Whitecker007
Legende
auch mir den Spannungen die du bisher drinne hast.
Schreibt man ganß nicht gan"ß"?
ich lach mich hier so weg alter
.:AI Tweaker:.
AI Overclock Tuner [Manual]
CPU Ratio Setting [7,0]
FSB Frequency [430]
PCI-E Frequency [100]
FSB Strap to North Bridge [333]
DRAM Frequency [851]
DRAM Static Read Control [disabled]
DRAM Read Training [disabled]
MEM. OC Charger [enabled]
AI Clock Twister -> [lighter]
AI Transaction Booster -> Manual
Common Performance Level -> [13]
******** Please key in numbers directly! ********
CPU Voltage [[B]1,27500V[/B]]
CPU GTL Voltage Reference [Auto]
CPU PLL Voltage [1,5V]
FSB Termination Voltage [1,22V]
DRAM Voltage [2,1V]
NB Voltage [1,20V]
NB GTL Reference [Auto]
SBridge Voltage [1,1V]
PCIE SATA Voltage [1,5V]
Load Line Calibration [deaktiviert]
CPU Spread Spectrum [deaktiviert]
PCIE Spread Spectrum [deaktiviert]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
CPU Margin Enhancement [Performance Mode]
.:Advanced - CPU Configuration:.
C1E Suppport [Enabled]
Max CPUID Value Limit [Disabled]
Intel (R) Virtualization Tech [Enabled]
CPU TM Function [Enabled]
Execute Disable Bit [Enabled]
[Tue Nov 03 12:51:08 2009]
Self-test 1024K passed!
[Tue Nov 03 13:07:29 2009]
Self-test 896K passed!
[Tue Nov 03 13:23:23 2009]
Self-test 768K passed!
[Tue Nov 03 13:38:45 2009]
Self-test 640K passed!
[Tue Nov 03 13:54:09 2009]
Self-test 512K passed!
[Tue Nov 03 14:09:27 2009]
Self-test 448K passed!
[Tue Nov 03 14:25:06 2009]
Self-test 384K passed!
[Tue Nov 03 14:40:56 2009]
Self-test 320K passed!
[Tue Nov 03 14:56:32 2009]
Self-test 256K passed!
[Tue Nov 03 15:12:28 2009]
Self-test 224K passed!
[Tue Nov 03 15:27:48 2009]
Self-test 192K passed!
[Tue Nov 03 15:43:19 2009]
Self-test 160K passed!
[Tue Nov 03 15:58:46 2009]
Self-test 128K passed!
[Tue Nov 03 16:13:57 2009]
ganß vergessen das er nen QC hatt und kein DC glaub mach mir bald ne Liste User1. X Hardware^^
:AI Tweaker:.
FSB Frequency [450]
DRAM Frequency [901]
CPU Voltage [1,29375V]<-- habe ich nur testweise erhöht um vcore bei nem abbruch auszuschließen
CPU PLL Voltage [Auto]<---- sollte ich hier nochmal mit fixem wert testen (large)?
DRAM Voltage [2,1V]
NB Voltage [1,20V]
[Tue Nov 03 19:16:17 2009]
[Tue Nov 03 19:31:50 2009]
[Tue Nov 03 19:46:55 2009]
[Tue Nov 03 20:03:07 2009]
[Tue Nov 03 20:19:16 2009]
[Tue Nov 03 20:35:16 2009]
[Tue Nov 03 20:50:21 2009]
[Tue Nov 03 21:06:06 2009]
[Tue Nov 03 21:22:02 2009]
[Tue Nov 03 21:37:25 2009]
[Tue Nov 03 21:53:21 2009]
[Tue Nov 03 22:09:28 2009]
[Tue Nov 03 22:25:19 2009]
[Tue Nov 03 22:41:30 2009]
bin mal gespannt was deine CPU so für den Takt an V-Core braucht.
also:Das heisst, ich müsste für jede einzelne vFSB und GTL - Kombi bei jedem angetesteten FSB-Schritt 3,5 Std. Large laufen lassen, um sicher zu sein??
470Mhz gehen noch relativ leichthab aber schon von Der Asus Reihe auch schon 471 FSB 24/7 gesehen nur weiß ich die vFSB/vNB nicht mehr.
