[Sammelthread] Asrock AOD790GX/128M (AMD 790GX)
ASRock AOD790GX/128M, 790GX
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Supports CPU up to 140W
3. ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
4. AMD 790GX + SB750 Chipsets
5. AM3 CPU Ready!
* FSB 2600 MHz (5.2 GT/s)
* Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
* Supports Hyper-Transport 3.0 (HT 3.0) Technology
* Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3300 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Integrated 128MB side port memory for iGPU
* Supports ATI™ CrossFire™ and Hybrid CrossFireX™
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* 1 x eSATAII 3.0 Gb/s connector
* 2 x IEEE1394 ports (one port on back panel, one header on board)
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI with DVI-to-HDMI Converter
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* 1 x USB/WiFi header
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver, Extra ESD Protection
* Free Bundle: 1 x ASRock XFire Switch Card, 1 x DVI-to-HDMI Converter
* 7.1 CH Windows® Vista™ Premium Level HD Audio, DAC with 110dB dynamic range (ALC890 Audio Codec)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x eSATAII Port, 1 x IEEE 1394 Port, 1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
2. FAQ - Frequently Asked Questions
- "Lassen sich 3 Pin Lüfter steuern?"
Nein das geht nicht.
- "Ist der Sideportspeicher alleine nutzbar?."
Jawohl das ist möglich.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&s=AM2+
3.2 Reviews
http://www.pctreiber.net/thread.php?threadid=10224
http://www.cpu3d.com/review/5844-1/asrock-aod790gx-128m-motherboard/introduction.html
http://www.thinkcomputers.org/index.php?x=reviews&id=850
http://my.ocworkbench.com/2008/asrock/AOD790GX-128M/g1.htm
http://www.amdzone.com/index.php/reviews/66/10542-asrock-aod790gx128mb
3.3 Interessantes:
- Sideportspeicher ist alleine nutzbar
- Asrock OC Tuner unter Windows zum Übertakten
- Stromsparender als der Vorgänger 780G
- DVI auf HDMI Adapter im Lieferumfang enthalten
3.4. Overclocking
4. Preise
http://preisvergleich.hardwareluxx.de/deutschland/a365733.html
http://www.hardwareschotte.de/hardware/preise/proid_9775432/preis_ASROCK+AOD790GX128M
http://www.preistrend.de/suchen.php?q=AOD790GX&s=0&a=&z=&x=0&y=0
http://www.google.de/products?q=ASRock+AOD790GX&hl=de&scoring=p
5. Bekannte Probleme:
unter XP ist die 2D Performance bei allen 7er Chipsätzen nicht sehr hoch. Den Treiber aktualisieren bringt etwas. Ganz schlimm ist es mit Treibern unter dem 8.12er!
6. Fixes:
Lüfteregelung mit Speedfan:
http://www.hardwareluxx.de/community/showpost.php?p=13259216&postcount=587
7. Bios:
1.70er Version ist aktuell, doch gibt es hier Probleme mit der Core-Freischaltung
normal müsste das unter Vista auch gegen.Es gibt immer eine DOS version und eine fürs OS.Musst halt schauen welche welche ist.
Bei mir wird die Asrock HP grade nicht richtig angezeigt sonst hätte ich ein Link gepostet.
@efe
Du hast doch die Version für Vista schon geladen:
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&T=B&ID=2241
und ich gehe davon aus, dass du diese Anweisung befolgt hast:
http://www.asrock.com/support/BIOSUI.asp?cat=Windows3#Vista
Also entpacken und die AFUWIN.exe als Administrator ausführen (Rechtsklick).
Hier liegt vielleicht ein Fehler vor.
Denn Vista behandelt ZIP-Dateien grundsätzlich als normale Ordner und du kannst die Exe-Datei ausführen, aber sie findet evtl. die *.sys Dateien nicht.
Entpacke das gesamte Paket in einen Ordner z.B. auf dem Desktop.
Natürlich alle Programme - Virenscanner, Hilfsprogramme usw... - vorher beenden.
Vorher und nach dem Biosupdate die Bios-Default-Werte laden.
Ob ein Problem mit dem nicht erkannten Prozessor vorliegt und dadurch ein Biosupdate nicht möglich ist, wäre noch eine Möglichkeit.
Es gibt immer wieder mal eine Meldung darüber, wo das Biosupdate erst mit einem bereits unterstützten Prozessor durchgeführt wurde und danach erst die neue CPU eingesetzt wird.
PCtreiber.net ist eine gute Anlaufstelle für Besitzer eines Asrock-Boards und eine weitere Anfrage zu deinem Problem kann nicht schaden.
Das Board unterstützt die Phenom II Prozessoren ab der ersten Biosversion.
