[Sammelthread] Asus Rampage II Extreme R.o.G. (Intel X58) [2]
Chrisch
Legende
Münsterland
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 12 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
    - Triple channel memory architecture
    - * Supports Intel® Extreme Memory Profile (XMP)
    - **Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
Expansion Slots
  • 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
  • 2 x PCIe 2.0 x 1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8 -Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
Internal I/O Connectors
  • 3 x USB connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector
  • 7 x SATA connectors
  • 1 x IEEE 1394a connector
  • 1 x Chassis Fan connector
  • x 8-pin ATX 12V Power connector
  • 24-pin ATX Power connector
  • 1 x EL I/O Shield Connector
  • 3 x thermal sensor connector
  • 1 x En/Dis-able Clr CMOS connector
  • System Panel
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 8 x ProbeIt connectors
  • 1 x LCD Poster connector
  • 1 x BIOS FlashBack boot up selection header
  • 1 x ROG light connector
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Special Features
  • External LCD Poster
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Accessories
  • ProbeIt Cable
  • 3-Way SLI Cable
  • SLI Cable
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: Xfastest.com)​
Das BiosDas Bios
- Bilder folgen
Biostemplate (Extreme Tweaker)Biostemplate (Extreme Tweaker)
Code:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
OC From CPU Level Up:
OC From Memory Level Up:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
EPU II Phase Control:
Loadline Calibration:
CPU Differential Amplitude:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
QPI/DRAM Core Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
Keyboard TweakIt Control:
CPU Spread Spectrum:
PCIE Spread Spectrum:
CPU Clock Skew:
IOH Clock Skew:
CPU-Configuration
CPU Ratio Setting:
C1E Support:
Hardware Prefetcher:
Adjacent Cache Line Prefetch:
Intel(R) Virtualization Tech:
CPU TM Function:
Execute Disable Bit:
Intel(R) HT Technology:
Active Processor Cores:
A20M:
Intel(R) C-STATE Tech:
-C State package limit setting:
DRAM Timing Control
DRAM CAS# Latency:
DRAM RAS# to CAS# Delay:
DRAM RAS# PRE Time:
DRAM RAS# ACT Time:
DRAM RAS# to RAS# Delay:
DRAM REF Cycle Time:
DRAM WRITE Recovery Time:
DRAM READ to PRE Time:
DRAM FOUR ACT WIN Time:
DRAM WRITE to READ Delay:
DRAM Timing Mode:
DRAM Round Trip Latency on CHA:
DRAM Round Trip Latency on CHB:
DRAM Round Trip Latency on CHC:
DRAM WRITE to READ Delay(DD):
DRAM WRITE to READ Delay(DR):
DRAM WRITE to READ Delay(SR):
DRAM READ to WRITE Delay(DD):
DRAM READ to WRITE Delay(DR):
DRAM READ to WRITE Delay(SR):
DRAM READ to READ Delay(DD):
DRAM READ to READ Delay(DR):
DRAM READ to READ Delay(SR):
DRAM WRITE to WRITE Delay(DD):
DRAM WRITE to WRITE Delay(DR):
DRAM WRITE to WRITE Delay(SR):
DRAM REF Voltage
DRAM DATA REF Voltage on CHA/B/C:
DRAM CTRL REF Voltage on CHA/B/C:
DownloadsDownloads
Bios Downloads
  • Bios 0407
    - First release Bios
  • Bios 0503
    - Revised QPI/DRAM Core Voltage setting in CPU Level Up
  • Bios 0602
    - Fix system may hang after resume from S3
    - Improvie Memory compatibility
  • Bios 0701 (beta)
    - keine Changelog
  • Bios 0705
    - Fixed the CPU ratio setting incorrect in TweakIt Batch File function.
    - Revised the default value of keyboard TweakIt control hotkey to "P" in BIOS setup
  • Bios 0804
    - Updated EC firmware (Fixed system would hang at POST with ADAPTEC SAS RAID Controllers ASR-5405 attached.)
  • Bios 0901
    - Fixes Bug issues with 4870X2's in Crossfire X not showing Video.
    - Fixed Memory Compatibility Issues
  • Bios 0903
    - Fixed the function for adjusting BCLK abnormal in TurboV when set BCLK > 200MHz in BIOS setup
  • Bios 0904
    - System Stability Improved When Overclocking Bclk High
  • Bios 1001
    - Fix AI suite report different CPU temperature as LCD Poster
  • Bios 1403 (beta)
    - keine Changelog
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 2-15 im Handbuch nachschlagen.
[/blockquote]
hi ihr gauner:wink:
....ich hab mir grad mal in der stadt so ein stromverbrauchsmessgerät gekauft,
und muss sagen ich bin ganz schön erschrocken :eek:
also der I7@ 4 Ghz 1,34v und die GTX 280 ,1 festplatte und das Aquaduct , noch paar gehäuselüfter ziehen mal schnell 450w aus der dose bei prime + 3D Mark 280er @ stock !
Nicht das ich mich jetzt über verbrauch beschweren will , denn der is mir ziemlich schnuppe aber bisschen überrascht bin ich schon !
wenn alles stock läuft , also ohne übertaktung komm ich genau auf 161w !
Habe schon mehrmal geschrieben das ich 490Watt aus der dose ziehe mit meim sys
Aber egal rocken muss es :)
Bist nicht aleine wir sollten bei den konzernen nachfragen nach mengenrabatt :)
ach ja marvin du hast ja auch ``nur`` ne 280er ....wenn ich die 280er auch noch max takte hab ich die gleichen werte wie du !
