Erklärt mir diesen Ausdruck bitte genau und wie es funktioniert... Stand bei meinem Board integrated VGA ist ein Nforce 2 Board...
NVIDIA GeForce4 MX GPU(Graphics Processing Unit) with up to 128MB Frame Buffer?
thx
PS: Was haltet ihr allgemein von diesem Board
NVIDIA nForce2 IGP / MCP
SPECIAL FEATURES
MEMORY Maximum 3.0 GB
3 x 184-pin DDR SDRAM DIMM
Dual Channel DDR 200/266/333(See Dual Channel Guidelines)
Dual Channel Guidelines For Dual-channel DDR (128-bit) high performance, at least 2 or more DIMM modules must be installed. (It has to be the combination of DIMMA and DIMMB.) With only one DIMM installed, the memory performs only at 64-bit.
EXPANSION SLOT 3 x PCI
1 x AGP ( 4X / 8X)
1 x CNR (Optional)
I/O 1 x Parallel , 1 x Serial
Support Ultra DMA 33/66/100/133 Bus Master Modes
6 x USB 2.0 Port (2 x Rear USB 2.0 , 4 x Front USB 2.0 )
1 x CD-In Connector
1 x Chassis Open Header (Optional)
1 x Floppy
1 x Front Audio Header
1 x Game Port, 1 x Speak-out, 1 x Line-in, 1 x Mic.-in
1 x IrDA Header
1 x PS/2 mouse, 1 x PS/2 keyboard
1 x RJ-45 LAN Jack
1 x S/PDIF Header (Optional)
1 x TV Out Header
1 x VGA Port
1 x Wake On Lan Connector (Optional)
4 x IDE Hard Disk Devices
INTEGRATED VIDEO NVIDIA GeForce4 MX GPU(Graphics Processing Unit) with up to 128MB Frame Buffer
INTEGRATED AUDIO Realtek ALC650/655 6-Channel AC97 CODEC
LAN MCP NVIDIA MAC + Realtek RTL8201BL PHY
HARDWARE MONITOR FUNCTION AGP Voltage
CPU Temperature
CPU Voltage
CPU/System Fan Speed Controller
System Temperature
Vcore,+3.3V,+5V,+12V, -5V, -12V,5VSB(Stand By), V Battery
WarpSpeeder Hardware Monitor
Accessories 1 x HDD Cable
1 x FDD Cable
1 x TV-Out Cable(Optional)
thx
SPECIAL FEATURES
1 x AGP ( 4X / 8X)
1 x CNR (Optional)
1 x CD-In Connector
1 x Floppy
1 x IrDA Header
1 x RJ-45 LAN Jack
1 x TV Out Header
1 x VGA Port
CPU Temperature
CPU Voltage
System Temperature
1 x FDD Cable