Nur war der genaue Code bzw. die Bezeichnung nicht bekannt.
Ab der Biosversion 1.3 werden die Phenom II CPUs offiziell unterstützt.
Dein Prozessor läuft ja anscheinend normal und wird mit der korrekten Taktrate betrieben.
Nur die Bezeichnung der CPU wird nicht erkannt.
Udate:
OK.
Du hast es selbst gelöst und bist schneller als ich gewesen.
@3DNG
Bilder sagen mehr als tausend Wörter ^^
Virenscanner hab noch keinen drauf.
Bin am überlegen wie ich meinen ganzen Mozilla Favoriten, Add-ons mit samt Passwörter und Einstellungen übernehme kann auf den neuen pc.
Die Mozilla Nutzerdaten sind in diesem Ordner versteckt:
C:\Users\Benutzername\AppData\Roaming\Mozilla
@3DNG
kannst du mit MozBackup machen
Mal was anderes wird bei euch auch die IGP im Gerätemanager angezeigt obwohl ihr eine externe GraKa habt?
find den ordner nicht aber ich versuch mal alles kopieren.
wert schon schiff gehen.
dank dir isch
mit MozBackup war das kein pro.
Aber mit dein pro. kenne mich nicht aus hast du mal die Treiber neu drauf gemacht.
oder schalt den ongraker ab im bios.
@isch
ja wird sie, das ist ja auch normal ;)
ne bei mir wird die nicht angezeigt :d
dank dir isch
Habe mit den 8.12,9.1 und 9.2 getestet.
Im Bios habe ich auf PCIe gestellt
@isch
ne eben nicht erst nach einem Bios reset wurde die bei mir im GM angezeigt vorher nicht.
kannst du mir mal deine Bios Einstellungen sagen.Vielleicht habe ich nach dem reset nur irgend eine Einstellung vergessen.Habe zwar schon alles durch probiert aber man weis ja nie.
Das sieht bei mir so aus
Weil Primary Graphics Adapter auf PCIe steht. Alles andere ist bei mir (fast) identisch ;) Oder hast du ne nVidia Graka ? ;)
ne hab auch ne HD4670
Als ich das Board bekam war das Bios V 1.00 drauf.
Mit meinem Phenom II 940 hat es nicht gebootet, musste dann meinen alten X2 6400+ reinstöpseln um das Bios zu flashen.
Bis auf die ungekühlten Spawas bin ich mit dem Board zufrieden!
Die werden jetzt halt aktiv gekühlt.
Habe mir noch für ein zweit Sys so ein A770CrossFire Teil geholt, ist recht ähnlich.
Mal ne kleine Frage: Wie sieht das noch einmal mit der Onboardgrafik bzw. dem DVI-D Port aus?
Ist das ein Dual-Link DVI-Port, der auch Auflösungen von 2560x1600 beherrscht, oder ist bei 19xx mal irgendetwas Schluss?
"Als ich das Board bekam war das Bios V 1.00 drauf.
Mit meinem Phenom II 940 hat es nicht gebootet, musste dann meinen alten X2 6400+ reinstöpseln um das Bios zu flashen. "
Das war der Teil meiner Antwort, den ich mir gespart habe (weil sein Prozessor bereits lief).
Es wäre die Frage, welche Biosversion er hatte z.B. die 1.1.
Aber auch so ist es generell ein kleines Glücksspiel.
Manche neue Prozessoren arbeiten auch unter älteren Biosversionen - teils mit absurden Bezeichnungen z.B. Athlon 7000.
Bei anderen muss ein alter Prozessor eingesetzt werden.
Gibt's Erfahrungswerte mit PCIe-Soundkarten? Räumlich scheint mir das mit dem Kühler hinter dem PCIe x1 etwas eng zu sein...
Anschluß an TV (VGA -> S-Video)
hoffe ihr könnt mir weiterhelfen. Möchte meinen Mediacenter mittels VGA-Port an meinen TV, der eine S-Video Buchse hat, anschliessen. Es gibt zu diesem Zweck VGA zu S-Video Adapter (http://www.amazon.de/VGA-S-Video-RCA-Cinch-Adapter-Kabel/dp/B00185HMKW/ref=cm_cr_pr_product_top). Diese funktionieren aber nur, wenn das TV-Signal via VGA ausgegeben wird. Kann mir einer von euch bestätigen, dass dies baim AOD790GX/128M so ist. Lt. Recherche im Internet sollen nur wenige Graphikkarten dieses Feature unterstützen. :confused:
Danke und Servus,
Eracansan :haha:
PS. Hab da grad gefunden, was Du brauchst. Deshalb schreibe ich des nochmals hier am Anfang.
http://www.kab24.de/kabel-adapter/r...rtnr~7315~func~det~wkid~8743904768072815.html
Dazu braucht's dann noch den hier http://www.kab24.de/kabel-adapter/r...r~artnr~4098~func~det~wkid~2501922039470.html
LOL. Sonen Ding könnt ich auch gebrauchen, weil nächstens auch ein 790GX Board neikommt.
