[Sammelthread] Asus Rampage II Extreme R.o.G. (Intel X58) [3]
Chrisch
Legende
Münsterland
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 12 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
    - Triple channel memory architecture
    - * Supports Intel® Extreme Memory Profile (XMP)
    - **Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
Expansion Slots
  • 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
  • 2 x PCIe 2.0 x 1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8 -Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
Internal I/O Connectors
  • 3 x USB connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector
  • 7 x SATA connectors
  • 1 x IEEE 1394a connector
  • 1 x Chassis Fan connector
  • x 8-pin ATX 12V Power connector
  • 24-pin ATX Power connector
  • 1 x EL I/O Shield Connector
  • 3 x thermal sensor connector
  • 1 x En/Dis-able Clr CMOS connector
  • System Panel
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 8 x ProbeIt connectors
  • 1 x LCD Poster connector
  • 1 x BIOS FlashBack boot up selection header
  • 1 x ROG light connector
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Special Features
  • External LCD Poster
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Accessories
  • ProbeIt Cable
  • 3-Way SLI Cable
  • SLI Cable
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: Xfastest.com)​
Das BiosDas Bios
- Bilder folgen
Biostemplate (Extreme Tweaker)Biostemplate (Extreme Tweaker)
Code:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
OC From CPU Level Up:
OC From Memory Level Up:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
EPU II Phase Control:
Loadline Calibration:
CPU Differential Amplitude:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
QPI/DRAM Core Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
Keyboard TweakIt Control:
CPU Spread Spectrum:
PCIE Spread Spectrum:
CPU Clock Skew:
IOH Clock Skew:
CPU-Configuration
CPU Ratio Setting:
C1E Support:
Hardware Prefetcher:
Adjacent Cache Line Prefetch:
Intel(R) Virtualization Tech:
CPU TM Function:
Execute Disable Bit:
Intel(R) HT Technology:
Active Processor Cores:
A20M:
Intel(R) C-STATE Tech:
-C State package limit setting:
DRAM Timing Control
DRAM CAS# Latency:
DRAM RAS# to CAS# Delay:
DRAM RAS# PRE Time:
DRAM RAS# ACT Time:
DRAM RAS# to RAS# Delay:
DRAM REF Cycle Time:
DRAM WRITE Recovery Time:
DRAM READ to PRE Time:
DRAM FOUR ACT WIN Time:
DRAM WRITE to READ Delay:
DRAM Timing Mode:
DRAM Round Trip Latency on CHA:
DRAM Round Trip Latency on CHB:
DRAM Round Trip Latency on CHC:
DRAM WRITE to READ Delay(DD):
DRAM WRITE to READ Delay(DR):
DRAM WRITE to READ Delay(SR):
DRAM READ to WRITE Delay(DD):
DRAM READ to WRITE Delay(DR):
DRAM READ to WRITE Delay(SR):
DRAM READ to READ Delay(DD):
DRAM READ to READ Delay(DR):
DRAM READ to READ Delay(SR):
DRAM WRITE to WRITE Delay(DD):
DRAM WRITE to WRITE Delay(DR):
DRAM WRITE to WRITE Delay(SR):
DRAM REF Voltage
DRAM DATA REF Voltage on CHA/B/C:
DRAM CTRL REF Voltage on CHA/B/C:
DownloadsDownloads
Bios Downloads
  • Bios 0407
    - First release Bios
  • Bios 0503
    - Revised QPI/DRAM Core Voltage setting in CPU Level Up
  • Bios 0602
    - Fix system may hang after resume from S3
    - Improvie Memory compatibility
  • Bios 0701 (beta)
    - keine Changelog
  • Bios 0705
    - Fixed the CPU ratio setting incorrect in TweakIt Batch File function.
    - Revised the default value of keyboard TweakIt control hotkey to "P" in BIOS setup
  • Bios 0804
    - Updated EC firmware (Fixed system would hang at POST with ADAPTEC SAS RAID Controllers ASR-5405 attached.)
  • Bios 0901
    - Fixes Bug issues with 4870X2's in Crossfire X not showing Video.
