[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
na wenn er sagt dass das MB auf def settings läuft hat das auch nix mit zu wenig saft zu tun wenn er nichts über-/untertaktet...
kannste mal die standard testprozedur laufen lassen wie memtest, prime etc.?
Ja aber das board gibt/gab bei meinem RAM auch zu wenig spannung.
ändern kannste des im gladiator bios is auf der rechten seite der erste eintrag.
und dann musste dich weiterhangeln:bigok:
Danke. Werde es ausprobieren.
Aber wieso startet die dumme Mobo nach einem ClearCmos einwandfrei?
Wenn das dumme Dinge nächste Woche nicht läuft werde ich es wohl verkaufen,
grüße
Lartens
Passt ein Thermalright IFX-14 bzw. Xigmatek RS-1283 Red Skorpion auf das Foxconn Mars???
ifx-14 glaub ich mit ein klein wenig modifikationen.den anderne kenn ich nicht
Das mit dem Xegmatek RS 1283 könnte wegen der NB knapp werden werden. Daher habe ich den Xigmatek S 983 gewählt. Der passt perfekt auf das Mars und sieht klasse aus - egal, wie man ihn ausrichtet. Die Kühlleistung soll ähnlich gut sein, weil der Lüfter vom S 983 bis 2800 U/min dreht.
Also ich hab den IFX-14 drauf. Passt haarscharft in seitlicher Ausrichtung. Du musst nur einen der Foxconn Schriftzüge am NB-Kühler abnehmen.
Oder weiß jemand von euch eine Kompatibilitätsliste wo alle Lüfter aufgeführt sidn???
Welche 2GB Cl4 Speicherkit würde am besten mit dem Foxconn Mars harmonieren?
weiß jemand die Lochabstände Der Southbridge , der Northbridge und der Spawas ?
Hab nämlich vor das Board unter Wasser zu setzen :)
@ loneclone
kannste mal ein foto von der Modifikation posten? und wenn ich dich richtig verstehe hast du den Kühler senkrechte montiert? weil waagerecht kommt für mich nicht in frage...
danke und mfg
Foto kann ich grad nicht machen, aber ne Modifikation ist es nicht wirklich...man kann vom NB-Kühler einfach die Schriftzüge auf jeder Seite abnehmen...einfach seitlich rausschieben.
Und dann kann man den einfach draufsetzen und die Lamellen schließen direkt mit dem NB-Kühler ab.
ich hab das 2x2Gb von g.skill drauf die 1066mhz version. und es läuft ganz gut!^^
habe mein Board nun auch bekommen und verbaut. Läuft problemlos - sogar ohne Neuinstallation. Habe erst einmal Sparflamme eingestellt. Die im BIOS eingestellte VCore von 1,05V läuft im Idle mit 0,90V! Feine Sache mit EIST/C1E.
Etwas entäuschend ist, dass die Drehzahlen von FAN1 und FAN2 nicht ausgelesen werden.
Die in dem Fox- Tool angegebene NB- Temperatur entspricht der in Everest ausgewiesenen Mainboardtemperatur. Ich vermute daher, dass die Sensoren in der NB/SB nicht ausgelesen werden können.
Das Board und Sparflamme? Ein NoGo ;>
Bei mir hieß es sofort 35% mehr Leistung.
Ja, die 35% mehr Leistung habe ich auch - durch Strom sparen. :haha:
Habe unter Everest zwei neue Werte entdeckt:
Wo ist denn der Sensor der AUX Temperatur? Und eine North Bridge Kern Spannung (bei mir 1,71V) habe ich vorher auch noch nicht gesehen.
Der kleine NB Lüfter arbeitet ordentlich (bis fast 5000 U/min) und macht Sinn.
hab zwar Wakü, aber ich seh da keinen Sinn drin da die NB und Co. nicht warm werden...
@LordIT: Kannst eig die CPU nicht passiv kühlen?
...ja, bei meinen derzeitigen Einstellungen könnte man den CPU- Lüfter auch austellen. Im Idle würde gar nichts passieren. Leider entwickelt die E4400 relativ viel Hitze und mein Kühlervolumen ist nicht sehr hoch, dass unter Last nach längerer Zeit die Temps hochgehen würden.
wie gesagt - stehe ich der im Foxconn Tool angezeigten NB- Temperatur skeptisch gegenüber. Meiner Meinung nach ist das die Mainboardtemperatur. Die Sensoren der NB/SB lassen sich bei P35 Boards in Verbindung mit der Intel QST- Lüftersteuerung auslesen. Das Foxconn Mars hat diese leider nicht. Die Temperaturen im Inneren der NB/SB sind oftmals wesentlich höher als CPU- Kerntemperaturen (was sie auch dürfen).
