[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Also ich wollt den eigentlich auch montieren, allein schon weils cool aussieht, aber passt halt nicht wegen meinem IFX-14.
Aber wirklich brauchen tut man ihn nicht. Temps sind auch sonst absolut im grünen Bereich...naja gut, ich war ja vorher auch Brüter-Temperaturen von meinem Striker gewohnt. xD
die Heatpipe funktioniert außergewöhnlich gut, da hast du recht.
Wenn das Board eine Intel QST Lüftersteuerung hätte, könnte man die NB und SB Temperaturen auslesen (angezeigt als Temperatur 1 und Temperatur 2 in Everest). Dann wüsste man genau, ob der NB- Lüfter was bringt.
Könnte das mal jemand in Everest checken?
Also der kleine Verschluss für die Graka ist doch fürn arsch. Das plastik war so dünn, ich mach graka rein, platzt das plastik weg.
Graka hält zwar dennoch, aber sowas suckt doch derbst....
also mit Everest funktioniert das nicht, aber das Aegis Panel von Foxconn zeigt das an. Ich hab den Lüfter auf unter 1000 Umdrehungen eingestellt und da hört man den nicht, Temperatur liegt im Idle bei ca. 33°C und geht bei OC auch selten über 45°C...
Mhh ne 8800gts wird nicht von der grafiktreiberinstallation erkannt @64bit vista
lol? Die wird nich erkannt? Davon hab ich irgendwie noch nie was gehört...sicher das es an Vista liegt?
Bei meiner GT hat er net gemeckert.
Ach und in deiner Sig steht was von ner 9800GX2, hast du schon eine?!?
Hätte mal ne Frage wegen Speichererkennung.
Hab jetzt mal meine Crucial Ballistix und neuerdings die 8000er GSkills probiert. Bei beiden werden bei Standardsettings jedesmal die Timings die im EPP Profil gespeichert sind geladen. Bios ist P09. War das nicht mal so gedacht, daß das board aus kompatibilitätsgründen immer mit den Jedec konformen 800er Settings starten sollte und die
EPPs nur auf Nvidia boards zum tragen kommen, vorausgesetzt es ist im Bios freigeschaltet.
@TobiasAlt
Hab im GSkill thread gelesen, das du ebenfalls die 8000er einsetzt. Wurden bei dir auch automatisch die EPP settings gesetzt?
Also die Temperaturen wären für die NB wirklich sehr gut!
und das ist wirklich die NB- Temperatur, die da ausgelesen wird? Wenn das in dem Foxconn Tool ausgewiesen wird, müsste es unter Everest doch auch gehen? Hattest du vielleicht das Foxconn Tool schon vorher gestartet?
....hatte noch vergessen zu sagen, dass erst ab Everest Vers. 4.20 die Chipsatztemps. ausgelesen werden können und - wie gesagt - die Bezeichnung lautet: Temp. 1 und Temp. 2
Everest (neuste Beta):
MB-Temp. = NB-Temp.
AUX-Temp. = MB-Temp.
Habe im Bios die Temps verglichen, normal ist die NB-Temp. höher als die MB-Temp.
Gruss
little-oak
hab noch ne ältere Version von Everest, aber ich weiß ja das die NB nicht richtig heiß wird, von daher...
Solange man die NB noch mit der Hand anfassen kann und sich nicht verbrennt, ist doch alles ok. :d
War bei meinem Striker an der SB nich der Fall. :xmas:
Ist unterwegs. Er spackt bei der 8800gts atm rum, meint bei nvidia install, dass er keine treiber finden könnte bla...
EDIT:
Soo hab einfach die BFG CD reingelegt, die Treiber frisst er ohne Erbarmen. Liegt wohl an den neuesten Treibern von Nvidia...sehr komisch.
EDIT2 mit alter graka und altem ram 2x2gb DHX Corsair:
...hättest du den Thermalright auch um 90° drehen können? Das sieht so schon sehr knapp aus.
Nein kann ich net, NB Kühler ist das sehr im weg. Leider, zudem kommt der Lüfter wohl auch noch nach oben und saugt dann Luft dadurch, damit ich die Gehäusewand mit dem großen Lüfter zubekomm
Moin, Moin,
@Dark
liegt wahrscheinlich daran das,das Mars eins der besten Boards auf dem Markt ist.Es macht einfach kaum Probleme.
Hab nun wirklich schon fast alle Hersteller durch DFI,ASUS,GIGA,MSI,EVGA,ABIT.Mit 975/P35/X38,ob Server-oder Gamerboards !
Beim Mars muss ich keine Kompromisse machen,es hat für mich einfach alles was ein gutes OC-Board ausmacht.
Meiner Meinung nach hat da Foxconn ein erstklassiges Produkt auf den Markt gebracht, von dem sich vor allem die Premiumhersteller eine Scheibe von abschneiden können!:)
Gruss
little-oak
... eine Q9300 kostet ja auch eine ganz schöne Stange Geld. Hat halt nicht jeder.
Also wenn jemand eine Q9550 drauf hat, führt der hier im Forum nur Selbstgespräche. :haha:
das sehe ich genauso ... ;)
schade, dass es noch kein vergleichbares X38 board von foxconn gibt ... :heul:
naja, so teuer ist der nun auch nicht! ;)
der Q6600 war in seiner besten zeit auch nicht günstiger! :d
wir werden sehen ... :bigok:
Dafür gibts bald das Black Ops X48 Board...und das hat ja schon Weltrekorde aufgestellt....also man darf auf das Board gespannt sein. ;)
€dit: Mal noch ne ganz doofe Frage, diese ganzen kleinen Aufkleber, die beim Board mit dabei waren...wofür sollen die gut sein? Sind ja spiegelverkehrt...zum an die Scheibe kleben oder wie?
Wer hat hier nen e8400 drauf und wie hoch stabil getaktet? Spannungen wären auch interessant.
Ganz ehrlich? Hatte grade die in der Hand und hab mich selber gefragt wofür die sind :>
EDIT: Kannst dir ja noch die Hundemarke umhängen, btw 00297
:shot:
Naja, Leute gibts...ich kenn das von meinem kleinen Cousin, der macht sich sowas aus der Bravo auf den Arm...vielleicht schenk ich ihm die einfach mal. :haha:
Ähnliche Themen
