummer und Version durch, dann trage ich es nach.
hehe ich glaub das könnte schwer werden jemand mit 4x16GB Modulen zu finden:)
Ja klar logisch, Corsair Vengeance LPX CMK16GX4M4B3000C15 XMP Profil ist nur eins hinterlegt, lief auf Anhieb problemlos in den xmp Einstellungen.
Warum haben denn die z170 ROG boards unterschiedlichen RAM takt Support? Sollte doch bei jedem board gleich sein oder? das impact hat ja bis 4133 MHZ Support das Hero bis 3800 MHz und das formula 3733 MHz wie kommt dieser unterschied zustande?
Ach, wir sind doch hier im Hardwareluxx und 2x16GB reichen mir für den Anfang auch :d
Das ist richtig so mit dem XMP, nur einige der 1.20V Modelle haben noch ein zweites XMP für 1.35V. Sind nun drin :wink:
Das Impact hat auf Grund der nur zwei vorhandenen Steckplätze, des kürzeren Abstands der Steckplätze vom Sockel und vielleicht auch dank des allgemein besseren Tracings mehr Speichertaktreserven. Schau dir mal das ASRock Z170M OC Formula, aus genau diesen Gründen besitzt es - obwohl es ein High End µATX Modell ist - auch nur zwei RAM Steckplätze; ebenso mit sehr geringem Abstand zum Sockel. Eventuell hat das eine oder andere Modell auch ein zwei extra PCB Layer, die laut Raja@ASUS dabei helfen (können) VCCSA zu sparen.
Einige NCase-Nutzer berichten von Problemen mit dem Impact VIII. So soll der PC nicht gleich beim ersten Mal Betätigen des Power Buttons hochfahren, sondern erst beim zweiten Mal. Anscheinend tritt das Problem nur im Zusammenhang mit dem Case und Asus-Boards auf. Auch bei MSI-Boards soll das Problem auftreten. Kann sich einer darauf einen Reim machen? Habe auch ein NCase und mir nen Impact VIII zugelegt :confused:
Letztlich bootet nun jedes meiner Boards in groben 10s, wenn man die Einstellungen durchprobiert. Mich interessiert daher nur noch der Logo-freie Bootvorgang, aber das ist nicht mehr wichtig. Zwischen 32 und 16 Gbyte (8er Riegel) merke ich keinen Unterschied. XMP zickt ebenfalls nicht herum.
Ein doppelter Systemstart heißt meistens: der Speicher muss mehrmals erkannt werden.
War das auf meine Frage bezogen? Ich habe es selbst noch nicht erlebt, aber es soll sich wohl so verhalten, dass beim Drücken des Powerbuttons der Lüfter kurz anspringt und das war es dann. Erst beim erneuten Betätigen des Powerbuttons fährt der PC hoch. Beobachtet wurde dieses Phänomen mit Boards von Asus und MSI in einem NCase. Ich kann mir keinen Reim darauf machen. Das Problem wird hier und hier ganz gut beschrieben.
Hab jetzt schon ein wenig Bammel, dass Impact VIII zu nutzen, und auch keine Böcke, wenn nachher alles eingebaut ist (WaKü und co.), alles wieder auszubauen.
Wenn das Problem auch beim Tischaufbau ohne das Gehäuse selbst bestehen bleiben, deutet alles auf das Netzteil als Ursache hin. Vielleicht ist dieses nicht 100% konform zum ATX Standard. Das führte damals auch beim PicoPSU zu ähnlichen Problemen mit u.a. einigen Gigabyte Modellen.
Als Netzteil wird das Corsair SF600 verwendet. Ich bleibe jetzt erst einmal beim Impact und schaue dann.
War es bei den beiden anderen Problemgeplagten auch ein SF600?
War nach deiner Beschreibung nicht also die G510S am USB 3.1 Steckplatz der Auslöser für das Problem?
Alle anderen Kombinationen, selbst mit Gladius und G15-R an einem USB 3.1 Controller haben doch funktioniert?
Dann bekommst du dein Schmerzensgeld eher von Logitech ;)
Edit: Aber warum auch die Eingabegeräte an den USB 3.1 Anschlüssen verwenden? Deshalb ist wohl auch sonst niemand darüber gestolpert bisher. Du kannst das natürlich mal als Bug an den Logitech Support melden, vielleicht lässt sich die Kompatibilität der G510S an USB 3.1 Controllern mit einem Firmware Update herstellen/verbessern.
Meh, hab Mouse und Tastaturbezeichnungen verwechselt. Dann schreib eben den ASUS Support an deswegen, das grundsätzliche Vorgehen ändert sich dadurch ja nicht. Ich würde mich aber auch nicht wundern, wenn du nur gesagt bekommst es wären USB 2.0 oder 3.0 Anschlüssen zu verwenden (weil das eben die einfachste Lösung ist).
G.Skill hat aber großes Vertrauen in seinen Arbeitsspeicher:fresse2: wo andere eine Quirll zur Kühlung bei niedriger getakteten Ram beilegen lösen sie das mit einem dermaßen massiven und ausgefeilten Heat Spreader.:hail:
Die G.Skill Trident Z silber/rot DIMM Kit 16GB, DDR4-4133, CL19-21-21-41 (F4-4133C19D-16GTZA) sind eingebaut, zuletzt mit XMP Profil Ram Takt 4133 und 1.4Volt kein Booten, werde aber alle Möglichkeiten durchspielen.
