[Sammelthread] Gigabyte Z97X-SOC Force
--- GIGABYTE Z97 OC Microsite ---
GIGABYTE Z97X-SOC Force
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- GIGABYTE Z97X-SOC Force @ hwbot ---
Spezifikationen
Model numberGA-Z97X-SOC FORCE
EAN4719331812232
Form factorATX (305x244mm)
CPULGA1150
ChipsetIntel® Z97
MemoryNumber of slots: 4
Channels: Dual
Corresponding standard: DDR3
3300 (OC) / 3200 (OC) / 3100 (OC) / 3000 (OC) / 2933 (OC) / 2800 (OC) / 2666 (OC) / 2600 (OC)
2500 (OC) / 2400 (OC) / 2200 (OC) / 2133 (OC) / 2000 (OC) / 1866 (OC) / 1800 (OC) / 1600 / 1333
Built-in graphicsD-sub (1920x1200 @ 60Hz)
DVI-D (1920x1200 @ 60Hz)
HDMI 1.4a (4096x2160 @ 24Hz, 2560x1600 @ 60Hz)
DisplayPort 1.2 (4096x2160 @ 24Hz, 3840x2160 @ 60Hz)
Expansion slot4x PCI Express x16 (2x16, 1x8, 2x4 Lanes)
1x PCI Express x1
2x PCI
Multi-GPU4-Way AMD CrossFire, 2-Way NVIDIA SLI
Storage1x SATA Express*
6x SATA 6Gb/s (RAID 0/1/5/10 support)
*SATA Express and SATA3_4/5 Port shared
Audio7.1 Channel Realtek HD Audio (ALC1150)
LAN1x Qualcomm Atheros Killer E2201 (Gigabit Ethernet)
Interface6x USB3.0 (4x Backpanel, 2x Internal)
8x USB2.0 (4x Backpanel, 4x Internal)
Internal connector1x 24-pin ATX main power
1x 8-pin ATX 12V power
1x 4-pin ATX 12V power
1x OC PEG power
1x SATA Express
6x SATA 6Gb/s
1x CPU fan header
1x water cooling fan header (CPU_OPT)
6x system fan headers
1x front panel header
1x front panel audio header
1x S/PDIF Out header
1x USB 3.0 / 2.0 header
1x USB 2.0 / 1.1 header
2x USB 2.0 / 1.1 ports
1x serial port header
1x Clear CMOS jumper
1x power button
1x reset button
1x Clear CMOS button
1x Gear button
1x OC Turbo button
1x OC Tag button
1x OC Trigger switch
1x CPU BCLK Down button
1x CPU BCLK Up button
1x CPU Ratio Down button
1x CPU Ratio Up button
1x Memory Safe button
1x Settings Lock button
1x Direct to BIOS button
1x OC DIMM switch
1x OC PCIe switch
1x OC Ignition button
1 Clear Battery button
2x BIOS switches
1x onboard voltage measurement module
Back panel4 x USB 2.0 / 1.1 ports
4x USB 3.0 / 2.0 ports
1x optical S / PDIF Out connector
1x D-Sub port
1x DVI-D port
1x HDMI port
1x DisplayPort
1x PS/2 keyboard & mouse port
1x RJ-45 port
6x audio jacks (Center / Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In, Line Out, Mic In)
BIOS2x 128 Mbit flash
AMI UEFI BIOS
Support for DualBIOS
PnP 1.0a, DMI 2.7, WfM 2.0, SM BIOS 2.7, ACPI 5.0
Supported OSWindows 7 / 8 / 8.1
AccessoriesUser manual
Installation guidebook
I/O shield
Driver disk
4x SATA cable
OC brace
V-probes
2x SLI bridge
BIOS
1) Bilder
2) Spannungen
[table="class:grid"]
[tr][td]CPU Vcore[/td][td]0.500V bis 1.800V
-0.300V bis +0.400V[/td][td]in 1 mV Schritten (Override)
in 1mV Schritten (Offset)[/td][/tr]
[tr][td]CPU VRIN External Override[/td][td]1.000V bis 2.400V[/td][td]in 10mV Schritten[/td][/tr]
[tr][td]CPU Graphics Voltage[/td][td]0.500V bis 1.800V
-0.300V bis +0.400V[/td][td]in 1mV Schritten (Override)
[tr][td]CPU RING Voltage[/td][td]0.800V bis 1.800V
[tr][td]CPU System Agent Voltage[/td][td]-0.300V bis +0.400V[/td][td]als Offset in 1mV Schritten[/td][/tr]
