Produktüberblick:
A780GXH/128M
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Support for Socket AM3 processors: AMD Phenom™ II X4 / X3 and Athlon II X4 / X3 / X2 processors
3. Solid Capacitor for CPU power
4. Supports CPU up to 140W
5. Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
6. Supports Hyper-Transport 3.0 (HT 3.0) Technology
7. AMD 780G + SB710 Chipsets
* FSB 2600 MHz (5.2 GT/s)
* Supports Dual Channel DDR2 1066 with AM2+ CPU, and DDR2 1066/800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3200 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Supports ATI™ CrossFireX™ and Hybrid CrossFireX™
* Integrated 128MB side port memory for iGPU
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, orange @ x4 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* Supports ASRock Instant Boot
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver
* 7.1 CH Windows® Vista™ Premium Level HD Audio (VIA® VT1708S Audio Codec with QSound)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x HDMI port, 1 x RJ-45 LAN Port with LED, 4 x USB 2.0 Ports
Produktspezifikation:
Herstellerlink: http://www.asrock.com/mb/overview.asp?Model=A780GXH/128M&s=AM2+
Treiber- und BiOS-Downloadlink:
http://www.asrock.com/mb/download.asp?Model=A780GXH/128M&s=AM2+
Aktuelles BIOS: 1.70 Downloadlink: http://www.asrock.com/mb/download.asp?Model=A780GXH/128M&o=BIOS
Geizhalslink: http://preisvergleich.hardwareluxx.de/deutschland/a407102.html
Die Prozessorunterstützung mit dem Releasebios (1.00) ist bis zu den aktuellen AM3 Prozessoren gegeben (X3 710, 720BE, X4 810), natürlich werden alle bisherigen CPUs auch unterstützt (AM2 bzw. AM2+).
Mein Noctua NH-U12P passt wie eine Eins.
Der Onboardgrafikchip kann Auflösungen bis zu 2560x1600 fahren!!
Dies war bis vor kurzem beim AOD790GX/128M nicht möglich. Es könnte aber sein, dass dies mit dem aktuellen BIOS möglich ist.
Viele Eigenschaften gleichen dem "großen Bruder" AOD790GX/128M, da das A780GXH auf dessen PCB (Platine) basiert.
Und hier noch ein paar Bilder vom Einbau:
A780GXH/128M
Code:
General
CPU - Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
- Support for AM3 processors: AMD Phenom™ II X4 / X3 and Athlon II X4 / X3 / X2 processors
- Supports CPU up to 140W
- Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
- AMD LIVE!™ Ready
- Supports AMD's Cool 'n' Quiet Technology
- FSB 2600 MHz (5.2 GT/s)
- Supports Untied Overclocking Technology
- Supports Hyper-Transport 3.0 (HT 3.0) Technology
Chipset - Northbridge: AMD 780G
- Southbridge: AMD SB710
Memory - Dual Channel DDR2 memory technology
- 4 x DDR2 DIMM slots
- Supports DDR2 1066/800/667/533 non-ECC, un-buffered memory
- Max. capacity of system memory: 16GB*
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® XP and Windows® Vista™. For Windows® XP 64-bit and Windows® Vista™ 64-bit with 64-bit CPU, there is no such limitation.
BIOS - 8Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, DRAM, NB Voltage Multi-adjustment
- Supports Smart BIOS
Audio, Video and Networking
Graphics - Integrated AMD Radeon HD 3200 graphics
- DX10 class iGPU, Pixel Shader 4.0
- Max. shared memory 512MB
- Integrated 128MB side port memory for iGPU
- Three VGA Output options: D-Sub, DVI-D and HDMI
- Supports HDCP function
- Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
Audio - 7.1 CH Windows® Vista™ Premium Level HD Audio (VIA® VT1708S Audio Codec)
LAN - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111DL
- Supports Wake-On-LAN
Expansion / Connectivity
Slots - 2 x PCI Express 2.0 x16 slots (green @ x16 mode, orange @ x4 mode)
- 1 x PCI Express 2.0 x1 slot
- 2 x PCI slots
- Supports ATI™ CrossFireX™ and Hybrid CrossFireX™
Connector - 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10 and JBOD), NCQ, AHCI and "Hot Plug" functions
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x HDMI_SPDIF header
- CPU/Chassis/NB/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- CD in header
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports)
Rear Panel I/O I/O Panel
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x VGA/D-Sub Port
- 1 x VGA/DVI-D Port
- 1 x HDMI Port
- 1 x Optical SPDIF Out Port
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Other Features / Miscellaneous
Unique Feature - ASRock OC Tuner
- Intelligent Energy Saver (Support with Phenom CPU)
- Instant Boot
- Hybrid Booster:
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
- ASRock AM2 Boost: ASRock Patented Technology to boost memory performance up to 12.5%
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version), AMD OverDrive™ Utility, AMD Live! Explorer, AMD Fusion
Accessories - Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 Cables
- 2 x SATA Data Cables (optional)
- 1 x SATA 1 to 1 Power Cable (optional)
Hardware Monitor - CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU/Chassis/NB/Power Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore
Form Factor - ATX Form Factor: 12.0-in x 8.4-in, 30.5 cm x 21.3 cm
- Solid Capacitor for CPU power
OS - Microsoft® Windows® XP / XP Media Center / XP 64-bit / Vista™ / Vista™ 64-bit compliant
Certifications - FCC, CE, WHQL
Spannung manuell erhöt, timings manuell eigenstellt.
