Inhalt des Sammelthreads
4Biosdetails und OC Ergebnisse
Vom Board bereitgestellte Spannungen im Bios:
OC Ergebnisse
Core i5-750 Lynnfield @ 4Ghz / DDR3-1776
5Downloads
Bios Downloads (flashen auf eigene Gefahr!)
- Bios 0209
- release Bios - Bios 0504
- Improve system stability - Bios 0606
- Support Low Voltage DRAM Module - Bios 0711
- Disable EIST and CIE functions if BCLK is higher than 150MHz
- Support IXTU utility - Bios 0911
- Improve compatibility with some USB device - Bios 0915
- Improve memory compatibility
- Improve Auto Tuning performance - Bios 1002
- Improve system stability - Bios 1102
- Support new CPUs - Bios 1207
- Update JMicron 361 Option ROM
- Update EZ-flash 2 function
- Fix some PCIEx1 LAN card can't be detected at PCH PCIEx1 slot.
- Update CPU Level Up function.
- Fix CPU power always show 2.5W in EPU software.
