ATI HD 4870 RV770XT "Sammel-Thread + FAQ" Bitte bei Fragen die erste Seite lesen 7
Hi Leute,
kann mir wer von euch mal erklären, was bei dem ATI Radeon Bios Editior die Einstellungen bedeuten, also Clock 0-9?
Habe schon gelesen, dass es was mit den Zuständen zu tun hat, also Boot-, low, middle und high. Aber warum gibt es dann für boot z.b. nur 1 Wert und für die 3 anderen 3 anderen 3 Werte?
Und was bedeutet UVD, und jeweils das Power saving (1 und 3)?
Danke.
nur die obere Reihe beachten... die untere ist für Powerplay.
Clock info 00 = Boot
Clock info 01 = LOW (2D)
Clock info 02 = MEDIUM
Clock info 03 = High (3D)
Clock info 04 machste einfach gleich wie 03 also für 3D
Also habe hier mal gelesen und da steht:
"As you hold your mouse button, you can see that the background color of the clock info 00 boxes on the top of the tab changes. The boot state mostly, but not for all BIOSes, has only one clock info mode, mostly mode 00. Click and hold the State 1 now. In this example, it says "Power saving for notebooks..." and so on. This may differ for your BIOS. Clicking and holding state 1 in this example yields that state 1 corresponds to clockinfo 01, 02 and 03. Scroll the list box over to the right now. You may see something like "high performance" and/or "optimal performance". So, this state seems to be the mode the card usually is switched to after booting. The state has three modes, as you see. One is denoted as "low", one as "medium" and one as "high". This is a rule of thumb that might help you: Maybe the card finds itself in the "low" mode when being at the window's desktop (Windows XP). Windows Vista's aero desktop might require the card to switch to "medium". After starting a 3D application like a computer game, the card should switch to high. As you can see, for this state the "high" mode (clock info 3) has higher clock rates. To overclock the card for games, it should be a good idea to increase the settings here. For power saving in 2D mode, decrease the settings in clock info 01 in this example.
Please note that the RAM clocks should be the same for all clock infos as on the one hand, decreasing this doesn't save a lot of power and on the other hand, switching the mode (and switching the RAM clocks if they aren't all the same) will cause an annoying flickering of the screen. You understand now that ATI themselves programmed the RAM clocks to all the same values for a reason.
However, at least the GDDR5 RAM the 4870 and some future cards use is reported to consume more power, though. So it's up to you: Save power and lower the clocks or leave the clocks at high rates, waste some power but be free of any flickering on frequency switching.
Moving on in this example, state 2 (clock info 4, 5 and 6) is used for UVD, the video playback accelerator of ATI cards. You should leave those settings as they are. These are the clocks that the UVD section of the chip is running at. Usually (and also for this example, as you can see), those three clock infos are programmed the exact same values. If for some reason you decide to change those values, it might be a good idea to change those three clock infos to all the same values, at least.
State 3 (clock info 7, 8 and 9) is again high and optimal performance, as you can see scrolling the list box to the right again. So far, it is impossible to distinguish whether state 1 or state 3 is used for normal operation of the card. Just set the same settings for state 3 as for state 1 in this example."
Verstehe ich das dann so richtig?:
- Clock 0 ist fürs booten da und kann default bleiben
- Clock 1, 2, 3 steht für low/normal/high Performance ---> in 2D oder 3D oder gilt das für 2D UND 3D????
- Clock 4, 5, 6 ist für die Videofunktion und kann default bleiben
- Clock 7, 8, 9 ist wie auch Clock 1, 2, 3 für low/middle/high Performance zuständig und sollte gleich eingestellt werden ---> in 2D oder 3D oder gilt das für 2D UND 3D????
Hab grad entdeckt für die HD4870 von Sapphire gibts ein neues BIOS, downloadbar bei den Treibern für die Karte.
Hab aber leider noch nirgends gelesen, was da jetzt anders ist.
meint ihr, ich kann auf meine powercolor pcs+ ein anderes bios draufmachen? z.b. von sapphire oder so?
need Infos und Deine Erfahrungen..
ATI Overdrive geht jetzt bis 850 MHz GPU und 1200 MHz VRam.
Seh mir das ganze jetzt mit dem Bios Editor mal an. Brauch nen Moment.
*edit*
Also die lüftersteuerung wurde etwas geändert, der lufi dreht schneller.
Und das Powerplay feature ist auf enable gesetzt worden im Bios Editor, beim Alten Bios von Sapphire war das noch deaktiviert.
Die Takte im Editor sind bearbeitet worden..
Und das flackern vom VRam wenn der Takt geändert wird wurde behoben :d IST ja affen geil :d:d:d:d:d
Ich Upp mal gleich bilder vom Bios Editor mit alt und neu.
So auf die schnelle, Bitte schön.
