[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Aber naja, die Hundemarke ist das schärfste...wer von euch trägt die? ;>
...das kann man sich mitten auf die Stirn kleben - und danach nie wieder das Gesicht waschen! :haha:
Soo gx2 ist drin, erster 3dmark06 ohne OC, ohne irgendwelche einstellungen, 14500punkte.
Da schlummern noch guten 4-5k drin.
Habe hier im Forum keinen weiteren Foxconn X38A Besitzer gefunden, weswegen ich mich mit meiner Frage an euch wende.
Läuft bei euch die Lüftersteuerung einwandfrei, auch bei niedrigen Drehzahlen bis 1.500 U/min?
Ich habe schon alle Einstellungen im BIOS ausprobiert, leider erfolglos.
Danke vorab.
...hast du einen 3-PIN oder 4-PIN Lüfter? Welcher Lüfteranschluss funktioniert denn nicht?
Es sind allesamt 3 PIN Lüfter (CPU und System)
...also wenn der 4-PIN Anschluss über PWM regelt, läuft ein 3-PIN Lüfter dort volle Pulle. Das variable Signal liegt dann auf dem freien PIN 4, und PIN 2 hat volle 12V.
Läuft denn der andere 3-PIN Lüfter am SYS- Anschluss gedrosselt?
Habe gerade noch einmal genau aufs MB geschaut. Die beiden 120er Hauptlüfter mit den 3-PIN Anschlüssen stecken auf den beiden 4-PIN Anschlüssen, bezeichnet mit CPU und System. Es werden leider nur diese Anschlüssen und der FAN1 im BIOS und im Fox One Tool angezeigt. Auf dem 3-PIN Anschluss FAN1 steckt der beigelegte NB Lüfter, der bemerkenswerterweise trotz der dauerhaften 5500 U/min nur ein minimales, keinesfalls störendes Geräusch erzeugt.
In den letzten Jahren hatte ich jedoch mit keinem MB derartige Schwierigkeiten, also mit der Regelung von 3-PIN Lüftern auf 4-PIN Anschlüssen. Zumindest gabe es dann im BIOS dazu Optionen, damit ggf. die Regelung trotzdem wirken konnte.
Darüber hinaus erscheint mir mein erstes Foxconn MB durchdacht und sehr hochwertig aufgebaut.
Ob nun der Karton unbedingt so luxuriös und stabil gefertigt sein muss, stelle ich mal als Frage in den Raum, letztendlich muss der Kunde das mitbezahlen und wer baut sich daraus schon ein Möbel.:)
Ich hab mir aus den Kartons meines neuen PCs ne kleine Bude gebaut, willst mit mir dadrin spielen? :teufel:
Der läuft sicherlich auch mit voller Drehzahl. Schau doch mal in dein X38A Handbuch, ob der FAN1 regelbar ist. Beim Mars gibt es einen regelbaren 3-PIN NBFan-Anschluß. Ich würde für den NB-Lüfter einen regelbaren 3-PIN Anschluß wählen.
Offenbar fehlt die Option von PWM auf Voltage umzuschalten. Oder das BIOS hat nen Bug. Ich meine im Foxconn Forum eine Signatur mit dem P07 BIOS für das X38 gesehen zu haben. Vielleicht gehts damit besser. Oder einfach mal einen 4-PIN Lüfter testen.
Vielen Dank für die Hinweise. Ist vermutlich ein Bug. Bisher konnte ich leider kein aktuelleres BIOS für mein Board finden. Das Mars hat auch einen anderen Steuerbaustein, genauso wie alle neuen Boards aus der Quantum Force Serie. Auf der diesjährigen CeBIT hatte ich das Glück, auf einen kompetenten Mitarbeiter bei Foxconn zu stoßen, der professionell über Details informieren konnte.
Dann warte ich halt noch ein bischen.:shot:
Werden bei euch beide Coretemps richtig ausgelesen?
Bei meinem E8400 stimmen die Core0 temps im idle ~28°, aber Core1 zeigt immer 44° an.
Wenn ich dann @4ghz prime, dann geht auch die temp von core1 hoch, aber fällt NIE unter 44°. Ist das nur ein Bug, dass core1 nicht richtig angezeigt wird?
Habe Coretemp und everest 4.5 genutzt.
D.h.? Werd aus deiner Antwort nicht schlau. Ists also normal?
soll heißen das ich mehrere E8400 hatte und alle die Temps. unterschiedlich ausgelesen haben. Bei Einigen waren Idle Temps nur 3°C weniger als unter Last, bei Einigen waren die einzelnen Kerne extrem unterschiedlich...
Naja ging darum, dass core1 immer 44° anzeigt und der bei Belastung nur hoch geht und nie unter 44° dann im idle fällt.
Komisch^^
Komisch^^
ich würde neben den Core Temps auch gleichzeitig die Auslastung der beiden Kerne beobachten. Läuft die Auslastung synchron, sollten sich auch die Temperaturen der beiden Kerne gleich entwickeln.
Hat mich nur gewundert, dass der sensor net weniger als 44° anzeigen kann. Hat sich ja nun erledigt^^
Moin,
ich habe seit ca. 8 wochen in meinem Zweitrechner ein Foxconn Mars.
Jedesmal wenn ich den Rechner einschalte fängt die Kiste an zu piepsen. Sobald ich ein Clear CMOS durchführe fährt die Kiste einwandfrei hoch.
-Mobo lief/läuft auf Standardeinstellung.
- Bios Update Historie, P09, P11, G30 -> P12 noch nicht probiert
System:
- E 8400
- 8 GB Ram TWIN2X4096-6400C5DHX
-> passiert auch mit 4 GB
- MoBo Foxconn Mars
- NT Corsair HX 520
- Graka Asus 8800 GTS 512
- OS Vista Ultimate 64
Mit den Spannungen kenne ich mich nicht so aus. Kann man dieses OC-Geteste irgendwie asschalten?
Piepen läß sich nicht zählen, da es nur piept.
Foxconn Support angefragt 3x in den letzten 6 Wochen null Reaktion bisher.
Hat Jemand von euch einen Rat?
Dieses komplette durchpiepen hatte ich nur wenn ram zuwenig Saft hatte/falsche Timings.
na wenn er sagt dass das MB auf def settings läuft hat das auch nix mit zu wenig saft zu tun wenn er nichts über-/untertaktet...
kannste mal die standard testprozedur laufen lassen wie memtest, prime etc.?
Ich sagte doch nur, dass ich das Piepen bei dem Board daher kenn. Mehr nicht
Ähnliche Themen
