Asus Crosshair III Formula
Bilder:
Spezifikationen:
- AMD 790FX / SB750 Chipset
- Unterstützt AM3 45Nm Phenom II ; Athlon II CPU's (Sockel 941)
- 4 x DIMM, 16 GB, DDR3 1600*/1333/1066 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
- 2x PCIe 2.0 x16 Slots (Crossfire Unterstützung)
- 1x PCI
- 3x PCIe x1 (der schwarze für die SupremeFX)
- SupremeFX X-FI Audio Card
- Formfaktor: ATX
- 5x SATA 3 Gb/s ports 0,1,5,10,JBOD
- 1x eSATA
- 1x IDE
Lieferumfang:
- Handbuch + Quick Start Guide
- Treiber CD
- SupremeFX X-FI Soundkarte
- LCD Poster
- 5x SATA Kabel
- 1x IDE Kabel
- 2x USB/1x Firewire Slotblech
- Asus Q-Connector
- Kabelbinder
Herstellerlink:
ASUSTeK Computer Inc.
Preise:
Hardwareluxx - Preisvergleich
BIOS-Versionen:
- 0302 (Auslieferungs BIOS)
- 0403 ASUSTeK Computer Inc.-Support-
Changelog: Fix CPU uCode might not be loaded successfully.
- 0503 ASUSTeK Computer Inc.-Support-
Changelog: Fix the system may not be able to wake up from sleep mode of S1/S3/S4.
- 0601 Downloadlink gleich wie bei 0403 und 0503
Changelog: Support new CPUs
- 0702 Changelog: Fix inconsistency of CPU/Chassis fan speed with Q-Fan enabled in BIOS setup and Operating System.
- 0805 Changelog: 1.Fix Target DRAM Frequency may show incorrect with DDR3-1333 memory when DRAM Frequency is set to Auto in BIOS setup.
2.Show SATA information in IDE mode and hide them in RAID mode or AHCI mode in BIOS setup.
3.Improve ACC unleashing mode function.
- 0903 Changelog: 1. Fix Target CPU Frequency is incorrect in BIOS setup when CPU Ratio is set to manual mode.
2. Fix the system will increase extra Vcore voltage when selecting default ratio of the processor in BIOS setup.
- 1003 Changelog: 1.Fix it may fail to install OS when 4GB memory is used.
2.Fix the system may be unstable when unleashing mode is applied with certain CPU.
3.Fix S3 resuming may fail.
4.Improve the stability in Win7 when AHCI mode is enabled.
5.Support new CPUs. Please refer to our website:ASUSTeK Computer Inc.-Support-
- 1105 Changelog: Improve the function of setting up unleashing mode
- 1204 Changelog: Improve the stability of certain CPU
- 1301 Changelog: 1.Fix power button may not work under certain operating system with C1E enabled.
2.Improve USB performance with C1E enabled.
- 1403 Changelog: Improve system stability when AOD overclocking and EPU is enabled
- 1503 Changelog: 1.Fix Function Key may not work with certain keyboards.
2.Fix wrong hard disk size may be recognized in POST with quick boot disabled.
- 1602 Changelog: Crosshair III Formula BIOS 1602
- 1702 Changelog: Enhance the stability of certain CPU
- 1805 Support new CPUs.
- 1904 Support new CPus.
- 2002 1.Improve System Stability.
2. Support new CPUs.
- 2003 Improve system stability.
Kompatible Speicher lt. Asus (QVL)
Getesteter RAM:
- GeIL Value DIMM Kit 4GB PC3-10667U CL7-7-7 (DDR3-1333) (GV34GB1333C7DC) ---> OK
- OCZ ram 1600 LVAM 7-7-7-16-24@1,65V ---> OK
- 2x2048MB Kit A-DATA 1333MHz CL8 ---> OK
- GSkill F3-12800CL9D-4GBNQ ---> OK
- Corsair XMS3 Dominator DIMM Kit 4GB PC3-12800U CL8-8-8-24 (DDR3-1600) (CMD4GX3M2B1600C8 ---> OK
- OCZ DIMM 4 GB DDR3-1333 Kit (OCZ3P13334GK) ---> OK
- Patriot Viper II Sector 5 DIMM Kit 4GB PC3-12800U CL8-8-8-24 (DDR3-1600) ---> OK
- G.Skill Ripjaws 4 GB DDR3-1333 F3-10666CL7D-4GBRH DIMM Kit ---> OK
Kompatible Luftkühler:
Xigmatek Dark Knight - bedeckt den ersten blauen Ramslot
Scythe Mugen 2 - bedeckt die blauen Ramslots
EKL Alpenföhn Brocken
Noctua NH-U12P
Noctua NH C12-P
Review: (Englisch)
ASUS Crosshair III Formula Motherboard Review :: Introduction :: Motherboards.org
ASUS Crosshair III Formula Review
ASUS Crosshair III Formula Deutsch
Bekannte Probleme mit dem Board:
- ACHTUNG: bei win7 funz die creative software für die soundkarte nicht, die karte selbst läuft aber
- VCore Schwankungen, siehe ab Post 83 !
. War bischen umständlich an dit 0601 zu kommen, aber ich habs jetzt druff
