hab nujrnoch stereo sound bei winampt trotz aktiviertem 5.1 ? jmd ne ahnung? os is vista
ähm falls es den bei vista gibt hab ich ihn laufen lassen ^^Hast du mal den soundmax Assistenten laufen lassen?
Das wäre das erste, was ich davon lese. Ich habe farbikneue Platten, Kabel und Mainboard benutzt.
Kannst Du das mal bitte mit einem Link zur Fundstelle belegen?
Question:
The SATA ports on my motherboard behave quite strange lately. SATA devices connected to it may show one or more of the following symptoms from time to time:
- SATA devices not detected at POST stage or inside CMOS setup screen.
- SATA HDD cannot complete the installation of operating system after enabling AHCI or RAID function.
- Computer takes forever to install operating system or copying files.
- Operating system may hang while large disk access operations are under progress.
Is there anything I can try before sending it out for repair?
There could be various possible causes to result into issues as described. These include:
- Dirty SATA connectors:
o Cause: Dirty substances such as dust, dirt, rust, or oxidized surface on SATA connectors may result in improper contact with its peer, which degrades the signal quality, hence causes SATA communication problems.
o Suggestion: Please kindly try the following cleaning procedures and see if this helps to improve the current condition:
1) Prepare the following (can be found from your local chemist):
· Some alcohol (ethanol (C2H5OH))
· A packet of cotton stick
2) Shut down the system, and remove power cord.
3) Remove all devices connecting to SATA ports.
4) Flatten the cotton stick, and moist both ends with ethanol.
5) Dip the cotton stick into SATA port (the side with golden finger), and move the cotton stick sideways a few times to clean the SATA port.
6) Move on to the next SATA ports until the completion of this task. Note: Do not reuse the used end, and only use one end with each port.
7) Now do the same for SATA cable and SATA connector on SATA devices.
- Incorrect settings:
o Cause: Under many cases, the default settings for additional onboard SATA/RAID controller could have been set to [Disabled] when delivered. This will cause the controller to stop its function completely.
o Suggestion: Please refer to your user’s manual for detailed description on how to enable onboard SATA/RAID controller via adjusting jumper or BIOS settings.
- Controller limitations:
o Cause: There could have been a known limitation with the existing SATA/RAID controller, such as limited support to particular SATA standards or specifications.
o Suggestions: Try adjusting the SATA operation mode of the HDD via HDD jumper or specific tools provided by HDD vendors (Please consult your HDD vendor for further assistance.)
- Driver or HDD firmware issue:
o Cause: SATA/RAID Driver loaded may need to be matched with specific versions of SATA/RAID BOOTROM, or the controller’s behavior under AHCI mode, in order to allow the controller and device to function correctly. System may result in fail to install operating system, performance drop, or even not detecting HDD during OS installation process if the drivers are not matched. (Note: Some versions of Windows may have been bundled with a previously existed version of driver for a particular controller.) Only when this driver also matches with SATA/RAID BOOTROM or controller behavior under AHCI mode, would the controller be able to function without fail. The same could also happen if the HDD firmware is not fully compatible with such SATA/RAID controller.
o Suggestion: Always use the latest version of BIOS and drivers available from ASUS download page at: http://support.asus.com.tw unless specially mentioned on either the download page or FAQ page to avoid this kind of troubles. For HDD firmware issues, please kindly consult HDD vendor for further assistance.
- Broken SATA port, controller, cable or devices:
o Cause: Broken connector, controller, cable, or devices may also be the major causes of this kind of issue.
o Suggestion: Please try moving or replacing components in the order of:
§ Replacing SATA cable
§ Move among different SATA ports from the same controller
§ Move to SATA ports from a different controller (if available)
§ Replacing SATA devices
Please kindly consult your place of purchase for further assistance if none of the above helps to resolve the issue for your case.
Weiß auch nichtwarum das pro und nicht das P5K-E?
Scheint ein Script-Link zu sein, daher funzt der Inhalt nicht. Den Link habe ich von der englischen Seite bekommen, nachdem ich nach p5k premium unter faq gesucht habe.
klick mich
ich poste mal den Inhalt
ach so war des net gemeint ich meine ich würde jedem die asus empfehen der mehr will als einen office pc ,..da reicht dann asrock etcIch hab Vista, das wäre egal.
Ich brauche kein Wifi und wieso ist das Pro nur was für "Office-Rechner"?
Ich sehe auf die schnelle keine gravierenden Unterschiede![]()
war nichts pro bezogenach so war des net gemeint ich meine ich würde jedem die asus empfehen der mehr will als einen office pc ,..da reicht dann asrock etcwar nichts pro bezogen
aber dankbar für jeden Tipp.Bin gerade auf der Suche nach nem neuen Mainboard, dabei auf das Asus P5K-Pro gestossen.
Gibt es Erkenntnisse wie das Board mit Vollbestückung (800er) Ram reagiert?
Hinzugefügter Post:
Das beruhigt mich.
Ich glaube ich werde zuschlagen
Das einzige was mich stört ist der 24Pin Stromanschluss fast in der Mitte![]()
japp,.. habs drauf und naja alles easy ,.. bis jetzt nix negatives aufgefallen....Hallo Leuts,
hat schon jeman ein Biosupdate auf 1006 beim PK5-E gemacht?
kann mir jeman sgen ob es sich lohnt?
Dank euch!!!
Hinzugefügter Post:
Bin schon besoffen meine nartürlich das P5K-E!!!
Hi und vielen Dank für Deine Mühen, bei der Alkoholbehandlung scheint etwas Voodoo mitzuspielen, aber ich bin ja durchaus bereit, herumzuexperimentieren (Greife nach jedem Strohhalm)....
Gruß Ws
Ein P5K soll werden.
Jedoch das Premium oder das P5K-E ?
Unterschiede ? Erfahrung ?
Vom Geld her ist es mir egal.
Nimm das P5K-E da das Premium HDD Bugs hat.
Es läuft nicht mit allen Felstplatten.
Moin allasaits,
habe mein Deluxe von 0601 auf 0705 upgegradet, weil ich mitunter einige harte Resets mit meinen 4 GeIL-Riegeln hatte und dem Log zur 0603er Version zu entnehmen war, dass einige "RAM issues" beseitigt wurden. Das Upgrade klappte tadellos.
Seither aber gibts Ärger: das BIOS merkt sich einfach nicht mehr die Einstellungen, auch nicht beim Anlegen, Speichern und Abrufen eines O.C. Profiles. Dabei geht es nicht nur um die OC-Einstellungen; auch andere elementare Einstellungen (z.B. RAID) sind plötzlich wieder auf Default.
Kennt jemand auch dieses Problem? Gibt's da ne Lösung zu?
Bin aktuell mittelmäßig verzweifeltaber dankbar für jeden Tipp.
Greeetz, Thomas
