We've learned that Intel is going to change its policy on overclocking once it moves away from the LGA775 platform onto the desktop Nehalem platform, which is currently known as Bloomfield, which uses the LGA1366 socket. This will be the only platform from Intel which will overclock in the future, as the company is not going to support overclocking on other platforms.
Below the Bloomfield is the Lynnfield and Havendale processors, both using the LGA1160 socket. Neither of these are likely to get any overclocking abilities, although we're not sure how Intel can prevent third-party motherboard manufacturers from adding overclocking features to their boards.
However, with most of the Northbridge being located inside the CPU of these models, it might be possible for Intel to make some changes as to what the BIOS can access and how the bus speed is controlled. If this is indeed the case, then this is very sad news for all enthusiasts, as it means that a huge group of users will never be able to afford to buy an overclockable platform, from Intel, that is.
It's early days as yet and Intel might change its stance on this, but we find it peculiar that they've decided on this move; but it's never easy to figure out the reason why Intel does something.