    - Fixed Memory Compatibility Issues
  • Bios 0903
    - Fixed the function for adjusting BCLK abnormal in TurboV when set BCLK > 200MHz in BIOS setup
  • Bios 0904
    - System Stability Improved When Overclocking Bclk High
  • Bios 1001
    - Fix AI suite report different CPU temperature as LCD Poster
  • Bios 1403 (beta)
    - keine Changelog
  • Bios 1504
    - Updated configuration table of OC Station.
    - Fixed Target DRAM Frequency incorrect for DDR3-1333 with non-extreme CPU when set DRAM Frequency to auto in BIOS setup.
    - Supported display warning message when set CPU Voltage or QPI/DRAM Core Voltage over 1.8V in TurboV.
  • Bios 1639
    - Improve memory compatibility
    - Updated ASUS EZ Flash 2 from V3.38 to V3.44
    - Updated ASUS O.C. Profile from V1.38 to V1.44
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 2-15 im Handbuch nachschlagen.
[/blockquote]
erster lol
Wie heis wird eure NB so im Durschnitt bei Overclocking, ich komme nicht über 60^c bei recht gu belüfteten Gehäuse!?
Ich habe bis zu 70°C NB Temp-.-
Allerdings scheint es sich nicht auf die stabilität auszuwirken.
Mal ne andere Frage. Meint ihr ich könnte mit nem HK 3.0 Cu meine CPU Temp noch etwas drücken? Habe inner PCGHXtreme gelesen dass mein Culpex xt Di 10Grad wärmer ist als ein HK 3.0 Cu...kommt mir ein bißchen viel vor, aber wenn es stimmt würde ich mir den holen.
ich wird ihn mir bestellen, ;-) ich habe den Ek supreme dieser war damals schon besser wie der cuplex laut Tests,da waren es auch 10c° aber ich glaube die unterschiede sind wirklich sehr marginal und für 1 - 2 c° noch 20 € auszugeben lohnt nicht , du kannst ihn ja auch wieder zurück schicken :) aber wär cool wenn du mal ein vorher nacher Temp vergleich hier zeigst :d
erster lol
Hi Hardy,
also meine NB & SB werden selbst nach über 24h prime nicht über 65-68°C warm. Sys. rennt wie in der sig ;) Allerdings ist bei mir die gehäuse seitenwand zugeschraubt und das case selbst bis auf 2x 120er@600rpm + 140er im NT und die 4870X2 die alle nur hinten rauspusten komplett abgedichtet ;)
Hatte aber mal die seitenwand ab beim prime test und es waren NB & SB 10°C kühler aber wayne, will das ding möglichst staubfrei und leise :shot:...
Ich denke die temps sind im absolut grünen bereich.
Board ist aus China nur zur info...
china 4 the win ;> die boards nehm sich rein gar nix, bei der Maximus reihe sah das etwas anders aus :)
Hi Leute, hab leider im falschen Thread gepostet gehabt, eigentlich wollte ich das ja hier posten. Hab etwas rumgetestet und von ganz klein angefangen. Hier mein Post, hoffe auf eure Meinung:
Meine Grundidee war, dass ich mich erstmal voll auf den CPU-Takt konzentriere, und später erst den RAM behandle. Also habe ich mal Northbridge und QPI-Sachen erstmal ausser Acht gelassen. Stimmt denn meine Überlegung überhaupt? Ich habe jetzt mal folgendes Setup ausprobiert, hier meine Screenshots. Vielleicht hilft das ja dem einen oder anderen OC-Newbie, der vorm gleichen problem wie ich steht. Ich hab auch absolut nix dagegen, wenn jemand was abschreibt, ich versteh nicht was es mit dieser Geheimniskrämerei auf sich hat. Nunja, wie auch immer, hier meine Einstellungen soweit:
Das war heute mittag auch verdammt heiß bei mir im Zimmer... Momentan lass ich den gleichen Test mit gleichen Settings, allerdings mit VCore 1.23750V (also ein Schritt weniger in den BIOS-Einstellungen) laufen, und die Höchsttemperatur beträgt 75°. Mal schauen, obs gut geht über die Nacht...