Aber das geilste ist auf diesen Bildern zu erkenennen. Gut hinsehen und gucken was sich da geändert hat und erahnen was langsamm kommen tut :d (POWERPLAY IST IM ANMARSCH)
Da das scheinbar unter gegangen ist wollte ich das nochmal posten!:wink:
So das sollte verständlich sein...
Hey Leute,
ich habe seit heute eine wassergekühlte HD4870X2 von "Grafikkartenpower.de"...
Leider musste ich feststellen, dass sie unter last (z.B. crysis, 3dmark06) extrem laut piept und quietscht...
Der Typ von Grafikkartenpower.de meinte, das wäre normal und alle "neuen" karten würden das machen... Ich hab es in 2 sytemem ausprobiert... (einma 750W und einma 550W)
Es ist wirklich unglaublich nervtötend!
Habt ihr auch solche Probleme?
Kevin27
Das habe ich gelesen, jedoch steht ja in der Beschreibung, dass die Clocks 01, 02 und 03 gleich den Clocks 07, 08 und 09 sein sollen.
Dies würde ja leicht deinem Bild wiedersprechen.
Und Powerplay ist derzeit noch nicht implementiert, richtig?
Nun die Preise der HD4850 512MB fallen wieder leicht, und die 1GB Version pendelt sich langsam ein bei 230 - 240 Euro.
Nur wer etwas länger warten will/ möchte wird wohl ab Mitte Oktober mit NEUEN Preisen verwöhnt werden:
HD 4850 512 MB 100-110 Euro
HD 4870 512 MB 160-170 Euro
HD 4870 1GB ca. 200 Euro belohnt werden
Die X² dann wohl um die 350 Euro oder gar weniger.
Grund: Die Neuen Refresh GT200 (b) von NV kommen und somit werden wohl die HD4870/4850 geschlagen um 15-20% rechne ich und daher muss wohl am Preis geschraubt werden, nach knapp 4 Monaten....:banana:
werde mir da auch noch ne zweite HD-4870 512MB holen, oder gar ne 1GB Version und die alte verkaufen.
Kann mir wer sagen welche 4870 mit 1gb eine alternative Kühlerlösung hat welche deutlich leiser ist als die Standard Kühlung ?
Hey Leute,
Kevin27
jep ist normal, alle pfiepen/pfeifen, das liegt leider an den billigen Bauteilen
Würde das neue Bios von Sapphire auch mit der Powercolor funktionieren?
Woher hast du die Infos?
Da das mit dem neuen Sapphire-Bios ganz gut klingt, würde ich meine auch gerne flashen. Das Problem ist, das ich 2 Stück@CF habe. Im Thread hat mal jemand beschrieben, wie das geht, unter dos mit einer Kommandozeile und versch. ID´s für die Karten. Da bin ich aber leider nicht so der Experte. Kann man CF mittlerweile auch unter Windows (Vista 32) flashen? Wenn ja, sicher mit dem Ati-Flash-Tool? Erst die eine, dann die andere? Reboot dazwischen, oder gleich beide? Wäre supi, wenn da jemand helfen könnte.
Danke im Voraus.
MfG...
Kann einer mal sagen, ob es jetzt mit dem neuen Sapphire Bios auch einen geringeren IDLE Stromverbrauch gibt?
Werden andere Hersteller nachziehen?
Aber ist das wirklich SOO laut?!?!
das kann doch dann nicht deren ernst sein, meine gute alte 8800gt macht auch solche geräusche, aber nur sehr selten (crysis menü, ati tool usw) und dann auch nur sehr leise...
Die X2 macht bei jeder belastung super laute Geräusche! Ist das wirklich bei euch allen auch so? Könnt ihr damit leben?
kann ich das sapphire bios auf die powercolor klatschen?
welches Bios wäre das denn? - habe ich was verpasst? - vorteile?PP kanns ja nivht sein^^
Bestimmt! Ich würde für eine Lüftersteuerung das Palit/ Gainward bios der GS oder Sonic Edition empfehlen .
Ich hbae die Palit Sonic Edition ist die Lüftersteuerung, vom geregelten Lüfter, erste Sahne! Im Idle 700 u/min und beim Raufregeln unterlast ist es sehr Gleichmäßig und dreht nicht in Etappen hoch runter wie die Normalen Karten.
Taktraten sind auch etwas höher 775/1000 . Für Mich also ganz ok !
Hat den Schon jemand versucht auf die Dual Bios Karten ein neues Bios zu flashen ?
Es geht um das neue Bios von Sapphire, wo jetzt auch PP im Bios aktiviert ist.
Bios kann man auf der Homepage von Sapphire downloaden, ich weis nur nicht ob es auf der Powercolor funktioniert
Na das sind ja mal interessante Nachrichten.
auch haben will :)
Gib mir bitte bescheid wenn du näheres weisst.
...habe noch nie nen Bios von ner Graka geflasht :hmm: :(
kann ja nicht schwerer sein als ein normales Bios zu flashen....
auch haben will :)
Ist sogar leichter würde ich sagen! ;)
Ähnliche Themen
