Spezifikationen Spezifikationen
CPU
- AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
- AMD 140W CPU Support
- AMD Cool 'n' Quiet™ Technology
- Supports 45nm CPU
- Northbridge:
- AMD 890FX chipset - Southbridge:
- AMD SB850
- 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
- Dual Channel memory architecture
- 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
- 1 x PCIe 2.0 x4
- 2 x PCI 2.2
- Support ATI CrossFire™X Technology graphics cards
- SB850 Chipset
- 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10 - JMicron® JMB363 PATA and SATA controller
- 1 x SATA 3Gb/s port (Black)
- 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
- SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
- EAX® Advanced™ HD 4.0
- X-Fi CMSS®-3D
- X-Fi Crystalizer™
- Creative ALchemy
- Supports Blu-ray audio layer content protection
- Supports 1 Optical S/PDIF out port at back I/O
- Supports 1 x S/PDIF out header
- Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
- Marvell 8059 Gigabit LAN controller
- 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
- 6 x SATA 6Gb/s connectors (Red)
- 1 x SATA 3Gb/s connectors (Black)
- 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
- 7 x ProbeIt measurement points
- 3 x Thermal sensor connectors
- 1 x IEEE1394a connector
- 1 x SPDIF_out connector
- 1 x 24-pin ATX power connector
- 1 x 8-pin ATX 12V power connector
- 1 x En/Dis-able Clr CMOS switch
- 1 x Core unlocker switch
- 1 x Turbo key II switch
- 1 x Power on switch
- 1 x Reset switch
- 1 x OC Station Header
- 1 x Go Button
- System panel connector
- 1 x External SATA
- 1 x S/PDIF Out (Optical)
- 1 x IEEE 1394a
- 1 x LAN(RJ45) port
- 8 -Channel Audio I/O
- 1 x PS/2 Keyboard port(purple)
- 2 x USB 3.0/2.0 ports
- 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
- 1 x ROG Connect On/Off switch
- 1 x Clr CMOS switch
- Turbo Key II
- Core Unlocker
- ASUS Q-Connector
- ASUS Q-Shield
- ASUS Q-Fan 2
- ASUS EZ Flash 2
- ASUS CrashFree BIOS 3
- ASUS MyLogo 3
- User's manual
- 1 x I/O Shield
- 1 x ROG Connect Cable
- 1 x 2-in-1 ASUS Q-Connector Kit
- 1 x 2-in-1 SATA 6.0Gb/s Cables
- 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
- 1 x 2-port USB2.0 + ESATA Module
- 1 x Crossfire Cable
- 1 x Cable Ties Pack
- 1 x ROG Theme Label
- 1 x 12-in-1 ROG Cable Label
DownloadsDownloads
Bios Downloads
- Bios 0505
- First release Bios - Bios 0602
- Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS. - Bios 0701
- Improve the stability of certain hard drives. - Bios 0707 (BETA)
- Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
- Enhance gaming performance.
- Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
- Enhance SATA6G performance
- Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS. - Bios 0801
- Improve memory compatibility - Bios 0905 (BETA)
- Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
- Enable support of CPU ratio control for 6 core Thuban processor via OC Station
- Enable ROG Connect and OC Station support under high HT Frequency.
- Enable the support of CPU Level Up function for Phenom II X4 965
- Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control - Bios 1005
- Improve system stability - Bios 1102
- Support new CPUs
Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
- EK Waterblocks Fullcover EK-FB ASUS Crosshair 4 Nickel Plexi Edition / Acetal Edition
- MIPS ASUS Crosshair IV Fullcover POM Edition / POM + Nickel (limited) Edition
- Anfi-tec ASUS Crosshair IV Formula Lightcover Mosfest + NB Kühler & Anfi-Tec SB Kühler
keine der seiten von denen du deine infos bezogen hast ist aktuell, leider.
