	--- GIGABYTE Z97 OC Microsite ---
GIGABYTE Z97X-SOC Force
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- GIGABYTE Z97X-SOC Force @ hwbot ---
Spezifikationen
	| Model number | GA-Z97X-SOC FORCE |
| EAN | 4719331812232 |
| Form factor | ATX (305x244mm) |
| CPU | LGA1150 |
| Chipset | Intel® Z97 |
| Memory | Number of slots: 4 Channels: Dual Corresponding standard: DDR3 3300 (OC) / 3200 (OC) / 3100 (OC) / 3000 (OC) / 2933 (OC) / 2800 (OC) / 2666 (OC) / 2600 (OC) 2500 (OC) / 2400 (OC) / 2200 (OC) / 2133 (OC) / 2000 (OC) / 1866 (OC) / 1800 (OC) / 1600 / 1333 |
| Built-in graphics | D-sub (1920x1200 @ 60Hz) DVI-D (1920x1200 @ 60Hz) HDMI 1.4a (4096x2160 @ 24Hz, 2560x1600 @ 60Hz) DisplayPort 1.2 (4096x2160 @ 24Hz, 3840x2160 @ 60Hz) |
| Expansion slot | 4x PCI Express x16 (2x16, 1x8, 2x4 Lanes) 1x PCI Express x1 2x PCI |
| Multi-GPU | 4-Way AMD CrossFire, 2-Way NVIDIA SLI |
| Storage | 1x SATA Express* 6x SATA 6Gb/s (RAID 0/1/5/10 support) *SATA Express and SATA3_4/5 Port shared |
| Audio | 7.1 Channel Realtek HD Audio (ALC1150) |
| LAN | 1x Qualcomm Atheros Killer E2201 (Gigabit Ethernet) |
| Interface | 6x USB3.0 (4x Backpanel, 2x Internal) 8x USB2.0 (4x Backpanel, 4x Internal) |
| Internal connector | 1x 24-pin ATX main power 1x 8-pin ATX 12V power 1x 4-pin ATX 12V power 1x OC PEG power 1x SATA Express 6x SATA 6Gb/s 1x CPU fan header 1x water cooling fan header (CPU_OPT) 6x system fan headers 1x front panel header 1x front panel audio header 1x S/PDIF Out header 1x USB 3.0 / 2.0 header 1x USB 2.0 / 1.1 header 2x USB 2.0 / 1.1 ports 1x serial port header 1x Clear CMOS jumper 1x power button 1x reset button 1x Clear CMOS button 1x Gear button 1x OC Turbo button 1x OC Tag button 1x OC Trigger switch 1x CPU BCLK Down button 1x CPU BCLK Up button 1x CPU Ratio Down button 1x CPU Ratio Up button 1x Memory Safe button 1x Settings Lock button 1x Direct to BIOS button 1x OC DIMM switch 1x OC PCIe switch 1x OC Ignition button 1 Clear Battery button 2x BIOS switches 1x onboard voltage measurement module   |
| Back panel | 4 x USB 2.0 / 1.1 ports 4x USB 3.0 / 2.0 ports 1x optical S / PDIF Out connector 1x D-Sub port 1x DVI-D port 1x HDMI port 1x DisplayPort 1x PS/2 keyboard & mouse port 1x RJ-45 port 6x audio jacks (Center / Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In, Line Out, Mic In)   |
| BIOS | 2x 128 Mbit flash AMI UEFI BIOS Support for DualBIOS PnP 1.0a, DMI 2.7, WfM 2.0, SM BIOS 2.7, ACPI 5.0 |
| Supported OS | Windows 7 / 8 / 8.1 |
| Accessories | User manual Installation guidebook I/O shield Driver disk 4x SATA cable OC brace V-probes 2x SLI bridge |
BIOS
1) Bilder
 2) Spannungen
| CPU Vcore | 0.500V bis 1.800V -0.300V bis +0.400V | in 1 mV Schritten (Override) in 1mV Schritten (Offset) |
| CPU VRIN External Override | 1.000V bis 2.400V | in 10mV Schritten |
| CPU Graphics Voltage | 0.500V bis 1.800V -0.300V bis +0.400V | in 1mV Schritten (Override) in 1mV Schritten (Offset) |
| CPU RING Voltage | 0.800V bis 1.800V -0.300V bis +0.400V | in 1mV Schritten (Override) in 1mV Schritten (Offset) |
| CPU System Agent Voltage | -0.300V bis +0.400V | als Offset in 1mV Schritten |
| CPU I/O Analog Voltage | -0.300V bis +0,400V | als Offset in 1mV Schritten |
| CPU I/O Digital Voltage | -0.300V bis +0,400V | als Offset in 1mV Schritten |
| DRAM Voltage | 1.160V bis 2.100V | in 20mV Schritten |
| DRAM Termination | 0.325 bis 1.939V | in 3mV Schritten |
| PCH Core | 0.650 bis 1.300V | in 5mV Schritten |
| PCH I/O | 1.050V bis 1.900V | in 5mV Schritten |
3) BIOS Downloads - Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
- F3 (Initial Release)
- F4 (Changes: Enhanced OC & Memory Compatibility)
- F5 (Changes: CPU Microcode Update)
- F6 (Changes: G3258 Overclocking, Improve SSD Performance)
- F7e (Changes: Beta, Support future NVMe SSD drive)
- F7 (Changes: CPU Microcode Update, Achtung: Es ist anschließend kein Downgrade mehr möglich!)
- F8 (Changes: Enhanced 5th Gen Core Processors/Broadwell Support)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr, Garantieverlust!)