[tr][td]CPU I/O Analog Voltage[/td][td]-0.300V bis +0,400V[/td][td]als Offset in 1mV Schritten[/td][/tr]
[tr][td]CPU I/O Digital Voltage[/td][td]-0.300V bis +0,400V[/td][td]als Offset in 1mV Schritten[/td][/tr]
[tr][td]DRAM Voltage[/td][td]1.160V bis 2.100V[/td][td]in 20mV Schritten[/td][/tr]
[tr][td]DRAM Termination[/td][td]0.325 bis 1.939V[/td][td]in 3mV Schritten[/td][/tr]
[tr][td]PCH Core[/td][td]0.650 bis 1.300V[/td][td]in 5mV Schritten[/td][/tr]
[tr][td]PCH I/O[/td][td]1.050V bis 1.900V[/td][td]in 5mV Schritten[/td][/tr]
[/table]
3) BIOS Downloads - Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
  • F3 (Initial Release)
  • F4 (Changes: Enhanced OC & Memory Compatibility)
  • F5 (Changes: CPU Microcode Update)
  • F6 (Changes: G3258 Overclocking, Improve SSD Performance)
  • F7e (Changes: Beta, Support future NVMe SSD drive)
  • F7 (Changes: CPU Microcode Update, Achtung: Es ist anschließend kein Downgrade mehr möglich!)
  • F8 (Changes: Enhanced 5th Gen Core Processors/Broadwell Support)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr, Garantieverlust!)
News & Reviews
HARDWARELUXX Review Gigabyte GA-Z97X-SOC Force im Test
Hardwareluxx News: Gigabyte zeigt Intel Z97-Mainboards
Hardwareluxx News: Computex 2014: Gigabyte zeigt das GA-Z97X-SOC Force LN2
International Reviews
00) Gamezoom
01) Hartware.net
02) Tweakpc
03) Awardfabrik
04) ProClockers
05) OMF
06) Pclab.pl (Vergleichstest, 34 Modelle)
07) shahrsakhtafzar
08) Hardware Asylum
09) EasyCOM (ua)
10) Benchmark.rs
11) ocaholic
12) PC Perspective
13) PCaxe
14) pctuning.tyden.cz
15) Hardware.Info United Kingdom (Vergleichstest, 19 Modelle)
16) PC Ekspert
17) Legit Reviews
18) Benchit
19) HotHardware (Vergleichstest, 5 Modelle)
20) AnandTech
21) Z97 Motherboard LN2 Roundup @ Hardware.Info United Kingdom
ASRock Z97 OC Formula
ASUS Maximus VII Gene
MSI Z97 XPower AC
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tips (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
  • Das Verhalten der Stromsparmechanismen beim Übertakten (vom Z87X-OC):
  • Power-Off Dead Syndrom (Rechner lässt sich plötzlich nicht mehr einschalten)
    Wie ich dem Problem entgegne:
    Man kann das Board wieder zum Leben erwecken, indem man mit einer Litze das Netzteil manuell startet, während der Hauptstecker auf dem Mainboard sitzt. Das System läuft an, startet dann nochmal neu und danach geht es auch schon wieder in Windows.
    Alternativ: Das Board stromlos machen, die Batterie entfernen und das Board entladen (lassen, ca ~ 5 Minuten Wartezeit genügen).
emissary42 schrieb:
Falls noch jemand das Bild von der Verpackung als Wallpaper haben möchte:
Ist nur abfotografiert, sieht aber halbwegs original aus.
Updates: Review Sektion, Spannungsangaben (UEFI), OC-BIOSe
Geplant ist ein kombiniertes User Review. Mit dem Speicher geht es los, denn der ist wirklich überfällig.
Schöner Thread :wink:, das Gigabyte wäre es bei mir fast geworden. Bin gespannt auf deinen Test! - um welches Kit handelt es sich?