Zumindest laufen sie mit 3866MHz
4000Mhz:fresse2:
4040Mhz bei 1.4 Volt ist Schluß an den Timings brauche ich dann nicht mehr herumspielen sind dann die gleichen wie bei DDR4-4000.
Mist sind nur 8GB einer kaputt? Da war die ganze Zeit nicht richtig eingesteckt, wieder zum Anfang mit 3600MHz sieht jetzt aber schlechter aus mit 16GB.
Scheint bei 3733Mhz mit 1.4Volt Schluß zu sein mit zwei 8GB Riegel..........:sleep:
4000Mhz:fresse2:
Teste beide Module einzeln. Wenn beide für sich 4000+ laufen, wird das Kit an sich in Ordnung sein. Vielleicht bekommst du die 2x8 @ 3866 anschließend mit etwas Gefrickel auch noch stabil :bigok:
Gladius Firmware version 1.29 ... der Asus Support könnte die Maus "kompatibler" machen.
@ sledhammer
Die Tridentz laufen also nach meinen Erwartungen. Ohne das Impact VIII werden sie wohl "langsamer" laufen müssen. Oder es liegt an der CPU. Viel Spannung nützt manchmal was und manchmal überhaupt nicht. Ebenso müßte man IO und SA anpassen. Ich spiele mit dem Gedanken mir das Kit zu kaufen.
Hat schon mal jemand die aktuelle MEI Firmware von Station driver geflasht und macht es überhaupt Sinn diese zu aktualisieren?! Und hab ich das richtig verstanden das consumer die 1,5 MB version flachen müssen?
Ich bin so jemand der permanent die aktuellsten Treiber und Firmware auf dem PC haben muss;)
Nachricht gelöscht
Die 3866MHz laufen auch:fresse2:, die Einstellung im Bios ist DRAM Power Phase Control DRAM- Leistungsphasensteuerung auf Extreme, und die Volt Spannung wieder auf Standard 1.35 gestellt.
Da könnte noch was gehen, schön wäre eine glatte Zahl von 2000. Oh man hätte ich diese Einstellung mit 3866 bloß so gelassen lief ja mit dem Post hier im Forum. Wollte dann gleich auf 4000 aber kommt kein Booten und wieder zurück auf 3733MHz, vielleicht noch über den BLCK mit 101 das sind dann für den Ram 3916MHz würde auch reichen.
4040MHz sind aber auch verlockend:fresse2:, aber nur 8GB und wohin mit dem anderen Riegel.
2h gezockt und stabil mit 3733MHz
Den BLCK mal auf 101 gestellt und der Ram läuft jetzt mit 3770MHz, irgendwie muß das Bios Schrittweise angepaßt und jedes Mal neu gebootet werden für 3866, diese Hauruck Methode geht nicht.
@***** die XMP Timings im Bios sind nichts besonderes hinterlegt sind 19-21-21-41-2N alles andere steht auf Auto
Hallo Leute,
ich hoffe ihr könnt mir mit meinem Probleme helfen, da ich mittlerweile schon am verzweifeln bin:
Hier zuerst einmal meine Hardware:
Asus Maximus VIII Hero Alpha
i5 6600k
Zotac GTX 960 AMP
Corsair Dominator 3000MHZ 16gb
256Gb SSD EVO
1tb SSD EVO
h115i Corsair Wasserkühlung
7x Corsair LED 140mm Lüfter
BeQuiet 630W Pure Power Netzteil
OS: Windows 10 Pro 64Bit
Bios: 1902
Treiber und Windows Updates sind aktuell
Das Problem ist das mein PC in unregelmäßigen Abständen nicht herunterfährt (Monitor, HDDs und Tastatur/Maus gehen aus) die Lüfter laufen allerdings weiter. Benutze ich den PC nur ca. 1 Stunde zum Surfen etc. fährt der PC anstandslos herunter, game ich allerdings 2 Stunden+ bleiben die Lüfter beim herunterfahren eingeschaltet.
Hier im ROG Forum haben mehrere das Problem
https://rog.asus.com/forum/showthread.php?81504-solution-windows-doesnt-shutdown-on-maximus-boards
Was ich schon probiert habe:
Clear CMOS
Bios reset
Lüfter über BIOS steuern lassen (FAN Control)
unterschiedliche MEI Treiber ausprobiert
Was ich noch testen werden:
ErP auf s4+5 einstellen
USB 3.1 Controller Bios deaktivieren
Hat sonst noch jemand eine Idee?
Das einzige was ich im BIOS konfiguriert habe ist der Takt des RAM's auf 3000Mhz
Ist das vielleicht der Verursacher des Problems?
Ich gehe mittlerweile fest davon aus, dass das Problem vom BIOS aus kommt.
Ich hoffe ihr könnt mir weiterhelfen :)
Poste statt CPU-Z mal einen MemTweakIt Screen. Die primären Timings sind eher uninteressant, die Magie passiert in den anderen :fresse:
Edit: Den Download Link hatte ich vor ein paar Tagen erst hier im Thread gepostet, du findest es sonst aber auch in den Support Downloads jedes Maximus VIII Models.
Das einzige was ich im BIOS konfiguriert habe ist der Takt des RAM's auf 3000Mhz. Ist das vielleicht der Verursacher des Problems?
Das kannst du relativ leicht selbst testen, indem du den Speicher testweise @ Standard laufen lässt.
Das werde ich gleich mal testen wenn ich zu hause bin. Nur will man die 3000mhz ja auch voll auskosten, wenn man schon so einen Speicher hat :shake:
