hab mir eine 7800 GT CO gekauft diese soll ja
GPU Taktfrequenz
470 MHz
Speicher Taktfrequenz
1100 MHz
haben Riva Tuner zeigt allerdings an
core clock
275,4 MHz
Ram clock
1096,88 Mhz
ist das korrekt (gibts da noch irgent einen multiplyer ?) oder warum werden nicht die 470 Mhz angezeigt ?
$ffffffffff ----------------------------------------------------------------
$ffffffffff Northbridge information
$0400000000 Description : NVIDIA nForce4 series
$0400000001 Vendor ID : 10de (NVIDIA)
$0400000002 Device ID : 005e
$0400000003 AGP bus : not supported
$ffffffffff Display adapter information
$0000000000 Description : NVIDIA GeForce 7800 GT
$0000000001 Vendor ID : 10de (NVIDIA)
$0000000002 Device ID : 0092
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : PCIE
$000000000f PCIE link width : 16x supported, 16x selected
$0000000009 Base address 0 : d8000000 (memory range)
$000000000a Base address 1 : c0000000 (memory range)
$000000000b Base address 2 : none
$000000000c Base address 3 : d9000000 (memory range)
$000000000d Base address 4 : none
$000000000e Base address 5 : 00009000 (I/O range)
$ffffffffff NVIDIA specific display adapter information
$0100000000 Graphics core : NV47 revision A1 (20x1,7vp)
$0100000001 Hardwired ID : 0090 (ROM strapped to 0092)
$0100000002 Memory bus : 256-bit
$0100000003 Memory type : DDR3 (RAM configuration 05)
$0100000004 Memory amount : 262144KB
$0100000100 Core clock domain 0 : 275.400MHz
$0100000101 Core clock domain 1 : 275.400MHz
$0100000102 Core clock domain 2 : 275.400MHz
$0100000006 Memory clock : 548.438MHz (1096.875MHz effective)
$0100000007 Reference clock : 27.000MHz
GPU Taktfrequenz
470 MHz
1100 MHz
core clock
275,4 MHz
Ram clock
1096,88 Mhz