Den RAM habe ich natürlich nur auf 600MHz laufen. Turbo-Mode habe ich auch deaktiviert, damit er nicht von alleine die CPU-Geschwindigkeit verändert, so dass sie eben immer fix ist. HT ist natürlich an, lass ich immer an! Ich bin auf die OCZ-Seite und hab mir genau meinen Speicher angeschaut, und bei der Spannung stand dort 1,65V drin, also hab ich das auch so übernommen. Ich hoffe das passt. Auf jeden Fall habe ich damit Prime95 5 Stunden laufen lassen, und hab keinen Fehler gehabt. Was denkt ihr zu den Settings? Sind die ok, oder habe ich noch irgendwas falsch eingestellt? Meine Frage nun lautet: wie sieht richtigerweise der nächste Schritt aus, damit ich meinen DDR3-Ram auf 1.600 oder max. 1.866MHz laufen lassen kann?? Was genau muss da verändert werden? Bin für jeden Tip/Anregung sehr dankbar.
viele Grüsse,
Sloop.
Sloop du brauchst nicht in 2 Threads gleichzeitig Posten!
Überleg wo du deine fragen stellen willst und mach das in dem Thread I7 OC Thread oder hier im REII Thread
Das gespamme muss nicht sein!
@Sloop
Ergebnis ist sehr gut, aber die Temperaturen sind immer noch sehr hoch meiner Meinung nach.
Um den Ram zu testen geh halt auf 1600MHz und teste Prime Large FFTs. Bei 12GB wirst du bestimmt mehr QPI brauchen. Wieviel musst du halt testen.
Hast du denn mal den Sitz des Kühlers überprüft, und ob wie Wärmeleitpaste gut verteilst ist? Zuviel WLP ist auch nicht gut. Ein paar Grad lassen sich da bestimmt noch rausholen, ansonsten würde ich nicht mehr viel höher gehen mit LuKü. 3,8GHz sind aber schon gut für LuKü. Hast du beide Lüfter an Noctua?
Gruß Martricks
@Matricks: Ich kriegs einfach nicht gebacken. Wenn ich 1600MHz wähle, dann wird schon beim POST vom BIOS nur 10GB angezeigt vom gesamten RAM. Den Rest erkennt der irgendwie nicht. Hab grad diverse Einstellungen durchprobiert, mit der QPI-Spannung, IOH-Spannung, DIMM-Spannung und UCLK und QPI Link Data Rate. Habs einfach nicht hinbekommen. Hat jemand 'ne Idee was ich da eintragen könnte um den Speicher mit 1.600MHz zum Laufen zu Kriegen?
EDIT: Hab mal das 1600er Profil vom BIOS geladen, dabei alles auf Auto gelassen und BIOS hat die 12GB mit 1600MHz erkannt. Dann hab ich mir mal die Werte angeschaut. Der hat 1.786V DIMM-Spannung gewählt! *SHOCK* ist das nicht viel zu viel des Guten? Ab 1.65V glaub ich, sagt mir das BIOS in roter Schrift, dass es ab hier zu CPU-Schäden kommen kann. Was nu?? Wenn ich die DIMM-Spannung auf 1.7V setze, dann erkennt er den RAM als 1600er und volle 12GB. Aber ist das der richtige Weg? Hab etwas Angst wegen der DIMM-Spannung ...
@sloop
setzt mal die QPI auf 1,35 - 1,4 V und schau mal ob er dann 12 GB erkennt
zu wenig erkannten Speicher ist: Speicher defekt, zu wenig QPI oder Kühler auf der CPU zu feste angezogen
Morgen Ingo,
Sag mal hattest du mal ne Nvidia mit dem Rampage laufen?
Gab das nen Unterschied? (Bclk)
Hab zur Zeit ne GTX 260 drin. Könnte heute ne 4890 bekommen.
Hallo Stefan,
na, hatte bisher immer ATI und war bisher immer zufrieden damit!
Ich denke nicht das es sich auf die BCLK auswirkt, oder ?
