Neues offizielles Bios!
http://www.abit.com.tw/page/de/down...rd&pTITLE_ON_SCREEN=AN7&pSOCKET_TYPE=Socket+A
BIOS ID:1.5
Please use the AWDFLASH v8.24F flash utility to update the AN7 BIOS.
Added Auto-Shutdown function when CCMOS jumper is set to pins 2-3. The correct CCMOS jumper should be on pins 1-2; in case it is placed on 2-3, the CPU core voltage will be abnormally high, an the system will shut down automatically to protect the CPU from damage.
Fixed an issue where USB-ZIP will be detected as a harddisk.
Updated SI3112 SATA BIOS to v4.2.47.
Revised the characters in "Wakeup by Alarm".
Enhanced USB 2.0 device compatibility, "Integrated Peripherals / OnChip PCI Device / USB 2.0 Device Compatible / Disabled -> Enabled".
Fixed an issue where SCSI boot ID cannot be selected when certain SCSI cards are installed.
Fixed an issue where SATA HDD boot up will fail if a PS/2 mouse is not installed.
Fixed an issue where the system will show 119 degrees under certain circumstances.
BIOS compile date: 03/04/2004
Schon jemand getestet?
BIOS ID:1.5