- Extreme OC (LN2): X04 / X06 / X08
- JZ Mod: Computertechnik JZelectronic
- Tweaktown (by stasio): GIGABYTE Latest Beta BIOS
- BETA F7e (Changelog: improve system performance)
- BETA F8A (Changelog: Enable eDRAM ratio control for Broadwell CPU)
News & Reviews
HARDWARELUXX Review Gigabyte GA-Z97X-SOC Force im Test
Hardwareluxx News: Gigabyte zeigt Intel Z97-Mainboards
Hardwareluxx News: Computex 2014: Gigabyte zeigt das GA-Z97X-SOC Force LN2
International Reviews
00) Gamezoom
01) Hartware.net
02) Tweakpc
03) Awardfabrik
04) ProClockers
05) OMF
06) Pclab.pl (Vergleichstest, 34 Modelle)
07) shahrsakhtafzar
08) Hardware Asylum
09) EasyCOM (ua)
10) Benchmark.rs
11) ocaholic
12) PC Perspective
13) PCaxe
14) pctuning.tyden.cz
15) Hardware.Info United Kingdom (Vergleichstest, 19 Modelle)
16) PC Ekspert
17) Legit Reviews
18) Benchit
19) HotHardware (Vergleichstest, 5 Modelle)
20) AnandTech
21) Z97 Motherboard LN2 Roundup @ Hardware.Info United Kingdom
ASRock Z97 OC Formula
ASUS Maximus VII Gene
Gigabyte Z97X-SOC Force
MSI Z97 XPower AC
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
- Hersteller Modell @ Preisvergleich | Quelle | kompatibel | Einschränkungen / Anmerkungen
- Hersteller Modell @ Preisvergleich | Quelle | inkompatibel | Grund
- be quiet! Dark Rock Pro 3 | User: iCrack | kompatibel
- Prolimatech Megahalems (alle Modelle, ab Rev 2) | User: emissary42 | kompatibel
- Thermalright Archon SB-E / IB-E (X2) | User: emissary42 | kompatibel
- Zero Infinity Phantom Knight | User: emissary42 | kompatibel
- --> Bitte helft mit sammeln!
2) RAM
- ADATA XPG V3 AX3U2933W4G12-DBV-RG | User: emissary42 | kompatibel | XMP wird mit 12-15-15 statt 12-14-14 geladen
- Corsair Dominator GT CMT6GX3M3A2000C8 | User: emissary42 | kompatibel
- Corsair Dominator Platinum CMD16GX3M4A2666C10 | User: emissary42 | kompatibel
- Corsair Vengeance CMZ8GX3M1A1600C9 (Ver5.12) | User: BlackNinja03 | kompatibel
- G.SKILL Ares F3-2133C9D-8GAB | User: emissary42 | kompatibel
- G.SKILL RipjawsX F3-2400C11D-8GXM | User: emissary42 | kompatibel
- G.SKILL TridentX F3-2400C9Q-16GTXD | User: emissary42 | kompatibel
- G.SKILL TridentX F3-2400C9D-8GTXD | User: emissary42 | kompatibel
- OCZ Reaper HPC Low Voltage OCZ3RPR2133C7LV4GK | User: emissary42 | kompatibel | Achtung: Module besitzen kein XMP!
- Samsung Green MV-3V4G3D | User: counterstriker | kompatibel | auch @ DDR3-2133(+)
- Team Group Elite TED38192M1333HC9DC | User: astra 1.8 | kompatibel
- Team Group Vulcan Orange TLAD316G2400HC11CDC01 | User: iCrack | kompatibel
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links & Tips (im Forum & im WWW)
1) Hardwareluxx
- http://www.hardwareluxx.de/communit...ews-links-bilder-reviews-z97-h97-1010600.html
- http://www.hardwareluxx.de/communit...table-guide-und-full-custom-liste-989828.html
- http://www.hardwareluxx.de/community/f11/intel-haswell-sockel-1150-geruechte-faq-infos-930594.html
- http://www.hardwareluxx.de/communit...l-sockel-1150-haswell-laberthread-962401.html
- http://www.hardwareluxx.de/communit...rgebnis-thread-kein-quatschthread-959285.html
2) WWW (international)
- Gigabyte OC Lab: GIGABYTE OC Lab had its first visitors, world records broken!
- Gigabyte Tech Blog: Windows XP Tools (Z97 Windows XP Downloads)
- Overclockers: The GIGABYTE Z97X Overclocking Guide
 Mirror @ XS: The GIGABYTE Z97X Overclocking Guide
- Gigabyte Support kontaktieren: Gigabyte eSupport (Germany)
3) Tips & Tricks
- Das Verhalten der Stromsparmechanismen beim Übertakten (vom Z87X-OC):
- Power-Off Dead Syndrom (Rechner lässt sich plötzlich nicht mehr einschalten)
 Wie ich dem Problem entgegne:
 Man kann das Board wieder zum Leben erwecken, indem man mit einer Litze das Netzteil manuell startet, während der Hauptstecker auf dem Mainboard sitzt. Das System läuft an, startet dann nochmal neu und danach geht es auch schon wieder in Windows.Alternativ: Das Board stromlos machen, die Batterie entfernen und das Board entladen (lassen, ca ~ 5 Minuten Wartezeit genügen).
emissary42 schrieb:
 ich will per Software auslesen können, was ich einstelle. Nicht mit nem Multimeter. Also, wenn ich 1,270V einstelle und 1,284V auslese, dann kann ich sicher sein, dass dennoch 1,270V anliegen?