Doch
Die Atis können mehr PCIe Takt ab , das heist kannst mehr geben und den BCLK etwas höher ziehen!
Wenn du sie bekommen kannst nimm sie denke so 2-3Bclk sind noch drinne!
Mit einer 9400 NV komme ich auf 228 aber stable zu bekommen ist ein andere sache!
Coole Sache :) 2-3 BCLK wären Traumhaft - über einen mehr stabil würd ich schon freuen
@sloop
Hatte ich probiert. Keine Chance! Die einzigste Abhilfe, um den RAM vollständig als 12GB zu erkennen, ist die von mir erläuterte DIMM-Spannung ,aber die bereitet mir etwas Sorgen wie gesagt.
Versuch mal die QPI auf 1,43V und die Timings Entschärfen!
Das ist mit den 1,65V Vdimm ist ein Mythos der von ASUS initiert wurde.
Kein anderer Hersteller warnt ab 1,65V.
Intel gibt bis 1,875V frei ... das ist interessanter, da es ja über den Speicherkontroller läuft und der sitzt bekanntlich bei den I7 wieder auf der CPU.
Jetzt ist halt nur die Frage, was der Speicherhersteller freigibt. ;)
@Smooth
Hmm. Ich meine wäre schon geil wenn man mehr Saft auf die Riegel geben könnte, aber warum begrenzen dann alle Hersteller von Ram auf 1.65V. Muss ja einen Grund haben. Die Riegel können das bestimmt ab, aber mit Board oder CPU ist so ne Sache. Nicht abzusehen wie geil so mancher Ram bei mehr Saft abgehen würde^^
Gibt es irgendwo einen offiziellen Bericht darüber oder so? Würde dann sofort mehr draufgeben....dann wären selbst mit meinem 1600er Ram 1800 oder mehr drin.
Das hat was mit der Diferenz zwischen QPI VTT und VDImm zutun!
Die Diferenz darf nicht größer wie ~0,5V sein Standart QPI VTT 1,15V + 0,5V Unterschied zur Vdimm = 1,65V VDimm
Intel gibt 1,87Vdimm Frei dafür muss aber die QPI mit angehoben werden das die Diferenz nicht zu groß wird!
@Marvin82
Würde heissen, da ich momentan QPI=1,310V am laufen habe, dürfte ich den Ram bis auf 1.81V anheben? Wäre natürlich geil.
Scheinst dich ja echt gut auszukennen. Respekt! Aber lass den Test erstmal andere machen^^ Hab erstmal genug Geld in den Rechner investiert.
@Marvin82
Theoretisch schon aber ob das auch Praktisch der CPU nicht schadet ist eine andere Sache!
Ich versuche auch immer unter Bzw knapp über den 1,65V zu liegen!
Bin grad am überlegen 211x19 mit 1.310V QPI und 1Stufe mehr VDIMM als offiziell erlaubt zu testen. Immerhin untervoltet er ja noch leicht unter 1.65V. Sind meistens 1.640V,1,647-max 1.65V. Wenn mein Ram dann 1680 oder so mitmacht wäre nämlich echt geil. Wird aber bestimmt wieder nicht funzen. Geh erstmal einen drauf lassen und überlege es mir nochmal^^
Edith: Geht nicht. Nur 1Stufe über max. erlaubter VDIMM resultiert in nur noch 4088MB angezeigtem Ram. Auch QPI auf 1.350V hilft da nicht weiter. Also bringt es in meinem Fall nix ausser ne Verschlechterung. Hat jemand ne Erklärung dafür? Marvin du sagtest doch dass du nur minimal drüber laufen gelassen hast. Ging das bei dir gut?
Dat geht bestimmt gleich alles kaputt du!
Nein mach man das ist doch noch vollkommen Ok, also ich habe schon 5Wochen eine QPI von 1.52V fahren müssen und das ging alles gut... Wenn nur 4GB angezeigt werden trotz erhöter QPI dann stimmen die Timmings nicht, jedenfalls hatte ich das Problem beim T3eH8! Oder dein gesamtes Setup, Bios bezogen, ist nicht Ok!
