Chrisch
Legende
- Ort
- Münsterland
- Laptop
- Fujitsu Lifebook U727
- Intel Core Ultra 5 265K
- ASUS TUF Gaming Z890-Plus WIFI
- Custom Wakü - 280 & 360 Rad. intern / Heatkiller IV Pro / Laing D5 etc.
- 48GB Patriot Viper XTREME 5 DDR5-8200
- MSI Geforce RTX 5070Ti Ventus X3 OC
- LG 27GL850-B & Acer Predator XB241H
- Lexar NM790 2TB / KC3000 1TB & 2TB / Kingston A2000 500GB NVMe
- Hyte Y60
- Fractal ION+ 860W Platinum
- Keyboard
- Kingston HyperX Alloy Origins
- Mouse
- Logitech G502 X Lightspeed
- Windows 11
[blockquote]
Inhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
Biostemplate (Extreme Tweaker)Biostemplate (Extreme Tweaker)
DownloadsDownloads
Bios Downloads
Wichtige InformationenWichtige Informationen
[/blockquote]
CPU
- Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
- Supports Intel® Dynamic Speed Technology
- Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
- Northbridge:
- Intel® X58 Express chipset - Southbridge:
- Intel® ICH10R
- 6 x DIMM, Max. 12 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
- Triple channel memory architecture
- * Supports Intel® Extreme Memory Profile (XMP)
- **Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
- 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
- 2 x PCIe 2.0 x 1 ( the PCIEx1_1 (black) is compatible with audio slot)
- 1 x PCI 2.2
- Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
- * We recommend that you use full tower chassis for building a 3-Way SLI system.
- Intel ICH10R controller
- 6 xSATA 3 Gb/s ports
- Intel Matrix Storage Technology Support RAID 0,1,5,10 - JMicron® JMB363 PATA and SATA controller
- 1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
- 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
- 1 xSATA 3.0 Gb/s port
- SupremeFX X-Fi Audio Card
- ADI® AD2000B 8 -Channel High Definition Audio CODEC
- EAX® Advanced™ HD 4.0
- X-Fi CMSS®-3D
- X-Fi Crystalizer™
- Creative ALchemy
- Supports 1 x S/PDIF out header
- Supports Coaxial/Optical S/PDIF out ports on rear
- Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
- 3 x USB connectors supports additional 6 USB 2.0 ports
- 1 x Floppy disk drive connector
- 1 x IDE connector
- 7 x SATA connectors
- 1 x IEEE 1394a connector
- 1 x Chassis Fan connector
- x 8-pin ATX 12V Power connector
- 24-pin ATX Power connector
- 1 x EL I/O Shield Connector
- 3 x thermal sensor connector
- 1 x En/Dis-able Clr CMOS connector
- System Panel
- 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
- 8 x ProbeIt connectors
- 1 x LCD Poster connector
- 1 x BIOS FlashBack boot up selection header
- 1 x ROG light connector
- 1 x PS/2 Keyboard port(purple)
- 1 x External SATA port
- 2 x LAN (RJ45) port
- 6 x USB 2.0/1.1 ports
- 1 x IEEE1394a port
- 1 x Clr CMOS switch
- External LCD Poster
- Onboard Switches: Power / Reset / Clr CMOS (at rear)
- EL I/O
- Q-Fan Plus
- ROG BIOS Wallpaper
- ASUS EPU-6 Engine
- ASUS Q-Connector
- ASUS Fan Xpert
- ASUS EZ Flash 2
- ASUS CrashFree BIOS 3
- ASUS MyLogo3
- ProbeIt Cable
- 3-Way SLI Cable
- SLI Cable
- ASUS Optional Fan
- 3 in 1 ASUS Q-Connector Kit
- UltraDMA 133/100/66 cable
- SATA cables
- SATA power cables
- 2-port USB2.0 + IEEE 1394a module
- EL I/O Shield
- Thermal sensor cables
- Cable Ties
- User's manual
Code:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
OC From CPU Level Up:
OC From Memory Level Up:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
EPU II Phase Control:
Loadline Calibration:
CPU Differential Amplitude:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
QPI/DRAM Core Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
Keyboard TweakIt Control:
CPU Spread Spectrum:
PCIE Spread Spectrum:
CPU Clock Skew:
IOH Clock Skew:
CPU-Configuration
CPU Ratio Setting:
C1E Support:
Hardware Prefetcher:
Adjacent Cache Line Prefetch:
Intel(R) Virtualization Tech:
CPU TM Function:
Execute Disable Bit:
Intel(R) HT Technology:
Active Processor Cores:
A20M:
Intel(R) C-STATE Tech:
-C State package limit setting:
DRAM Timing Control
DRAM CAS# Latency:
DRAM RAS# to CAS# Delay:
DRAM RAS# PRE Time:
DRAM RAS# ACT Time:
DRAM RAS# to RAS# Delay:
DRAM REF Cycle Time:
DRAM WRITE Recovery Time:
DRAM READ to PRE Time:
DRAM FOUR ACT WIN Time:
DRAM WRITE to READ Delay:
DRAM Timing Mode:
DRAM Round Trip Latency on CHA:
DRAM Round Trip Latency on CHB:
DRAM Round Trip Latency on CHC:
DRAM WRITE to READ Delay(DD):
DRAM WRITE to READ Delay(DR):
DRAM WRITE to READ Delay(SR):
DRAM READ to WRITE Delay(DD):
DRAM READ to WRITE Delay(DR):
DRAM READ to WRITE Delay(SR):
DRAM READ to READ Delay(DD):
DRAM READ to READ Delay(DR):
DRAM READ to READ Delay(SR):
DRAM WRITE to WRITE Delay(DD):
DRAM WRITE to WRITE Delay(DR):
DRAM WRITE to WRITE Delay(SR):
DRAM REF Voltage
DRAM DATA REF Voltage on CHA/B/C:
DRAM CTRL REF Voltage on CHA/B/C:
DownloadsDownloads
Bios Downloads
- Bios 0407
- First release Bios - Bios 0503
- Revised QPI/DRAM Core Voltage setting in CPU Level Up - Bios 0602
- Fix system may hang after resume from S3
- Improvie Memory compatibility - Bios 0701 (beta)
- keine Changelog - Bios 0705
- Fixed the CPU ratio setting incorrect in TweakIt Batch File function.
- Revised the default value of keyboard TweakIt control hotkey to "P" in BIOS setup - Bios 0804
- Updated EC firmware (Fixed system would hang at POST with ADAPTEC SAS RAID Controllers ASR-5405 attached.) - Bios 0901
- Fixes Bug issues with 4870X2's in Crossfire X not showing Video.
- Fixed Memory Compatibility Issues - Bios 0903
- Fixed the function for adjusting BCLK abnormal in TurboV when set BCLK > 200MHz in BIOS setup - Bios 0904
- System Stability Improved When Overclocking Bclk High - Bios 1001
- Fix AI suite report different CPU temperature as LCD Poster - Bios 1403 (beta)
- keine Changelog
- Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
- Dazu bitte Seite 2-15 im Handbuch nachschlagen.
[/blockquote]