....so unD wo is der rallyedriver?......SUBARU *Brüll* :hwluxx:
würd mich mal sein verbrauch interessieren , oder jemand der ne 295er hat !
....ihr habt doch bestimmt alle den triple sli test auf CB gelesen oder :confused:
ich kann nicht glauben das die da so wenig Stromverbrauch hatten
ich zitiere CB mal .....Der Rechner mit GeForce GTX 285 im 3-Way-SLI-Modus schafft es auf 681 Watt !
SOLL DAS EIN WITZ SEIN :confused:
Hast den Monitor und sonstige Sachen vielleicht noch mit dran? TFT (60-90W)
Habe es nicht gelesen aber 681Watt ist realistisch wenn Stock:d
Bei Triple SLI hätte ich so 760-780Watt
was idle ? 360W ? ..... kannste mal deine settings näher erläutern subaru ? warum denn 360w idle , bisschen viel oder , was haut da so rein ?
takt mal bitte die 295er hoch und dein prozzi auf 4Ghz dann lass prime und nen 3D Mark kurz laufen ....würd mich mal interessieren was sich deine kiste dann reinpfeift !
....ich wills wissen weil ich mir nich sicher bin ob mein corsair NT HX620 reicht für ne 295er
DANKE schonmal subaru
---------- Beitrag hinzugefügt um 22:26 ---------- Vorheriger Beitrag war um 21:37 ----------
...... sag mal geht die seite bei euch auch so oft nich grad ...was da denn los ?
Bei mir:
i7 920 @ stock
2x GTX260 Black Edition
mit Vantage saugt das Teil bis zu 490W aus der Dose.
Prime + Furmark saugen bis zu 450W
Netzteil atm noch ein HX620
@Acid_Angel
zieh mal beim Idle rund 50-60 Watt ab ;)
Lautsprecher, TFT und Kleinkram. Aber 300 frisst er schon.
So, CPU auf 3.8; 295 auf 648/1476/1150 mit 1.015 volt. LinX und 3DMark06 ca. 550 Watt Peak.
Eine 620er könnte evtl. knapp werden.
4ng3ldust....dann würd dein sys ja weniger brauchen umso mehr es belastet is , hast dich verschrieben oder ?
wie laufen deine apogee´s ? wollt mir die ja auch zuerst kaufen , nur hat einer aus dem forum hier abgeraten , hätt ihm mal nix glauben sollen !
Mfg.
570W Spitze hatte ich mit einer GTX 285 OC 792/1640/1480 und dem i920 auf 4,2 Ghz bei 1,43V Vcore
Bei Prime und Vantage mit 24" -Monitor.
subaru .... meinst wird knapp ? ....hm jetzt sollt man mal wissen wie viel mehr die 295er braucht ! Die 280er zieht denk ich mal minimum 60% von ner 295er oder ?
....also bei mir 450W wenn alles vollast , davon die 280er weg und die 295er dazu vom verbrauch ....sollt eigentlich reichen oder ....wenn meine rechnung so hinkommt !
Ja finde ich selbst sehr eigenartig, aber Vantage zieht bei den ersten beiden Test ungemein!
Idle liegt das Sysstem bei knapp über 200W.
Hab alle 3 Primevarianten versucht und diese lagen zwischen 310-325W.
Dazu noch Furmark Stability Test.
Kann ich noch nicht viel dazu sagen. Warte noch auf Subaru's Netzteil dann wird gleich mit 3-Way-SLI gebencht und dann auch erst RAM und CPU mal richtig oc'ed.
Ich weiß bisher nur das 670Mhz 7-7-7 einwandfrei liefen.
Mfg.
Mein System hat 315 Watt im Idle und unter Load mit Prime95 i7@3800MHz und Furmark mit 2x MSI OC 280GTX @ 1680x1050->16xAA 820 Watt!
an angeldust dann laufen sie doch klasse , war auch nich anders zu erwarten von den apogee´s ....sehr geiler speicher , hatte ihn als DDR2 !
.... haufen holz @mike aber ich kann ja auf keinen fall sagen ne 295er braucht so viel wie 2 x 280GTX ....denk mal die liegen erheblich drüber !
@ web..... was heisst .....295 auf 648/1476/1150 mit 1.015 volt ??? hast du sie undervolted ???
Ich kann dir aber nicht mal die Voltage sagen ;) Sind die 1600er.
Meine 2 GTX260 werden auch so auf dem Niveau von den GTX280 liegen.
übertaktet auf 648 GPU; 1476 Shader und 1150 RAM und dabei untervoltet auf 1.015 Volt.
Idle bekommt die Karte 0,95 Volt.
Ich hab mir auch ewig Gedanken über ein Netzteil gemacht.
Normal wäre es ein Corsair HX1000 oder Enermax Revolution 850W geworden. Da liegt man sicher nicht falsch.
hx 1000 is mit sicherheit auch klasse ja , aber les ma den test von dem topower .... echt klasse , kompl. kabelmanagement 1100W und kostet grad mal 163€
Der Test ließt sich schon mal nicht schlecht. Vielleicht überlege ich es mir doch noch einmal.
1100W sind aber eigentlich sehr überdimensioniert für mich.
tja ich hab mir auch mal die frage gestellt wie viel watt brauch ich ..... jetzt hab ich mein scheiss ! ergo.....dieses mal nimmer unter 1000watt !
Nervt mich alles ausbauen und kabel wieder so sauber verlegen !
leider hat ja nur das HX 620 die praktischen flachbandkabel !
Was hat das HX1000 für Kabel? Dachte das wären die gleichen?
Für das Temjin TJ07 sind die Kabel das HX620 aber etwas kurz wie ich finde!