Nun zu den anderen Sachen, wobei ich glaube, dass das oben die bessere Lösung ist. Denn daraus könntest Du sogar später das volle RGB Signal durchschleifen, u.U. mit ein paar Änderungen.
logo geht das.
Du könntest Dir auch nen RGB > Scart Kabel selber machen.
Aber das Dingens da geht schon.
Danach brauchst Du aber wieder ein Verängerungskabel. Ich seh's nicht ganz, ob's SVHS Stecker oder Buchse ist. Je nach dem musst Du danach entweder nen SVHS Adapter und ein normales SVHS Kabel zum TV haben.
Dazu ein Kabel für den Sound. Also nen "Y-Klinker Adapter to Coaxial und dann mit nem CoaxialKabel zum Audioeingang am TV.
Oder gleich dieses hier. http://www.amazon.de/Hama-Audio-Kab...0028634?ie=UTF8&s=ce-de&qid=1235571213&sr=1-7 2 Meter
oder
das 5 MeterKabel hier http://www.amazon.de/Kabel-KLinke-S...028634?ie=UTF8&s=ce-de&qid=1235571213&sr=1-12
Diese ganzen Dingens gibt's auch im Set wo alles drin ist. Musst aber selber schauen, ob das lohnt. Ist teuer. http://www.amazon.de/Hama-DVD-Ansch...6204220?ie=UTF8&s=ce-de&qid=1235571370&sr=1-1
Wenn Du nen LCD und ev. daran nen HDMI hast, kannst Du auch nur Video und Audio über HDMI übertragen.
Wie gesagt. Da gibt's nen Fred im Forum, wo Du ne Anleitung bekommst, wie Du aus einem ScartKabel Ein RGB to SCART Kabel machst. Hier... http://www.forumdeluxx.de/forum/showthread.php?t=212414
Bevor Du da den VGA > SVHS Adapter kaufst, stell mal sicher, ob der SVHS Anschluss nen Stecker oder ne Buchse hat. Du bräuchtest eine Buchse, damit das SVHS Kabel danach kompatibel ist.
Hier hab ich noch ne Seite gefunden...
http://www.kab24.de/kabel-adapter/r...ub2~SVHS~func~anzeige~wkid~2501922039470.html
Und hier auch wieder des Komplettset. Aber schau Dir die ganze Sache erst an.
http://www.kab24.de/kabel-adapter/r...o~artnr~8459~func~det~wkid~2501922039470.html
Lol ich hab Gefunden, was DU brauchst.
http://www.kab24.de/kabel-adapter/r...A~artnr~7307~func~det~wkid~2501922039470.html
zunächst danke für Antworten Arkos. :d
Leider kann ich mit einem SCART Stecker nichts anfangen, weil ich gerne den VGA -> S-Video Adapter verwenden möchte. Nur bevor ich ihn mir kaufe möchte ich sicherstellen, dass das Motherboard das TV Signal via VGA ausgibt. Wie bereits geschrieben unterstützen das nicht viele Graphikkarten.:confused:
Servus,
Eracansan
Da meine Frage wohl in der Masse an Posts untergegangen ist, wiederhole ich die noch einmal:
Wie sieht's nun mit dem angeblichen DVI-D Port aus?
Kann der Anschluss nun 2560x1600 oder ist immer noch bei 1920x1080 Schluss? Die habe ich damals, als ich im Besitz des Boards war, bemängelt. Micki Krause meinte, dass dies wohl auf den noch frühen Treiber zurück zu führen sei.
Und auch meine zweite Beschwerde des Boards möchte ich klären. Besteht das Problem des Nichterkennens der Festplatte, mit Tools wie Speedfan, Everest und ähnlichen Programmen, weiter?
Hallo.
Wollte mir das Board eventuell auch kaufen. Hat jemand Erfahrung dem Board und einem Phenom II 940 BE gemacht? Muss man erst einen alten CPU anschliessen um die BIOS zu flashen? Wo könnt ich es bestellen?
Danke im Vorraus
Hallo.
Danke im Vorraus
Hab das Board zeit Sonntag, habe es dirkt mit dem Phenom II 940 BE zusammengebaut.
Lief auch mit 3 Ghz ohne pro. nur cpu Phenom II wurde nicht erkannt. Bios Version 1.40 ist jetzt drauf und ( über Windows geflasht ) bin sehre zufrieden mit dem Board.