Ich werde wegen einiger Everest Sensorwerte mal dort im Forum nachfragen. Dort sitzt ein Moderator, der echt Ahnung hat.
Auch könnten die Foxconn Ingenieure Auskunft über den NB- Sensor geben. Ob wir dort eine ausführliche bzw. ehrliche Antwort erhalten?
Eine NB- Temperatur von maximal 35°C ist ein echtes Kaufargument und diese wird ja schließlich auch im Aegis Panel angezeigt.
der große xigmatek (120mm) passt nicht, hab den gestern montiert und kann den nur in richtung NT blasen lassen, werd aber morgen mal schauen obs geht wenn ich das "Dach" der HP abnehme obs dann geht!
Habt ihr auch das Problem gehabt, dass beim NB ein paar Pins verbogen waren?
Bei mir sind die der Frontaudio und HDD-LED verbogen...
Da ist nix verbogen...jedenfalls bei mir.
@LordIT: Also meine angebliche NB wird deutlich wärmer. Wenn ich auf 500fsb geh und den Lüfter net anhab, dann geht °C auf gute 50-60°C. Mit dem kleinen Fan max 39°
@Heimwerkerking:
Die Probleme beim großen Xigmatek habe ich auch befürchtet.
Bei mir waren auch keine PINs verbogen.
...das spricht für einen Sensor in der NB. Wäre ja toll!
Und was ist mit der AUX- Temp? Sollte der Sensor in der SB sein?
Mir ist im BIOS aufgefallen, dass bei meinen Einstellungen die EIST Option nicht auf enabled stehen bleibt. Habe folgende Schritte gemacht:
EIST auf enabled, speichern mit F10 und nach Neustart wieder ins BIOS. Dort stand EIST dann auf disabled.
Bisher habe ich immer per BIOS übertaktet. Ist dies beim Mars auch in Windows möglich bzw. empfehlenswert?
Was bringen die neueren BIOS- Versionen in der Praxis?
Ist bei mir ebenfalls so. Obwohl immer wieder anderes behauptet wird.
Sobald ich übertakte wird EIST im Bios disabled.
Getestet mit P09,P11,P12,G29,G30.
Ausserdem habe ich immernoch keine Antwort darauf gefunden, warum mein Speicher immer
mit den EPP settings erkannt wird. Sollte eigentlich nur bei Nvidia Boards funktionieren. Und falls das ein feature im Mars Bios ist, wäre es nicht schlecht wenn man es an- und abschalten könnte. War bei meinen Crucials so und auch bei den Gskill 8000.
habe gelesen, dass EIST bei OC technisch gar nicht gehen kann. Das würde wegen des veränderten RAM- Multi zu Problemen führen.
Aber über C1E funktioniert ja die Absenkung von Multi und VCore im Idle.
Bei dem RAM + EPP bin ich überfragt. Bei mir wird wohl die normale SPD eingelesen. Wie soll das funktionieren und wie erkennt man, dass EPP eingelesen ist?
In einem der ersten Tests die ich vom Mars gelesen habe, weiss leider nicht mehr wo, wurde bemängelt, daß sich EIST beim übertakten nicht abschaltet. Leider kenne ich auch die Bios Version nicht mehr mit der sie getestet haben. Meine aber es war die G26. Egal damit lässt sichs leben.
Du kannst doch mit cpu-z oder memset die im Eprom der Speicher hinterlegten Werte auslesen. Dort stehen die Jedec kompatiblen Werte und die für EPP. Bei den G-skills z.B.
die Jedec Werte für 266 und 400Mhz und als EPP Wert die 500Mhz. Eigentlich sollte jedes Board erst einmal mit den eingetragenen Jedec Werten starten, damit es keine Komplikationen gibt, weil nicht jedes Board in der Lage ist die Werte und Spannungen zu erreichen. Das Mars nimmt aber jedesmal, alles auf Auto, die Werte die als EPP Profil gespeichert sind.
Ist soweit ich weiss ne Erfindung von Nvidia und ist als Feature in deren Chipsatzbasierten Boards eingebaut.
LordIT
hast du des p11 drauf? und undervoltet? wenn ja des is bei mir seit dem p11 auch so.
wenn ich oc kann ich aber beides einstellen.
ach ja temps sin bei mir 300fsb und nb-lüfter auf 90<5 max 55°
bei CPUz kann ich nichts besonderes finden:
auch Everest zeigt nichts von EPP. :confused:
@°Leon°
Wenn du im BIOS EIST enabled einstellst, speicherst, und dann EIST nochmal im BIOS aufrufst, steht dann EIST bei dir auch auf disabled?
@Heimwerkerking:
passt doch :d
http://www.awardfabrik.de/forum/showpost.php?p=141736&postcount=23
Ähnliche Themen
