Official ASUS BIOS and Program Updates - [H]ard|Forum
P8P67 Deluxe / Pro / EVO / Standard / - 1305 -
Change Log -- Improved OC performance using Multipliers or Auto Overclocking
- Improved BCLK and DRAM OC capabilities when enabling the “Internal PLL Overvoltage” option in BIOS. Note - Sleep/Hibernate will not operate properly due to Intel Specs.
- Improved USB performance, Improved P67 XMP profile compatibility (please note, memory with X58/P55 XMP profiles will generally work but is not optimized for P67 and will usually cause problems when overclocking in several cases)
- Per Core Save Fixed
- Disable/Enable BT
- Minor Bug Fixes including new Auto Rules for C-States (C3/C6) when overclocking. If you are overclocking, C-States will be disabled for enhanced performance.
- Intel RAID will not support bootable volumes greater than 2.2TB yet, Intel plans a firmware update shortly to allow this operation. AHCI and IDE are not affected.
- Enhanced AI Suite II compatibility
Note - These UEFI releases will be on our FTP and Support Sites shortly.
UEFI 1305 - Pro
P8P67-PRO-ASUS-1305.rar
UEFI 1305 - Standard
P8P67-ASUS-1305.rar
UEFI 1305 - EVO
P8P67-EVO-ASUS-1305.rar
UEFI 1305 - Deluxe
P8P67-DELUXE-ASUS-1305.rar
- Disable/Enable BT
UEFI 1305 - Pro
P8P67-ASUS-1305.rar
UEFI 1305 - EVO
UEFI 1305 - Deluxe
Das paradoxe ist ja, dass man mit günstigeren Boards meist bessere OC Ergebnisse hinbekommt, siehe MSI GD65 oder P8P67 Evo... Im Schnitt gute 200-250MHz mehr Takt, das sind Welten beim Benchen.