Es sind zwei Samsung basierte TridentX, die auch schon in der Kompatibilitätsliste stehen ;)
Das Training insbesondere mit X-PSC soll ziemlich ätzend sein, aber ich wollte einfach mal was Neues haben und mit meinem Z87X-OC war ich nicht unzufrieden. Die meisten Alternativen sind aus der Auswahl rausgeflogen, weil sie entweder keinen DisplayPort besitzen (ASRock OCF, ASUS Hero/Gene) oder das VRM ein zu großer Rückschritt gewesen wäre (MSI Mpower*).
Gibt es eventuell eine Black Friday Aktion von Gigabyte? Irgendwas womit ich sparen könnte? Wäre ja blöde jetzt einfach so zu kaufen... Gefällt mir außerordentlich gut! Denke mal mein Dark Rock Pro 3 passt, teste es dann natürlich!
Ich brauche aber keine neue CPU, mein 4670K läuft wie Sau :/
Schade! Naja, morgen bezahlt man keinen Versand für Gigabyte MoBos bei Mindfactory...
Ist mir doch driss egal, das kann sonst wat für ein Brauch sein, wenn ich damit Geld spare, dann heiße ich den Brauch in DE willkommen. Egal woher er kommt...
So, BIOS Screens sind nun auch online.
Hast du vielleicht ein Bild des Mainboards im Betrieb? Bezüglich der Beleuchtung des Mainboards, das würde mich noch interessieren...
Ich habe kein Bild aus der Dunkelkammer. Hier im Büro sind eher ergonomische Helligkeitsverhältnisse angesagt :fresse:
Geben die verlinkten Reviews dazu nichts her?
Habe nichts passendes gefunden, hoffe nur, dass MB ist kein Blingbling Board und kann sämtliche Beleuchtung abstellen :)
Ich sehe von meinem Board nur die Debugsegmentanzeige, den Power-Button und die LED für HDD-Zugriffe und das aktive BIOS leuchten.
Das hört sich gut an :) Danke!
Ich hoffe ja, dass durch die Amazon Aktion hier in den nächste Tagen noch ein paar Leute eintrudeln^^
Ein paar Fotos vom Board kommen die Tage auch noch. Wenn es sonst noch Wünsche für den ersten Beitrag oder Fragen gibt, immer raus damit.
Amazon Aktion? :X
Waren es nicht Amazon die einfach mal ein Board zu viel ins Paket gelegt haben?
Ich habe davon nichts mitbekommen, gibts nähere Infos? :D
Hoppala... Verdammt. Hätte ich das vorher gewusst. Jetzt hat Mindfactory eine PayPal-Zahlung von mir erhalten [emoji24]
Dafür ist es glaube ich auch schon eine Weile zu spät ;)
OK, ich freue mich einfach nur auf das Board. Endlich dem 4670K so richtig die Sporen geben...
Sag mal, macht es Sinn, auch im normalen OC Bereich mit diesen genialen kleinen Schaltern die beiden ungenutzten DIMM-Slots sowie alle ungenutzten PCIe-Slots abzuschalten? Ich meine, Strom sollte es ja mindestens sparen oder? Und Nachteile hat man ja keine dadurch, also spricht nichts dagegen alles unnötige abzuschalten, richtig?
Die PCIe Slots hatte ich bei meinem Z87X-OC in der Regel auch deaktiviert. Dass man die Speichersteckplätze nun abschalten kann ist für mich auch Neuland, also keine Erfahrungswerte bisher.
Werde das beides mal probieren :) ich freue mich wie Bolle auf das Brett
bin nun ernsthaft am überlegen das soc einzubauen. leider weiss ich, dass windoof dann wieder probleme machen wird (erst vor kurzem von asus z97x hero auf gigabyte z97x ud3(?) umgebaut, zwei rechner, der eine hat sofort alles erkannt, der andere wollte keine usb geräte annehmen [identische firmenrechner mit identischer software])
oder gibt es da was zu beachten?
ende der woche werde ich wohl auf wakü umbauen, da würde ich dann wahrscheinlich sowieso wechseln, aber bis dahin habe ich langeweile (urlaub und frau nicht :banana:)
Treiber drüber, fertig. Oder halt schnell Stündchen für die Installation opfern :D
